Official OPPO BDP-103 Owner's Thread - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
Old 11-02-2013, 01:26 PM
KC-Technerd's Avatar
Quoted: 64 Post(s)
Liked: 137
Originally Posted by pqwk50 View Post
Does the Oppo/Marvell still do processing when Video & Audio go thru HDMI-1, it's just that the AVR would process that signal after the Oppo did? Or does the Oppo not apply any processing if Video & Audio are sent thru HDMI-1?
All video from the HDMI 1 output on the BDP-103 has at least some processing performed by the Oppo's Marvell QDEO processor regardless of settings and other connections. If an AVR connected between either of the Oppo's HDMI outputs and a display is set to apply video processing it will be in addition to any performed by the Oppo's processors.
KC-Technerd is offline
Old 11-02-2013, 02:13 PM
somelogin's Avatar
I wonder if I could use a lot of extra processing just to slow down the picture and even out with the audio. lol
somelogin is offline
Old 11-02-2013, 02:40 PM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
If your display has some motion handling settings, try increasing the amount. That will slow down it's video processing and hopefully not increase SOE to the point you reduce it again.
dsinger is offline
Old 11-02-2013, 03:00 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1069 Post(s)
Liked: 1032
Just "in case" my audio sync issues are related to my receiver I may end up splitting it and seeing if it helps that as well, although with the insanely dumb decision of having a FRONT hdmi out, I may not even try it. I have ALWAYS had audio sync issues way before using any sort of receiver and like I said both with directv and cable and discs. And it always seems to me (it's sometimes hard to tell) that it's usually the sound coming too late instead of too early, so I have now ay to correct it. And I remember someLG tvs I tried had it where you could delay by negative ms, but that never seemed to fix it either.
The Oppo has a front panel HDMI INPUT. Both HDMI outputs and 1 HDMI input are located on the rear panel. It's doubtful that sending HDMI1 direct to your display and HDMI2 to your AVR for audio would help with any A/V sync issues. If you continue to have A/V sync issues, the first place to look is to disable any video processing in your display (things like motion compensation, for example).
gsr is online now
Old 11-02-2013, 03:47 PM
somelogin's Avatar
I have all of that type of thing off. Actually I am using an ISF mode on a kuro so I don't know what the settings specifically for that mode itself are, but I know these issues have always plagued me for some reason, no matter which tv or mode I use. I do remember when I had a sony LCD and a panny plasma and connected the 93 to both of them at the same time, the sound would come in at way different times. I believe it came in earlier on the panny. Even when you have all the extra processing disabled, some tvs are worse than others. I'm glad to hear that the front hdmi is an input though! I thought it was mighty dumb to put an output there, but an input is not QUITE as dumb.
Old 11-02-2013, 04:01 PM
Ganymed4's Avatar
Quoted: 107 Post(s)
Liked: 80
Windows Server 2012 R2 Essentials and Oppo SMB.
Just wanted to let you know, that this works very well. I didn't had to install any patches. Works out of the box. However, some files are not shown like m2ts. A folder containing this kind of file is just empty - if there is only the m2ts file. You need to make an account for the oppo and login to this account.
Also, don't be disappointed, 2012 R2 doesn't have a DLNA-server out of the box. But you can add it, download it here: http://www.microsoft.com/en-us/download/details.aspx?id=40837
If somebody has mentioned this already, please excuse my double-post.
PS: I have it, because I have a MS-Technet subscription.
retate likes this.
Ganymed4 is online now
Old 11-02-2013, 04:10 PM
Ganymed4's Avatar
Quoted: 107 Post(s)
Liked: 80
Regarding this, I have one request to make to Oppo: Can you please show the file size and not only the file name via DLNA. This would be extremely helpful. Thank you!
Or do I have to send this to Oppo directly? Thanks.
Old 11-02-2013, 04:14 PM
gwsat's Avatar
Quoted: 2176 Post(s)
Liked: 2406
Originally Posted by KC-Technerd View Post
^ Despite my past resistance to it, I'm becoming more and more sold on setting HDMI audio to LPCM and letting the Oppo do the bitstream decoding.
I have never had a moment's trouble with bitstream connections. In fact my old BD player, a Sony PS 3, couldn't pass HD audio any other way. Similarly on my 103 there seem's not to be a dime's worth of difference in audio quality between HD audio processed by the 103 using bitstream or setting things up to have my Yamaha RX-V3900 receiver decode it.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
Old 11-02-2013, 04:27 PM
miike8888's Avatar
Hi!
oh god!…….the OPPO doesn't do 23.976 when streaming mkv remux files!:( it outputs it in 60hz……how is this even possible for an high-end brand to do this kind of mistake?!
does anybody know if OPPO is working on a fix?….if not they should be because the people who buy OPPO:s are hardcore film fans and this is NOT acceptable at at all.
miike8888 is offline
Old 11-02-2013, 04:34 PM
ingramba's Avatar
Quoted: 111 Post(s)
Liked: 104
Hi all, got my new toy today locally at Bestbuy Magnolia. Really surprised to find one in store! Anyways, I'm very excited to get this thing installed. I currently use a Panny 500 which is no slouch itself. I've always wanted a OPPO because of you guys & gals smile.gif and because we have a thirst for having the best our hobby allows! I'm really interested in using the analogue outs to improve sound on my Onkyo TX-NR809. Will analogue get rid of the harshness I get from blu-ray & CDs? I use Polks all around 5.1. All new owner tips appreciated! Thx and don't forget to set your clocks back tonight!
ingramba is offline
Old 11-02-2013, 04:35 PM
Quoted: 64 Post(s)
Liked: 137
My AVR sometimes mutes bitstream playback for the first instant of video playback, which now does not occur when using LPCM (it did with previous firmware versions). I do have one title that trips up my Pioneer on Dolby True HD when sent via bitstream, but the Oppo handles the decoding to LPCM just fine. I have read of a few Dolby TrueHD titles that seem to trip up the AVRs bitstream decoding, but not the Oppo's. I also see the advantage of using LPCM in the circumstance of playing back Secondary Audio. My Pioneer AVR also handles dialog normalization differently than the Oppo ultimately resulting in bitstream audio being played back 4dB louder than LPCM. Other than those items, just as you said, "not a dime's worth of difference."
Old 11-02-2013, 04:38 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2273 Post(s)
Liked: 2854
Always email suggestions or problem reports directly to OPPO Tech Support. Do not assume they will spot something just because you post it here.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 11-02-2013, 04:39 PM
Quoted: 64 Post(s)
Liked: 137
Originally Posted by miike8888 View Post
Hi!
oh god!…….the OPPO doesn't do 23.976 when streaming mkv remux files!frown.gif it outputs it in 60hz……how is this even possible for an high-end brand to do this kind of mistake?!
It has been stated many times that Oppo intends to fix this with the next firmware release. What is surprising is that a firmware release broke this when it was working correctly before, and that it is taking so long to get it resolved. The firmware update was supposed to be before the end of October, so hopefully we'll see it sometime in the next week or two.
Old 11-02-2013, 04:40 PM
Read the FAQ!
Liked: 2854
Hi!
It's a bug and OPPO has already said they are working on a fix.
--Bob
Old 11-02-2013, 04:52 PM
Read the FAQ!
Liked: 2854
Firmware updates generally include more than just a single bug fix. Some fixes also take longer because they involve co-releases from the chip vendor(s). As a Beta Tester, I can't discuss work in progress, but I think it's fair to say OPPO really does not withhold releases without good reason.
--Bob
Old 11-02-2013, 05:11 PM
Ganymed4's Avatar
Quoted: 107 Post(s)
Liked: 80
Thank you Bob!
Old 11-02-2013, 05:32 PM
Quoted: 64 Post(s)
Liked: 137
--Bob
Sorry Bob. It was not my intent to make it sound like Oppo was withholding a fix. I understand that you can't discuss the work in progress. I also understand that Oppo has been busy with the release of the 103D and a firmware update for the 93/95 since the last beta release for the 103/105. I was just surprised that 24 fps mkv playback broke with 58-0719B on July 19, 2013 when it had previously been working correctly, and that 60-8080B on August 12 corrected the displayed frame rate of the file on the info bar, but not the playback frame rate. I understand there could be a number of reasons for this, and I am not suggesting any specific reason, although I've been hoping that it isn't the result of a BDA mandate, but I think that would have been made public long ago if that were the case.
prsut likes this.
Old 11-02-2013, 05:34 PM
retate's Avatar
Quoted: 40 Post(s)
Liked: 44
Thank you for the information. I plan to move my Server 2012 Essentials to R2 in the near future.
Bob
retate is offline
geebo's Avatar
Quoted: 70 Post(s)
Liked: 34
Is there any way to put my concert DVDs on a hard dive so that they will play on the 103 with menus?
geebo is online now
One-Man Content Creator
wmcclain's Avatar
Quoted: 2701 Post(s)
Liked: 1925
We always blame Mediatek for media file issues.
-Bill
KC-Technerd likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 11-02-2013, 05:35 PM
wmcclain's Avatar
Liked: 1925
With menus: no. There are various ways to copy individual titles.
-Bill
Old 11-02-2013, 05:51 PM
Read the FAQ!
Liked: 2854
-Bill
Yes, that's usually a safe bet. Unless of course we can blame Netflix, instead.
--Bob
Old 11-02-2013, 06:23 PM
geebo's Avatar
Quoted: 70 Post(s)
Liked: 34
Thanks. Sure wish the ISO playback didn't have to go away...
geebo is online now
Old 11-02-2013, 11:04 PM
JMCurtis's Avatar
I just got my Oppo 103 about 3 weeks ago and had a question.
I have it hooked up to my Yamaha Video Receiver's HDMI 1 connection and I've noticed that audio is delaying starting about 2 seconds into a movies, etc. After that, when the audio does start, it is synced properly, and If I go to start the movie over, I then don't have the audio start delay.
I haven't as yet, updated the Oppo's firmware, as everything else seems to be fine. Also, from what I can tell, it seems only BD's are affected by this. Have not noticed it with DVD's.
Can anyone help me with this? Does the current firmware update fix this issue.
JMCurtis is offline
Old 11-03-2013, 12:01 AM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2035
If you're using bitstream try switching to LPCM. That change will not effect audio quality.
htwaits is offline
Old 11-03-2013, 03:39 AM
miike8888's Avatar
Hi!
are OPPO working on a fix for this issue as well?
Old 11-03-2013, 09:04 AM
lujan's Avatar
Quoted: 1925 Post(s)
Liked: 762
I've noticed this as well and have not noticed this on any other players except the Oppo. Also, when you pause a movie, the Oppo takes longer than other players to start again from pause. Others on this forum have mentioned that the Oppos have to spin the disk back up from pause but it happens even with a pause of only a minute or so.
lujan
133 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is online now
Old 11-03-2013, 09:12 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
I'm not sure how long it takes for the disc to spin down. But, it is longer than a few seconds.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 11-03-2013, 10:14 AM
Quoted: 64 Post(s)
Liked: 137
Hi!
It appears to me that Oppo already has fixed this issue with the latest firmware, to the point that the Oppo itself is no longer contributing to this issue. I believe that anything in the HDMI chain can be a cause or contributor to this issue, so results may vary based on the equipment the Oppo is connected to. This is a rather complex issue involving the HDMI handshake, particularly when switching frame rates.
In my situation, it appears that the remaining occurrences of audio muting at the beginning of playback are a result of my AVR, not the Oppo. For me, they now only occur when the Oppo outputs bitstream, only rarely, and with durations of no more than a fraction of a second. They do not occur at all when the Oppo outputs LPCM. On earlier versions of Oppo's firmware they were more frequent, consistent whether bitstream or LPCM, and the duration was considerably longer.
My remaining occurrences seem to be the result of the AVR muting for an instant while it determines the type of bitstream it is receiving.
Old 11-03-2013, 11:59 AM
somelogin's Avatar
What negatives are there to using LPCM? Must be some, or there wouldn't be choices.
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
