Official OPPO BDP-103 Owner's Thread - Page 466 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #13951 of 24632 Old 12-30-2013, 06:51 AM
pbarach's Avatar
Quoted: 352 Post(s)
Liked: 206
For minor smudges I wet a Kleenex and apply a little tap water to the disc, then gently dry radially with a soft towel. For gooey stuff, I use a spray meant for cleaning LCD screens and a microfiber cloth.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #13952 of 24632 Old 12-30-2013, 07:11 AM
Mongo171's Avatar
Quoted: 897 Post(s)
Liked: 1327
Originally Posted by Chere View Post
That's the best thing about redbox BDs. For the most part they are usually almost like new and not abused as much as their counterpart regular dvds.
By the way what method does everyone use to clean their dvds/ blu rays?
I use distilled water and a VERY soft cloth, going from the inside of the disc to the outside.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
post #13953 of 24632 Old 12-30-2013, 07:22 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 225
I will add "lint-free" to the cloth. Aside from that...
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #13954 of 24632 Old 12-30-2013, 07:32 AM
Mongo171's Avatar
Quoted: 897 Post(s)
Liked: 1327
Yes. Sorry that I left that out. We used lint-free tissue paper in the Navy and at intel when we cleaned optics. You don't want any streaks of residue or particles left over from the cleaning process.
post #13955 of 24632 Old 12-30-2013, 08:17 AM
4mula1's Avatar
Liked: 26
Originally Posted by billymerritt View Post
I noticed since upgrade to latest firmware when I power up the 103 I will not get audio signal display on my Onkyo TX-SR906. When I start a disc with audio then it will be in display of the receiver. It use to display on receiver before the update if I'm not mistaken. However with my 93 it displays audio when the 93 powers on. Only difference in the two is 103 audio is out to HDMI and 93 Optical out. Anyone else notice this or is this normal? the Onkyo TX-SR906 is only 1.3 HDMI so maybe that's the reason, and on a side note, sometimes when power on 103 will not show the home menu and just hangs and have to power off and on to get it to work, don't happen often but enough to be annoying at times. Any ideas you long time Oppo users?
Ever since the last firmware update, my 103 will freeze before the splash screen when powered on. Power cycle, the it works fine.
4mula1 is offline
post #13956 of 24632 Old 12-30-2013, 08:52 AM
Quoted: 204 Post(s)
Liked: 225
Interesting that you bring up the lenses. I use the same cloths for my BDs/DVDs, photographic lenses, and even for the last steps in cleaning up my guitars. Good, soft, clean, lint-free cloth is great to have around in general.
post #13957 of 24632 Old 12-30-2013, 08:53 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 44
Sounds like someone needs to do a factory reset maybe?
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #13958 of 24632 Old 12-30-2013, 09:21 AM
4mula1's Avatar
Liked: 26
I was told that the new firmware does that on its own. But I guess it won't hurt to do a manual reset as well.
4mula1 is offline
post #13959 of 24632 Old 12-30-2013, 09:37 AM
Quoted: 40 Post(s)
Liked: 44
If you have a USB stick you could always save the settings first then apply the reset.
Hometheatergeek
aka AL
My Current System
post #13960 of 24632 Old 12-30-2013, 12:20 PM
thirdkind's Avatar
Originally Posted by bonzichrille View Post
Yes, I just sent a message to Oppo USA. I hope they take the feedback and make a change to the firmware. The majority of my media library are blu-ray movies that have been ripped to 720p. Saves space and I have learned how to encode things. I really thought that the Oppo would be my perfect mediaplayer but this lack of 24p switching has really but a dent in my perfect setup.
I got a response from them. Sounds like they really want to do it, but MediaTek is the holdup:
Since there is no 720p/24Hz specifications in the HD standard, and the player has the potential of outputting a native signal, we did not want to have a scenario where Source Direct was set and the player was outputting 720p/24Hz.
Going from 720p/24Hz to 1080p/24Hz is something that we would like to pursue, but MediaTek has been very adamant that they need to do a frame rate conversion when scaling. We will continue to pressure them to support scaling without a frame rate conversion in the cases where the output will be 1080p.
thirdkind is offline
post #13961 of 24632 Old 12-30-2013, 12:43 PM
irissky's Avatar
Hi, I just purchased an Oppo BDP-103 and really like it, it sounds and looks great.
However, I've been trying to get it to play music from my Logitech Media Server (LMS) setup, without success.
The 103 sees the LMS ok, but when I select a file within a directory to play, the play indicator briefly points at the file, then quickly skips through the whole list without playing anything.
Thinking it was a problem with LMS, I downloaded Jriver Media Center (JMC), but had the same exact result.
Oppo technical support suggested a simple DLNA server oShare, and which does work. By the way, regular windows file sharing (SMB) works as well, but lacks good search, tagging, ect. feature.
Has anyone else encountered this with LMS or JMC ? By the way, I'm running the latest firmware from Oppo (beta), and tried the last regular firmware, so that isn't the problem.
Thanks in advance,
BB
edit: Sorry, meant to post this to the BDP-103 user's thread.
irissky is offline
post #13962 of 24632 Old 12-30-2013, 02:05 PM
darthkringle's Avatar
I own a BDP-105; however, for my setup I found that using the Digial output into a stand alone DAC was a better solution. I know the whole point of the 105 was for the DAC and I am not utilizing it. So with that said, if I move to a 103, there should be ZERO difference in audio quality assuming I am not using the analog sections correct? Or is the better Power Supply in the 105 etc a factor? Thanks!!
darthkringle is offline
post #13963 of 24632 Old 12-30-2013, 02:08 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2972 Post(s)
Liked: 2225
Correct, no difference. Some may say the power supply matters for digital data but they are in the minority here.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #13964 of 24632 Old 12-30-2013, 02:13 PM
Quoted: 204 Post(s)
Liked: 225
Thanks in advance,
BB
What file types are you streaming?
Do you have transcoding turned off in JRMC?
I routinely stream ALAC, FLAC, and MKV files from JRMC to the BDP-103 with no issues. I did have to turn off transcoding in JRMC's DLNA server to get everything to work properly.
post #13965 of 24632 Old 12-30-2013, 02:26 PM
-Bill
Thanks much!
post #13966 of 24632 Old 12-30-2013, 02:37 PM
irissky's Avatar
Thanks for the reply. I'm new to JRMC, after using Logic Media Server for a good while.
Right now I'm trying to get audio working. I've tried Flac, MP3, and WAV and the player just skips over them.
Where is the transcoding setting you refer to ?
Thx
irissky is offline
post #13967 of 24632 Old 12-30-2013, 03:27 PM
obie_fl's Avatar
Liked: 33
I use LMS with Flacs and MP3s here without problem. Make sure you drill down through the Music folder.
obie_fl is offline
post #13968 of 24632 Old 12-30-2013, 04:47 PM
Quoted: 204 Post(s)
Liked: 225
Thx
1) Go to: Tools > Options > Media Network > Add or configure DLNA Servers
You should have a dialog box labeled "DLNA Server" showing, with 2 panes.
In the Lower pane, set the following:
2) Audio Format: PCM 24-Bit
3) Audio:Advanced > Stereo Downmix: OFF (unchecked)
4) Audio:Advanced > Volume Leveling: OFF (unchecked)
5) Audio:Advanced > Sample Rate: Same as Source
6) Audio Mode: Original
7) Video Mode: Original
8) Press the OK button at the bottom of the screen
That puts the DLNA server into a state where it does not try to do anything to the audio or video files it server up.
post #13969 of 24632 Old 12-30-2013, 05:37 PM
irissky's Avatar
Thanks for the help, I'll try these out tonight and report back.
BB
irissky is offline
post #13970 of 24632 Old 12-30-2013, 08:53 PM
KC-Technerd's Avatar
Quoted: 95 Post(s)
Liked: 146
Originally Posted by holisticmonkey View Post
I'm not sure about the root issue here but 10ms is extremely perceptible (to myself and other viewers... with a range of 30ms I see mouth movements that don't start until after the first few words are spoken or entire sentences that you don't hear until after the mouth has stopped moving). I have no way of measuring the real deltas at the moment but the feedback from you and other parties makes me suspect that the 10ms steps in my OPPO are larger than 10ms... though that would be a non-trivial bug that I'd think others would have reported by now.
I will note that it's less obvious if I skew to larger positive values, so my constant need to adjust may have been in part that I was tuning it to the minimum viable offset. However, the first film I tested after getting your response required +70ms, the one after that didn't get close to matching up until I set it back to +30ms... So far I've been unable to watch two films in a row without spending the first 10 minutes trying to find long speaking sections and fiddle with the offsets.
I've done a bit more research on this & done some more testing on my own setup. I've found that there is considerable variance between DD TrueHD, DTS-HD MA, and considering whether bitstream or LPCM is selected, and if 24p or 60hz is used. The audio advance ahead of video ranges from 20ms to 120ms for my system. I'm not sure how much of that to attribute to the BDP-103, and how much to attribute to the AVR I am using.
I found the following papers that illustrate and describe the undetectability plateau and detectability threshold of A/V sync:
Audio/Video Synchronization Standards and Solutions
A Status Report
RECOMMENDATION ITU-R BT.1359
RELATIVE TIMING OF SOUND AND VISION FOR BROADCASTING
Based on the information in those documents, I ultimately reset the audio delay for my BDP-103 to 110ms in hopes of containing the entire range of variation within the undetectability plateau, or at least within the detectability threshold.
I don't even think any sync checking devices would help given that they're against registration content (if I understand correctly). Since I have variance across content, I can't imagine it would do me any good.
I'm not certain what you mean by "against registration content".
KC-Technerd is offline
post #13971 of 24632 Old 12-31-2013, 09:30 AM
mgulenproto's Avatar
Originally Posted by warrian View Post
I will second this endorsement. The internal/external region free mod kit from JVB Digital definitely seems the one to have. No problems with updates or operation for me. Although like some others, you really do need to turn off Auto Resume to switch regions properly.
Originally Posted by gwsat View Post
Just installed the latest update and it performed as advertised. When I powered up my 103 for the first time after the latest update was installed, I was prompted to either reset the 103 to factory defaults, which was highly recommended, or keep the present settings. I decided to believe the Big Computer in the Sky and pressed the Reset to Factory Defaults button. Since then everything has gone well.
On another issue discussed here recently, I installed a JVB Digital all regions modification chip in my 103 in April and it has performed flawlessly ever since. Highly recommended!
hi guys, I just got my oppo 103, and just signed up to the forums.
I've already purchased the mod kit from avsdigital on eBay. it's the one that u have to manually change regions.
then I saw your recommend on this one from JVB.  Would u recommend the jvb version over the one I've purchased?
I haven't installed mine yet. just wondering if it's worth getting the jvb one instead?
also, been using netflix on it through WiFi, and no issues other than an audio glitch every now and then.  it sounds like a really loud spike in the audio.  not every movie either, just every so often. any idea what that is?
thanks
mgulenproto is offline
post #13972 of 24632 Old 12-31-2013, 10:50 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3077 Post(s)
Liked: 3967
Originally Posted by Ganymed4 View Post
Originally Posted by HPQ View Post
When I turn on the NAD, I see the below.
Source 1
PCM Stereo
I then went to Oppo and changed the setting to Auto and then played a movie and on the NAD, it shows
Source 1
Dolby Digital
I then went back to Oppo and changed the setting to Bitstream and then played the same movie and on the NAD, it shows
Source 1
Dolby Digital
No change on the NAD..
So, I guess I am good? yes/no??
I would say YES. smile.gif Now you can leave the Bitstream or better Auto setting in the Oppo or make your own listening test, if you can hear differences for the different settings and if yes, then choose the one you like best. However, there may be no audible differences. But I would leave the setting on Auto. I think the Oppo does this right.
And: Have fun!
The HDMI Audio AUTO setting is a bit different from the BITSTREAM setting.
First of all, if the track you are playing is already LPCM (i.e., not a Bitstream), then the output will be LPCM. The OPPO does not re-encode LPCM tracks into Bitstream.
If the track you are playing is Bitstream, then the question arises whether the destination device is CAPABLE of processing that Bitstream. The issue is that some devices (e.g., most TV sets -- for their built-in speakers) will accept the traditional, lossy Bitstreams (DD and DTS) but not the newer lossless Bitstreams (Dolby TrueHD and DTS-HD MA).
If you are playing a Bitstream track with AUTO or Bitstream output selected, the player will handshake with the destination device to see if it can accept that Bitstream AS IS. If the answer is NO then:
1) AUTO switches the output to LPCM -- i.e., it decodes the lossless Bitstream into high bit-rate LPCM for output -- up to the number of LPCM channels the destination can receive.
2) Bitstream switches to using the "compatibility" track instead. Blu-ray discs always have a "compatibility" track for just such purposes. For a Dolby TrueHD primary track, the compatibility track will be traditional DD (up to 5.1 channels). For a DTS-HD MA primary track, the compatibility track will be traditional DTS (up to 5.1 channels). HDMI devices should all be able to a accept the compatibility track.
The choice to use LPCM may give you superior results since you get the high bit-rate decode (instead of a decode of the lower bit-rate "compatibility" Bitstream). And for destination devices that can accept multi-channel LPCM at high bit-rate that would be a good solution. HOWEVER, some devices -- again, typical TVs come to mind -- will accept DD 5.1, or even DTS 5.1 traditional Bitstreams but will only accept stereo (2.0) LPCM. What the TV does with that 5.1 input when played on its built-in stereo speakers may be different than a simple down-mix to stereo. It may have some sort of psycho-acoustic surround sound processing for example. And if you enjoy that sort of thing, you might want to be able to retain the 5.1 input.
So for such a destination device you may prefer to retain the 5.1 sound track, even if that means passing the lossy "compatibility" Bitstream instead of the original, lossless Bitstream primary track.
SO:
1) Selecting LPCM output will get you LPCM and only LPCM. If your destination device can only accept stereo LPCM you will get a stereo down-mix. The decode to LPCM is ALWAYS from the full quality primary track -- then down-mixed to a fewer number of channels for output if your destination can't accept the original number of channels. (All this down-mixing is automatic by the way -- part of the HDMI handshake -- not affected by the "Down-mix" setting in the Speaker Configuration settings in the OPPO which only applies to the ANALOG audio outputs.)
2) Selecting BITSTREAM will get you Bitstream if the primary track is a Bitstream (and LPCM if the primary track is LPCM). But if the primary is a lossless Bitstream and your destination device can't accept that, then you will get the "compatibility" Bitstream instead.
3) Selecting AUTO will get you Bitstream if the primary track is a Bitstream AND the destination can accept that AS IS -- at its original quality. If the destination can't accept the Bitstream AS IS -- or if the primary track is LPCM -- you will get LPCM up to the number of channels the destination allows. This may give you HIGHER quality audio because the LPCM is decoded from the full, lossless, high bit-rate Bitstream, or it may give you LOWER quality audio if the destination forces the player to down-mix that LPCM to stereo. If you are playing a lossy Bitstream primary track, and the destination can accept that, then you get that DD or DTS Bitstream. This may let you get multi-channel into a destination device that can only accept stereo for LPCM data. You might wonder why on earth anyone would make a device that can accept multi-channel Bitstream but only stereo LPCM? Well, that was actually the norm in the period just before HDMI came into the picture, because that's exactly how Optical and Coax (S/PDIF) digital audio cabling works.
For MOST people selecting either LPCM or BITSTREAM output (at your personal preference) is the way to go. This would be for everyone, for example, using a modern AVR which can accept EITHER the full, lossless Bitstream formats (TrueHD and DTS-HD MA) OR multi-channel (up to 5.1 or 7.1) high bit-rate LPCM. If you have an AVR like that and select the AUTO option, it will still work, but it makes the HDMI handshake more complicated, meaning you might get a retry which slows down getting to the content you want to view.
--Bob
freespace303 likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #13973 of 24632 Old 12-31-2013, 11:16 AM
Read the FAQ!
Liked: 3967
Originally Posted by KC-Technerd View Post
Thanks again for being so responsive. I'm not sure about the root issue here but 10ms is extremely perceptible (to myself and other viewers... with a range of 30ms I see mouth movements that don't start until after the first few words are spoken or entire sentences that you don't hear until after the mouth has stopped moving). I have no way of measuring the real deltas at the moment but the feedback from you and other parties makes me suspect that the 10ms steps in my OPPO are larger than 10ms... though that would be a non-trivial bug that I'd think others would have reported by now.
I did get a response from the OPPO support staff but it was basically dismissive of my complaint (telling me I must have post processing turned on). At this point I'm frustrated enough to give up and switch back to the BDP-83, maybe keeping this player around for 3d films only.
Separately, I still think no offset should be necessary on the OPPO side. Regardless of the delay processing the image on the display, I would expect it to be consistent with high def content from my Roku (through AV) vs content from the OPPO also through AV. It's clearly not the case, no other media source going through my AV suffers from this.
What you are seeing is not what you think you are seeing.
At 24 frames per second, one frame of film is just under 42ms. So it is IMPOSSIBLE for a 30ms A/V sync error to result in a situation where you can see the lips moving for SEVERAL WORD before the matching audio is heard. A 30ms error is less than one "frame time".
Forget about buying any fancy sync testing gear. What you need instead is a calibration disc that has a synch check track on it of known quality -- i.e., the audio and video REALLY ARE IN SYNC on that track to begin with. You can NOT reliably check for sync errors with real movies or TV programs, because inherent sync error is present in lots of commercial content (for a variety of reasons).
Two good calibration disc choices are: (1) Spears & Munsil Version 2, Blu-ray, available direct from OPPO Digital and elsewhere, and Disney's "WOW World of Wonder", Blu-ray, available from AMAZON.
I've checked the sync delay adjustment in the OPPO against that offered in my Anthem Statement D2v, and the step size in the OPPO appears to be accurate.
Now, once you are using a test of known quality (from one of these calibration discs) if you've found a bug where changing the A/V Sync setting in the OPPO is causing things to go wacky you'll have a reliable and repeatable test case (that calibration disc) which you can use to ferret out exactly what set of steps are causing this problem. Steps you can communicate to OPPO Tech Support.
The amount of sync error you are reporting -- several words or whole sentences of video before or after the corresponding audio -- is so great that if this were normal in the player this thread would be filled with howls of indignation. So again, I'm not saying it isn't happening. What I'm saying is that what you THINK is going on here -- normal sync adjustment errors -- is NOT what's going on. There is SOMETHING ELSE going on, and we just need to ferret that out.
Of course the first thing you should do is make sure you have the latest firmware in your 103, as various types of sync error present in the earliest firmware releases have since been fixed.
Go to Setup > Device Setup > Firmware Information and check the version number for the "Main" firmware. The current "Official" firmware release will end "1204". Even better, the current "Public Beta" firmware release -- available for download from the OPPO Digital support page for the 103, for installation via a USB stick -- will end "1225B".
IMPORTANT NOTE: If on the first power up after the firmware install the player offers a Recommended Reset be done, you SHOULD do that.
--Bob
post #13974 of 24632 Old 12-31-2013, 11:53 AM
pdalton's Avatar
I'd really appreciate advice and information about whether we should upgrade from our existing Oppo BDP-83 to either the Oppo BPD-103 or the Oppo BDP-105.
After trying to read a lot of the information on this thread, it's clear to me that I'm a far less sophisticated participant than most, so I'm hopeful that those of you who are far more knowledgeable about what's important and what's not can give me some guidance.
I don't want anyone to feel I've wasted their time by inviting analysis of features and improvements that we're not going to be able to use (at least not anytime soon), so I hope it will be helpful to let you know our circumstances: First, we don't have a 3D-capable projector and we have no immediate plans to get a new one, so -- at least for the foreseeable future -- we're not concerned about the obvious difference of being able to play 3D discs. Second, we connect our player to our receiver (and then our receiver to the projector) using only the HDMI connections, so differences between the players regarding their analog-out capabilities won't make a difference to us now, either. Of course, in a few years, it's possible we may want 3D badly enough to get a new projector, so having a player with that capability would be useful then. Nevertheless, unless someone can explain why we would get an objectively discernible benefit from using analog audio connections instead of HDMI, it's unlikely that -- even if we needed a new receiver tomorrow -- we'd get one with analog inputs for the purpose of taking advantage of a disk player's analog outputs.
So, the first real question is -- for us and the way we use the player -- are there good reason to move up from the BDP-83 we have now?
If so, then the next question is whether -- for us and the way we would be using the player -- are there good reasons to select the BDP-105 over the BDP-103? (I'm afraid I don't understand the technical differences between the 103 and 105 well enough to know whether the having the105 would make sense for us over the 103.)
Finally, in case any of it makes any difference in advice you can provide, here are some background specifics. We have a dedicated room for our "theater" (15'x17'x8'), which has no windows, is carpeted, its walls and ceiling are painted in matte chocolate brown (a compromise from the originally "desired" matte black), it has no ceiling light fixture, but it does have dimmable light sconces on 2 walls and "ambiance" led rope lighting inside crown molding around the ceiling. The relevant components we have are: An Epson 1080UB projector (not 3D, obviously); a 5'x9' screen built using Wilsonart's Designer White laminate (a concept obtained here on the AVS site); the BDP-83; an Onkyo RC-360 receiver; Klipsch speakers (RSX-5s [fronts & rears], RVX-42
, RX-42s [sides]); an NHT SW2P sub and a PolkAudio PSW202 sub (subs may get upgraded to a single SVS in the next year or so).
Paul
pdalton is offline
post #13975 of 24632 Old 12-31-2013, 12:00 PM
wmcclain's Avatar
Liked: 2225
Analog output in a player is mainly for people who have already spent mightily on other analog gear. Most who have HDMI in their receivers are using that.
For an HDMI setup you should not expect an upgrade in A/V quality. The possible exception would be the Darbee processing in the -103D. It's a feature not available previously and is generating a fan base. When used properly it is a subtle effect.
-Bill
pdalton likes this.
post #13976 of 24632 Old 12-31-2013, 12:42 PM
Read the FAQ!
Liked: 3967
Paul,
You do not need the 105. The first thing you'll notice with the 103 or 103D is that they are quite a bit faster than the 83 you are using now.
You'll also gain some Internet services that you might enjoy such as VUDU or Netflix.
There are more subtle improvements in audio and video processing capabilities that you may or may not notice. If you do ever get into playing media files instead of shiny discs you'll find the new OPPO players far FAR more capable than the 83.
Oh, also the new players have no fan. Some folks get annoyed by fan noise from the 83.
--Bob
pdalton likes this.
post #13977 of 24632 Old 12-31-2013, 12:51 PM
gwsat's Avatar
Quoted: 2882 Post(s)
Liked: 3236
Originally Posted by mgulenproto View Post
I've already purchased the mod kit from avsdigital on eBay. it's the one that u have to manually change regions. then I saw your recommend on this one from JVB.  Would u recommend the jvb version over the one I've purchased?
No all regions modifications chip will change Blu-ray regions automatically. For example if you had your modified BD player set to play Region A BDs, the only way to get it to play Region B BDs is to enter the code called for by the modification chip's manufacturer. You have to reverse the process to shift back to Region A. Fortunately, it's easier where DVDs are concerned. Simply set your player to Region 0 and it should play all DVDs. Also, many, maybe most, BDs these days are universal, which means that a BD player will play them regardless of the region it is limited to.
mgulenproto likes this.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
post #13978 of 24632 Old 12-31-2013, 12:57 PM
Thanks for the reply - Yes, my Insignia that i used to use was the same way - when changed to B, it stayed until i put in another region disk and then i changed for that.
My concern is that in the write up in the JVB is " This is a modification for the OPPO BDP-103/105 DVD player. After installation it will enable the player to show movies with a different region. This means for example that a region 1 movie will play on a region 2 player, without giving the region code or protection error."
So me, this sounds like you don't have to enter a code.  Is this just misleading, or am i reading it wrong?
post #13979 of 24632 Old 12-31-2013, 01:21 PM
gwsat's Avatar
Liked: 3236
It was misleading. Keep in mind when you are reading JVB's advertising blurb that that DVD regions are identified by number, !, 2, 3, etc. What they don't say is that BD regions are identified by letter, A, B, C, etc. Thus the advertising blurb is talking about DVDs only in a way, which to me at least is misleading. Although I give JVB an A+ for the quality of their all regions chips, they get an F in the truth in advertising department.
gwsat is offline
post #13980 of 24632 Old 12-31-2013, 01:26 PM
Haha!  I get it now.  Thanks for clarifying.   Hopefully my AVS one from ebay arrives soon so I can test it out!
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
