Official OPPO BDP-103 Owner's Thread - Page 487 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #14581 of 24401 Old 01-27-2014, 01:35 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
Which firmware do you have? The lastest beta firmware, IIRC, addresses this issue.
JazzGuyy is online now
post #14582 of 24401 Old 01-27-2014, 02:12 PM
westmd's Avatar
Quoted: 770 Post(s)
Liked: 260
I wonder if any of the OPPO BDP103 owners ever compared the 7.1 analouge out against a BDP 105 analouge out for movie listening and what the result was. In the 105 owners thread most people think it would not make a difference. Oppo themselves stated that the 105 would be more dynamic. I am just wondering if it would make sense to go from the 103 to the 105 and sending my preamp (lexicon MV5) into retirement by connecting the 105 directly to my amps.
westmd is offline
post #14583 of 24401 Old 01-27-2014, 02:32 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
My old preamp didn't have HDMI. When I got my 105, I sold it and ran right from my 105 to my amp. Sonic bliss ever since.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #14584 of 24401 Old 01-27-2014, 02:46 PM
pandy4's Avatar
Quoted: 16 Post(s)
Someone told me that even with this player, the HDCD only works through the analog outs. Is that true? To me, it sounds better through the HDMI.
pandy4 is offline
post #14585 of 24401 Old 01-27-2014, 03:04 PM
rdgrimes's Avatar
Quoted: 2000 Post(s)
Liked: 1335
Not true. If your AVR does not decode HDCD, set the player to decode it. You should note a ~6db drop in volume. If your AVR does decode HDCD, set the player's decoding to off.
There are cases where an AVR will not play nice with un-decoded HDCD over HDMI, in which case you should also set the player to decode. There are other cases where an AVR will not play nice with decoded (20-bit) HDCD over HDMI, in which case you're on your own.
rdgrimes is offline
post #14586 of 24401 Old 01-27-2014, 03:09 PM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
Well.... I can confirm that if you have an audio CD that contains HDCD flagging, the HDCD icon on the Oppo will illuminate wink.gif
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #14587 of 24401 Old 01-27-2014, 03:32 PM
Lloyd-TX's Avatar
Quoted: 21 Post(s)
Liked: 47
Originally Posted by htwaits View Post
What I understand is that the devices that receive HDMI cable signals modify the incoming signal to compensate for the expected signal loss over a 6' cable. The Redmere cables are active and add their own compensation to the signal for the extra length of the cable run over six feet.
Monoprice recommends not using two Redmere cables in the same signal path to avoid complications that are hard to diagnose. I don't think that they are saying that you are sure to have problems, but that it's safer to avoid complicating the signal path from source to display with more than one active cable.
Hmmm - I did not realize that Monoprice recommended against more than one Redmere HDMI cable per "path".
FWIW, I'm running 6' Monoprice Redmere cables from my Oppo 103 and my HD cable STB to my RX-Z7 receiver, then a 10' Redmere cable from the Z7 to my Panny 65V10 display. Everything has been rock-solid and trouble free since I went to the Redmere cables three months or so back.
Best regards,
Lloyd C.
Lloyd-TX is offline
post #14588 of 24401 Old 01-27-2014, 03:37 PM
Coyote Waits
htwaits's Avatar
Quoted: 921 Post(s)
Liked: 2030
You're not the only one. Monoprice must be trying to error on the safe side. They also recommend 24 AWG HDMI in situations where I've used 28 AWG and 36 AWG passive HDMI cables with great stability.
htwaits is online now
post #14589 of 24401 Old 01-27-2014, 05:33 PM
Tgterm's Avatar
Quoted: 178 Post(s)
Not sure if this question is directed at me, but if it is I am on the latest 'official' release (bdp10x-67-1204) not the latest public beta release. I looked at the release notes (not sure if they were comprehensive) on the oppo site and nothing jumped out as a fix to my issue, but I am not sure.
Tgterm is online now
post #14590 of 24401 Old 01-27-2014, 06:04 PM
HomeGuy's Avatar
I have a question about splitting the audio and video. Is there anything to be gained? I have it setup like that now and I notice that Directv is sometimes slow to connect. I've always ran it like that so I don't know if going to one cable would help.
HomeGuy is offline
post #14591 of 24401 Old 01-27-2014, 08:02 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
There is something in the beta description about addressing staticky noise in some files. Don't know if that is your specific problem.
post #14592 of 24401 Old 01-27-2014, 08:03 PM
Coyote Waits
htwaits's Avatar
Quoted: 921 Post(s)
Liked: 2030
Unless you have to get around an AVR because it doesn't pass 3D or have some other special situation, there is no audio or video quality gained by using two HDMI outputs.
post #14593 of 24401 Old 01-28-2014, 06:59 AM
Tgterm's Avatar
Quoted: 178 Post(s)
Hi -
I was hoping for some second opinions...
I have contacted OPPO about the occasional loud pop / momentary audio loss I have been experiencing when streaming Netflix over wifi with the 103.  Their troubleshooting has focused on my audio connection...
I have a Marantz SR7300OSE...an older receiver without HDMI inputs(!), so I have the OPPO connected via optical audio, set at Bitstream.  They are claiming that I should, instead, use the analog audio connections as they are better...first opinion I am looking for...do you agree with that?
When I did a quick compare between my 7.1 analog input vs. the optical through the OPPO, I thought the optical sounded much better...so perhaps I have a speaker configuration issue.  I found optical to be louder and much fuller sounding...and have always had difficulty getting enough sub into my mix with analog.
Which leads me to my next question - I can configure my analog speaker config with the Marantz or with the OPPO...which one supersedes the other?  Should I have the Marantz all set to 0, and use the OPPO to configure the speakers...or vice versa?  How does the system know which to apply?
Last question - does anyone believe that the occasional loud pop / momentary audio loss I have been experiencing when streaming Netflix over wifi has anything to do with my audio going bitstream over an optical cable?
Thanks very much!
T
post #14594 of 24401 Old 01-28-2014, 07:28 AM
praz's Avatar
Liked: 26
Originally Posted by wmcclain View Post
If you want DSD from SACD you need to use HDMI2. For LPCM both HDMI will work.
This restriction is removed on the -103D, by the way.
-Bill
Another question. I will use LPCM for SACD so that Audyssey will not be bypassed at the receiver. I guess deciding what to do is based on the undefeatable NR on HDMI output 1. As I wrote earlier I will use the player as a transport only. Is the NR something to be concerned about if using output 1 and if so is there any downside to using output 2 for DVD, Blu-ray, SACD and DVD-A? I can also go with the 103D so that HDMI output 1 can be used without NR but I will not be using the Darbee processing as I already have a Darblet.
praz is offline
post #14595 of 24401 Old 01-28-2014, 07:37 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2694 Post(s)
Liked: 1921
Do you not have one of these players at present? The best course is to try the alternatives yourself rather than depend on what other people say.
"NR something to be concerned about": for some people it is, for some it isn't. It has not troubled me.
For transport only, there is no down side to HDM2 on the -103.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #14596 of 24401 Old 01-28-2014, 07:37 AM
ckronengold's Avatar
Quoted: 56 Post(s)
I have the same receiver, and that used to be my setup before getting a new receiver.
IMHO, you are comparing the DACs between boxes, and the OPPO definitely has the upper hand. Beyond Netflix, you'd benefit greatly by having the OPPO handle the audio decoding. On bluray, for example, it can decode a DTS-HD or TrueHD signal and pass the full analog range to the receiver to play. With optical, you can't pass a HD audio stream to the Marantz, only regular DTS and Dolby. So you're missing out on the full audio experience.
Whether or not it "sounds better" could have to do with a number of factors. Are you using decent interconnects? Do you have other settings impacting the sound that maybe you aren't aware of being active? I'd put the receiver on "Direct Sound" with zero processing and start from there.
Hi -
T
Media Room: Epson 5030 / Marantz 7010 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #14597 of 24401 Old 01-28-2014, 08:03 AM
hernanu's Avatar
Quoted: 593 Post(s)
Liked: 1070
Hi -
I agree with Oppo.
The optical link has inherent limitations that prevent you from using the 103 to its full audio capabilities. Most bluray titles now provide a soundtrack that is lossless (TrueHD, DTS-HD-MA). This means you get the exact sound from the title as recorded. The other alternatives (DTS, Dolby Digital) are lossy, which means that in their mode of compression, some of the audio information is discarded, never to be regained. Your digital (optical) connection can't do the lossless formats.
The analog connection allows you to play lossless sound, since the translation is done within the player, and you get the audio signals directly through the analog connections.
Another drawback is that some audio formats are excluded by design from the optical connection. SACD (another lossless format, this time just for music), is precluded from playing through the connection. This is not an issue for the analog connections, since the decoding is done in the player.
The reason for that is that it's designed that way. This article explains it very well:
The long and short of it is that when the sound is mixed for LFE and in some cases with the sub itself, those signals are lowered. In the case of LFE it can be -10db, for the sub by -5db.
This is transparent for digital signals (like the optical link and for HDMI), since the decoder inside of your Marantz (and most others) automatically boosts the incoming signal. On analog, once the signal is decoded and put on the analog connections, the sub is 10 to 15 db lower in comparison.
So you have to make up the difference at the receiver the sub signal needs to be boosted, so either take a meter and match it appropriately or do it by ear, but boost the sub's channel using your receiver's settings.
The speaker configuration should be done on the 103.
The Oppo. You do need to tell the receiver what configuration you have, etc. but I don't think it does any processing of the input analog signals (some rare receivers do).
Thanks very much!
T
No idea on this.
hernanu is online now
post #14598 of 24401 Old 01-28-2014, 08:21 AM
Quoted: 467 Post(s)
Liked: 197
Most of Netflix's 'HD' movies use 5.1 channel Dolby Digital Plus audio complete with an 640Kbps Dolby Digital 'core', which are both 'lossy'.
You Marantz amp might not like decoding Dolby Digital at 640Kbps via SPDIF, it more likely favours the DVD standard bit-rate of 448Kbps...
post #14599 of 24401 Old 01-28-2014, 08:46 AM
praz's Avatar
Liked: 26
-Bill
No I do not have an OPPO yet. Currently I use a Panasonic for Blu-ray and a older Pioneer Elite for DVD, SACD and DVD-A. The Elite is starting to have freezing issues with some newer DVDs so I'm looking for a replacement. Needing source direct to feed to my Radiance and SACD/DVA-A capability limits my choice of a replacement player. The below info in the FAQ was confusing me as to the use of HDMI output but rereading it seems to only apply when using both outputs. So it sounds as if using output 2 will work well for me. Thanks again.
HDMI1 outputs video at the highest possible resolution and mutes audio. (Or: HDMI1 will always have the best video but may not have audio in certain cases, such as when HDMI2 is doing HD audio bitstreaming).
HDMI2 outputs video at a resolution that can sufficiently carry the best audio. It will always have audio but video is delivered on a "best effort" basis -- in some cases (such as when 3D is sent over HDMI1 but the HDMI2 device does not support 3D), a black screen will be sent to HDMI2.
praz is offline
post #14600 of 24401 Old 01-28-2014, 11:06 AM
lorenmc's Avatar
I'm seriously thinking of purchasing a BPD-103 or BPD-103D and I was hoping that some of you knowledgeable owners would be able to confirm the following.
  1. The BDP-103 or 103D will stream, over SMB, MKV files that contain full quality Blu-Ray rips with Dolby TrueHD and DTS-HD Master Audio tracks.
  2. The BDP-103 or 103D supports MKV files that contain PGS subtitle tracks.
  3. Cinavia detection still does not happen for MKV files over SMB
From reading various threads and FAQs it's my understanding that with current firmware the above statements are true but I would appreciate a definite 'yes' or 'no'.
lorenmc is offline
post #14601 of 24401 Old 01-28-2014, 11:41 AM
wmcclain's Avatar
Liked: 1921
All true.
-Bill
AlexanderDelarg likes this.
post #14602 of 24401 Old 01-28-2014, 11:56 AM
lorenmc's Avatar
All true.
-Bill
Thanks Bill. I appreciate the Unofficial FAQ you put together as well.
lorenmc is offline
post #14603 of 24401 Old 01-28-2014, 12:03 PM
Tgterm's Avatar
Quoted: 178 Post(s)
Thanks for the information.  By 'Direct Sound' do you mean 'Source Direct' on the Marantz?  I will have to look at that when I get home...do you know if you can set it to Source Direct on a input by input basis?  E.g., have it set to Source Direct on the DVD player or 7.1 channel input on the Marantz, but use the Marantz's DAC for DirecTV for instance?
T
post #14604 of 24401 Old 01-28-2014, 12:10 PM
Tgterm's Avatar
Quoted: 178 Post(s)
Originally Posted by hernanu View Post
I agree with Oppo.
No idea on this.
Great info, thanks!  A bit confused, so I probably have some dumb questions...
"On analog, once the signal is decoded and put on the analog connections, the sub is 10 to 15 db lower in comparison.
So you have to make up the difference at the receiver the sub signal needs to be boosted, so either take a meter and match it appropriately or do it by ear, but boost the sub's channel using your receiver's settings."
When you say "make up the difference at the receiver", if I figure out a way to bypass the receiver's DAC (might be this Source Direct thing...need to look into it) would I then be making up for the Sub with the OPPO Speaker Management capability, right?
I have also read that if I do go Source Direct on the Marantz (and I know this is a Marantz question, not an OPPO...) the Marantz will not employ my subwoofer.  I have not confirmed that and find that a bit odd...but I guess anything is possible.  Not sure what I would do about that if that were the case.
T
post #14605 of 24401 Old 01-28-2014, 12:37 PM
Quoted: 56 Post(s)
Yes, Source Direct. My bad. Direct Sound is on the new Onkyo. Forgot what it was called on the marantz.
I don't recall if you can assign surround modes to each input, or if they just default to whatever the last mode used was, or default to whichever mode that input was set to. You'll have to experiment unless someone else can weigh in.
T
post #14606 of 24401 Old 01-28-2014, 12:59 PM
Quoted: 56 Post(s)
Making up the difference in volume can happen at the speaker level, so it still 'goes around' the DAC and surround sound processing. You control it in the speaker level setup. But that would apply for all inputs, not just the analog inputs.
According to the manual (page 6 http://www.manualslib.com/download/99047/Marantz-Sr7300.html) tone control and bass management are bypassed, and Front, Center and Surrounds are set to "large" and the Sub is ON.
T
post #14607 of 24401 Old 01-28-2014, 01:17 PM
Tgterm's Avatar
Quoted: 178 Post(s)
T
Control it with speaker level set up in the Oppo or on the marantz when source direct is on?
Sent from my SCH-I545 using Tapatalk
post #14608 of 24401 Old 01-28-2014, 01:32 PM
Quoted: 56 Post(s)
Yes, you should do the +10db in the OPPO. That would allow you to leave the Marantz balanced for the rest of your inputs.
P 70: http://download.oppodigital.com/BDP103/BDP-103_User_Manual_English_v1.2.pdf
post #14609 of 24401 Old 01-28-2014, 01:38 PM
hernanu's Avatar
Quoted: 593 Post(s)
Liked: 1070
At the receiver. The reason the signal for LFE was lowered was because it was expected to be louder than the others.
So the signal goes in low to the receiver and the level is raised in the receiver.
As was mentioned earlier, this is mostly beneficial when playing a disk or a lossless file by SMB or a DLNA, since broadcasts and streaming services like Netflix are only capable of delivering lossy sound like DD+ and DTS. For those, the optical link would be fine.
It's for bluray or lossless files that you'll see the benefit from the analog connections in your setup.
post #14610 of 24401 Old 01-28-2014, 01:49 PM
Quoted: 56 Post(s)
Presuming the OPPO is the only source with the original issue, this would needlessly affect the bass of any other source devices connected to the receiver.
I do not believe you can adjust the speaker level settings for individual sources on the Marantz 7300.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
