Official OPPO BDP-103 Owner's Thread - Page 386 - AVS Forum | Home Theater Discussions And Reviews
 850Likes
post #11551 of 24340 Old 09-05-2013, 05:49 PM
KC-Technerd's Avatar
Quoted: 55 Post(s)
Liked: 130
Originally Posted by DeLaw View Post
KC-Technerd I tried all three inputs to the Samsung,Still get the same response.
The best thing for me to do is get a compatible AV Receiver to replace The Sony DB-830. I do have a place for it.
The Idea of a splitter requires to much of another trial and error that I don't fell like dealing with. The switch I have
coming out of the SC-07 HDMI-2 out is hooked to a cheap 24in HDTV that I use when I do not want to turn on the large TV, and a 26in HDTV that goes to the Kitchen.Only one of the two will work at one time and will work with or without the large TV that is hooked to the HDMI-1 OUT.
I used to have a Sony STR-DB930 that is still in the family. It always had a peculiar dip right at the frequency of Glenn Frey's voice.
Hopefully having another HMDI receiver between the Oppo and the Samsung will isolate the Samsung from the Oppo so the Oppo doesn't set itself for the audio capabilities of the Samsung.
KC-Technerd is online now
post #11552 of 24340 Old 09-05-2013, 06:07 PM
RobDec's Avatar
Quoted: 126 Post(s)
thanks Rdgrimes
I have been out of the loop since I purchased to 83. My other equipment has some years behind it. Looks like ill go for the 105. From what I hear the 105 wont be replaced til fourth quarter 2014.
Rob
RobDec is offline
post #11553 of 24340 Old 09-05-2013, 06:11 PM
Quoted: 55 Post(s)
Liked: 130
Originally Posted by RobDec View Post
I guess my question is given that the 105 has better DACs and a better anolog board, will it give a considerable better sound than the 103s, on the analog end? I currently have the 83, but no 3D. Im not looking for better bells and whistles, just Audio quality.
Thanks again Rob
I think the biggest advantage of the 105 in audio quality is if you are connecting analog outputs of the 105 directly to power amps. Second option would be through a receiver (AVR) or preamp that is not re-digitizing the audio for processing. Even then, the reviews I've seen suggest the improvement in audio quality is real, but subtle (over the analog outputs on the 103). I don't think you're going to find anything near a night and day difference between the two. If you use HDMI (or S/PDIF) for audio to your receiver or preamp, then the DAC in the Oppo isn't being used anyway, so there would be no difference.
My AVR uses ES9016 Sabre32 Ultra DACs which are better than the DAC in the 103, but a step below the ES9018 Sabre32 DAC in the 105. There's lots of discussion to be found on which DACs are better, and how much of a difference they actually make vs. other factors such as DAC implementation.
Here's a few reviews that focus on the audio quality/capability of the 105:
http://hometheaterreview.com/oppo-bdp-105-universal-blu-ray-disc-player/?page=2
http://www.soundandvisionmag.com/article/review-oppo-bdp-105-universal-disc-player?page=0,1
http://news.cnet.com/8301-13645_3-57565878-47/oppo-bdp-105-not-your-average-blu-ray-player/
post #11554 of 24340 Old 09-05-2013, 06:36 PM
RobDec's Avatar
Quoted: 126 Post(s)
Thanks KC-Technerd
I am using the analogs for SACD, DVD-A, Dolby True, and DTS HD MA. Im using optical and coax for the Lex processing.
If the difference is only subtle and using the second option, Im favoring the 103. Ill have to research the reviews you recommended.
Rob
RobDec is offline
post #11555 of 24340 Old 09-05-2013, 06:39 PM
kendo70433's Avatar
Does anyone else see that Neuromancer's Post #1 has been mostly deleted? Or is it just some strange rendering on my browser?
Ken
kendo70433 is offline
post #11556 of 24340 Old 09-05-2013, 06:43 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2580 Post(s)
Liked: 1765
Ken
It's the whole forum. Intermittent melt down today.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #11557 of 24340 Old 09-05-2013, 06:59 PM
Quoted: 55 Post(s)
Liked: 130
Thanks KC-Technerd
Rob
Rob
I struggled with the decision between the 103 and 105 myself. Ultimately, I just couldn't justify the extra cost of the 105 unless I was going to use it as my preamp/processor directly output to power amps. I decided instead to put the money toward an AVR with good DACs, and a room correction system.
I believe your Lexicon has an analog bypass mode. Understand that only when you're using that mode would you really be hearing the ESS Sabre DAC in the 105. Otherwise the analog input from the Oppo is being re-digitized by an ADC in the Lexicon, and eventually converted back to analog by the Lexicon's DAC(s).
Brett
post #11558 of 24340 Old 09-05-2013, 07:21 PM
RobDec's Avatar
Quoted: 126 Post(s)
Thanks Brett
I read your recommended reviews and Ive decided to get the 103. If the audio difference is subtle I opt for the 103.
In my decision making process I also decided to save the $700.00 for a good processor.
Thanks to all who replied!
Rob
RobDec is offline
post #11559 of 24340 Old 09-05-2013, 07:40 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2156 Post(s)
Liked: 2726
Ken
It's not your browser. AVS is having a stroke. This is happening to random posts in random threads. If you Quote or Edit the post the full text is still there, it just isn't being displayed correctly when you view the thread normally.
Bill has already alerted the AVS Forum Operations folks.
ETA: And just that fast, the problem with THAT particular post is fixed. But the problem may still be showing up elsewhere. If you see a post showing just a couple lines, then ending in an ellipsis (...), that's probably a post showing this problem.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #11560 of 24340 Old 09-06-2013, 05:37 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1032 Post(s)
Liked: 948
Guys, the moderators have been deleting posts that announce hacked firmware. Similar to discussing illegal movie downloads, my understanding is that it's against AVS policy to discuss hacked firmware on AVS, especially if said firmware enables (or re-enables) features that were removed at the request of entities such as the movie studios. It's probably best to discuss such things on another forum where there aren't such policies.
gsr is offline
post #11561 of 24340 Old 09-06-2013, 06:30 AM
Super Moderator
teachsac's Avatar
Quoted: 632 Post(s)
Liked: 911
Please continue to report these posts. Asking for payment for "hacked" firmware is not allowed on this site.
S~
mhobart likes this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #11562 of 24340 Old 09-06-2013, 06:33 AM
globalnomad's Avatar
A reasonable policy.
globalnomad is offline
post #11563 of 24340 Old 09-06-2013, 07:01 AM
Ricoflashback's Avatar
Quoted: 635 Post(s)
Liked: 335
Re the OPPO 105 as a "Pre Amp" or "Pre Processor" -
I tried connecting my Directv satellite receiver via HDMI to my OPPO 103 and ran into "HDCP" content protection problems with premium channels. Has anyone else experienced this?
Also - - the OPPO 105 only has one HDMI "in" - - so I assume that you'd need to have an HDMI switcher if you had more that one component that you wanted to connect in that mode.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #11564 of 24340 Old 09-06-2013, 07:15 AM
Quoted: 55 Post(s)
Liked: 130
I see two HDMI ins, just like the 103. One on the back and one on the front.
post #11565 of 24340 Old 09-06-2013, 07:28 AM
Quoted: 635 Post(s)
Liked: 335
Ah, I missed the one in the front. But still - - that would look kind of messy running an HDMI cable from there. I would have designed it with two HDMI "in" connections on the back. That would really cover 90% of the HT setups - - satellite box & media player.
Home Theater Setup
post #11566 of 24340 Old 09-06-2013, 07:35 AM
Quoted: 55 Post(s)
Liked: 130
^ Not my favorite place to connect a permanent HDMI cable either.
post #11567 of 24340 Old 09-06-2013, 11:12 AM
SeeMoreDigital's Avatar
Quoted: 464 Post(s)
Liked: 194
This is a good policy that I personally fully support...
I also think it would be helpful if the moderating team announced such forum rule infractions within this topic (together with the members name) to deter others who might do the same wink.gif
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #11568 of 24340 Old 09-06-2013, 11:27 AM
Tornado Red's Avatar
Quoted: 289 Post(s)
Liked: 233
Same here. I have a show or two I can't get via cable, I run HDMI from my Blackberry Playbook to the front of the 103 and stream the sows that way, it works great as a temporary connection.
Tornado Red is offline
post #11569 of 24340 Old 09-06-2013, 11:46 AM
4mula1's Avatar
Liked: 26
Originally Posted by wmcclain View Post
Currently: no Cinavia detection on M2TS or MKV.
-Bill
Are you talking no Cinavia detection at all for MKV, or just over SMB? I have had MKV files played via USB where Cinavia did kick in and I got the popup and lost sound. The work around was to ReMux and remove the chapter references. Then it played fine with no interruption.
4mula1 is offline
post #11570 of 24340 Old 09-06-2013, 12:01 PM
wmcclain's Avatar
Liked: 1765
That's news to me. I'll run some tests.
-Bill
wmcclain is offline
post #11571 of 24340 Old 09-06-2013, 12:04 PM
Quoted: 464 Post(s)
Liked: 194
Which movies?
post #11572 of 24340 Old 09-06-2013, 12:12 PM
TheFactor's Avatar
Liked: 106
Who's running the new FW and there thoughts ? I usually upgrade mine wireless threw the Internet but this one looks only to be Avaiable via USB or a disc . I'm not having any issues with my 103 and works great for everything I use it for so not sure I want to upgrade .
TheFactor is offline
post #11573 of 24340 Old 09-06-2013, 12:15 PM
wmcclain's Avatar
Liked: 1765
The most recent firmware is 0808B, B for beta. You can use network firmware upgrade only for going from beta to beta, or from production to production. Else you need to use USB or disc.
-Bill
TheFactor likes this.
wmcclain is offline
post #11574 of 24340 Old 09-06-2013, 12:22 PM
Charles R's Avatar
Liked: 534
After he saw her on my 65" Sammy with the Darblet and all her facial imperfections - - he said and I quote - "I'm not in love anymore."
If it's anything like my experience with the Darblet it created not revealed them. At least it did the moment I applied it on top of the already contrast boosting processes via my display or HTPC.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #11575 of 24340 Old 09-06-2013, 12:26 PM
wmcclain's Avatar
Liked: 1765
You're correct. I'm getting cinavia detection and prevention on Total Recall (2012) in MKV.
I don't know when this first appeared. I'll check M2TS.
The studio noose tightens.
-Bill
wmcclain is offline
post #11576 of 24340 Old 09-06-2013, 12:29 PM
Quoted: 464 Post(s)
Liked: 194
-Bill
Oh... bummer!
post #11577 of 24340 Old 09-06-2013, 12:40 PM
TheFactor's Avatar
Liked: 106
-Bill
Thanks for the reply ! Is it a worth while FW Upgrade and any issues reported that you know of ? I've got the previous FW and has been working great for everything I use my 103 for .
post #11578 of 24340 Old 09-06-2013, 12:45 PM
wmcclain's Avatar
Liked: 1765
It's not urgent if you are having no problems. This is our standard advice for all updates.
If you report problems then our first advice is "make sure you are running the latest firmware".
-Bill
wmcclain is offline
post #11579 of 24340 Old 09-06-2013, 01:16 PM
Quoted: 635 Post(s)
Liked: 335
The Darblet isn't for everyone. Some folks just do not like the image, period. It doesn't change the resolution or anything like that. it doesn't "boost" the contrast or change it - - it just enhances it. It makes the image look considerably sharper, but dimensionally it takes a huge leap forward. To me, the colors look fantastic - - brighter, sharper, more vivid. All this with no negative consequences to the image and without artifacts.
It definitely sharpens the image - especially for projectors. And, in response to your comment that the Darblet "created it," - - not in my opinion. The same "stubble" effect that I saw on the show when I was channel surfing is evident with other broadcasts. It truly does "lift the veil."
I do not use any HTPC in my setup, so we're probably not comparing apples to apples. But that's o.k. - - to each his own.
Home Theater Setup
post #11580 of 24340 Old 09-06-2013, 01:20 PM
TheFactor's Avatar
Liked: 106
-Bill
Ricker62 likes this.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
