Official OPPO BDP-103 Owner's Thread - Page 502 - AVS Forum | Home Theater Discussions And Reviews
 913Likes
post #15031 of 24755 Old 02-14-2014, 04:45 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Originally Posted by gsr View Post
The only case where he isn't getting the OSD display from his AVR is when watching content that comes from the Oppo because his AVR's HDMI output effectively gets ignored in that case. He wasn't complaining about that, just point out that it's a minor downside of the configuration he's using. The HDMI loop may not be an issue if his AVR doesn't keep all HDMI inputs active all the time - if it were a problem, there would be no question about it as he wouldn't be getting any picture at all.
Exactly. He said it was a "caveat" that he wasn't able to see the AVR's volume setting on his projector.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
post #15032 of 24755 Old 02-14-2014, 06:36 PM
mconley1015's Avatar
Has anyone been able to create flac/mp3 playlists on a networked drive and play them on the 103D? I have been able to create m3u playlists and play them back through LMS Whitebear but no such luck on a direct connected drive. I would love to hear from others on this. With that said I am quite pleased with the unit so far. I have had it for a week but haven't had lots of time yet.
Could someone point me to the basics of creating SMB shared drive through windows Vista?
My previous setup for attached storage used with the 95 (which i sold for $660.00 on ebay BTW): Two 2 TB WD Caviar green HDS loaded into a dual port powered USB Thermaltake Black X. Works perfectly. watched the BD movie Prisoners last night and was very impressed with PQ.
Next, I spun up my reference Jeff Beck Blow by Blow 5.1 SACD and just wow! I am glad I moved to the BDP 103D away from the BDP 95. The analog 7.1 on the BDP 95 just didn't work well in my room and I could not justify keeping the unit AND upgrading.
The audio output from HDMI 103D is superior and I have a new Oppo with all the improvements that come with it. Had I been able to afford both I would have kept the BDP 95 for audio but just cannot justify that move....unfortunately.
mconley1015 is offline
post #15033 of 24755 Old 02-14-2014, 07:18 PM
KC-Technerd's Avatar
Quoted: 98 Post(s)
Liked: 147
Originally Posted by Mongo171 View Post
I know that he has an HDMI loop and needs to reconfigure his setup. We already told him that and he said it works with the loop, but didn't get AVR OSD.
Here's the problem with using Dual Display with this configuration.
If the input on the Oppo is set to 1. BLU-RAY Player, the OSD video from the AVR never makes it to either HDMI output on the Oppo. The thick purple dashed line represents the routing of the OSD video from the AVR.
If the Input on the Oppo is set to the input from the AVR, and the AVR is selected to the input from the Oppo, then a continuous HDMI Loop is created. But with the Oppo's input not selected to 1. BLU-RAY Player neither the BD image, nor any other image generated from the Oppo itself will be available on either HDMI output.
A true HDMI loop in his current configuration is avoided only by avoiding simultaneous selection of the HDMI input from the AVR on the Oppo and the HDMI input selection from the Oppo on the AVR. As long as those two selections are not made simultaneously, there is no HDMI loop. If he were to select the HDMI input on the Oppo, and the BD/DVD input on the AVR simultaneously, the HDMI loop would exist. This remains the same whether Split A/V or Dual Display is selected, other than the type of video information passed through the loop (HDMI 2 could be outputting a blank video signal in Split A/V mode).
Neither of these scenarios would result in the AVR's OSD being displayed over the BD image even if the HDMI loop wasn't an issue.
KC-Technerd is offline
post #15034 of 24755 Old 02-14-2014, 10:17 PM
globalnomad's Avatar
I don't believe M3U playlists are supported at the moment, but cue files that point to multiple audio files in the same folder are. To get around this limitation, I use Foobar to export playlists as hard links. See this post for how to do it.
Also, while the settings have changed somewhat between Vista and Win 7, here's my post about how I got SMB to work.
globalnomad is offline
post #15035 of 24755 Old 02-15-2014, 01:46 AM
winston99's Avatar
Originally Posted by winston99 View Post
I called Dish and they had me unplug the dish for 10 seconds to force an update and i did not lose video after but i don't think this is the same update that occurs every night, I'll have to wait until tonight at 1:30 am and see what happens.
Update:
Ok, I lost video again when dish did it's nightly update. Changing the input on the oppo to blue ray and back to hdmi in back did not restor video, nor did switching resolutions. There is some activity on the tv screen when I cycle through the inputs but it is just a minor change in the brightness of the blank black screen, my point being that the tv is receiving some sort of signal. I use the analog outs and I do not lose audio. Power cycling the dish does not restore video.
Power cycling the 103 restores video.
Think I will try and revert to a previous version of the 103 firmware and see what happens tomorrow night.
BTW- unplugging the dish from the wall does not force the same kind of update that dish forces every night . I know because I tried it yesterday and when I plugged the dish back in I did not lose video.
winston99 is offline
post #15036 of 24755 Old 02-15-2014, 04:06 AM
SeeMoreDigital's Avatar
Quoted: 487 Post(s)
Liked: 208
7. Added 24 Hz support for customer-encoded video files in 480P24 and 720P24 formats. The original frame rate can be preserved when upscaling the content to 1080p, e.g., when Resolution is set to 1080P, the 720P23.976 content is output as 1080P23.976, and 720P24 is output as 1080P24. Previously, these formats were frame-rate converted to 60 Hz.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #15037 of 24755 Old 02-15-2014, 04:27 AM
I have some playlists I created using Logitech Media Server (Native software for the squeezebox) that I can play through the Network interface by going through the Whitebear LMS server. However I cannot use the same playlists copied to the attached drive. Interesting. I am going to also try your workaround method also. If my method works logic dictates that others have found combinations that work also. I tried the oShare server for playlists also but obviously that did not work. oShare works well playing my flac files where Whitebear is a bit slow and clumsy but zips right through all my playlists perfectly.....again, interesting (to me anyhow). Thank you for your input globalnomad and I will check out the links about SMB and Vista you were kind enough to provide. I did a search for a couple of different keywords but did not find the link you provided.
post #15038 of 24755 Old 02-15-2014, 05:33 AM
ThePrisoner's Avatar
Quoted: 285 Post(s)
Liked: 200
I'm trying to come up with a work around for enabling gapless playback while using the iOS Media Control app. My display is a Panasonic plasma, I always put my 103 in pure audio mode to black out the HDMI signal to avoid image retention. If I could avoid turning my display on that would be cool!
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, ProMonitor 800; SVS PC12-NSD (2)
ThePrisoner is online now
post #15039 of 24755 Old 02-15-2014, 06:00 AM
claud's Avatar
Just ordered two 103s from Oppo. One will go to my son and be connected to Sony HT-ST7 sound bar that has DTS Master and DDTru. Should i just send audio to this sound bar by HDMI from HDMI 2 and let sound bar decode or should i have 103 decode and send it to sound bar ?
Got Tubes?
claud is offline
post #15040 of 24755 Old 02-15-2014, 06:35 AM
alphamalex's Avatar
I always change the input on the OPPO first, and then flip my AVR input to either BD, Satellite, or PS3 (never simultaneously) .. maybe that's how I avoided the loop. BTW, what happens when you do get in a loop? Maybe I should try it smile.gif
And yes, I am fairly certain HDMI2 just outputs audio in Split AV mode. I think it is in place so users like me who do not have a 3D ready receiver can send video to the 3D projector via HDMI1, and send audio to our older receivers via HDMI2.
Freddy ..
alphamalex is offline
post #15041 of 24755 Old 02-15-2014, 07:39 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
The only way to enable gapless playback is from the 103's onscreen interface. You'll have to turn your tv on and use the onscreen interface to select your usb attached media directory you want to play back, then enable the gapless setting by pressing the "option" button on your 103 remote. Once you do that, you can turn off your tv. From that point, you may be able to run the MediaControl HD app to see what music you are playing back as gapless, and you may jump to the next track using the app, but you won't be able to enable gapless from the app for another directory on your usb drive. You'll need to turn your tv back on for that.
DanF8500 is offline
post #15042 of 24755 Old 02-15-2014, 07:43 AM
Quoted: 285 Post(s)
Liked: 200
Thanks Dan. I thought maybe someone here came up with a trick but that's cool. Like I said, I enable pure audio so no harm, no foul. The most important thing is the gapless playback! Thanks again!
post #15043 of 24755 Old 02-15-2014, 07:45 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Freddy ..
All of this could be avoided if you hook up Dish and the PS3 to the OPPO first, then output everything to the AVR. The OPPO can do its thing to the video and you still get audio through the AVR.
post #15044 of 24755 Old 02-15-2014, 08:00 AM
DrZaus's Avatar
Hi Guys, I have the Oppo 103 it's about 6 month old or so.. I cannot play my Avengers disc anymore, it says no movie found, sometime it works sometimes it doesn't.. the I stated to watch blu ray rips via hard drive.. that was fantatstic.. It a seagate 4tb drive with 1 tb of movies in the NTFS formmated drive.. recently I added more files to the 4tb drive and poof, some movies display, some load 100% and plays the movies and some goes to 50% loading and all I get is audio and no video.. at first I thought it was the hard drive.. then I copied the movies files to a thumb drive, some played and some did the exact same thing, loaded 50% and no video, only audio.. are all my files corrupt? it can't be, they play fine when I attach the drive to my PC Anyone experience this? I did a factory reset and still the same issues.. Do I need to contact and return this unit?
DrZaus is offline
post #15045 of 24755 Old 02-15-2014, 08:13 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1235 Post(s)
Liked: 1271
Two things are needed to avoid a loop:
1. Don't select the input on your AVR that HDMI2 out from the Oppo is connected to while also selecting the HDMI input on the Oppo that your AVR's HDMI output is connected to. (I know, that's pretty obvious)
2. The AVR needs to shut off any handshakes with the HDMI input that HDMI2 out from the Oppo is connected to when you select other inputs on your AVR. This one is more subtle and some receivers play nicely (apparently yours does), while others don't.
You get a wild 3D effect where the picture has endless depth (like picture in picture in picture in picture......) and seems like it's never going to end... biggrin.gif Seriously though, what happens is the picture will just go blank as the HDMI / HDCP handshake will fail.
Yes, that's correct. Choosing the Dual Display option would actually have some negative ramifications for what audio formats would be sent to your AVR, so it would be the wrong choice in your configuration.
Since you clearly aren't experiencing any issues with HDMI loops, the only reason to change your configuration would be if you really wanted to see the OSD from your receiver when watching content played from the Oppo itself. The solution, as already suggested by others, would be to connect all your HDMI sources to a HDMI switch, send the output from the switch to the HDMI input on your Oppo, the HDMI output from the Oppo to the AVR, and the AVR HDMI output to your display. But if you're happy with what you have now and don't find the lack of OSD from your AVR to be an issue when playing content on the Oppo, then there's no reason to change anything or add the expense of a HDMI switch.
gsr is offline
post #15046 of 24755 Old 02-15-2014, 08:37 AM
alphamalex's Avatar
So I'd need an HDMI switch with a remote to flip the input, right? Add one more to the collection smile.gif
I currently count 5 from 103, 3007, PS3, Satellite, CD player .. I should look to a smart remote I suppose ... $$
post #15047 of 24755 Old 02-15-2014, 08:49 AM
Quoted: 487 Post(s)
Liked: 208
Is it just me or does anybody else think that 'input' number 2 should be 'HDMI IN-BACK' instead of 'HDMI/MHL IN FRONT'?
Cheers
post #15048 of 24755 Old 02-15-2014, 09:00 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Satellite and PS3 can be hooked up to the HDMI Inputs on the OPPO. No need for a switch.
post #15049 of 24755 Old 02-15-2014, 09:14 AM
apw2607's Avatar
Quoted: 291 Post(s)
Liked: 337
If you want to use DLNA, serviio supports playlists. Not just audio playlists but video playlist where tracks can reside across any combination of folder structure. I use them all the time with my 103D. They will also show up on a DLNA remote app too. Lots of flexibility.
apw2607 is offline
post #15050 of 24755 Old 02-15-2014, 09:29 AM
Quoted: 98 Post(s)
Liked: 147
Freddy ..
I'm not 100% sure what happens with an HDMI loop, but I can't imagine it would be anything good. Any kind of loop like that with A/V equipment usually results in feedback. I have one possible loop (audio only) in my system that I do hit on occasion. That is HDMI to the TV, and optical digital back to the TV. If I accidentally have the TV selected to the HDMI input from the AVR, and the AVR selected to the optical input from the TV, I get a high pitched hum/whine.
HDMI2 always outputs a video signal (possibly blank video) when Split A/V mode is active. From the BDP-103 User Manual:
In Split A/V mode, HDMI 1 OUT has video only with no audio, but HDMI 2 OUT will have audio and possibly video. This is because HDMI embeds audio into video data so there must always be a video signal, even if it’s only a blank screen, to carry audio through.
From the Knowledge Base Article "Understanding Split A/V Mode":
Note: While HDMI 1 will only output video while Split A/V mode is active, HDMI 2 will output both an audio and video signal.
You can see what format of video the BDP-103 is outputting on HDMI 2 by pressing the INFO button and using the PAGE UP/DOWN buttons to scroll to the next page. One of the screens there shows what is being output on both HDMI outputs across the bottom of the screen. What I typically see when using Split A/V mode and playing a 1080p Blu-ray is:
"HDMI 1: 1080P@24Hz 4:4:4 36b   No Audio           HDMI 2: 1080P@24Hz 4:4:4 24b   Bitstream".
I don't have a method of viewing HDMI 2 while keeping HDMI 1 (and therefore the Split A/V mode) active in my system, so I can't see if the video output from HDMI 2 is blank or not.
I remember reading a post, and I thought it was somewhere in this thread, concerning how with HDMI the audio is carried in the video blanking interval requiring there to be a video signal, and which digital audio formats required which minimum video resolutions. Of course I can't find that now.
Additionally, Split A/V mode is only active when both of the 103s HDMI outputs are connected to active HDMI inputs. Your AVR may not make it's BD/DVD HDMI input active unless it is selected.
Dual Display mode differs by outputting the highest level video and audio that is compatible with both connected HDMI devices. Dual Display is also only active when both of the 103s HDMI outputs are connected to active HDMI inputs.
post #15051 of 24755 Old 02-15-2014, 12:52 PM
Coyote Waits
htwaits's Avatar
Quoted: 948 Post(s)
Liked: 2099
I'm not familiar with your sound bar, but you can try it both ways. I wouldn't expect you to be able to hear a difference. I use LPCM instead of bit stream and am happy and audio trouble free. wink.gif
htwaits is offline
post #15052 of 24755 Old 02-15-2014, 02:09 PM
DrZaus's Avatar
Did another test run on the Oppo Blu-ray player, none of my blu-rays work now..WTF..
DrZaus is offline
post #15053 of 24755 Old 02-15-2014, 02:13 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3233 Post(s)
Liked: 2518
Sounds like it's busted. Contact OPPO for warranty repair.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #15054 of 24755 Old 02-15-2014, 02:51 PM
DrZaus's Avatar
I just emailed Oppo, hoping to get a quick response. I even tried a new thumb drive and a WD passport drive.. it load's 50% and all I get is a blank screen with full audio.. I did not expect this failure rate for a high end blu-ray player. mad.gif
DrZaus is offline
post #15055 of 24755 Old 02-15-2014, 02:55 PM
Sebring1's Avatar
I had to load the firmware twice.
Sebring1 is offline
post #15056 of 24755 Old 02-15-2014, 02:57 PM
wmcclain's Avatar
Liked: 2518
High failure rate? How many have you had?
-Bill
Smarty-pants likes this.
wmcclain is offline
post #15057 of 24755 Old 02-15-2014, 03:58 PM
DrZaus's Avatar
This is my first unit..
DrZaus is offline
post #15058 of 24755 Old 02-15-2014, 03:59 PM
DrZaus's Avatar
I did a factory reset and tried again.. I should have never done the update, it was working awesome before..
DrZaus is offline
post #15059 of 24755 Old 02-15-2014, 05:14 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Nothing in this world is produced that is 100% perfect all of the time. There are some lemons out there. However, we don't hear of OPPO's being bad from the factory much on this thread, or the other OPPO threads.
OPPO has great customer service and they will take care of you.
htwaits likes this.
post #15060 of 24755 Old 02-15-2014, 05:26 PM
Jacob305's Avatar
Quoted: 84 Post(s)
Liked: 48
+1.
Jacob
Jacob305 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
