Official OPPO BDP-103 Owner's Thread - Page 505 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #15121 of 24403 Old 02-18-2014, 03:31 PM
pbarach's Avatar
Quoted: 322 Post(s)
Liked: 194
Originally Posted by JazzGuyy View Post
I can certainly send .flac files from my computer to the Oppo by us oShare from my Windows 8.1 desktop over my wireless network. I don't use .mkv files so I can't comment on those.
Are you actually sending them by selecting them on your PC, or are you using oShare on your PC and choosing the files on your monitor using the Oppo remote?
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #15122 of 24403 Old 02-18-2014, 03:44 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
I am using oShare on my Oppo through the Oppo interface to select the .flac files from my computer. To me, this produces the same result so I am not so concerned with the mechanism.
JazzGuyy is online now
post #15123 of 24403 Old 02-18-2014, 07:04 PM
pbarach's Avatar
Quoted: 322 Post(s)
Liked: 194
I do this, too. But some people are looking for a way to select the files to be played on a PC so they don't have to turn on a monitor to do the selection. That's what pushing a file means.
pbarach is offline
post #15124 of 24403 Old 02-18-2014, 07:11 PM
LairdWilliams's Avatar
Quoted: 202 Post(s)
Liked: 224
Yes indeed.
And also, when you have a large collection, it is nice to have a better browsing/selection interface to use for doing searches, ad-hoc playlists, etc.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is online now
post #15125 of 24403 Old 02-19-2014, 02:25 AM
kevpatts's Avatar
Hey all,
I'm thinking of getting a BDP-93 or 103, but I have a few questions. The reason I'm considering these is because of the high quality DAC in them, the other features don't really interest me all that much.
My AV32R-DP can't handle TrueHD or Master Audio, and I'd like these. I was considering hooking up both the 5.1 bypass and coax connections from the Oppo to the Tag McLaren but I want to only use the 5.1 bypass for discs that support these lossless formats, otherwise I'd prefer to use the DAC in the AV32R as it's better I believe (never heard the Oppo).
Is it possible to configure the device to do this automatically or would I have to manually do it each time? I know I'd have to manually change source on the AV32R but that's okay.
Kevin
Amps: Tag McLaren AV32R-DP, 3x Musical Fidelity P140
Speakers: B&W 604, 601, LCR600, ASW675 Series 3
Cables: Nordost Super Flatline MKIII
Video: Optoma HD25-LV, 140" Black Widow screen
Sources: Custom built XBMC/Plex HTPC, PS4, Xbox 360, FreeSat HD & Saorview HD
kevpatts is offline
post #15126 of 24403 Old 02-19-2014, 02:37 AM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
Originally Posted by kevpatts View Post
Hey all,
Kevin
All outputs are all active on the player when in use (unless you tell it otherwise in settings).
So, you can use the 5.1 analog output AND the spdif (coax) output at the same time, just simply switch the source input on your Tag manually when you want to switch back and forth.
I have no idea how good the Tag's DAC is, but think you will be quite pleased with how the 103 sounds. It's actually pretty good.
Smarty-pants is offline
post #15127 of 24403 Old 02-19-2014, 02:42 AM
kevpatts's Avatar
Thanks man, that's good to know. The Tag, even though it hasn't been made in a decade of so now, is still considered one of the best receivers out there for it's DACs.
kevpatts is offline
post #15128 of 24403 Old 02-19-2014, 04:39 AM
Ganymed4's Avatar
Quoted: 104 Post(s)
Liked: 80
I am still looking for an App, which allows to remote control the Oppo and allow me access to shares and play them via the Oppo. The OppoMedia App is something but it works only with local USB drives, connected directly to the Oppo and not network drives.
To explain this in more detail: I would like to play Music from my DLNA network shares to the Oppo and control this - choose the e.g. music - via an Android App.
I can do this with my AVR -
Stop, the solution just comes to my mind: A DLNA Server App on Android.This might work. I just tried playing music from an Android phone connected to the same LAN/WiFi network than the Oppo. This worked flawlessly.
The DLNA Server App showed the Oppo 103 as a media renderer but also listed all other DLNA sources in the network. I haven't tried it yet but following the logic of media source and media renderer, this DLNA App might be able to initiate playing files from a media source to a media renderer.
FYI, I was using the 'Bubble DLNA Server' from GooglePlay store. There are other DLNA server Apps in the store which might do as well. I haven't tried. I will post results here.
Ganymed4 is online now
post #15129 of 24403 Old 02-19-2014, 04:55 AM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
I personally do exactly this using the Mediahouse app on my android tablet, I select my pc's ps3 media server, then my oppo 103d as the play-to device, browse my files and play them one at a time or I can set them up in a queue.
There is a free version of it, so no harm in trying it out.
There are other apps out there just search UPNP\DLNA and you should find a fair selection.
TorTorden is offline
post #15130 of 24403 Old 02-19-2014, 04:59 AM
Ganymed4's Avatar
Quoted: 104 Post(s)
Liked: 80
Yes, thank you and it also works for me. Stupid me, I should have tried this earlier. Thank you TorTorden.
post #15131 of 24403 Old 02-19-2014, 06:31 AM
jake51's Avatar
Quoted: 62 Post(s)
Just to be absolutely sure: Can the supplied WiFi dongle be used to wireless Netflix?
jake51 is offline
post #15132 of 24403 Old 02-19-2014, 06:37 AM
mpalmieri1203's Avatar
Liked: 44
Sure can!
mpalmieri1203 is offline
post #15133 of 24403 Old 02-19-2014, 06:55 AM
Quoted: 747 Post(s)
Liked: 623
^Anything that requires a network connection can be done over a hardwired connection OR with the wireless dongle.
post #15134 of 24403 Old 02-19-2014, 07:50 AM
jake51's Avatar
Quoted: 62 Post(s)
jake51 is offline
post #15135 of 24403 Old 02-19-2014, 10:21 AM
goshjosh08's Avatar
This may be a silly question, but I was wondering if the 7.1 audio out from the oppo 103 is superior to the HDMI out. I also have an Onkyo TX NR818 and am just trying to get the best audio and video. From the replies I am reading it seems best to use the video processing of the Oppo and sending one HDMI out to my TV and then sending the audio to the Onkyo for audio processing. What are your thoughts??
goshjosh08 is offline
post #15136 of 24403 Old 02-19-2014, 10:22 AM
AlexanderDelarg's Avatar
Quoted: 151 Post(s)
Liked: 170
If you have a capable receiver it is best to let the Oppo handle the video and the receiver to handle the audio. If the receiver is much older, then the Oppo may be the better option for both.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #15137 of 24403 Old 02-19-2014, 10:23 AM
goshjosh08's Avatar
Is it better to use the HDMI outs or the 7.1 audio outs??
post #15138 of 24403 Old 02-19-2014, 10:27 AM
Quoted: 151 Post(s)
Liked: 170
HDMI 1 for video and HDMI 2 for audio I believe. I am not an expert with the Oppo as I have just received mine but have read quite a bit of the threads here on the Oppo. Let the experts chime in too.
post #15139 of 24403 Old 02-19-2014, 10:27 AM
goshjosh08's Avatar
Ok thank you!
post #15140 of 24403 Old 02-19-2014, 11:12 AM
Quoted: 747 Post(s)
Liked: 623
There can be several reasons to use analog audio, like if you have an older avr that doesn't accept hdmi.
Some people also like to use analog audio no matter what, but when you do, it's best to have a well treated room for sound.
With modern AVRs, they use special digital sound correction software like Audyssey, and if you have such a capable device,
then it's best for most people to use that software to get the best sound from audio via HDMI.
In your case I would recommend using the hdmi for audio. The TX-NR818 is made specially for that type of configuration.
goshjosh08 likes this.
post #15141 of 24403 Old 02-19-2014, 11:12 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1066 Post(s)
Liked: 1026
There's no need to use both HDMI outputs unless you have a specific need to. Some examples where you may need to:
1) You have a display that's 3D capable, but your AVR isn't.
2) You have an AVR that doesn't have a video passthrough mode or still does some amount of video processing even when in passthrough mode.
3) You have an AVR that can process DSD (the 103's HDMI1 output can't pass DSD, the 103D does not have this limitation).
In these cases, it makes sense to send the Oppo's HDMI1 output to the display, the Oppo's HDMI2 output to the AVR, and configure the Oppo for split A/V. In most other cases, just send the Oppo's HDMI1 output to the AVR, the AVR's HDMI output to the display, and configure the AVR for video passthrough mode on the input the Oppo is connected to in order to keep things as simple as possible.
ril850 and goshjosh08 like this.
gsr is online now
post #15142 of 24403 Old 02-19-2014, 11:16 AM
goshjosh08's Avatar
If I got the Oppo 105, would it have better video and audio processing vs my Onkyo? Should I run the Onkyo out to the Oppo and then back?
post #15143 of 24403 Old 02-19-2014, 11:20 AM
goshjosh08's Avatar
Ok thank you GSR
post #15144 of 24403 Old 02-19-2014, 11:21 AM
Quoted: 747 Post(s)
Liked: 623
It will only have better ANALOG audio. ...and again, in your case hdmi digital audio would probably be your best choice.
When it comes to digital audio and video processing, the 103 and 105 are virtually identical. So the best choice for you would most likely be the 103.
post #15145 of 24403 Old 02-19-2014, 12:04 PM
pbarach's Avatar
Quoted: 322 Post(s)
Liked: 194
The only audio advantage for HDMI2 is that it can send DSD signals to your AVR. You only get DSD from SACDs. And you lose the ability of your AVR to apply room correction such as Audyssey when DSD signals are coming in.
pbarach is offline
post #15146 of 24403 Old 02-19-2014, 12:52 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2034
I haven't seen a Bob Pariseau post for three weeks. Anyone know anything?
htwaits is offline
post #15147 of 24403 Old 02-19-2014, 01:07 PM
bwillcox's Avatar
Quoted: 352 Post(s)
Liked: 169
Perhaps that (loss of room correction) depends on your AVR or preamp. With the Yamaha units I own the DSD signal is first converted to PCM for such processing. Only when in Pure Direct mode will the DSD signal be converted directly to analog. But then, Pure Direct never applies room corrections, bass managment, or DSP effects anyway.
Bob
1) JVC DLA-X750, Yamaha CX-A5100, Outlaw Audio 7900 & 7700, Oppo UDP-203, Roku Ultra, Sony HAP-Z1ES
2) Sony XBR-75Z9D, Yamaha RX-A3050, 2xOutlaw Audio 2200s, Oppo UDP-203, Roku 4, Sony HAP-Z1ES
3) Sharp LC-70UH30U, Yamaha RX-A2050, Oppo BDP-103, Roku 4
bwillcox is online now
post #15148 of 24403 Old 02-19-2014, 01:12 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
Nope. Anyone have his number to check on him?
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #15149 of 24403 Old 02-19-2014, 01:18 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2697 Post(s)
Liked: 1924
Bob's well, but has been moving during the ice storms. He says his cables myteriously relocate from box to box, but once he gets the new wall treatments done he'll be back.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #15150 of 24403 Old 02-19-2014, 01:24 PM
Robinson ------'s Avatar
He is in Sochi.
JVC rs4810 (115)
Pioneer Kuro-9gen (50)
Oppo 103d
Marantz sr7001
Klipsch rb81/rc62/rs52
Robinson ------ is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
