Official OPPO BDP-103 Owner's Thread - Page 384 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 09-03-2013, 06:41 PM
icirider's Avatar
I upgraded the firmware today in ignorance of the incompatibility with SACD-R....now I find that the DVD-A discs I've burned from HD Tracks (legitimately purchased) will not play at all either. This is a big problem for me. I see that downgrading firmware is not a possibility. Any suggestions are most welcome.
icirider is offline
Old 09-03-2013, 07:53 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
Contact OPPO and have them issue a RMA for the player to be returned for downgrading to a previous firmware release. As this is not a warranty issue, you will be responsible for the shipping of the player to them, but they will cover return to you.
Neuromancer is offline
Old 09-03-2013, 09:40 PM
RicMau's Avatar
Originally Posted by Ricoflashback View Post
I ended up going with 7.1 and using a dedicated 7.1 amplifier (Wyred4Sound MMC-7) and it seems to work the best for my area, "sense of space" wise.
So, how are your connecting your "separates"? are you connecting your OPPO to the Pioneer thru HDMI (digital)? and from Pioner to the MMC-7?
RicMau is offline
Old 09-04-2013, 12:04 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Exactly. I'm using my Pioneer SC65 as a preamp with Morrow Audio RCA Interconnects (unbalanced) to the MMC-7 amplifier. HDMI1 from the OPPO 103 to the Pioneer AVR/preamp. The OPPO works great for Redbook CD's and astounding for SACD's. Especially Japanese mastered SACD's.
I'm currently listening to Steely Dan's Gaucho (Multichannel). Great separation, tight bass with power and superb mids & highs. Now I see why folks go with "separates." The Pioneer SC65 was nice by itself (7.1 - 130 wpc) but the MMC-7 with 220 wpc and the same Class D design is night and day. The amp is still in the break in period and it sounds better everyday.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is online now
Old 09-04-2013, 12:45 AM
Razvanel's Avatar
Originally Posted by OPPOrtunist View Post
I believe you are disregarding the several additional features of the Oppo which are completely absent from the Panasonic, to wit:
b) the possibility to shift the position of subtitles.
AFAIK the Panasonic can do that. Not only the 500 but the newer models too.
R
Razvanel is offline
Old 09-04-2013, 02:35 AM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 140
Originally Posted by Repdetect View Post
Originally Posted by rdgrimes View Post
If your only concern is watching BD and DVD via HDMI, it makes very little difference what player you buy. Get whatever is simplest to make region free.
Kudos for such a refreshingly frank answer.
It's posts like this that make oppo and the oppo avs threads such great resources.
True ... as long as those cheaper players don't fail the basics such as outputting correct RGB or YCbCr color spaces, which is very common. Also many of these cheaper players fail some of the challenging cadence tests for US and European video sequences.
The Oppo is the only one I know of that has earned a perfect score of 100 on the complex cadence tests and has ZERO measured errors when dealing with RGB/YCbCr color spaces.
OPPOrtunist likes this.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
Old 09-04-2013, 05:39 AM
monteplus3's Avatar
Hi, I purchased the Oppo 103 about a month ago and have a standard HDMI connection to my Sony STR-DA5800ES AVR. Since the Sony has input capability for multi-channel audio, I am wondering if there would be any advantage to setting this type of connection up with the Oppo? I'm not really clear what the benefit would be with this connection versus the single HDMI connection I have now, if any. I really only use the Oppo for watching movies, and use a somewhat primitive Sony CDPCX455 CD changer for listening to music (or internet radio or MP3). Any advice would be appreciated....thanks!
monteplus3 is offline
Old 09-04-2013, 06:17 AM
bluechunks's Avatar
Quoted: 78 Post(s)
Liked: 115
Keep it simple. Use HDMI and send HD Audio digitally to the AVR.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is online now
Old 09-04-2013, 08:30 AM
oztech's Avatar
Liked: 101
It gives people an option to use the DAC in the Oppo if they feel its better than the one in their AVR.
It also allows people with older AVR's that have no HDMI inputs to take advantage of Hi-Res audio.
This is all provided their AVR has 7.1 inputs.
oztech is offline
Old 09-04-2013, 08:34 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
A lot of older AVRs may only have 5.1 inputs but that would be adequate for a 5.1 system and the Oppo is just as happy feeding 5.1 as 7.1. smile.gif
JazzGuyy is offline
Old 09-04-2013, 11:03 AM
hernanu's Avatar
Quoted: 593 Post(s)
Liked: 1070
I'd echo bluechunks, you probably want to keep it simple.
If you want to play with it, especially with music, you can set the multi channel connections up and bypass processing in your AVR, see whether the DACs in the Oppo are better than the Sony.
I have a good AVR (Pioneer Elite VSX-33), and use my Oppo to feed a bitstream to it, letting it do the sound processing. The real question is if the Oppo's DACs are better than the Sony's.
Just an aside, have you tried any music on the Oppo to compare?
hernanu is online now
Old 09-04-2013, 11:21 AM
monteplus3's Avatar
No, have not played music on the Oppo, just movies. I was really wondering if the sound quality for movies would be enhanced with the multi-channel set-up as opposed to digital, but apparently not....sounds like I'm just as well off sticking with the one HDMI cable.
The multi-channel connection seems like quite a unique feature for a player like this to have, so it led me to believe that by not having my system connected in this manner, I might be missing out on something.
If I am just as well off with my HDMI connection, I might as well avoid running four analog cables from the Oppo to my AVR and go with bluechunks' advice.
Old 09-04-2013, 11:49 AM
Quoted: 649 Post(s)
Liked: 349
I thought the main benefits of the "Analog" outputs was to take advantage of the OPPO DAC as well a feed direct DSD signal. Or is that only available via HDMI2 on the OPPO with the caveat that your receiver must be able to handle DSD.
I ended up playing SACD's - - which sound fabulous - - via HDMI1 from the OPPO with the "PCM" setting on. (Bitstream for movies) There might be additional processing going on with with my Pioneer SC65 receiver - - even in "Pure Direct" mode, but it is far more convenient to run it this way since the SC65 AVR does not handle DSD direct. It can take a DSD signal, but it just converts it to PCM.
Anyway - - for simplicity sake - - I run everything out of HDMI1 - - and the OPPO does a great job with Multichannel music as well as Bluray movie soundtracks.
Home Theater Setup
Old 09-04-2013, 01:33 PM
JKR1963's Avatar
Quoted: 191 Post(s)
Liked: 88
I just ordered a region free kit off of ebay as I want to be able to play other region Blu ray movies (and DVD). I want to order some "Region Free" disc's (the tv show Strike Back + some R.2 stuff) from Amazon UK. The site says that they won't play in US 60i Blu ray players "as the Blu-ray discs are authored to UK 50i specs". Can anyone here confirm that these 50i disc's will play normally with the 103 and the region kit. I want to make sure before I order any disc's. I have ordered lots of Region Free Blu rays from Amazon UK and they always play........I wonder why they would also make different 50i mastered disc's when all of them are UK marketed disc's?
JKR1963 is offline
Old 09-04-2013, 01:35 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Yes, all OPPO players have always played 50hz sources.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 09-04-2013, 01:39 PM
JKR1963's Avatar
Quoted: 191 Post(s)
Liked: 88
Thank You wmcclain.
JKR1963 is offline
Old 09-04-2013, 03:20 PM
icirider's Avatar
Thanks, looks like that's the plan.
icirider is offline
Old 09-04-2013, 05:42 PM
DeLaw's Avatar
BDP-103 can output audio and video to two 3D or 2D TVs simultaneously!!! But when I do this I get only a stereo signal to the main. I will also lose all surround on the main system when the second TV is turn on no matter what source I have it on. The main (HDMI 1) is connected to a SC-07 then to a Sony KDL-65w5100. The second out (HDMI 2) is connected to a Samsung UN32EH5300, and to a Sony DB830 Through the coaxial of the BDP-103. Both setups play fine by themselves. Anybody got any idea what is happening.
DeLaw is offline
Old 09-04-2013, 08:04 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
You will want to use HDMI 2 to your primary system and HDMI 1 to your secondary system. This will allow you to get high resolution audio with HDMI and video through both HDMI outputs.
Also use Dual HDMI of Split A/V.
Old 09-04-2013, 08:34 PM
parawing742's Avatar
Can anyone who already owns the 103 tell me how quickly it can switch from the HDMI input back to a regular Blu-ray menu? I'd like to eliminate the HDMI switch in my setup (not enough inputs on my receiver) and the only other HDMI device I have is a Roku. What I'd like to do is to have the Roku connected to the 103 input. If it takes like 20 seconds to switch between the the input and a Blu-ray than it's not going to work for me as I want it to be as fast as my existing setup.
parawing742 is offline
Old 09-04-2013, 08:59 PM
KC-Technerd's Avatar
Quoted: 64 Post(s)
Liked: 136
From the user manual Page 53:
2. Dual HDMI Output: Allows you to select the output mode when both HDMI Output ports are in use. If only one HDMI Output is active, this selection will not apply.
Split A/V (recommended) – Use HDMI 1 OUTas the dedicated video output port and HDMI 2 OUT as the dedicated audio output port. This setting will ensure the best possible picture quality and the highest possible audio resolution.
Dual Display – Send digital audio and video signals to both HDMI Outputs simultaneously. This setting is only recommended when two HDMI displays are required, since the surround sound audio signal may be down-mixed to stereo and the original audio quality may be lost.
Also see: Understanding Dual Display Mode from the Oppo Knowledge Base.
Apparently when using Dual Display mode, the audio codec is limited to the capabilities of the least capable attached and active HDMI device. The Samsung is probably only accepting 2-channel LPCM via HDMI 2 and thus also limiting the HDMI 1 output to 2-channel LPCM as well.
You can always push the info button on the remote, followed by the page up or down to see what the Oppo is actually outputting on HDMI 1 and HDMI 2 for both video and audio. This may help you figure out for sure what is going on, and the best workaround solution.
A possible work-around (only one I can think of) would be to switch the Dual HDMI Output setting to "Split A/V", and reverse your 1 and 2 HDMI connections, as I think Neuromancer was trying to describe above. This would provide video by HDMI to both outputs (HDMI 2 limited to 24 bit) but only HDMI 2 would output audio (to your Pioneer SC-07) which would then not be limited by the other HDMI output. It sounds like the Samsung would not need any audio via HDMI, since you have the coaxial connection to the Sony STR-DB830.
KC-Technerd is offline
Old 09-04-2013, 09:13 PM
Quoted: 64 Post(s)
Liked: 136
Switching to the HDMI inputs will stop the play of the Blu-ray disc (or any disc in the tray). The disc will not continue to play while one of the HDMI inputs is selected. Switching back to the Blu-ray player will immediately bring up the Oppo home screen menu for the Blu-ray player, but you must re-start play of the disc. Getting back to the Blu-ray disc's menu can take some time.
Old 09-04-2013, 10:24 PM
ahkim's Avatar
Sorry if I read this out of context. Are you saying that the picture quality of the Oppo is not better than any other good bluray player? I only watch Bluray and bought the oppo as I thought the PQ was superior to any other player. I thought that using the dual HDMI improved the PQ. Thanks.
ahkim is offline
Old 09-04-2013, 10:46 PM
oddmania's Avatar
Quoted: 12 Post(s)
oddmania is offline
Old 09-04-2013, 11:01 PM
Done Deal DR's Avatar
Quoted: 94 Post(s)
Liked: 142
Man. I wish I had that...
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
Old 09-04-2013, 11:12 PM
oddmania's Avatar
Quoted: 12 Post(s)
I'm thinking of buying DARBEE DVP 5000 and connecting it from my BDP-103 to my Samsung 64"F8500 PLASMA,But I don't know if I'll notice any difference or is it even worth it ?!!
oddmania is offline
Old 09-04-2013, 11:21 PM
Quoted: 94 Post(s)
Liked: 142
People have reported great results with it, along with pictures that actually display differences. I'd definitely buy it but I don't like the idea of adding a device in the HDMI chain like that. This device solves that problem, wonder how much it will cost... maybe my standard 103 will be finding a new room in the house.
Old 09-05-2013, 12:12 AM
Coyote Waits
htwaits's Avatar
Quoted: 920 Post(s)
Liked: 2030
The contents of any Blu-ray that contains 1080p data really needs very little processing on it's way to a 1080p display. If the contents a the Blu-ray disk are 1080i (usually TV source material), then the data has to be deinterlaced by the player, AVR or display. There is not going to be enough difference between Blu-ray players for most people to buy the OPPO Blu-ray players for Blu-ray alone. If you are also using the HDMI outputs, then there shouldn't be a difference in audio either.
There is a significant difference if you are playing DVD disks. Few people buy the OPPO players exclusively for Blu-ray play back. At least that's been the majority conclusion in the OPPO 83, 93,103, 95, and 105 threads. There is a long list of other reasons to own an OPPO.
If you are unhappy with your purchased, there is another benefit of owning an OPPO -- the very high resale value. biggrin.gif
There is no measurable PQ gain from using both HDMI outputs. There are other reasons for that feature too. I may not be able to continue this exchange because I'm not sure that I'll be back to AVS for the next ten days.
Take your time to learn more about your player. I think you will have two good options -- keep it to enjoy, or sell it and save some money. smile.gif
htwaits is offline
Old 09-05-2013, 04:30 AM
DeLaw's Avatar
Thanks for the help KC-Technerd I will have to leave it set up like it is. The Samsung TV is the one that is receiving Stereo. What I didn't like the most is just having the Samsung
on causes this problem even though it's set to another input. I might try a splitter out of the SC-07 to the Sony. I already got a switch on the SC-07 out HDMI-2.
DeLaw is offline
Old 09-05-2013, 05:17 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
I have now owned the Darbee DVP5000 since last August. It is in the signal chain Oppo 103 >> Denon 4311ci >> Darbee >> Sharp 70" Aquos display. Once you own one of these and appreciate the "lifting of the veil" that is done by the Darbee you will not want to go back and watch your TV shows or blu-rays without it. I'm glad to see Dr. Darbee is now making headway with getting OEMs to start using it in their products.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
