Official OPPO BDP-103 Owner's Thread - Page 415 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 10-16-2013, 06:14 AM
mumbleypeg's Avatar
Quoted: 26 Post(s)
Originally Posted by hernanu View Post
I don't know... if you're spending 499 for the 103, why not spend 495 for the cable. It does have long grain copper conductors, which apparently are better than short or no grain copper conductors. It also is bidirectional ethernet communication capable... you know... for efficient operation. It also has signal conductors, which make it ARC capable.
It is compatible with most HDMI devices, maybe they can list which HDMI devices they are not compatible with, so as not to spend 495 to communicate with them.
I have no idea how my monoprice HDMI cables work with my Oppo, given that they lack any long or short grains. I must be lucky, but do feel inadequate.
Don't feel inadequate, feel lucky. A digital signal either arrives at the other end of a cable or it doesn't.
mumbleypeg is offline
Old 10-16-2013, 06:16 AM
iang153's Avatar
Quoted: 65 Post(s)
Liked: 25
Originally Posted by DSperber View Post
Just one more comment...
If your Verizon box is a Motorola-family device (as I believe it is), you're probably referring to the "hidden hardware setup menu" being reached by having the unit powered off while the TV is still powered on, and then pushing the MENU button on the front panel of the box. This triggers that hardware setup menu going out to the TV, where you can configure both audio and video via HDMI. And it is here that you would find the "native" option. Or, maybe there's some other method with your particular DVR model.
I believe these Verizon FIOS voxes are a cousin of the Motorola DCX* boxes (and their OEM equivalents from Cisco, etc.) which used to have a problem "retaining native" with previous firmware versions depending on whether you used an AVR or not in between the DVR and the HDTV or if you connected the DVR directly to the HDTV. This was tied to early problems with the HDMI handshakes involved when there were three or more devices in the HDMI relay between source and destination.
In fact, this loss of "native" (and reversion back to a default of fixed 720p or fixed 1080i, neither of which was what you wanted) was probably the most irritating thing about trying to use the desired "native" setting. The workaround was either (a) be sure to power the DVR OFF FIRST, and DVR ON LAST, when you had an AVR between the DVR and HDTV, a trick which usually was successful except with certain AVR brands like Denon whose settings seemed to counteract the trick, or (b) connect the DVR DIRECTLY TO THE HDTV VIA HDMI and not involve the AVR for video, a method that was pretty much 100% always successful... although you might really wanted to have used the AVR to route video.
More recent firmware in these Motorola-family (and Verizon cousins) boxes seems to have finally overcome this "loss of native" problem completely, even when AVR's are between the DVR and HDTV. You may or may not be so lucky with your Verizon DVR.
So... my recommendation is to periodically confirm that the Verizon box is putting out 720p when you're watching a 720p channel, and is putting out 1080i when you're watching a 1080i channel. The "i" (info) button on the 103's remote will display two bands of information, one at the top of the screen showing information about audio/video input to the 103, and a second at the bottom of the screen showing audio/video output from the 103 on both HDMI-1 and HDMI-2. You want to see the correct 720p or 1080i "input" information in that top band, and of course you'll see 1080p/60 in the "output" information band at the bottom.
In other words, you really do want to confirm that your FIOS box is always putting out "native" as you've set, and is not prone to the "losing native" issue we users of the Motorola DCH/DCX equipment previously faced for many years. Hopefully this is now truly fixed in current firmware.
That's a good suggestion - I have Comcast with a Motorola RNG200N - I can set it to 'native' but the next time it's turned on after having been turned off for a few hours it's back to the default of 1080p/60 (even though Comcast cannot actually broadcast 1080p) - so good to occasionally confirm it's still set to native...
iang153 is online now
Old 10-16-2013, 06:35 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Originally Posted by gadgtfreek View Post
Mine works fine with the Harmony One ... I then have a 15 second pause ...
Just wondering why a full 15 second pause?
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
Old 10-16-2013, 07:05 AM
pqwk50's Avatar
Guys, how often do you come across Blu-ray discs that don't support resume?
The Oppo manual states: "Some Blu-ray Discs do not support resuming and will always play from the beginning."
One thing I've always liked about DVD is being able to save the position I was at when I left off watching a movie. If I switch to Blu-ray, am I going to lose this ability for a number of movies?
pqwk50 is offline
Old 10-16-2013, 07:09 AM
OPPOrtunist's Avatar
The majority of BD´s in my collection do not support the resume function. However, some recent BD´s have the resume function encoded on the disc.
ntculenuf likes this.
OPPOrtunist is offline
Old 10-16-2013, 07:13 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2688 Post(s)
Liked: 1921
This is not specifically an OPPO issue. It has been one of the most objectionable features of Blu-ray since day 1. Discs with Java programming (which is most of them) cannot be automatically resumed by the player. Discs without Java can be resumed just like DVDs.
Discs with Java are supposed to provide a resume feature through their own programming, but in the early days very few did. It has become more common now but not at all universal.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 10-16-2013, 07:30 AM
pqwk50's Avatar
-Bill
Yeah, I know it's not specific to OPPO.
Not having resume IMHO is a good reason not to get Blu-Ray. It would make watching a movie a PITA if you don't finish it all in one sitting. I'm surprised this isn't a priority for Blu-Ray to fix.
It reminds me how disappointed I was that HD-DVD didn't win the format war :( (Seems like prices would be cheaper today with HD-DVD and we'd still have the great features of DVD). I'd rather have lower disc capacity with DVD features than what Blu-Ray offes personally. Blu-Ray seems too riddled with DRM and it has ruined the format and experience for consumers. But not having a Resume feature is really inexcusable IMHO.
B 26354 likes this.
pqwk50 is offline
Old 10-16-2013, 08:07 AM
117olddude's Avatar
Quoted: 21 Post(s)
I look at the resume w/BD differently. I'm always so...happy.... when a disc will resume, it's like a little early holiday present. I shut off the system while a new disc is playing, then turn it back on later and the little pop up appears asking if I want to resume. Yay!!!!
Of course, for the majority, it's boo, and then I have to wait through ads, loading, get to scene selection, and try to find my spot.
We could also bring up the issue of loading and all the crud we have to go through to get the disc going in the first place. The early Harry Potter movies would just start after loading. That's heaven.
Love the quality of BD, really dislike the hoops I have to jump through to watch some discs, especially the ones that you can't go directly to menu on. Or the ones you can't even skip 3-5 ads to get to the menu. Do the manufacturers really think my being forced to watch trailers
will make me want to buy those movies?
B 26354 likes this.
117olddude is offline
Old 10-16-2013, 08:19 AM
hernanu's Avatar
Quoted: 593 Post(s)
Liked: 1070
It reminds me how disappointed I was that HD-DVD didn't win the format war frown.gif (Seems like prices would be cheaper today with HD-DVD and we'd still have the great features of DVD). I'd rather have lower disc capacity with DVD features than what Blu-Ray offes personally. Blu-Ray seems too riddled with DRM and it has ruined the format and experience for consumers. But not having a Resume feature is really inexcusable IMHO.
I feel your pain at both the lack of a resume feature and the demise of HD-DVD. I still have my trusty HD-A35 which plays my 150+ HD-DVD's very well, thankyouverymuch. But the war was lost and I waited until a bluray player that matched the 35 in capabilities and quality came out.
I bought an Oppo BDP-83 a year and a half after the last shot was fired and the barricades were down. It has more than held its own in disk playing, and the enhancements put in have put it far beyond what the A35 is capable of. I've also been able to buy new movies of the highest caliber PQ and AQ and feed them to my HT system, keeping it happy.
The java programming on blurays has been abused and misused by the movie companies, and arguably is inferior to that of HD-DVD, but, like an old romance, that has gone and faded leaving only the sweet memories.
I like when resume is available, but it is a crapshoot in blu. If not, I index to the scene and either rewatch a part (no problem for me) or play the "attempt to find the exact spot I left at last time" game.
hernanu is offline
Old 10-16-2013, 08:59 AM
LairdWilliams's Avatar
Quoted: 199 Post(s)
Liked: 224
Originally Posted by Neuromancer View Post
The Roku Stick uses MHL for power and remote control commands as well as audio and video. The Roku Box 3 uses external power and uses HDMI for audio and video only. There are no HDMI CEC or MHL commands available to the Roku Box 3 so you can use the OPPO remote to control the Roku Box 3.
The Roku Box 3 is faster than the Roku Stick. The UI (as far as I remember) is the same.
Also, the Roku 3 box can make use of a WIRED network, which is almost always vastly superior to a wireless connection for streaming reliability.
(It will also still do wireless instead, if you are stuck with that as your only option)
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
Old 10-16-2013, 09:24 AM
On some discs, you can add a bookmark where you stop watching, and then go to that position upon resumed replay. A little more cumbersome than automatic resumption, but nevertheless easier than trying to remember where you left off and finding that spot.
Old 10-16-2013, 09:38 AM
4mula1's Avatar
Liked: 26
A work around I have found is just remember what chapter you are on. (I have even gone as far as to write down the chapter number on a sticky note and attach it to the Blu-ray cover.) Then when you go to start viewing again, just navigate to that chapter. Not as convenient as "resume", but functional.
4mula1 is offline
Old 10-16-2013, 10:14 AM
pqwk50's Avatar
Wait a minute -- the Streaming Stick can't make use of the wired connection available with the BDP-103? I assumed it would just access the internet via the OPPO wired connection. Does the Streaming Stick REQUIRE wireless?
I absolutely will be using WIRED network. So if Streaming Stick does not allow WIRED, then my buying decision is made easy.
pqwk50 is offline
Old 10-16-2013, 10:17 AM
pqwk50's Avatar
On the DVD player I have now (an Onkyo which has been a stellar performer for me), I have a memory setting feature. If I press the button on the remote, that point in the movie is saved in memory and when I next start the disc, I can tell the player to resume from that point. HEAVEN!  Frankly, I won't even be playing Blu-ray if all the discs don't have this feature. It's so disappointing how the movie studios have ruined the high-def disc format :(
Good workaround!
Problem though is you still got to wade through unskippable content most of the time just to get to the menu screen. Studios have ruined the format. IMHO you got a problem when a person prefers lesser VQ because the format is so crippled with DRM and "forced-viewing" of stuff you've seen a million times already and don't want to have to sit through again.
pqwk50 is offline
Old 10-16-2013, 10:19 AM
wmcclain's Avatar
Liked: 1921
That's correct: the RSS uses it's own wireless only. It does not use the player's network connection.
-Bill
Old 10-16-2013, 10:20 AM
wmcclain's Avatar
Liked: 1921
That'll teach 'em.
-Bill
Old 10-16-2013, 10:45 AM
pqwk50's Avatar
That'll teach 'em.
-Bill
LOL. If they were teachable, they wouldn't be spending so much on anti-piracy but instead would be spending on venues for people to purchase and use the content they buy in "legal" ways.
I just find it too onerous to not have resume, so not using it is solely to make me happy :)
**but ultimately it would teach them if enough people didn't buy/rent Blu-ray :)
pqwk50 is offline
Old 10-16-2013, 11:07 AM
rdgrimes's Avatar
Quoted: 1995 Post(s)
Liked: 1326
I just find it too onerous to not have resume, so not using it is solely to make me happy smile.gif
**but ultimately it would teach them if enough people didn't buy/rent Blu-ray smile.gif
If you think that's bad on a movie, try watching a TV series on BD with 4-5 episodes per disc and no resume function.
rdgrimes is online now
Old 10-16-2013, 11:32 AM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
That is why in my house once a disc goes in, it is not removed or stopped until it is watched. That becomes an issue with some of my anime releases, as they often squeeze 8 or 9 episodes on a single Blu-ray.
Neuromancer is offline
Old 10-16-2013, 12:04 PM
DSperber's Avatar
Quoted: 226 Post(s)
Liked: 186
This is in fact a Motorola DCX box, manufactured by Cisco.
The box is up-converting everything to 1080p by default (like we want the 103 to do and not the Comcast box) because that's what the HDMI handshake said the HDTV can support. Even though you theoretically said you did NOT want the box to do that upconvert when you set it to "native", the "loss of native" firmware problem I described appears to be present in your particular piece of hardware.
I assume you have an AVR between the RNG2000N and your HDTV, with an HDMI "relay" involving two HDMI cables between the three devices.
You might try the "DVR OFF FIRST, DVR ON LAST" trick in terms of the sequence of power on/off. This power on/off sequence trick very often will be sufficient to "retain native".
EDIT: oops, typo on that sentence in my original post. I meant to type DVR but accidentally typed AVR. It is "DVR OFF FIRST, DVR ON LAST", when you have three or more devces in the HDMI relay from source DVR to destination HDTV as providing a good chance this will preserve "native". If there are now FOUR devices involved (DVR -> 103 -> AVR -> HDTV), or just THREE (DVR -> 103 -> HDTV) the jury is still out on whether or not your Comcast box will retain "native" or not.
Or, if you really don't need the AVR for video, why not just connect HDMI directly from Comcast box to the HDTV and also add an optical audio connection from the Comcast box to the AVR. Comcast only delivers Dolby Digital which works perfectly on optical audio, so this arrangement will lose you nothing on the audio side, but will retain "native" on the video side since the single-HDMI-cable solution direct from Comcast DVR to the HDTV is not subject to the "losing native" firmware bug.
EDIT: must not have been thinking clearly here. Obviously if you are going to route your DVR through the 103 and then on to the HDTV or through your AVR to your HDTV, you're not going to be connecting your DVR directly to your HDTV! Yes, if you didn't have a 103 that you wanted to use, I'd say connect the DVR directly to the HDTV with just one HDMI cable. But obviously if the 103 is going to be used as we've discussed, this single-cable option doesn't exist.
Of course this does mean you will need to use the INPUT button on your HDTV when you want to watch some other source (e.g. BluRay) coming through your AVR. But there's no such thing as a free lunch here, when your Comcast DVR has this "losing native" firmware glitch.
In any case it's still a prudent suggestion to periodically verify that your Comcast DVR is still putting out "native", especially when the "i" button on the 103's remote will show you that easily and instantly.
DSperber is offline
Old 10-16-2013, 01:06 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 950
That's a common problem with the Motorola boxes. To avoid it, you have to turn on TV first, AVR/Receiver second, Oppo next since you are running it through the Oppo, and the cable box last. Reverse the order on shutdown. That should keep you in native mode. If not, you can set it back to native.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 10-16-2013, 01:39 PM
pqwk50's Avatar
I watch a lot of TV. I use "movie" interchangeably to mean any DVD content.
pqwk50 is offline
Old 10-16-2013, 03:44 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2257 Post(s)
Liked: 2823
S~
What I found with those Comcast/Motorola boxes was you'd be in good shape if you just left them ON all the time. Of course if you have a DVR, that's normal (so it can record programs when you are not there). But you can do it safely with the non-DVR units as well.
If left ON, I found it only forget the "native" setting if there was a power failure.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 10-16-2013, 03:50 PM
Read the FAQ!
Liked: 2823
That'll teach 'em.
-Bill
Nah. They think they've got it right the way it is (not) working now. Just ask any Studio, and they'll say, "When was the last time you went to a movie theater that had a Resume Play feature?"
--Bob
Old 10-16-2013, 03:55 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
What do people do with the BDs from Universal that put up their own Universal screensaver when the disc is paused? I haven't figured out how to go back to PLAY unless I eject and reload the disc, then skip forward to where I left off.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
Old 10-16-2013, 04:01 PM
Read the FAQ!
Liked: 2823
Ah! You've not yet learned the Secret Handshake?
This is a rite of passage for anyone using Blu-ray.
Admittedly it is also a, "WHAT WERE THEY THINKING?", moment -- a perfect introduction to the world of Stupid Studio Programmer Tricks.
Anyway, there are a number of ways to escape this trap -- all of them non-intuitive. The one I use is Pop-Up Menu, which both dismisses the silly Screen Saver and also starts the movie playing again. (Technically that screen saver is implemented as a Pop-Up Menu, and so pressing that button dismisses it just like with normal Pop-Up Menus.)
Good news ahead, though! The most recent Universal Blu-ray title I've tested has a *NEW* programming style for them! Not only is this idiotic screen saver GONE, but they've ALSO replaced their incredibly annoying Menu Sound Effects with something much less ghastly.
--Bob
pbarach likes this.
wmcclain's Avatar
Liked: 1921
That's a FAQ from the BDP-83 days: How do I resume from the screensaver on Universal Studio discs?
Would it have killed Universal to recognize PLAY as canceling the screensaver?
-Bill
pbarach likes this.
mumbleypeg's Avatar
Quoted: 26 Post(s)
The last time that happened to me, I think hitting either thentop menu or pop up menu did It.
Old 10-16-2013, 04:26 PM
iang153's Avatar
Quoted: 65 Post(s)
Liked: 25
You might try the "AVR OFF FIRST, AVR ON LAST" trick in terms of the sequence of power on/off. This power on/off sequence trick very often will be sufficient to "retain native".
Or, if you really don't need the AVR for video, why not just connect HDMi directly from Comcast box to the HDTV and also add an optical audio connection from the Comcast box to the AVR. Comcast only delivers Dolby Digital which works perfectly on optical audio, so this arrangement will lose you nothing on the audio side, but will retain "native" on the video side since the single-HDMI-cable solution direct from Comcast DVR to the HDTV is not subject to the "losing native" firmware bug.
Thanks - you're right - I do have comcast to onkyo AVR to TV (through Darblet) - the Darbee is the reason I don't want to go comcast direct to TV. I have the DVR input on the AVR set to pass-through so I can watch TV (like news, etc.) without having to turn on the AVR. But I guess that's also why it reverts to 1080p. I could try the ordering of powering on and off (I use a harmony 900), so I'll play with that - but don't want to give up the Darbee by going comcast --> TV
sigh ...
Old 10-16-2013, 08:03 PM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Hello all,
Is Oppo working on a fix for the horrendous picture quality of Netflix. The new super HD on Apple TV looks amazing. Oppos version is washed. I will give credit for Oppos sound on Netfilix it does give you Dolby digital +.
HeffeMusic is online now
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
