Official OPPO BDP-103 Owner's Thread - Page 469 - AVS Forum | Home Theater Discussions And Reviews
 3139Likes
post #14041 of 24802 Old 01-03-2014, 04:11 PM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
Originally Posted by Jottle View Post
What feature? Are you referring to the new interface detailed in the link I posted? This is an interface update that supposedly rolled out a few weeks ago.
I just turned on my system to double check... I don't see the annoying giant preview menu there, it seems to only be on the NF site when I browse on my pc.
So I was actually wrong. The answer is NO.
EDIT!!!: Now I think NF is doing some goofy stuff, because I can't find that feature on the website or on the 103, and I KNOW for fact I saw it on one of them.
Perhaps they took it away temporarily or something is off with the servers. NF manages to annoy me constantly with their UI. It's just horrible IMHO.
Smarty-pants is offline
post #14042 of 24802 Old 01-03-2014, 05:59 PM
Kamikaze13's Avatar
Quoted: 106 Post(s)
Liked: 51
Originally Posted by holisticmonkey View Post
Thanks again for being so responsive. I'm not sure about the root issue here but 10ms is extremely perceptible (to myself and other viewers... with a range of 30ms I see mouth movements that don't start until after the first few words are spoken or entire sentences that you don't hear until after the mouth has stopped moving). I have no way of measuring the real deltas at the moment but the feedback from you and other parties makes me suspect that the 10ms steps in my OPPO are larger than 10ms... though that would be a non-trivial bug that I'd think others would have reported by now.
I will note that it's less obvious if I skew to larger positive values, so my constant need to adjust may have been in part that I was tuning it to the minimum viable offset. However, the first film I tested after getting your response required +70ms, the one after that didn't get close to matching up until I set it back to +30ms... So far I've been unable to watch two films in a row without spending the first 10 minutes trying to find long speaking sections and fiddle with the offsets.
I did get a response from the OPPO support staff but it was basically dismissive of my complaint (telling me I must have post processing turned on). At this point I'm frustrated enough to give up and switch back to the BDP-83, maybe keeping this player around for 3d films only.
I don't even think any sync checking devices would help given that they're against registration content (if I understand correctly). Since I have variance across content, I can't imagine it would do me any good.
Separately, I still think no offset should be necessary on the OPPO side. Regardless of the delay processing the image on the display, I would expect it to be consistent with high def content from my Roku (through AV) vs content from the OPPO also through AV. It's clearly not the case, no other media source going through my AV suffers from this.
Another thing you could try if you haven't already is the lip sync on your AVR if your model has it.
In OSD under Hardware Setup --->HDMI---->Lip Sync ON/OFF
Worth a try.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #14043 of 24802 Old 01-03-2014, 07:20 PM
digitalbabe's Avatar
Hi everyone, it has been 7 years since I upgraded our main system and I am getting a crash course in many areas. I have A new Denon AVR-X3000, Panasonic Vt60 and Tivo 4 Premiere. I already have a Panasonic BDT500 which I hoped to modify to makeot region free.
My question is, if I were to purchase the Oppo should I connect the Tivo to the Oppo, to let it process the video, and then connect the Oppo to the AVR? I am truthfully a little new at figuring out how to 'force' a certain components to process video. If I want the Oppo I am still considering to do it, and change the settings of the TV to not upscale anything?
The Tivo gives me options of what resolution to output. It says if I check all of the resolutions listed, the TV will scale the images. But I'd really want the Oppo or AVR to do it, correct? so how would I get the TV and AVR to leave the Tivo output alone (We also access Fios and Netflix through Tivo atm). Lastly is the OPPO's capability yo improve streaming and regular FIOS quality worth $400 more or can similar results be obtained if I connect the Tivo to the BDT500 I already own?
Thanks in advance for your help.
digitalbabe is offline
post #14044 of 24802 Old 01-03-2014, 07:36 PM
networkn's Avatar
Quoted: 12 Post(s)
Hi There!
Earlier I asked about Region Free Mod for the 103D and was sent a link, which I cannot find, but subsequently I see someone talking about having tried 2 and them not working. Has anyone got any of the mods working properly and if so which ones specifically so I can make sure I order something that works?
Prefer External, but can do internal as I did for my last 2 oppo's
networkn is offline
post #14045 of 24802 Old 01-03-2014, 07:38 PM
Super Moderator
teachsac's Avatar
Quoted: 837 Post(s)
Liked: 1360
You can't connect the TIVO to the Panasonic BDT500. It does not have an HDMI input. If getting the Oppo. I would set the TV to output in Native Resolution. Although I don't run my Tivo into the Oppo 103, I do run it natively to my TV to scale.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #14046 of 24802 Old 01-03-2014, 10:38 PM
sharok's Avatar
Quoted: 324 Post(s)
Liked: 103
Originally Posted by networkn View Post
Hi There!
Go to this link: http://www.ebay.com/itm/160942653070?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I tried it on my Oppo 103 externally and it worked fine. Then, I installed it internal and it is working fine too. I don't see why it wouldn't work with 103D.
MCaugusto likes this.
sharok is offline
post #14047 of 24802 Old 01-04-2014, 07:41 AM
gwsat's Avatar
Quoted: 3375 Post(s)
Liked: 3922
Hi There!
I have had a JVB Digital all regions mod in my 103 since April and it works perfectly. Note that the page I linked to indicates that there is a JVB Digital modification chip available for the 103D. I can't imagine that such a chip wouldn't work as well in your 103D as mine has in my 103.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is offline
post #14048 of 24802 Old 01-04-2014, 08:00 AM
SeeMoreDigital's Avatar
Quoted: 494 Post(s)
Liked: 208
Hi There!
Why not ask your question within the dedicated Official OPPO BDP-103D (Darbee Edition) Owner's Thread topic?
Ricker62 likes this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #14049 of 24802 Old 01-04-2014, 12:17 PM
S~
Hi Teach, thanks- I am curious-is your TV's scaling capability superior to that of the Oppo, and that is why you let the TV scale the output from the Tivo, or are you just out of ports on Oppo 103? Thanks again for your help.
post #14050 of 24802 Old 01-04-2014, 11:11 PM
Grampa's Avatar
I have an Oppo BDP-93 connected via digital optical/coax to an older Sunfire receiver, which lacks HDMI inputs. I am thinking about updating the player to the 103 to take advantage of its processing, connectivity, and better streaming options. I will likely connect it to the Sunfire using the 5.1 analog connections, and use the Sunfire mainly as an amplifier. I mostly use this setup for dvd/bluray movies, cable TV, and streaming (Netflix, Amazon). I know that the BDP-105 has better analog audio than the 103. Am I likely to hear a difference between the two players for movies, TV, and streaming? I'm probably more interested in movie dialog than music or sound effects, as I am somewhat hard of hearing and often miss some of the dialog.
Grampa is offline
post #14051 of 24802 Old 01-05-2014, 12:39 AM
Quoted: 751 Post(s)
Liked: 628
I would say for the most part you are probably fine with -103.
The analog audio in the -105 is better, but you should have some really nice amps and speakers to bring out that better sound,
not to mention a well treated and tailored room for analog audio.
For someone who needs the best clarity in dialog like you mention, I think the best thing for you to consider after getting the player is to possibly invest in a newer AVR that has good digital room correction software like Audyssey or something similar. It can make a big difference in the detail of your audio.
Also, your speakers can a big factor too... the better your speakers are, the better the clarity will be, ESPECIALLY the center channel speaker. Most of the dialog in surround sound movies comes from the center channel.
post #14052 of 24802 Old 01-05-2014, 01:12 AM
jjwinterberg's Avatar
Quoted: 68 Post(s)
Liked: 39
Anyone with,the new beta FW seeing playback problems? I'm getting hick ups on both bluray and SACD. Playback seems to stop momentarily and sometimes,pickup where it left off and sometimes after skipping ahead a few seconds. I backup to before the skip and the disc replays through where the skip occurred fine. I'm going back to the official FW.and see if maybe my player is going on me.
jjwinterberg is offline
post #14053 of 24802 Old 01-05-2014, 03:15 AM
Hurz111's Avatar
Hello to all Oppo users.
I have the new beta installed in my Oppo 103EU. I have no problems on Bluray, Bluray-Audio (YES, Close to the Edge), SACD (Genesis, Nursery Crime, Lamb lies down, Foxtrott), DVD-Audio ( King Crimson, Lizzard, Larks' tongues in aspic). Everything works fine.
Greetings from Germany
Hurz111 is offline
post #14054 of 24802 Old 01-05-2014, 03:39 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Settings for BDP-103 EU for playing very old US NTSC DVDs
I have a European player. And 95% of my material is either European PAL DVD or Blu-Ray. I have the 103 set to always convert to 24p. The reason for this is that my TV has a two frame input buffer, and so my receiver needs to be set for 83mSec a/v sync delay to compensate for the TV frame buffer. If I would set the 103's 24p conversion to Auto, then I would have to readjust the receiver's a/v sync delay every time the player switches between 24p and 50hz PAL output. This setup works for me for approximately 95% of my usage.
However, yesterday I tried to watch a 1982 NTSC DVD recording (from the N.Y. Met. Opera), and frankly the picture experience was totally ghastly (motion smearing, "Never Twice the Same Color", you name it). So my question is whether this is due to my having set the 103 to always convert to 24p? Or is there a better setting? And is there another setting that does not also require me to readjust the a/v sync delay on the receiver. I don't want to fiddle about with all these settings everytime I insert a disk. (Not to mention the topic of WAF...)
AndrewFG is offline
post #14055 of 24802 Old 01-05-2014, 04:20 AM
Jurgen's Avatar
Quoted: 13 Post(s)
AndrewFG,
Do you habe the latest firmware installed?
If not, I would advise to do it, to reset and then see if the problem still appears.
Jurgen is online now
post #14056 of 24802 Old 01-05-2014, 04:34 AM
Quoted: 494 Post(s)
Liked: 208
How sure are you that this particular DVD contains 3:2 pull-down. It might be 'pure interlaced'. In which case forcing 24p/24Hz will make it look pants!
post #14057 of 24802 Old 01-05-2014, 04:42 AM
cnjax's Avatar
Quoted: 21 Post(s)
Hello everyone,
New first time Oppo owner
Been reading this thread from the begining but only 188 pages in, so forgive me if I nissed something, I have the following components and trying to figure out the best connection route
AT&T Uverse box which I want to run to the OPPO
Dennon AVR 988
Since I do not care about 3d as my tv is not 3d, which is the best option, run everything through the Dennon out to the tv (hoping I can disable the dennon's video processing) or
split the connection from the oppo to the TV and use hdmi 2 to send audio to the dennon?
In my reading so far, there was huge discussions involving lip sync issues and sharpness settings with the qdeo processors have these been resolved or do the problems still exsist?
Any input and advice will be appreciated.
Thanks in Advance
Chris
LG 55EF9500
Samsung LN46B750
Oppo UDP 203
Oppo BD103
Denon AVR-x3200w
cnjax is offline
post #14058 of 24802 Old 01-05-2014, 05:33 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3320 Post(s)
Liked: 2588
Very likely. Not all NTSC titles can use the 24p setting. See the -93 FAQ for details: Is DVD 24hz conversion supported?
I had thought the setting had no effect on PAL DVD or Blu-ray. Since NTSC is only 5% of your material, leaving DVD 24p OFF would be the easy solution if you don't to manually adjust it.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #14059 of 24802 Old 01-05-2014, 06:26 AM
Mongo171's Avatar
Quoted: 978 Post(s)
Liked: 1405
Originally Posted by cnjax View Post
Hello everyone,
Dennon AVR 988
Thanks in Advance
Chris
There's a few different connection methods that can be made with your setup. It all depends on the inputs of your Denon.
Personally, I would go AT&T Uverse to HDMI Back Input on the 103. Then, HDMI 1 Out from the 103 to the TV and HDMI 2 Out to the Denon.
Or, go Uverse to HDMI 1 Back Input. Then, HDMI 1 Output to the Denon. From the Denon to the TV for video.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #14060 of 24802 Old 01-05-2014, 07:19 AM
AYColumbia's Avatar
Quoted: 22 Post(s)
No problems so far. You might want to reset your player to factory and see if that takes care of the issue.
AYColumbia is offline
post #14061 of 24802 Old 01-05-2014, 07:22 AM
cnjax's Avatar
Quoted: 21 Post(s)
I followed your second suggestion, the only setting I could find in the Denon regarding video processing was to turn IP scaler on or off. I changed it
To off, hoping that turned off the video processing
LG 55EF9500
Samsung LN46B750
Oppo UDP 203
Oppo BD103
Denon AVR-x3200w
cnjax is offline
post #14062 of 24802 Old 01-05-2014, 08:21 AM
Mongo171's Avatar
Quoted: 978 Post(s)
Liked: 1405
Are you happy with the results? There's always another way, another option.
Mongo171 is offline
post #14063 of 24802 Old 01-05-2014, 09:20 AM
Robinson ------'s Avatar
Of the top high end blu ray players, the only one without hdmi inputs is the Marantz right...
Marantz 7007
Cambridge 752
Oppo 103/5
JVC rs4810 (115)
Pioneer Kuro-9gen (50)
Oppo 103d
Marantz sr7001
Klipsch rb81/rc62/rs52
Robinson ------ is offline
post #14064 of 24802 Old 01-05-2014, 09:40 AM
cnjax's Avatar
Quoted: 21 Post(s)
So far things appear to be fine, since I used the oppo HDMI 1 out, do I need to change the sharpness setting to +1 or has this issue been
fixed? I have my denon set to auto lip sync so far so good, but keeping my eye open for any potential issue. Thanks for your help so far
LG 55EF9500
Samsung LN46B750
Oppo UDP 203
Oppo BD103
Denon AVR-x3200w
cnjax is offline
post #14065 of 24802 Old 01-05-2014, 09:49 AM
Mongo171's Avatar
Quoted: 978 Post(s)
Liked: 1405
Marantz 7007
Cambridge 752
Oppo 103/5
Correct.
Mongo171 is offline
post #14066 of 24802 Old 01-05-2014, 09:50 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3669 Post(s)
Liked: 4792
^ I recommend you leave Sharpness at 0.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #14067 of 24802 Old 01-05-2014, 09:51 AM
Mongo171's Avatar
Quoted: 978 Post(s)
Liked: 1405
After the recent few FW updates, most have gone back to Sharpness = 0. There are a few who still use Sharpness = 1. Try both and YOU decide.
What looks like Kate Beckinsale to one, looks like Roseanne Barr to another.
Mongo171 is offline
post #14068 of 24802 Old 01-05-2014, 11:07 AM
Grampa's Avatar
Thanks for the input. My receiver and speakers were pretty good when I got them, but they are now over ten years old. I may be wrong, but I think the amp portion of the Sunfire is still pretty good -- 200 Watts per channel, and still running pretty cool. But it lacks the processing capabilities of newer gear. My speakers are Triads. The center speaker is a Silver/6 Monitor, again pretty good when I bought it. I don't know anything about the Audyssey (just did a little checking, and was overwhelmed). The little bit I read indicates that it is designed to increase the number of good listening positions in the room. As 99% of our viewing involves just my wife and me, that may be less of an issue. Would it make sense to look for a preamp/processor that could be optimized for clarity in dialog, but that would still work well with my Sunfire as an amplifier and my Triad speakers? That is essentially what I was hoping the Oppo 103 or 105 would do.
Grampa is offline
post #14069 of 24802 Old 01-05-2014, 11:52 AM
pbarach's Avatar
Quoted: 365 Post(s)
Liked: 215
Which AT&T U-Verse box do you have? People on this thread generally want to run their cable boxes through the 103 because it does a better job at upscaling video than TVs or cable boxes,. In that situation, they recommend setting the cable box to send TV signals at "native" resolution (e.g., 480, 720, 1080) without doing any upscaling. However, some of the AT&T boxes don't have a "native" setting--you choose, for all channels, 480i and 1080i and that's that. So running the box's output through the 103 would be of questionable value as far as signal quality goes.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #14070 of 24802 Old 01-05-2014, 11:58 AM
networkn's Avatar
Quoted: 12 Post(s)
Because I didn't know it existed.
networkn is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
