Official OPPO BDP-103 Owner's Thread - Page 490 - AVS Forum | Home Theater Discussions And Reviews
 874Likes
Old 01-29-2014, 11:38 PM
plissken99's Avatar
Quoted: 129 Post(s)
Liked: 35
Originally Posted by rdgrimes View Post
Oppo does not guarantee support for any such "user generated" media files. But typically you would leave the video alone in the player and force the display to switch to T-B 3D playback. The player does not convert SBS or T-B 3D to frame packed output. Anyhow if your TV cannot display 3D images from the files, it either an issue with the files or with the TV.
Got it working! I had the player set to auto on the resolution, I switched it to "source direct" and it worked like a charm!
lanping09 likes this.
The more things change, the more they stay the same.
Snake Plissken
plissken99 is offline
Old 01-30-2014, 12:35 AM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Originally Posted by jlpowell84 View Post
Ok I will for sure and get familiarized with these units. So what is the conventional ways to hook these up? I see one can do away with an AVR but I don't want to give up Audyssey.
I think people who want to keep Audyssey almost always us a single HDMI connection to their AVR, but there are examples where people do unique arrangements that I don't bother to follow. Bob's post are a treasure chest of information.
An OPPO is worth the effort even if it's just to decide to go are not. smile.gif
I just ran across this 103D review in the 103D thread.
htwaits is online now
Old 01-30-2014, 03:28 AM
pbarach's Avatar
Quoted: 333 Post(s)
Liked: 201
HDMI1 to your AVR, HDMI from your AVR to your TV. Your other sources can be connected either to the AVR or to the Oppo; either way, Audyssey will be availablec to all digital sources getting sent to your AVR.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
Old 01-30-2014, 04:32 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2792 Post(s)
Liked: 2015
Originally Posted by Jon Middleton View Post
I assume it's easy to select which signal the OPPO outputs, the Direct TV vs the disc?
The remote has an INPUT button which displays a popup list of the options.
The Setup menu also has Power On Input which can be set to Blu-ray or Last Input, the latter handy if you are commonly watching from some other input.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Old 01-30-2014, 07:08 AM
em0ti0n's Avatar
Is it normal that mkv files (PAL DVDs, ripped by MakeMKV) are being displayed as 576p titles when the Oppo is set to "direct"?
There is nothing in the desert and no man needs nothing.
em0ti0n is offline
Old 01-30-2014, 07:48 AM
studiozut's Avatar
Instead of 576i? Is MakeMKV set to "de-interlace" when ripping? My PAL discs are still boxed in storage, so I have yet to test them, but in theory they would output 576i in Source Direct, and I'm assuming a straight rip of a PAL disc would as well.
Oppo bdp-103 | Sony XBR4 52" | Denon 3310CI | KEF speakers
studiozut is offline
Old 01-30-2014, 07:53 AM
Jon Middleton's Avatar
Quoted: 188 Post(s)
Liked: 137
I think maybe the best way is to use a preamp/processor to receive audio input from the OPPO as well as other sources. Mine is an old Rotel. If you can find a PrePro with Audessey, you can feed the Analog in from the OPPO, then use the other inputs for other sources. I have a turntable as my only other audio source into the Rotel. The Rotel feeds an Adcom 100WPC amp in the equipment rack, which in turn powers the rear surrounds. The Rotel also feeds a Bryston 4B, via in-wall Canare interconnects to the screen wall. The Bryston powers the LF and RF Watt/Puppy V's. An in-wall IC feeds an M&K V125 powered sub, making my system 4.1. Weird, I know, but I want movie sound coming out of the WP's.
Jon Middleton is offline
Old 01-30-2014, 07:57 AM
Quoted: 188 Post(s)
Liked: 137
-Bill
Thanks, Bill, that's what I assumed. I've never owned a BDP that accepted inputs from other sources.
Old 01-30-2014, 09:07 AM
em0ti0n's Avatar
Well, I can't see 'de-interlace' option in MakeMKV. Is there supposed to be such option? Playing straight from a disc results in 576i as expected, when the player is set to 'source direct'.
em0ti0n is offline
Old 01-30-2014, 09:21 AM
studiozut's Avatar
Afraid I'm not familiar with MakeMKV. Maybe they call it "pull-down" or "interpolation"?
Glad to hear disc outputs 576i in Source Direct though.
Old 01-30-2014, 09:26 AM
em0ti0n's Avatar
I have investigated MakeMKV menus and there is nothing video-related. MakeMKV should not touch the video, it puts movie content into a different container only.
I am afraid this way the video is not deinterlaced by the Oppo, it just gets upscaled. Or am I wrong?
em0ti0n is offline
Old 01-30-2014, 09:28 AM
SeeMoreDigital's Avatar
Quoted: 469 Post(s)
Liked: 197
Whether the Oppo outputs an 'i' or 'p' signal should depend on how the PAL MPEG-2 video stream has been flagged. If you want to find out how the MPEG-2 stream has been flagged you can use an application called MediaInfo.
However, the MPEG-2 video stream on many PAL DVD movies have actually been encoded using 'progressive' frames but are flagged as 'interlaced' to conform with the DVD standard. Thankfully, such video streams can be 're-flagged' using an application called ReStream prior to muxing into the MKV container....
em0ti0n and studiozut like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
Old 01-30-2014, 09:37 AM
em0ti0n's Avatar
Thank you for the explanation. I will look into this further as I am actually re-ripping everything from the scratch - so now it is a good time to utilise this information. Thank you again.
em0ti0n is offline
Old 01-30-2014, 11:34 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Ok. So I can just buy an hdmi switch and connect all my sources to the Oppo direct and then output everything from the Oppo to the JVC with the existing HDMI cable and then use the second HDMI out on the Oppo to send the audio from EVERYTHING connected back to the AVR, or does it only output the bluray audio from the Oppo? Basically 5 devices go into the Oppo and the Oppo outputs to the JVC through 1 output and then all the audio from all 5 sources connected to the Oppo will go the the AVR through the second HMDI out put on the Oppo? Hope that made sense. LOL.
If I already have a darbee, could I put it directly after the hdmi switch and before it enters the Oppo? Would that give me the same effect as the built in darbee in the 103d? Any benefit with the built in darbee vs. the original one?
Finally, is it really worth it to do all this? Will I get a better picture from having the Oppo upscale to 4K vs. just sending a 1080p signal from my AVR and just using eshift 3 on the 1080p image? When you go into your info menu on the JVC, does it show the 3840 x 2160 res?
conan48 is offline
Old 01-30-2014, 11:39 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Which hardware region free mod do yo guys recommend? Seen them as cheap as 50.00. Does anyone know if the jailbreak firmware works without issue? and is there anyway to remove cinevia infection?
thanks
conan48 is offline
Old 01-30-2014, 12:22 PM
jlpowell84's Avatar
Quoted: 1695 Post(s)
Liked: 737
jlpowell84 is online now
Old 01-30-2014, 01:42 PM
wmcclain's Avatar
Liked: 2015
I would put it between the OPPO and the display.
Functionally they are the same. Folks in the Darblet thread sometimes report power-on and handshaking problems which don't happen with the -103D.
Which is that?
From discs? No.
From the player? No, but currently it is enforced only on files on optical media. Future rules may be different.
-Bill
wmcclain is offline
Old 01-30-2014, 04:26 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
The firmware is something I saw on ebay. Haven't really researched it myself. If you set the Oppo to 4K upscale, does the darbee still function? I was told the darbee does not process 4K signals, so wouldn't that be a waste of money if you have a 4K tv and upscale everything to 4K from the Oppo?
conan48 is offline
Old 01-30-2014, 06:08 PM
steviebstrummin's Avatar
Quoted: 40 Post(s)
I just connected my brand new Oppo BDP-103 and tried to wirelessly connect with Netflix. The display indicated the connection failed and that I needed a "Network Adapter"
I know my wireless network signal is strong as I just returned a Samsung BDF-5900 that was connected wirelessly to my network just this morning.
I traded in the Samsung for the Oppo as I know it is a much higher quality product (and a heckuva lot more expensive). But I will say when i started up the Samsung for the very first time it prompted me immediately for my wireless network key etc and I was able to sign uo for and receive Netflix with two or three minutes.
So do I really need a separate "Network Adapter"?
Any ides to help me troubleshoot and get on line would be greatly appreciate. I use an Apple Airport Extreme router with an Airport Express upstairs as a signal booster.
steviebstrummin is offline
Old 01-30-2014, 06:13 PM
wmcclain's Avatar
Liked: 2015
That was answered in the other thread. Darbee is before 4k scaling.
-Bill
wmcclain is offline
Old 01-30-2014, 06:24 PM
wmcclain's Avatar
Liked: 2015
Try the BDP-103 thread: http://www.avsforum.com/t/1432162/official-oppo-bdp-103-owners-thread
The player comes with a USB wireless adapter and extension cable so you can position it as needed. Were those things not in the box? You have selected wireless in the Setup menu?
-Bill
wmcclain is offline
Old 01-30-2014, 06:27 PM
Quoted: 188 Post(s)
Liked: 137
The problem with connecting the OPPO directly to your display is that you won't be able to see on-screen menus for your AVR unless you also run HDMI from your AVR to the JVC. I will have that problem because my PrePro predates HDMI. I'll need to run Component to my Sony from the Rotel because that's the lowest res input in accepts. I won't need to access the Rotel OSD often, so won't run a component cable in wall.
Old 01-30-2014, 10:22 PM
Quoted: 40 Post(s)
-Bill
Thanks Bill, I guess it pays to look at all the contents of the box. Thanks for the heads-up, I'm good to go and already enjoying the Oppo. Thanks again!
Old 01-31-2014, 07:41 AM
studiozut's Avatar
Thoroughly enjoying the 103. Thanks again for the help here. Next upgrade: eye exam next week...
mlmcgahee likes this.
Old 01-31-2014, 01:36 PM
rickydenim's Avatar
Quoted: 17 Post(s)
I'm trying to update the pro modchip in my 103AU using the fw update on Gattiweb's site but it won't read from the usb (sandisk). Can anyone who's done this let me know what stick worked for them? I don't want to have to go out and buy a bunch of usb sticks to find one that works!
rickydenim is offline
Old 01-31-2014, 02:21 PM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
Be sure it's formatted as FAT or FAT32. Generally, lower capacity usb sticks work better than higher capacity ones in my experience. I always use a really old 512mb one I have had for years and it is perfect.
JazzGuyy is offline
Old 01-31-2014, 02:39 PM
pbarach's Avatar
Quoted: 333 Post(s)
Liked: 201
I use an 8 GB cheapie formatted as FAT32 without any problems.
pbarach is offline
Old 01-31-2014, 03:29 PM
rickydenim's Avatar
Quoted: 17 Post(s)
It was a 16gb Sandisk Cruzer and def formatted to FAT32 but I think maybe all the silly software that it comes with is probably the issue. I'll find a cheapy one today with no frills..hopefully better luck! Thanks!
Old 01-31-2014, 07:01 PM
cougar75's Avatar
Quoted: 39 Post(s)
Liked: 32
Well, I ordered a BDP-103. Should be here Wednesday. Will be using it with a Samsung 65F9000 4k display.
ceat likes this.
cougar75 is offline
Old 01-31-2014, 08:08 PM
orac 7's Avatar
hi there. I also have had the very same handshake problems with connecting my oppo 103 to benq 1070,via 12m hdmi. All you have said word for word,i don't have an amp with hdmi, (pioneer vsa-e07) and its great ,not wanting to get rid of,so I tried a splitter form amazon ,and all is working ,happy days , here is the item   ( WMicroUK Top Quality HDV912 HDMI 1.4 Splitter 1 x 2,all 3D formats up to a 297MHz TMDS clock by WMicroUK ) 4kx2k@30hz, it is well made, and works a treat ,
orac 7 is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
