Official OPPO BDP-103 Owner's Thread - Page 367 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 08-15-2013, 06:38 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2688 Post(s)
Liked: 1921
Originally Posted by STEVE MORRILL View Post
I have a Motorola cable box running through my OPPO then to my Sony LED. I had a persistant problem with audio synchronized to the video until I downlaoded the July 24th Firmware. This problem has been succesfully solved however I now get a random black screen when changing channels. The only way to correct the black screen is to power down the OPPO 103. Will the latest 08/12/13 BETA firmware correct the black screen problem?
I'm not sure about the new firmware; I would try it.
As a workaround, instead of powering down you might try to initiate a new HDMI handshake. On the player side, switch to different output resolution and back again, say 1080p to 1080i and back to 1080p. If there is no image on the screen the front panel of the player shows what is happening.
This may only correct the output chain. For input: does the cable box have any similar control?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Old 08-15-2013, 06:53 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Survey: Does your '103 display Album Art when playing Music from a UPnP / DLNA Media Server?
Has anyone had any success in getting the '103 to display album art when playing songs from a UPnP / DLNA server? (In my case, it always displays only the image of a stylised music note). And if anyone has had success, can you please also state the circumstances under which it is working:
1) Which UPnP / DLNA Media Server software are you using?
2a) Are you using the player to browse the music library and select the song to play ("pull" play)?
2b) Or are you using another control point to browse the music library and command the song to play ("push" play)?
3) In case of 2b) which control point software (app) are you using?
AndrewFG is offline
Old 08-15-2013, 06:55 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
I have a Motorola cable box running through my OPPO then to my Sony LED. I had a persistant problem with audio synchronized to the video until I downloaded the July 24th Firmware. This problem has been succesfully solved however I now get a random black screen when changing channels. The only way to correct the black screen is to power down the OPPO 103. Will the latest 08/12/13 BETA firmware correct the black screen problem?
Your cable box is set to "native" output. It is sending 1080I on some channels and 720p on other channels. Some TVs will blank when there is a resolution change. Change the Oppo setting from Auto back to 1080P output.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
Old 08-15-2013, 07:08 AM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
Don't know about playing music from a server. But the Oppo does not support "external album art" in folders, such as "cover.jpg".
It only supports album art found imbedded in the music file tags of each music file.
I had to manually update my 1100 FLAC files using MP3Tag to install each of my 500 album folders' "cover.jpg" into the FLAC tag of each music file in each album folder. Took a while, but I now do have album art while playing FLAC from a USB drive.
DSperber is online now
Old 08-15-2013, 09:00 AM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
I have all my music files stored on a Synology NAS. And 'Gracenote' disabled on the Oppo...
When I use the Oppo to navigate to my FLAC files via UPnP (or SMB). The title, artist, album, genre and album art information is displayed from the files meta-data without issue.
When I use the Oppo to navigate to my AAC.m4a files via UPnP. Only the title, artist, album and genre information is displayed from the files meta-data. There is no album art!
When I use the Oppo to navigate to my .MP3 files via UPnP. Only files who's meta-data has been saved to the UTF-16 format are able to display the title, artist, album, genre and album art information
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
Old 08-15-2013, 11:38 AM
SHadoWFoX's Avatar
I have searched this thread but did not find mention of my question, so here it goes and hope there is a way to do this.
How does one control multiple Oppo players (e.g. 83 and 103) with remote such that only the intended target player will respond?
I have seen posts where people said the remote programmed for 83 or 93 automatically works for 103 when the old player is replaced by the new player. It seems to me if I have both players then both players will respond to the remote commands at the same time.
Shadow Fox
SHadoWFoX is offline
Old 08-15-2013, 11:54 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
There are three available remote control settings on each remote. You select either 1, 2 or 3 on the back of your remote under the battery cover and you must also go into the setup of each Oppo player and tell it which remote setting you have chosen. If you have a region-free mod, you may have to make additional changes to make it work. You will have to check with the supplier of your mod for that process. The regular process is in the manual for your player(s).
JazzGuyy is offline
Quoted: 40 Post(s)
Liked: 43
Leave the 83 the way it is and turn to page 10 in the manual to find out how to change the 103 remote.
Hometheatergeek
aka AL
My Current System
Old 08-15-2013, 12:04 PM
SHadoWFoX's Avatar
Jazz and HTG
Thanks for your pointers. Can the remote code be programmed into an universal remote such as Harmony One as two separate devices? If so then I will be very happy.
Li
Shadow Fox
Old 08-15-2013, 12:14 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2257 Post(s)
Liked: 2823
Jazz and HTG
Li
Yes, Harmony has a standard way of doing this, and has the several remote codes in their database.
I forget the exact process -- there's a programmable remotes forum here where the Harmony experts hang out if you need help -- but it is something like you set up the "normal" OPPO in your Harmony (which will, by default be its code set #1) and then you do a Verify Buttons, during which the Harmony stuff figures out you need one of the alternate code sets and loads that into your configuration instead.
NOTE: If you lose wall power or pull the power plug then ANY of the OPPO remote code sets will power on the player. But once the player powers up, it will switch back to the code set you have previously specified in Setup.
So after power is restored, the first time you try to power up one player with the remote, the other player(s) will also power up. Just go power them down, and they will be back to normal.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 08-15-2013, 12:19 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
--Bob
It'll probably be easier to set up the Harmony remote if you make the 83 use remote codeset 2 or 3 and leave the 103 on codeset 1. The set of codes for the 103 are a lot more complex than the 83's codes to cover all the additional functions.
JazzGuyy is offline
Old 08-15-2013, 12:22 PM
Read the FAQ!
Liked: 2823
^ In the Harmony, each player gets configured as a separate Device, so there's no problem using the 103 codes for the 103 and the 83 codes for the 83, with each of those then separately refined for which code set # is desired.
I.e, Player 1 is the 103 code set #2, and Player 2 is the 83 code set #3, or whatever.
--Bob
Old 08-15-2013, 12:27 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Bob, are all the codes for the alternate codesets available for the 103 in the Harmony database? They weren't a while ago. I know they are for the 83 which is why I suggested leaving the codeset alone for the 103 and using the alternative for the 83.
JazzGuyy is offline
Old 08-15-2013, 12:30 PM
SHadoWFoX's Avatar
Wonderful technology and excellent forum members. smile.gif I am all set to add the 103 to my system.
Thanks for your quick response.
Shadow Fox
Old 08-15-2013, 12:57 PM
Read the FAQ!
Liked: 2823
I haven't checked, myself, but my memory is that someone posted here the alternate code sets were live for the 103 when he tried it with his Harmony.
--Bob
Old 08-15-2013, 01:13 PM
TheFactor's Avatar
Liked: 106
--Bob
I have a Harmony one and never reprogrammed it from when I had my 95 and it works perfectly with my 103 .I believe I posted that here previously .
TheFactor is offline
Old 08-15-2013, 01:21 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
That's not the issue here. It's whether the Harmony database has all the alternate codeset values for the 103 for someone who needs to program his remote to handle multiple Oppo players and thus needs to have a different codeset specified for each player. You want to be sure that the Harmony database contains all these codesets so that a codeset change will work properly.
JazzGuyy is offline
Old 08-15-2013, 01:32 PM
Quoted: 40 Post(s)
Liked: 43
^^ the other option would be to change the code set on the original remote for the 103 then learn the command to the Harmony.
Hometheatergeek
aka AL
My Current System
Old 08-15-2013, 01:34 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Yeah, but learning individual commands for more than a handful of commands is a big pain in the posterior. smile.gifsmile.gif
JazzGuyy is offline
Old 08-15-2013, 01:47 PM
chileboy's Avatar
I'm also getting album art successfully with Twonky Server running on my NAS - almost all of my files are .FLAC, a few Amazon-purchased are MP3, all have embedded album art. And "Yes", to Question 2a.
- Mark
chileboy is offline
Old 08-15-2013, 01:55 PM
TheFactor's Avatar
Liked: 106
Old 08-15-2013, 02:06 PM
Quoted: 40 Post(s)
Liked: 43
What you couldn't handle that? Us old A/V installers had to do that when the first universal remotes came out. tongue.gif. But I was just talking about him teaching the power on command. I wonder if the open command is different between the 83 and 103. I use the open command on my Harmony to turn on the 103.
Hometheatergeek
aka AL
My Current System
Old 08-15-2013, 02:24 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
That's why I never wanted to be in the installation business. I've done the setup on a few of my own systems and the hours it took to get the right wires in the right places, everything measured and properly adjusted and all the other stuff you had to do was enough for me. When I bought a new receiver earlier this year, I found out the process was a lot simpler than it used to be. Of course, this time I had a receiver and not three separate power amps to deal with. No wonder a lot of people don't get into home theater. The hassles can be horrendous if you don't plan and have patience. smile.gifsmile.gifsmile.gif
JazzGuyy is offline
Old 08-15-2013, 03:41 PM
Tornado Red's Avatar
Quoted: 292 Post(s)
Liked: 238
Good point Al. Assume the OP wouldn't be running both Oppos at the same time? If not, just change the power on command for either one. Since the other will be off, it even though the other commands are the same it won't see them. Or have I been out in the sun too long today smile.gif ??
Tornado Red is offline
Old 08-15-2013, 04:28 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
You would have to also at least program the "Open" button since using that button on a player would also turn on the other one. I'm not sure that there might not be other buttons that could do something to a player that was turned off. I'm not going to bother to test it. My 83 and 105 are in different rooms now so I don't have the OP's issue.
JazzGuyy is offline
Old 08-15-2013, 04:34 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
BTW, I want to mention that I corresponded with Oppo today with regard to the subtitle repositioning you can do with the BDP-10x. I mentioned that I would like to do finer positioning adjustments because sometimes I can't get the subtitles in the ideal spot to minimize their overlay of the picture. They told me that the new beta supports this finer adjustment. I haven't downloaded and installed the new beta yet. Perhaps one of you who has done this has noticed this improvement and could comment on it. Thanks in advance.
JazzGuyy is offline
Old 08-15-2013, 04:50 PM
Read the FAQ!
Liked: 2823
I don't know if it is as fine an adjustment as you'd like, but it is definitely improved in that direction.
--Bob
Old 08-15-2013, 05:01 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
I'll let you know. I'll be installing the beta sometime in the next day. We've been watching a lot of subtitled stuff lately and, especially when the aspect ratio is 2:35:1 or so, it is great to position the subs in the black bar space at the bottom and have zero overlap with the picture. With the existing movement, the ideal position would chop off the bottom of some letters that went "below the line". I was feeling the need for a position in between this one and the next higher. I don't remember anyone ever complaining about this but sometimes Oppo anticipates our needs. That's one reason I love 'em.
JazzGuyy is offline
Old 08-15-2013, 05:42 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
ALL of the common remote commands are the same for the 83, 93/95, and 103/105. The only differences are the new commands that have been added, such as the Netflix button. If you have multiple players in the same room, codeset 2 or 3 should be used for the additional player(s) and that means that ALL of the commands will need to be switched to the other codeset - you can't just decide to use the codeset 2 power command and then continue to use the codeset 1 buttons for the rest of the functions.
gsr is offline
Old 08-15-2013, 06:54 PM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
I just installed an Oppo in my parents' dedicated media room, connected to a Sony STR-DA1800ES and then to a Sony 70" LED panel. I've updated it as of last night and also updated both the Sony units. A few issues:
  • The Oppo remote lights up but won't control the player. I've checked the settings and toggled all three remote codes; nada.
  • The HDMI Control features of all three are enabled but the Sony remotes won't control it either
  • The Oppo iOS app is great but currently the only way to control it.
Is the remote issue perhaps related to the HDMI Control settings? I do believe I tried it right out of the box with nothing touched on any units and it wouldn't work either (even putting it an inch from the IR sensor on the front panel). Any suggestions? I gave up on it at around 11pm last night and am heading back over tomorrow to finish up.
PGT FTW is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
