Official OPPO BDP-103 Owner's Thread - Page 451 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #13501 of 24402 Old 12-06-2013, 09:37 AM
yankee14's Avatar
Thanks there seems to be an acknowledgement that there are problems accepting passwords.
I have an Apple TV but the remote is limited, that is why I was trying it through the OPPO.
I will work on it later .
One question:
When you say: "I would avoid using administrator accounts for SMB access via the Oppo."
What entry would I use, please note that I am 70 and limited in computer knowledge.
yankee14 is offline
post #13502 of 24402 Old 12-06-2013, 10:31 AM
gwsat's Avatar
Quoted: 2163 Post(s)
Liked: 2384
Just installed the latest update and it performed as advertised. When I powered up my 103 for the first time after the latest update was installed, I was prompted to either reset the 103 to factory defaults, which was highly recommended, or keep the present settings. I decided to believe the Big Computer in the Sky and pressed the Reset to Factory Defaults button. Since then everything has gone well.
On another issue discussed here recently, I installed a JVB Digital all regions modification chip in my 103 in April and it has performed flawlessly ever since. Highly recommended!
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
post #13503 of 24402 Old 12-06-2013, 12:03 PM
Adam-DiVine's Avatar
Originally Posted by apw2607 View Post
Agreed. I'm surprised more people are not noticing it. I do think it effects only some titles though. Give stereo a try and report back if that fixes the problem. Although its "stereo" .. the track still contains Dolby Surround, therefore switch you're receiver to Pro Logic (II) ... and it will still sound very good !!
Edit - scratch that, just realized you're running a stereo setup anyway !
I'm not sure if others are experiencing the same problem that I am. It makes Netflix watching almost unbearable. I am going to hook up an old stereo preamp to my system to rule out the receiver, but again this problem only started when I switched from the 93 to the 103D. I will have to check if the problem is only with 5.1 titles or with stereo titles as well. Maybe I should contact oppo?
Adam-DiVine is offline
post #13504 of 24402 Old 12-06-2013, 01:07 PM
warrian's Avatar
I will second this endorsement. The internal/external region free mod kit from JVB Digital definitely seems the one to have. No problems with updates or operation for me. Although like some others, you really do need to turn off Auto Resume to switch regions properly.
________________________________________
Sony Bravia KDL-55BX520 / Pioneer VSX-54TX
OPPO BDP-103D / Xfinity X1 / Klipsch Speakers
warrian is offline
post #13505 of 24402 Old 12-06-2013, 01:55 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
I had better customer service from them as well.
Jacob
Jacob305 is online now
post #13506 of 24402 Old 12-06-2013, 02:32 PM
Morris Jones's Avatar
I noticed others reporting audio troubles with the Netflix app.
I tried my first "Super HD" movie a couple of weeks ago (Serenity) and had all sorts of data-rate problems. Worse, the Center speaker audio was being routed to my Left Surround.
I've been seeing friends post on Twitter asking if others are having Netflix data rate problems. Hopefully this is a network problem they'll be able to deal with.
Morris Jones
Monrovia, CA
http://www.whiteoaks.com
Old Town Astronomers: http://www.otastro.org
Morris Jones is offline
post #13507 of 24402 Old 12-06-2013, 06:15 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2272 Post(s)
Liked: 2852
OPPO UK has now posted the Official 1204 firmware for the EU versions of the 103/105/103D
http://www.oppo-bluray.co.uk/customer-services/firmware-updates/
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #13508 of 24402 Old 12-06-2013, 07:59 PM
pbarach's Avatar
Quoted: 321 Post(s)
Liked: 194
I guess my question is why are some people not having audio troubles with Netflix? I have had none at any time, except for an occasional movie where the sound was egregiously out of sync.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #13509 of 24402 Old 12-06-2013, 10:07 PM
Rhythmx's Avatar
Quick Question. The 1080p/24 selection is now Auto, Forced or Off. Should I leave it on Auto, or Forced. Auto seems to work fine. Wasn't sure since the old firmware used Auto, ON and OFF.
Mark
Rhythmx is offline
post #13510 of 24402 Old 12-06-2013, 10:15 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
Some people say that in general, when using settings with an auto-or-explicit option, you should set it to an explicit setting when possible.
Sometimes that will take stress off of the processor in the player so it has less to do, and thus less things to overwhelm/overwork it.
Not sure if that applies in this case, but If all the displays that are connected to the player do support 1080p/24, then you can change it to "forced" if you want to. Then again if it's working fine the way it is, you can leave it on "auto" too.
Smarty-pants is offline
post #13511 of 24402 Old 12-07-2013, 10:48 AM
Given the distributed nature of Netflix, it makes sense to me that people in some areas would see problems that aren't evident in others. Not so much physical geography as network topology.
Mojo
Morris Jones
Monrovia, CA
post #13512 of 24402 Old 12-07-2013, 10:51 AM
boe
boe's Avatar
Quoted: 899 Post(s)
Liked: 414
Anyone with the XBR-65X850A and the Oppo 103? Have you tried 3D yet? I can't get it to work.
I've tried disconnecting the HDMI from my AVP and going directly from the 103 to the TV. The TV reports 3D signal detected.
I tried pressing the 3D button on my remote - tv says 3D on
I put on 1 pair of glasses - light flashing green - still I either get things way out of phase like a 3" wide ghost from the image or no ghost but still no 3D
I put on another pair of glases - also flashing green - still no 3D
On the TV, I went to the home - then 3D settings - It says on, auto, auto, auto .. I've tried adjusting just about all - still no 3D through any of the glasses that came with the TV
On the Oppo, I've tried changing the screen size, depth - etc - still no 3D on the glasses.
I'm at the same level as the TV - clear line of sight - no 3D.
Tried turning on and off lights - no 3D.
Does it require two hdmi cables? I'm currently using one - when it said 3d signal detected I thought it only required one but I could be wrong as I've never set up 3D before. Again, currently it is going direct from the 103 to the XBR.
boe is offline
post #13513 of 24402 Old 12-07-2013, 10:57 AM
pbarach's Avatar
Quoted: 321 Post(s)
Liked: 194
Mojo
Then the blame must not rest on Oppo or its Netflix app.
pbarach is offline
post #13514 of 24402 Old 12-07-2013, 11:29 AM
boe
boe's Avatar
Quoted: 899 Post(s)
Liked: 414
In addition to not being able to get 3D to work - I'm pretty sure the fault lies with me; I can't get 4K to output from the 103 with the new firmware. I have 4K set to forced on the Oppo but the XBR-65X850A only sees it as 1080p. I hook up the Sony 4K media player to the same HDMI port and it sees it as 2160p so I know it isn't the port but perhaps something I'm doing wrong on the oppo.
boe is offline
post #13515 of 24402 Old 12-07-2013, 11:59 AM
CHG
CHG's Avatar
Quoted: 13 Post(s)
Jacob
I have had great customer service from JVB Digital, as well. They even responded to one of my emails at 2:45 in the morning. Just a couple of hours after I had emailed them.
CHG is offline
post #13516 of 24402 Old 12-07-2013, 12:18 PM
Kayess's Avatar
I have older Denon receiver that doesn't support HDMI input and a sim2 projector that only supports 1080i and has HDMI input. I am thinking about getting the Oppo 103 as my Pioneer 51FD's HDMI stopped working.
I have a couple of questions that someone may be able to answer:
- How does the analog 7.1 output of the BDP-103 sound?
- Will I see a noticeable video difference in quality (as opposed to another player like my pioneer) on 1080i?
Eskay
Kayess is offline
post #13517 of 24402 Old 12-07-2013, 03:15 PM
Tornado Red's Avatar
Quoted: 293 Post(s)
Liked: 239
I'm wondering if anyone else has had issues with the new Eric Clapton BD release of the Crossroads Guitar Festival 2013 on their 103. I bought it on release day a few weeks ago and found the video virtually unwatchable, it was that bad. Heavy, heavy grain, flickering background light and gray banding across the screen. Only during the concert though, interviews were fine. I saw one bad review, that was on hometheatershack where the reviewer had similar issues to mine (not sure of his test delivery system). I read a good write up on Blu-ray.com with none of the issues I had. Hmmm. I returned the BD today and got another copy, same thing as the first one. I pull the BD out of the Oppo and put it in my Sony 350 in my living room and it looks fine. The disc looks bad on the Oppo with old firmware, and no better with the new Dec.5/13 firmware. I've never had this happen to a Blu-ray like this before, I would sure appreciate it if anyone has any insight to what my issue might be, thanks.
Tornado Red is offline
post #13518 of 24402 Old 12-07-2013, 03:20 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
It may well be that it is 1080i 30 or 1080i 25 or 50. It was probably shot on video. If you have 1080p 24 turned on on your Oppo, try turning it off and see if that makes a difference.
JazzGuyy is offline
post #13519 of 24402 Old 12-07-2013, 03:36 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
The OPPO logo will be 1080p/60Hz, so there will be no 4K. Ensure that you have 4Kx2K Output set to FORCED and not AUTO.
Ensure that you are playing back a 1080p/24Hz content such as a Blu-ray.
Try using the HDMI 4 input on your 4K display.
Ensure that you are using HDMI 1 and not HDMI 2 when connected to the display.
Neuromancer is offline
post #13520 of 24402 Old 12-07-2013, 04:16 PM
boe
boe's Avatar
Quoted: 899 Post(s)
Liked: 414
Thanks - 4K it is set for forced on the Oppo
I am using a bluray disc - Avatar
I tried HDMI 4 - that is the one that shows 2160p for the 4K media server but only shows 1080p for the Oppo
I am using HDMI 1 on the oppo - tried connecting it to HDMI 1 and 4 on the Sony.
UPDATE - Thanks - I switched it over to Ironman 2 (not a great movie) and it is output is now 2160p - I tried it on both HDMI 1 and 4 and it works.
Now if you guys can help me figure out what I've messed up on the 3D I'll be golden! I've tested with Avatar and another 3D movie - neither one works with the settings I've got. You get out of phase video.
boe is offline
post #13521 of 24402 Old 12-07-2013, 04:43 PM
Quoted: 293 Post(s)
Liked: 239
Ah ha. Thanks for the info. Although that wasn't it, it did get me looking at my video settings. Since near the beginning of 103 ownership 9 months ago, I've been running +2 for sharpness (old eyes). I've never had a negative response to running +2 until now. There's something about this disc when set at +2 sharpness on the Oppo that makes the video just brutal. Moving to sharpness 0 has rid this of about 90% of my issues. This will never be considered reference video I don't believe on this disc, but a lot of the background in it is very dark, and all the small anomalies that come with that seem to be exacerbated by +2.
post #13522 of 24402 Old 12-07-2013, 05:15 PM
Quoted: 293 Post(s)
Liked: 239
While I'm here this evening, I thought I'd pass along another small anomaly. I purchased "Breakfast In America" by Supertramp on BD recently. I'm an avid collector of BD concerts, but this is the first I've owned from the new High Fidelity Pure Audio Blu-ray series. Sound is phenomenal, btw, easily rivals some of my SACDs. There are 3 audio options, all sourced from 24bit/96khz. As an aside here, although there have been Blu-ray audio only discs in the past (i.e. Pink Floyd's TDSOTM and WYWH, Tom Petty's Mojo, etc) these pure audio discs are made to be played with no display, if you'd like to use, say, an Oppo 105 running analog in a 2 channel set up, for example. The 3 audio options are seen on the front of my 103, up/down arrows access those. Left/right accesses the tracks.
Anyway, the audio options are (all 2.0 on this disc) PCM, DTS-Master and Dolby TrueHD. The DTS and Dolby tracks are very close, but I slightly prefer the Dolby. I've had this disc for a few weeks and it's played fine using the Dolby version. After I updated the firmware on my 103 yesterday to the new Dec.5/13 issue, I've started to miss the beginning second or so of any song on this disc I try to access, be it forward or backwards. But only when I use Dolby TrueHD, the DTS and pcm versions are unaffected. I didn't have this issue before the new firmware. I've written Oppo and their response was that it was likely a handshake issue. While I certainly agree it would seem to be that, it wasn't a problem before the new firmware. They recommended that I unhook the HDMI video (if I was running split, which I am). Well, that didn't help and really I shouldn't have to unplug a cable so I don't miss the beginning of songs on a particular disc. I know, first world problems, eh? Seems kind of petty I guess, I'll run DTS for now, but just thought I'd point out that issue with DolbyTrueHD. I know with audio dropouts on Dolby TrueHD movies that are to hard fix, Oppo probably wishes DolbyTrueHD would just go away rolleyes.gif
post #13523 of 24402 Old 12-08-2013, 01:31 AM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Frame packed 3D will always be 720p/24 or 1080p/24. There is no specification for current generation of players/displays for supporting this at 4K/24.
post #13524 of 24402 Old 12-08-2013, 05:44 AM
pbarach's Avatar
Quoted: 321 Post(s)
Liked: 194
Eskay
The analog outputs are great. However, if your Denon receiver has RoomEQ or Audyssey, it won't be active when you're using the EXT IN inputs on your receiver, and you will need to set bass management chocies and speaker distances on the Oppo unit. Concerning the video difference, I find that the Oppo does a better job upsampling DVDs than my Pioneer BDP-320, but there is no difference between the players that I can see when I'm watching BluRay discs.
A nice advantage of the Oppo over any of the older Pioneer plays is much faster startup and load times.
pbarach is offline
post #13525 of 24402 Old 12-08-2013, 06:17 AM
SteveV's Avatar
I ordered a BPD-103 yesterday and just now realized that I violated my #1 rule in buying HT gear: confirm it has discrete power on/off codes. I've had a look at the Oppo Excel download that lists all the discrete codes. The first code in the list is the Power toggle command and the last couple of commands are "On" and "Off" which hopefully correspond to Power On and Off.
Since this is Oppo I'm guessing I'm OK but can someone confirm that the 103 does in-fact have discrete IR power on/off codes?
Thanks--Steve
SteveV is offline
post #13526 of 24402 Old 12-08-2013, 06:21 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2696 Post(s)
Liked: 1921
Thanks--Steve
Yes, it does.
The remotes used to have buttons for the discrete codes but when real estate became scarce they were removed. The codes are still available, though.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #13527 of 24402 Old 12-08-2013, 06:45 AM
SteveV's Avatar
Originally Posted by wmcclain View Post
Yes, it does.
-Bill
Perfect.
Thanks -- Steve
SteveV is offline
post #13528 of 24402 Old 12-08-2013, 07:16 AM
KC-Technerd's Avatar
Quoted: 64 Post(s)
Liked: 137
I found that I was partially incorrect about the Oppo logo splash screen not being displayed when the unit is turned on (with the 67-1204 firmware). Apparently the handshake on HDMI 1, at least in my case, obscures the splash screen. However, I am briefly seeing it on HDMI 2 prior to the home screen. The audio volume information is no longer being overlaid on the splash screen and now does not appear until the home screen is displayed. I also found that after the firmware update that the Output Volume had been reset to Variable/100 rather than Fixed. I'm 99.9% certain that it had been set to Fixed prior to the update. The settings were restored from those stored on a connected USB flash drive.
KC-Technerd is offline
post #13529 of 24402 Old 12-08-2013, 07:35 AM
boe
boe's Avatar
Quoted: 899 Post(s)
Liked: 414
Thanks - I'm not trying to get 3D to be 4K, I'm just trying to get 3D to work. All I can manage is to get a picture with shifted images like they have a ghost to the left or the right of the main image. To quote McBain - "Ahh - my eyes, these goggles do nothing".
boe is offline
post #13530 of 24402 Old 12-08-2013, 07:49 AM
yin
yin's Avatar
Quoted: 24 Post(s)
I have a Oppo 103 and it is working on RS 232 codes,but I have one problem, how can I shift the subtitles up and down and watch the movie at the same time using which RS 232 code?
What does the command look like if I want to shift 5 points up or 5 points down?
yin is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
