Official OPPO BDP-103 Owner's Thread - Page 517 - AVS Forum | Home Theater Discussions And Reviews
 877Likes
post #15481 of 24511 Old 02-26-2014, 10:54 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2796 Post(s)
Liked: 2023
Originally Posted by Sebring1 View Post
I cannot find any reset or restore factory settings anywhere in the menus for either my 103 or 105. There is a settings management for backing up settings to a USB stick and reloading them. When I installed the latest firmware there were three optional installations which I did. It did not reset my settings. Last night I had to unplug the 103 and plug it in again to get it to work at all. it would not work by turning it on and off several times. The 105 usually has to be turned on and off twice to load discs (DVD or BD.)
There is more than one screen of settings; are you scrolling down to see all the options?
Here is an outline of the Setup Menus: http://watershade.net/wmcclain/BDP-103_Settings_Checklist.html
Do you not see all those options on your player?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #15482 of 24511 Old 02-26-2014, 11:12 AM
Sebring1's Avatar
Setup Menu > Device Setup > Reset Factory Defaults
It is not there.
Sebring1 is offline
post #15483 of 24511 Old 02-26-2014, 11:13 AM
Sebring1's Avatar
-Bill
It is not there. I scrolled all the way down.
Sebring1 is offline
post #15484 of 24511 Old 02-26-2014, 11:18 AM
wmcclain's Avatar
Liked: 2023
Contact OPPO support.
-Bill
post #15485 of 24511 Old 02-26-2014, 11:40 AM
Sebring1's Avatar
I downloaded the firmware again from the support page, reinstalled and now the factory reset options show up. Hopefully this will resolve the startup issues as well.
Sebring1 is offline
post #15486 of 24511 Old 02-26-2014, 12:30 PM
William Moore's Avatar
Help again! I turned on my player for the first time after connecting the cat5 cable, and once the player powered up, it did a firmware upgrade and gave me the option of doing a reset to factory defaults, which I chose to do. Then the player powered down by itself, so I waited about a minute to see if it would power back up, but it didn't so I turned it on, pressed "open" on the remote and the drawer opened but then it immediately closed. I pressed "open" again and the drawer opened and then immediately closed. I turned off the player, waited a few seconds, turned it back on and pressed "open," the drawer again opened and also closed by itself. I recall reading something about this on the forum awhile back but I can't remember what the fix is. I have also contacted Oppo about this. Any ideas what might be wrong?
William Moore is offline
post #15487 of 24511 Old 02-26-2014, 12:39 PM
wmcclain's Avatar
Liked: 2023
Are you using the OPPO remote? Does it do the same thing if you use the buttons on the front of the player?
-Bill
post #15488 of 24511 Old 02-26-2014, 12:56 PM
-Bill
Problem solved, apparently. I discovered that i had failed to remove the clear vinly sheet which covers up the display AND the drawer. Stupid! So the drawer wasn't opening at all but from across the room I couldn't tell that. I peeled off the cover and then everything was OK. I hope that this didn't screw something up inside, but that explains why the player went into the "close" mode right away.
post #15489 of 24511 Old 02-26-2014, 01:04 PM
AlexanderDelarg's Avatar
Quoted: 152 Post(s)
Liked: 173
That's good news, nothing serious at all, just new owner error.  I am a new owner myself so don't feel bad. Welcome to the club.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #15490 of 24511 Old 02-26-2014, 01:26 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2565 Post(s)
Liked: 3235
. . . .I hope that this didn't screw something up inside, but that explains why the player went into the "close" mode right away.
No harm done. The Tray has a safety switch. In case it can't open fully, such as due to running into the door of a cabinet, it closes again.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #15491 of 24511 Old 02-26-2014, 01:54 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Originally Posted by rexdragon View Post
99% of the time this behavior can be attributed to the actual files themselves and NOT the player. I too have a usb 4tb hd which contains digital movie files (mkv, avi, mp4) and when the hd is attached to my Sony bluray player (S790), 20% of my files exhibit the exact same behavior you're describing. However, when the hd is attached to the oppo, 100% of my files is playable with no problems. Apparently, when the digital file is encoded with a codec (video and/or audio) that is incompatible with the player's decoder (any blu ray player is basically a computer with an optical drive) then you're gonna have playability problems.
As for your Avengers disc's strange behavior (sometimes it works, sometimes it doesn't), it sounds more like there may be a problem with your player's optical drive system (dirty or an actual malfunction) which means it requires servicing. Good luck mate!smile.gif
I guess I am going to have to convince my wife that the s790 has got to go, as I have the same issue when network streaming .mkv's with dtsma/dts 7.1.
Calling sony to ask if the s6200 would solve this issue gets me no where, and it appears that the oppo 103 handles this task perfectly 100% of the time.
is amazon still the best price to grab this guy at?
thank you!
wase4711 is offline
post #15492 of 24511 Old 02-26-2014, 01:59 PM
OK. Now I have another issue. I connected both the player's HDMI outs to my Marantz receiver, with #1 going thru the BluRay input and #2 going into another HDMI input. I wanted to have the video from that second output so I could pair it with the 7.1 analog outputs of the player, just to have that second playback option. Well, with both outputs of the player connected, by default apparently, the player goes into "Split AV Mode" with video only coming from #1 and audio only coming from #2. So, I was getting no audio on my BluRay input of the receiver. And then, according to the book, if I switch to "dual Display" mode, the surround sound may be downmixed to stereo. What's up with that? And, is there any way around this, or will I have to use an HDMI splitter from #1 out so I can feed the full audio and video signal into separate inputs on my receiver? I just don't understand why Oppo configured both outputs that way.
post #15493 of 24511 Old 02-26-2014, 02:02 PM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 289
You don't have to configure it that way. All outputs are active on the Oppo so just connect one HDMI cable to your AVR and analog outs from your Oppo to the appropriate inputs on your AVR. Then you merely need to switch the AVR to choose either HDMI audio or analog audio.
JazzGuyy is offline
post #15494 of 24511 Old 02-26-2014, 02:20 PM
Quoted: 152 Post(s)
Liked: 173
thank you!
Amazon - $499 with free 2 day shipping if you are an Amazon Prime member. The warranty applies as Amazon is an authorized OPPO seller.
wase4711 likes this.
post #15495 of 24511 Old 02-26-2014, 02:22 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
When I ordered my oppo from amazon, at the time, I was not a prime customer so I just selected free shipping 5 days. But then it showed up at my house in 2 days. I was very happy. smile.gif
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
post #15496 of 24511 Old 02-26-2014, 02:26 PM
Quoted: 152 Post(s)
Liked: 173
Nice.  I do enjoy using Amazon for many purchases that run a a wide gamut.
post #15497 of 24511 Old 02-26-2014, 02:40 PM
flinchn's Avatar
Quoted: 138 Post(s)
Liked: 202
Originally Posted by Bob Pariseau View Post
HDMI 1 output in the 103 uses the QDEO video processing, HDMI 2 output does not. Most people use HDMI 1 for video. Most also use HDMI 1 for audio, but some cable both outputs with HDMI 2 going to their AVR for audio and HDMI 1 going direct to the Display. For more info on the QDEO processing I'd suggest looking at the FAQ for the 103 -- the link will be found at the top of the first post of this thread.
--Bob
Apologies if I'm wrong or this is a beaten horse:
I think I read somewhere that HDMI2 was preferable by some as the primary video output since by bypassing the chip you mention it defeats some noise reduction (I think that was it)? And other people using HDMI1 bumping up sharpness to +1 to help against it?
I'm on HDMI1 because I like the picture just fine on my Sony 4k, but I always have open ears for improvements.
flinchn is offline
post #15498 of 24511 Old 02-26-2014, 02:43 PM
flinchn's Avatar
Quoted: 138 Post(s)
Liked: 202
Originally Posted by lujan View Post
I don't know if you will come across this.
Happened on Gravity 3d. I think it's something in my chain, possibly my darblet. But as long as I can force it, no problem. Good guy oppo: allows a workaround for touchy 3d flags!
flinchn is offline
post #15499 of 24511 Old 02-26-2014, 02:54 PM
ray0414's Avatar
Quoted: 9605 Post(s)
Liked: 8098
in your experience does the oppo 103 in general have less digital noise than standard blu ray players without losing detail/depth?
65KS9800 *new*. 65JS9500 4K HDR and lots of it!
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
Review of KS9800vsJS9500 w/side by side pix: http://www.avsforum.com/forum/166-lc...l#post45720113
ray0414 is online now
post #15500 of 24511 Old 02-26-2014, 03:10 PM
flinchn's Avatar
Quoted: 138 Post(s)
Liked: 202
Can't tell you. Coming from an oppo 83
flinchn is offline
post #15501 of 24511 Old 02-26-2014, 04:03 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Bump - can anyone tell me if the BDP-103 supports 3D MKV files?
Originally Posted by BobearQSI View Post
I had thought I read somewhere that the current firmware supports playing 3D Blu-rays on MKV.
I bought Gravity 3D today, and just wanted to test the 3D MKV feature. I ripped to an MKV using the latest MakeMKV downloaded today. The only video option was the 3D track. After ripping, the output MKV file says in media info:
Code:
Video
Format             : AVC
Format/Info        : Advanced Video Codec
Format profile     : Stereo High@L4.1 / High@L4.1
MultiView_Count    : 2
I'm playing over my network via SMB. However, the video is not in 3D. Putting the disk in the Oppo, it plays in 3D. Is this supported? If so, how do I get it to use the 3D from the MKV?
BobearQSI is offline
post #15502 of 24511 Old 02-26-2014, 04:03 PM
thehun's Avatar
Quoted: 651 Post(s)
Liked: 544
Originally Posted by SeeMoreDigital View Post
Out of interest... Is there any particular reason why the Oppo does not support playback of Meridian Lossless Packed (MLP) PCM streams?
I realise that MLP is a proprietary technology, but it is used for packing Dolby TrueHD audio streams, which can be played by the Oppo!
Are you referring to the USB input? It certainly plays back DVD-A discs with internal decoding of MLP, but it won't stream it to outside decoding, for lack of hardware [Except a handful of Meridian controllers] and licensing issues.
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #15503 of 24511 Old 02-26-2014, 04:14 PM
lujan's Avatar
Quoted: 2022 Post(s)
Liked: 820
I don't have the darblet so maybe it won't happen to me?
lujan
138 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #15504 of 24511 Old 02-26-2014, 04:40 PM
Has anyone actually viewed the video coming from HDMI #2? I'm thinking of running it directly to my display and plugging it into my DVI adapter for the video and then pairing this with the 7.1 analog inputs. That way, it wouldn't matter what the Oppo did to the audio coming from #2, as along as it left the audio from output#1 intact. Right?
post #15505 of 24511 Old 02-26-2014, 05:05 PM
DrMichael's Avatar
Quoted: 86 Post(s)
Liked: 52
Question....I am selling my 103 to my father and was wondering if he should use the oppo to process his video? He has a 5 year old Onkyo AVR and my thought was the video processor would be more up to date than the Onkyo.
LG OLED e6 65
McIntosh MX160 precessor / McIntosh MC8207 amp
Martin Logan Motion 50XT Center
Martin Logan Motion 60XT Fronts / 40 Rears
SVS PB13-Ultra (2)
Oppo UDP-203/Furman ELITE-20 PF /Playstation 4/ Apple TV/Nintendo Switch
DrMichael is offline
post #15506 of 24511 Old 02-26-2014, 05:26 PM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 319
Make sure you are are on INPUT BLU-RAY and that you have no disc in the player. Go into Setup Menu, Device Setup, then press the UP arrow key. Do you see Reset Factory Defaults highlighted or is the player still skipping this option?
Neuromancer is offline
post #15507 of 24511 Old 02-26-2014, 05:36 PM
Sebring1's Avatar
I went to the Oppo support page, downloaded the firmware again and reinstalled it. The reset settings now show up.
Sebring1 is offline
post #15508 of 24511 Old 02-26-2014, 06:27 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I think I am ready to pull the trigger on this oppo, since I cant stream mkv/dts ma/7.1 properly through my s790 sony;
since I am using a pioneer sc-25, which is only hdmi 1.3a, should I run the video through hdmi 1, and run the audio through hdmi 2 out to my Pioneer, or just run i hdmi cable from the oppo to the pioneer?
I am not sure if I can get 4k upscaling if I dont run a seperate hdmi directly to the SonyTV
I assume I can get 7.1/dts-ma streaming from my network server, through the oppo, doing it this way..
thanks!
wase4711 is offline
post #15509 of 24511 Old 02-26-2014, 08:07 PM
KC-Technerd's Avatar
Quoted: 73 Post(s)
Liked: 137
I have. With my system it is very easy to switch between the video from HDMI 1 and HDMI 2. I have not yet been able to positively discern any difference in the image quality from Blu-ray discs between the two.
KC-Technerd is offline
post #15510 of 24511 Old 02-26-2014, 08:14 PM
Quoted: 73 Post(s)
Liked: 137
If you're using the 7.1 analog outputs on the Oppo to your audio system, the audio from both HDMI outputs would be inconsequential.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
