Official OPPO BDP-103 Owner's Thread - Page 433 - AVS Forum | Home Theater Discussions And Reviews
 891Likes
post #12961 of 24634 Old 11-06-2013, 07:15 AM
Lloyd-TX's Avatar
Quoted: 21 Post(s)
Liked: 48
Originally Posted by graphicguy View Post
Quick question. For some odd reason, I can't find my OPPO manual. I'm sure it's somewhere buried in all the other manuals I've kept for HT gear over the past decade, but I'm either not seeing it. Or, it's wandered off to a different location.
Onto the question....for comparison's sake, I want to have my pre-pro/AVR to do the DTS-HD/Dolby True HD decoding. What I can't find in the OPPO menu, is how to just use the player as a transport. Again, I'm sure it's something simple that I'm just overlooking. Gimme a hint here on where to look to make these changes.
Gracias!!!!!
Not trying to be a smart-a$$, just helpful. Here you go . . .
http://download.oppodigital.com/BDP103/BDP-103_USER_MANUAL_English_v1.6.pdf
Best regards,
Lloyd C.
Lloyd-TX is offline
post #12962 of 24634 Old 11-06-2013, 07:17 AM
Louie_18's Avatar
Quoted: 12 Post(s)
Guys need your help.
I'm having problems with my BDP-103 and Darbee DVP-5000.
My current connection is BDP-103 HDMI 1 output going Darbee Darbee then to Panasonic AE-7000...
When my Resolution Settings in my Oppo is set to Auto it seems that the Darbee is not accepting the video signal and thus my AE-7000 doesn't detect any source input.
Then I tried the 1080i Resolution setting in the Oppo and it works...
I tried removing the Darbee and connecting directly my Oppo to my AE-7000 and it works even if the Oppo Resolution setting is set to Auto or 1080p...
I also tried turning off the 1080p24 output in the Oppo video settings as well as choosing every option in the Color Space and Deep Color settings of the Oppo but still the same result when I connected it to the Darbee...
What other option or settings should I change so that the Darbee would accept 1080p signal from my Oppo?
Louie_18 is offline
post #12963 of 24634 Old 11-06-2013, 07:22 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2976 Post(s)
Liked: 2232
You don't mention trying 1080p output resolution, which is the result you want. Is that not working?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #12964 of 24634 Old 11-06-2013, 07:36 AM
Louie_18's Avatar
Quoted: 12 Post(s)
-Bill
The resolutions working when connected to the Darbee is 1080i and below...
Louie_18 is offline
post #12965 of 24634 Old 11-06-2013, 07:55 AM
wmcclain's Avatar
Liked: 2232
Ok, so 1080p works when connected directly to the display, but not with the Darbee between. 1080i works both ways.
Please confirm that you have:
  • 1080p24 OFF (note: this is separate from the DVD 24p setting)
  • HDMI color space set to YCbCr 4:4:4
  • HDMI Deep Color OFF
Still no good? What if you try the HDMI2 output instead, settings as above?
-Bill
post #12966 of 24634 Old 11-06-2013, 08:01 AM
KC-Technerd's Avatar
Quoted: 95 Post(s)
Liked: 146
Originally Posted by SeeMoreDigital View Post
I've uploaded a couple of 6.1Ch DTS-ES samples for you to try. Both of which work fine for me. Do they for you?
http://www.sendspace.com/file/0oknng
Cheers
Thanks. I'll try to play these sometime soon. I don't normally use the Oppo to play music files from my computer (DLNA and such) because my AVR works better for that and then I don't even have to turn the Oppo on. So I'm not sure if it's going to be easier to try to set that up, or just copy the file off to a USB flash drive (not easy to access as I have it set up right now. I probably just need to buy another one for temporary stuff like this to plug in the front). Are these samples all of the matrixed type DTS-ES?
KC-Technerd is offline
post #12967 of 24634 Old 11-06-2013, 08:46 AM
warrian's Avatar
Originally Posted by Bob Pariseau View Post
Yes, the MediaTek scaling is non-ringing. It is one of the big improvements in the latest MediaTek chips.
--Bob
This is actually my favorite thing about the 103 (and I'm hoping the 103D, when it arrives next week). Virtually no ringing!
It's part of why I found the Sharpness +1 "solution" so tragic. I've been known to whine a little about the DNR applied by the Marvel, especially on SD sources. But to my eyes and on my set-up the the Sharpness +1 adjustment brings the ringing back with a vengeance, completely defeating what I feel is one of the little miracles of this player.
________________________________________
Sony Bravia KDL-55BX520 / Pioneer VSX-54TX
OPPO BDP-103D / Xfinity X1 / Klipsch Speakers
warrian is offline
post #12968 of 24634 Old 11-06-2013, 10:35 AM
graphicguy's Avatar
No....not at all. Thanks so much to you and Bill.
Music so high you can't get over it....music so low you can't get under it!
graphicguy is offline
post #12969 of 24634 Old 11-06-2013, 12:30 PM
pqwk50's Avatar
Where does DAC (digital to audio conversion) occur with OPPO 103 for video?
The OPPO 103 decodes the video off disc and then sends this data to the TV. Is it sending analog or digital data? Is the TV converting the digital to analog or is the OPPO? Assume HDMI connection with CRT (ie analog) TV. Does this change if assuming a digital (LCD/Plasma) TV?
Concerning audio with an HDMI connection, the OPPO can send LPCM to AVR for the AVR to convert the LPCM to analog and then output to the speakers. Or the OPPO can send Bitstream to the AVR and the AVR will first decode the bitstream to LPCM and then convert that to analog for output to the speakers. If the analog connectors are used on the OPPO, then I assume the OPPO will convert the digital to analog and send an analog signal out. I'm trying to understand this process for the video element.
Trying to understand all this better. Thanks for anyone that can help me out.
pqwk50 is offline
post #12970 of 24634 Old 11-06-2013, 01:04 PM
wmcclain's Avatar
Liked: 2232
Video is all digital these days, no DACs involved, until inside the TV when it must generate some pictures. HDMI is a digital only carrier.
All correct. Only when you use the analog outputs are the player's DACs used.
-Bill
post #12971 of 24634 Old 11-06-2013, 01:06 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 225
Originally Posted by Kage View Post
Does anyone have the Roku stick? and how does it compare to the Roku 3 box?
The stick does not support wired network connectivity, so you are subject to all the crappy vagaries of wireless streaming. Repeat after me - wireless sucks for streaming. Avoid it if you can.
On the flip side, you can use your Oppo remote with the stick - and the stick is half the price.
In the end, I dropped the stick and went with the Roku 3 because the networking issue trumped everything else. I jack it straight into my AVR, since it can already output 1080p and there is really no mechanism AFAIK to take advantage of the Oppo's video processing with it anyway.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #12972 of 24634 Old 11-06-2013, 02:02 PM
JohnAV's Avatar
Quoted: 323 Post(s)
Liked: 483
I didn't find that the case with wireless streaming, as observed with both a RSS and a AppleTV3 connected to the two HDMI inputs on the BDP-105 I have. Depends on your WiFi gear used and of course your ISP connectivity. Playback using both have been fluid and usually at higher stream rates. On rare occasions I had the stream stop because of something happening with the host, but otherwise nothing to complain about.
The fact that Roku put their whole package in a dongle sized device is neat, but as you say its not at all useful for someone with wired connectivity. wink.gif
Oppo Beta Group
JohnAV is offline
post #12973 of 24634 Old 11-06-2013, 02:29 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3083 Post(s)
Liked: 3977
^ Similarly, I use Wifi exclusively, but with the native OPPO apps and with the ROKU Streaming Stick, even though I have Ethernet access available for the OPPO, just to check for problems like this.
I've had no problems that can be ascribed to the use of Wifi. You DO have to be careful to see that you have reasonable signal strength, and that you aren't operating your Wifi on a channel that's in heavy use by the neighbors.
Of course with Ethernet there are no such worries. But if the Wifi is working reasonably for computer use, it should also be working reasonably for the OPPO/ROKU apps.
NOTE: It IS possible for an Ethernet setup to work even WORSE than a Wifi setup. This can happen if you are mixing Gigabit with non-Gigabit gear in your Ethernet configuration and flow control is not properly set up in that set of Ethernet devices. What happens is that the faster units overrun the slower units, causing resends. No data is lost (because the resends work) but the extra resend traffic clobbers the throughput of the Ethernet. We've already had reports here of folks trying to stream from, e.g., SMB servers to the OPPO where Wifi worked when Ethernet failed to work. And that's what was happening. (The Wifi gear imposes flow control, so it doesn't exhibit the problem.)
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #12974 of 24634 Old 11-06-2013, 02:31 PM
somelogin's Avatar
Anyone going to answer me? How can the oppo be causing someone's black levels on their tv to rise? He says he is waiting on an email from oppo, not Panasonic, so obviously he was indeed saying the player caused it.
somelogin is offline
post #12975 of 24634 Old 11-06-2013, 02:37 PM
wmcclain's Avatar
Liked: 2232
People are trying to be kind. You're not having a problem yourself, right?
The player can't do that, presuming the Picture Adjustment controls are at zero. Using RGB PC Level is almost always a mistake, a misunderstanding of what the display requires.
Apart from that: the display may be buggy in responding to certain color spaces, resolutions, frame rates. The player doesn't cause that.
-Bill
post #12976 of 24634 Old 11-06-2013, 02:52 PM
Coyote Waits
htwaits's Avatar
Quoted: 940 Post(s)
Liked: 2079
I don't know if "He Says" is qualified to diagnose either a Blu-ray player or a plasma TV. Maybe the fact that no one is trying to relieve your angst is that they are exhausted from previous attempts. Try waiting to see if "He Says" posts OPPO's reply.
OPPO may suggest to "He Says" that he get his TV calibrated and that he make sure that his OPPO picture settings are at default settings.
htwaits is offline
post #12977 of 24634 Old 11-06-2013, 03:17 PM
B 26354's Avatar
Quoted: 41 Post(s)
Liked: 157
Oppo Tech Support just now confirmed that my 103 CAN recognize multiple USB thumb-drives, using a multi-input USB hub! Here's their response (which exactly mirrors Neuromancer's):
"As long as the USB hub in question is just a simple hub that has no hub management, which this hub appears to be, then it will work with the player. As long as the player can interface directly with the attached USB drives, the player will work perfectly with an attached hub and show each drive as a separate USB device."
Yet another in a never-ending-series of reasons why Oppo BD/CD players are the best on the planet!
Originally Posted by AndrewFG View Post
Today's external hard drives don't require any external power either wink.gif
Thanks, Andrew... I do have a 250GB USB external which I use for backing-up my laptop, and it doesn't require separate power... but I didn't actually realize that was true for all of today's large external HDs.
Even so -- re-addressing the question about why I don't just use a single large external USB hard-drive to accomplish my purpose -- probably the best reason for using multiple USB thumbs in this way, is that I am able to create a playlist for each thumb-drive -- so I end up with playlists for each separate genre of music to which I listen.
Using a single hard-drive would not allow that possibility, since no attached drive can have more than one playlist.
B 26354 is offline
post #12978 of 24634 Old 11-06-2013, 03:49 PM
thirdkind's Avatar
Originally Posted by Neuromancer View Post
So would you rather, to put it bluntly, have more **** broken for other people just to fix the stuff which is broken for you? That is a little selfish, don't you think?
A little defensive and accusatory, aren't we?
They broke core functionality 4 months ago. And yes, it's taken them a little while longer than I'd like to see it fixed. Once again, the tendency is there to assume that because YOU aren't affected by the problem, the value in fixing it is diminished. It's also easy for someone with access to pre-release firmware to throw stones at those of us who just have to twiddle our thumbs while we wait.
I would've taken beta firmware that fixes 24Hz and breaks other things in the meantime, and nobody else would've been forced to use it if it had undesirable side effects in their system.
thirdkind is offline
post #12979 of 24634 Old 11-06-2013, 03:56 PM
Read the FAQ!
Liked: 3977
^ Trust me. You do not want private Beta firmware that doesn't make it out as a Public Beta.
The interactions here are complicated -- probably how the bug snuck in in the first place. If there were an easy fix, it would be out there already. OPPO is on the case, but the fix is not ready yet.
--Bob
post #12980 of 24634 Old 11-06-2013, 03:57 PM
DSperber's Avatar
Quoted: 232 Post(s)
Liked: 189
Originally Posted by B 26354 View Post
I do have a 250GB USB external which I use for backing-up my laptop, and it doesn't require separate power... but I didn't actually realize that was true for of today's large external HDs.
Certainly not true of ALL external HD's.
In my experience, virtually all 1TB-2TB and larger USB drives are really SATA drives inside an external enclosure that has a USB interface to the computer. But the SATA drive inside requires a SATA power connector, which cannot be satisfied by the power running through the USB interface. So these drives always have a separate standard 12v AC power adapter that plugs into the drive (i.e. via the external enclosure), in order to provide adequate SATA power. Same as would be the case for an internal SATA hard drive inside your computer... it needs SATA power.
DSperber is offline
post #12981 of 24634 Old 11-06-2013, 04:49 PM
somelogin's Avatar
Anyone going to ever tell me if there is some centralized list of issues with the 103, waiting to be fixed? I want to be sure I know what all is going on. I think the 24fps issue was only for a certain file type which won't affect me, but there's a lottttt of bugs, apparently, and I may have overlooked some which I will run into.
post #12982 of 24634 Old 11-06-2013, 04:53 PM
wmcclain's Avatar
Liked: 2232
No, there is no such list.
-Bill
post #12983 of 24634 Old 11-06-2013, 04:54 PM
thirdkind's Avatar
--Bob
Thanks, Bob. I appreciate Oppo's diligence, even if I'm impatient about it smile.gif We all have things in this hobby that we're really picky about, and for me, it's motion judder caused by 24Hz > 60Hz conversion. Sticks out like a sore thumb to me. And frankly, I should've known better than to upgrade to a new firmware without a specific reason. It's a lesson learned.
It hasn't been a problem in some cases because I have the Blu-ray disc to fall back on, but for (legitimate) downloads, like iTunes media, there's no alternative.
post #12984 of 24634 Old 11-06-2013, 05:15 PM
somelogin's Avatar
Companied should start having their own public copies of known issues, if for no other reason than to then shut up the customers asking them about the same thing over and over.
Mike_WI likes this.
post #12985 of 24634 Old 11-06-2013, 05:27 PM
Mongo171's Avatar
Quoted: 898 Post(s)
Liked: 1328
Can't you partition a hard drive into different drives with your different genre on each partition?
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #12986 of 24634 Old 11-06-2013, 05:44 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
You ordered a 103D, correct? Then please stick to worrying about the 103D (which has its own separate thread). There's no point in worrying about a bug list (or anything else) for a product you aren't even going to own. Sheesh.
We answer the same questions over and over in these threads, many of which are already answered in the owner's manual, Oppo's knowledge base, and Bill's FAQ. So clearly, documenting things doesn't stop people from asking about them over and over. I would expect no different from a published list of known bugs. rolleyes.gif
gsr is offline
post #12987 of 24634 Old 11-06-2013, 06:11 PM
Read the FAQ!
Liked: 3977
Nope. Won't happen. That's a level of expectation / entitlement which is, quite simply, never going to be met. In all my years dealing with Consumer Electronics and Home Theater products I've yet to run into a single company that has even attempted to achieve that utopian standard of customer education.
--Bob
Mike_WI likes this.
post #12988 of 24634 Old 11-06-2013, 06:12 PM
Read the FAQ!
Liked: 3977
Bets?
--Bob
post #12989 of 24634 Old 11-06-2013, 06:24 PM
thirdkind's Avatar
If there's one thing this thread demonstrates, it's that people don't read manuals, FAQs, or any other documentation prior to posting. If they did, this would be page 43 and not page 434.
B 26354 likes this.
post #12990 of 24634 Old 11-06-2013, 06:35 PM
whippersnapper's Avatar
I don't want to discourage you from asking questions on this 103 OWNERS thread, but why are you so bitter about the OPPO 103 and OPPO in general? I've had mine for several weeks and it's very clearly an OUTSTANDING piece of well designed electronics. My family members are "tickled pink" with this Blu-ray player. And the knowledgeable experts on this thread have been very responsive to our questions--they've helped me get the very best of our OPPO103. Are you as bitter about and as unhappy with the other equipment you have in your home theater setup?
whippersnapper is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
