Official OPPO BDP-103 Owner's Thread - Page 406 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #12151 of 24401 Old 10-04-2013, 03:52 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
If you are Bit Streaming then yes, the player will pass NEO:X. DTS NEO:X found on titles like the Expendables 2 is actually a 7.1 soundtrack with additional meta data which the receiver will use to "properly" engage DTS NEO:X.
Don't know about Prologic II Z, as Prologic has always been a DSP processing, and not something that has been encoded explicitly in the source.
Neuromancer is offline
post #12152 of 24401 Old 10-04-2013, 05:31 PM
ntculenuf's Avatar
Originally Posted by iang153 View Post
Any idea if that's programmable into a harmony 900 remote? thanks....
Originally Posted by DSperber View Post
So you always have to use the INPUT button repeatedly on the remote to either cycle from 1 (BluRay) to 2 or 3 for the external inputs, or you can now select the input discretely with INPUT + 2 etc., or you can arrow-down to navigate through the available sources after pushing the INPUT button. No way to avoid this I'm afraid even on the initial state after power-up, but you'd also need to select your input any time you changed from what you were previously using.
Originally Posted by Bob_Ellis View Post
It's easier than that - press input and then the number of the input you want. For example < Input >< 3 > selects the rear HDMI input. Hope this helps.
Originally Posted by mdavej View Post
Depends on what you mean. You can press < Input > <3> on a 900 or add it to the start of an activity, but you can't put that in a sequence because the 900 can't do sequences.
You can make the harmony do this by adding it to the activity.
Activity >settings >review the settings for this activity >yes, but i want to add more control > then save on the next screen > then keep hitting next until you get to the please review the actions screen. From here you will be able to pick the OPPO from the drop down in the add action highlighted area and add the step you want it to do (Change inputs after it starts up).
I have done this with several other devices to customize a few things in my setup so that they will turn on, off change inputs ect.
ntculenuf is offline
post #12153 of 24401 Old 10-04-2013, 06:33 PM
iang153's Avatar
Quoted: 65 Post(s)
Liked: 25
Thank you - I'll try that!
iang153 is offline
post #12154 of 24401 Old 10-04-2013, 09:09 PM
pwiss's Avatar
Originally Posted by dropzone7 View Post
I don't have the equipment to consider myself an audiophile so analog inputs are not a concern for me. I have a DVDO DUO so I would most likely use "source direct" from whatever Oppo I end up with and let the projector do the 4K processing. I have read a bit about the Darbee and it would be nice to have it all in one box and not have that little add on device but I don't think it's a must so perhaps a used 103 is the best bang for the buck right now.
How many devices do you have running through the Duo? I had an Edge and sold it when I got the 103. I was only running my cable box through the Edge as I run my Computer straight to the TV. If you were able to sell the Duo then getting a 103d would be an increase in overall PQ from your current setup and very easy on the pocketbook.
pwiss is offline
post #12155 of 24401 Old 10-04-2013, 10:00 PM
NephiIim's Avatar
Hey all,
I am having issues with Netflix on my OPPO-103. It randomly will give me BkSOD while loading movie/episode. Multiple random failed Netflix logins. That's with both wired/wireless connection. Have done factory resets, DNS changes, with no effect. Also lately have been getting black screen after starting player. Player connected to Yamaha V667.
Anyone else getting issues like that?
NephiIim is offline
post #12156 of 24401 Old 10-04-2013, 10:14 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2272 Post(s)
Liked: 2852
Originally Posted by NephiIim View Post
Hey all,
What firmware are you running? I suggest you try the 0808B Public Beta firmware. If you have a US version 103, download that from the OPPO Digital support page and install it via a USB stick:
http://www.oppodigital.com/blu-ray-bdp-103/blu-ray-BDP-103-Support.aspx
Firmware version info is in Setup > Device Setup > Firmware Information.
Jot down your settings ahead of time. After the install you need to do a Reset to insure proper operation. On the first power up after the install a Recommended Reset will be offered, that's all you need. That one will preserve your existing network settings and Internet app login credentials.
If you are still having problems with Netflix after that, check the quality of your network hookup -- e.g., signal strength in Setup > Network Setup > Connection Info if using Wifi, and also the Network Speed Test in the My VUDU section of the VUDU app if you use that one.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #12157 of 24401 Old 10-05-2013, 12:47 AM
Razvanel's Avatar
Originally Posted by JazzGuyy View Post
The only way to get a BDP-103 cheaper is to either buy a used one or get one when Oppo has its occasional offering of refurbished units. There has never, ever been an Oppo sale and Oppo's limited dealerships are not allowed to discount.
Amazon has the Oppo 103 for sale for $485.50.
R
Razvanel is offline
post #12158 of 24401 Old 10-05-2013, 02:25 AM
molkenr's Avatar
Bill,
Both the Oppo and the WD TV go through the Onkyo receiver. Is motion interpolation when the image is too sharp that it looks artificial? It's really frustrating because I used to notice this effect on LCD TVs and always proclaimed that this was one of the reasons plasmas were better (!).
molkenr is offline
post #12159 of 24401 Old 10-05-2013, 05:35 AM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
R
I would hardly call $13.50 much of a discount. Probably offsets shipping.
JazzGuyy is offline
post #12160 of 24401 Old 10-05-2013, 06:01 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2694 Post(s)
Liked: 1921
Originally Posted by molkenr View Post
Bill,
Motion interpolation is user controllable, although often on by default. It gives an animatronic, soap-opera video effect.
But I can't tell from your description if that is what you are seeing or not, and I don't know if your plasma has the feature or not. It could be some other sharpness or image enhancement setting.
You should check the video settings on the display and confirm that nothing suspicious is turned on.
On the OPPO, do you have all the Picture Adjustment settings at zero?
Are you using 1080p as the output resolution? What happens if you turn 1080p24 off and on?
Can you connect the player directly to the display, bypassing the receiver, to see if the effect persists?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #12161 of 24401 Old 10-05-2013, 06:06 AM
Chris Mclintock's Avatar
hi all i just got my oppobdp103 and went to use vudu and it comes up country setting usa does not match location nzl (newzealand where i am) please change country settings and try again but i cant see a option to do this..any ideas?
Chris Mclintock is offline
post #12162 of 24401 Old 10-05-2013, 06:15 AM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 194
Hey all,
I have also have problems with multiple failed logins, both with the latest oficial firmware and the latest public beta. But I have found that these only happen when I have just turned on the player. If it's been running for a few minutes and doing something other than Netflix, or even just sitting idle at the home screen, I can login to Netflix on the first try without a problem.
The Black Screen of Death problem happened quite a bit before I installed the latest public beta--after that, it has happened maybe once...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #12163 of 24401 Old 10-05-2013, 07:23 AM
sirhc55's Avatar
Are you sure VUDU is available in New Zealand because it is not in Australia.
sirhc55 is offline
post #12164 of 24401 Old 10-05-2013, 10:33 AM
quovadis123's Avatar
Quoted: 46 Post(s)
Liked: 41
I seriously can't believe my eyes.
My Tv console is only 19" tall, and the Oppo is on the bottom shelf. Basically it is near ground level.
I plugged in my comcast Box in front of the Oppo and my Apple Tv in the back HDMI.
The front HDMI wire creates a loop that sticks out of the console. People could potentially trip on it.
Of course i could push the Oppo back further into the console, so the hdmi would be obliged to follow, but then I hardly see the Oppo.
Of course, alternately I could plug everything directly into my Sony 4k tv instead of the Oppo..but that defeats the purpose of having an oppo in the first place.
I could also plug everything into my HTST7 Sony sound bar, and have one HDMI out to the TV only...
Yet again this defeats the purpose of having an Oppo.
Grrr!!!
quovadis123 is offline
post #12165 of 24401 Old 10-05-2013, 10:49 AM
Read the FAQ!
Liked: 2852
^ There are right angle HDMI adapters you could use with the Front port -- for example check at Monoprice (an AVS forum sponsor), but you might find it better to switch to one of the newer, thinner HDMI cables that aren't so stiff and will hardly stick out forward at all when inserted in the Front port then wrapped around towards the back.
--Bob
post #12166 of 24401 Old 10-05-2013, 10:53 AM
Quoted: 46 Post(s)
Liked: 41
--Bob
You Clever man !!
post #12167 of 24401 Old 10-05-2013, 10:55 AM
Read the FAQ!
Liked: 2852
Originally Posted by pbarach View Post
. . . .I have also have problems with multiple failed logins, both with the latest oficial firmware and the latest public beta. But I have found that these only happen when I have just turned on the player. If it's been running for a few minutes and doing something other than Netflix, or even just sitting idle at the home screen, I can login to Netflix on the first try without a problem.
Next time you power up, go into Setup > Network Setup and do a Connection Test before launching Netflix. You may find the networking in the player has not quite woken up yet. (If the Connection Test fails, just do it again and see how long it takes for networking to wake up.) If you find it is regularly taking longer than seems reasonable for the networking to wake up you might want try some investigation of your in-house network setup
Another possibility is to switch to using Quick Start mode in the OPPO. Among other things, Quick Start leaves the network connection live even while the player is "off".
--Bob
post #12168 of 24401 Old 10-05-2013, 11:49 AM
Read the FAQ!
Liked: 2852
R
That was a short sale! Already back to normal (full) price again.
--Bob
post #12169 of 24401 Old 10-05-2013, 12:01 PM
Quoted: 46 Post(s)
Liked: 41
What does FW FOUND mean?
It's on the screen
post #12170 of 24401 Old 10-05-2013, 12:25 PM
rdgrimes's Avatar
Quoted: 2000 Post(s)
Liked: 1337
It's on the screen
It means the player has found a firmware update either on attached storage or via internet.
rdgrimes is offline
post #12171 of 24401 Old 10-05-2013, 12:35 PM
Coyote Waits
htwaits's Avatar
Quoted: 923 Post(s)
Liked: 2032
R
At this moment there is no such price for a new 103 at Amazon.
htwaits is online now
post #12172 of 24401 Old 10-05-2013, 03:01 PM
mumbleypeg's Avatar
Quoted: 26 Post(s)
mumbleypeg is offline
post #12173 of 24401 Old 10-06-2013, 03:22 AM
max90034's Avatar
Quoted: 24 Post(s)
I stopped with firmware updates back in Jan to keep iso trick to work. It is unfortunately too much pain however to make a folder, etc for every movie so I am planning just to rip my ISOs to uncompressed MKVs. The question is : does the latest firmware still allow to play MKV rips or it was somehow blocked as well?
max90034 is offline
post #12174 of 24401 Old 10-06-2013, 06:32 AM
Quoted: 46 Post(s)
Liked: 41
Received my Oppo 103 and 4k sony x9  tv yesterday.
Neither the Oppo nor the Sony x9 upscale SD content on comcast. Looks awful. Out of focus.
Apple tv and Netflix look good through the Oppo.
As you know I have been punishing You tube for the last 3 weeks to find 4k content on my PC. I really know what is there and what is not.
Both the Sony Tv and Oppo have you tube.
The selection on both of these is pathetic. With the same search criteria, I can find about 10% of existing stuff.
Obviously, one can copy the content on a thumb drive. However you cannot copy 4k on a thumb drive...it will not play. MAKES THE OPPO FREEZE...the TV will not play it either.
I need to figure out how to share my pc on both the Oppo and tv.
I may need some help with this ...
post #12175 of 24401 Old 10-06-2013, 07:02 AM
wmcclain's Avatar
Liked: 1921
Still works.
-Bill
post #12176 of 24401 Old 10-06-2013, 07:08 AM
wmcclain's Avatar
Liked: 1921
One question at a time. What do you most want help with? Obviously you need to ask Sony TV questions in a Sony thread.
The OPPO does not play 4k source material. It would be better if the player did not crash if you tried; get the details to OPPO support so they can generate an error message instead.
What do you mean SD content is not upscaling, out of focus? If the player is producing 1080p then it is upscaling. If your are using Source Direct then you would not expect any scaling. If the player and TV are producing the same bad image, then that indicates an issue with the TV, right?
-Bill
post #12177 of 24401 Old 10-06-2013, 08:21 AM
Read the FAQ!
Liked: 2852
Well obviously SOMETHING is doing upscaling or you'd end up with a postage stamp sized image in the middle of your TV screen.
While playing a Comcast SD channel through the OPPO, press the Info button on the OPPO remote to bring up its on-screen display. The top line will show what's coming into the OPPO as input. The bottom line will show what's going out the HDMI outputs from the OPPO as output.
First check the top line. It should show that the input is 480i/60. If it says the input is 1080i/60 or 1080p/60 or anything other than 480i/60 then it is *THE COMCAST BOX* which is doing the de-interlacing and upscaling. Which is exactly what you are trying to avoid!
So you need to find the settings in the Comcast to tell it you do NOT want it to de-interlace and upscale. Ideally, set the Comcast to produce "native" output -- meaning it will automatically switch to 480i or 720p or 1080i output according to what's coming in on the channel you are watching at the moment.
Now that said, image quality for SD content is all about perfection at every step of the video processing chain. The resolution and data rates for SD content are so low, that any damage to the image WILL be visible. On the other hand, if every step is done right, SD content can look surprisingly good!
Once the video is damaged at ANY step in the video processing chain, that damage can not be repaired -- the information is permanently lost and can not be, somehow, recovered. The best you can do is to try to blur the damage a bit so that it is less noticeable.
Now, the de-interlacing and upscaling in cable TV boxes (and Comcast's boxes are no different in this regard) are simply godawful. But *EVEN WORSE* is what some cable providers do to the content BEFORE they put it on the cable to send to your house! First, they use crappy source content -- copied and recopied with little care to quality until it looks worse than watching a VHS tape. Then they "bit starve" the channel used to transmit it on the cable -- meaning they have to over-compress the already damaged content so that it takes up less room on the cable "pipe". Why? Because they think people watching SD channels won't care -- i.e., they can get away with it -- and they want to preserve that cable bandwidth for some OTHER channels -- e.g., extras cost sports packages, etc.
If you are watching an SD cable channel that's been mangled like that it is going to look terrible. Period. Colors will be off, resolution will be reduced (even more than is already the case with SD) and even image geometry may be off (circles don't look like circles and/or the image is shifted in the frame). Often you will also have garbage noise on one or more side edges as well.
It's important to understand that the bulk of such damage has happened BEFORE the content arrives in your cable box. It's just shoddy broadcasting -- again, because the cable companies feel they can get away with it.
So what to do? First of all, the worst of this stuff will only be on SOME of your SD cable channels. Typically these are syndicated, special interest channels tossed into the cable package because they came bundled with other channels you (and the cable company) really want. So move around the list and try a variety of cable channels to see which are better.
Find the BEST SD cable channel(s) in your package and use THOSE to judge the difference between having the Comcast box do its own de-interlacing and scaling, vs. having the Comcast send 480i/60 to the OPPO so that the OPPO is doing the de-interlacing and scaling.
--Bob
post #12178 of 24401 Old 10-06-2013, 08:28 AM
Read the FAQ!
Liked: 2852
. . . .As you know I have been punishing You tube for the last 3 weeks to find 4k content on my PC. I really know what is there and what is not.
The 103 can not play 4K content. It can upscale normal resolution content to 4K output, but it can not play content which is already 4K. At all.
--Bob
post #12179 of 24401 Old 10-06-2013, 08:32 AM
Read the FAQ!
Liked: 2852
Sharing your PC with your Sony TV will be a topic for a Sony Owner's thread in the TV forum here.
For playing content on your PC through the OPPO, start with the FAQ (link available at the top of the first post of this thread). You will be looking for three things: (1) supported file content and container file formats for audio and video, (2) playing content from an SMB file-sharing server set up on your PC, and (3) playing content from a DLNA media server set up on your PC.
--Bob
post #12180 of 24401 Old 10-06-2013, 08:45 AM
wmcclain's Avatar
Liked: 1921
Also: a day is probably not enough time to go through all the TV controls and make sure you have the proper settings, and all the gimmick video processing turned off.
Do you have a calibration disc, and have you looked at an Alignment/Overscan pattern to verify that the display is doing 1:1 pixel mapping? That is step 1.
-Bill
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
