Official OPPO BDP-103 Owner's Thread - Page 523 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #15661 of 24422 Old 03-05-2014, 07:20 AM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
Thanks Bob I have only had my 103 a month and love it just have to get this issue fixed. How do you suggest cleaning the laser lens?
tyler webb is offline
post #15662 of 24422 Old 03-05-2014, 07:26 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2315 Post(s)
Liked: 2900
If it is just dust, there's a brushless cleaning disc you can use. Holes in the disc produce air turbulence. Others have used a squirt from a can of clean compressed air -- the type sold for cleaning camera lenses.
If the lens has picked up a film (oil particulates or smoke) then those won't work. Instead, remove the chassis lid, unclip the protective top plate on the optical drive. The two small lenses will be visible pointing up. Gently clean them with a Q-tip barely moistened with alcohol. While you are in there check for dust.
OPPO can also do this for you at modest cost, and if the lens is NOT the problem, then of course they'll fix it (warranty).
Give them a call if you need assistance either way.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #15663 of 24422 Old 03-05-2014, 07:41 AM
chileboy's Avatar
Originally Posted by dmusoke View Post
I have a problem that has eluded me for a past few firmwares on my BDP-105... I can't seem to get audio when my 105 is set to BITSTREAM. LPCM works fine. AUTO behaves like BITSTREAM. My pre-pro is the Anthem D2v... All units have the latest firmwares.
I'm having the same issue since the latest firmware update...and my pre/pro is an Anthem AVM50. Happens on standard DVDs also.
Maybe yours started exhibiting the symptoms earlier because you install the beta FWs? I generally only do the official releases, and the previous official did not do this.
I discovered that, if I start the disc playing, then go into the Anthem Source Setup, and then back out (don't need to actually change anything), it will solve the issue (I believe as long as the Oppo isn't turned off), so it seems to be some sort of handshaking issue.
- Mark
chileboy is offline
post #15664 of 24422 Old 03-05-2014, 07:47 AM
votru's Avatar
Question - play mp3 music via USB, OPPO output 2-channel only like Ipod direct connect to the AVR or 5.1? Try to eliminate mine old Sony 200 cd carousel and a Sony Blu-ray player that play ok music when listen to a cd. Sorry if already answer and thanks in advance.
votru is offline
post #15665 of 24422 Old 03-05-2014, 07:49 AM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
Bob is there a cleaning disk that you recommend? Looked for just a second on amazon but did not see any BRUSHLESS cleaning disk. My home is smoke free so i cant be smoke oil.
post #15666 of 24422 Old 03-05-2014, 07:55 AM
chileboy's Avatar
I found a couple of posts that seem to indicate the unit has discreet on/off - is there any way to "learn" it from the remote?
I have an older Home Theater Master MX-700 remote (which I still love) but there haven't been updates to the codes database for a long time.
- Mark
chileboy is offline
post #15667 of 24422 Old 03-05-2014, 08:01 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2713 Post(s)
Liked: 1942
- Mark
The older model remotes had the discrete on/off buttons but the current one doesn't. They were removed to make way for other things.
Can you enter codes directly into your MX-700? OPPO has a spreadsheet on their support pages listing the values.
Or does your database have the BDP-83? The old codes are the same and you could learn the new buttons from the current remote.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #15668 of 24422 Old 03-05-2014, 09:15 AM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
If you buy a cleaning disc, this is the one you want. It uses air and not brushes that can damage lasers.
http://www.newegg.com/Product/Product.aspx?gclid=CMHKpPXm-7wCFaVQOgod4DkAzw&Item=N82E16827994036&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-CD+%2f+DVD+Accessories-_-N82E16827994036&ef_id=UxdOPwAABVhWAsbn:20140305162251:s
Smarty-pants is offline
post #15669 of 24422 Old 03-05-2014, 09:50 AM
rdgrimes's Avatar
Quoted: 2011 Post(s)
Liked: 1344
Yes all my HDMI cables are new and highspeed.
Nevertheless you are describing a HDMI cable issue. New cables can be bad too. I'd start by swapping in a different cable from player to AVR and also from AVR or player to TV. Its an easy test to rule out the cable.
rdgrimes is online now
post #15670 of 24422 Old 03-05-2014, 11:05 AM
chileboy's Avatar
- Mark
-Bill
There isn't a way (that I know of, anyway) to directly input the codes. But, that is a good idea about seeing if one of the older Oppo models is in the database. The way the software works, I could add that as a separate unit, and then reference the on/off codes, without actually making it visible on the remote (when I first got the BDP-103, I simply learned every button). I will try this tonight.
Thanks Bill!
- Mark
chileboy is offline
post #15671 of 24422 Old 03-05-2014, 11:18 AM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
I don't think it a HDMI handshake issue because this always happens like 10 minutes into a blu ray. The handshake issue would start immediately right. My thinks is once the handshake is complete and the signal it there it should not cut out again. But I am not an expert.
post #15672 of 24422 Old 03-05-2014, 11:24 AM
rdgrimes's Avatar
Liked: 1344
Actually, that's exactly what a bad cable can do. HDCP handshakes occur regularly throughout a BD.
Point being that one should never assume a cable is good, you have to test it out by swapping. Many problems are resolved this way and its the first thing Oppo support will ask you to do.
Further steps should include making all settings explicit, no "auto" settings, this simplifies handshakes. You can also test a cable's bandwidth capability by turning off deep color or even lowering video output to 720p and see if the issue still happens. If problems still exist: change the way the player is connected - if it's a one-cable connection to AVR, try a 2-cable connect with HDMI-1 to TV and HDMI-2 to AVR. If it's already a 2-cable connect, try the opposite.
Take this from someone who's spent many frustrated hours trying to track down a problem only to have it mysteriously vanish with a cable swap.
post #15673 of 24422 Old 03-05-2014, 11:40 AM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
Thank you! I will do some cable swapping tonight and report back.
post #15674 of 24422 Old 03-05-2014, 12:05 PM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
What brand HDMI cables do you guys think are the most reliable?
post #15675 of 24422 Old 03-05-2014, 12:16 PM
wmcclain's Avatar
Liked: 1942
Forum sponsors Monoprice and BlueJeansCable are perennial favorites. You can get much more feedback in the HDMI forum.
-Bill
post #15676 of 24422 Old 03-05-2014, 12:17 PM
Jed1's Avatar
Quoted: 109 Post(s)
Liked: 59
HDMI cables from AVS forum sponsor Blue Jeans Cables is the best route you can go. I have been using HDMI cables from Blue Jeans for almost a decade now I have never had any issues with them.
http://www.bluejeanscable.com/
http://www.bluejeanscable.com/store/hdmi-cables/hdmi-cable.htm
I would not waste my time with anything else. I started using HDMI in 2004 with my first HDTV (an RCA DLP TV) and up till this day never experienced any failures with any HDMI connected equipment.
"You lose it in here you're in a world of hurt"
Jed1 is online now
post #15677 of 24422 Old 03-05-2014, 12:18 PM
gwsat's Avatar
Quoted: 2190 Post(s)
Liked: 2429
-Bill
You beat me to it. I have had good luck with cables from Monoprice, as have many other AVS members.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
post #15678 of 24422 Old 03-05-2014, 01:44 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2035
Our home is smoke/oil free, but the region where we live isn't. In any case, I've never needed to clean our OPPO 93. Go figure. wink.gif
htwaits is online now
post #15679 of 24422 Old 03-05-2014, 01:53 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2035
Don't forget the tip to change all "auto" settings to explicit settings. Anything that reduces the complexity of a HDMI path is worth the effort.
post #15680 of 24422 Old 03-05-2014, 02:51 PM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
Ordered these cables of amazon you guys check them out. I think they cover every format.
http://www.amazon.com/gp/aw/d/B0089DTVAK/ref=redir_mdp_mobile?ref_=pe_385040_30332200_pe_309540_26725410_item
wase4711 likes this.
post #15681 of 24422 Old 03-05-2014, 03:34 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
wase4711 is offline
post #15682 of 24422 Old 03-05-2014, 03:41 PM
tyler webb's Avatar
Quoted: 119 Post(s)
Liked: 41
Originally Posted by wase4711 View Post
Great maybe this will fix the problem!
post #15683 of 24422 Old 03-05-2014, 03:42 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
If overpaying for cables was your problem, this definitely will fix that!!!
Any thing else, you're on your own..
wase4711 is offline
post #15684 of 24422 Old 03-05-2014, 04:08 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
I use Monoprice HDMI with Redmere.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #15685 of 24422 Old 03-05-2014, 09:21 PM
jszei's Avatar
Quoted: 17 Post(s)
Originally Posted by Bob Pariseau View Post
^ What you are describing is usually due to out of whack, automatic gain/contrast control in the Display. In some Displays this happens at certain age points, where the control is trying to adjust for aging (poorly).
Check the owner's thread here for your Display to see if this is a known problem.
--Bob
Originally Posted by jszei View Post
My display is a new Sony vplhw50es projector professionally calibrated by Jeff Meier.
I didn't have this issue with my OPPO before the latest firmware release. I have watched the same scenes on my Xbox One through the same prepro and projector with no issue.
Saving Private Ryan is a good example when this occurs as it is fairly frequent and pronounced.
Has no one else experienced even subtle flashing in white areas while watching a bluray?
Digital chain: Synology DS1815+ -> Custom PC (Windows 2012R2 AO, Fidelizer, Roon, HQPlayer, JRiver) -> microRendu -> Audio Alchemy DDP1 and PS-5 -> Emotiva XPA-5 -> B&W 803s
Analog chain: Project RPM 3 Carbon with Blue Point #2 -> Moon 110LP -> Audio Alchemy DDP1 and PS-5 -> Emotiva XPA-5 -> B&W 803s
Theater: Marantz AV7701, Sony VPL-HW50ES
jszei is offline
post #15686 of 24422 Old 03-05-2014, 10:27 PM
Quoted: 747 Post(s)
Liked: 623
I watched both Rush and Captain Philips over the past 2 days and didn't notice anything like that... just hi-def bliss.
post #15687 of 24422 Old 03-05-2014, 10:44 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 141
I have the following settings in the Oppo 105:
Dual HDMI output -> Split A/V.
3D Output -> Auto (though my plasma is 2D only).
Color Space (HDMI1/HDMI2) -> RGB Video Level .... (I have a Pioneer KURO plasma).
Deep Color  (HDMI1/HDMI2) -> 30 bits.
HDMI Audio -> LPCM ( as BITSTREAM doesn't work).
The above problem only occurs when i play BD/DVDs. I run my cable box through the Oppo hdmi input and output to my D2v and the bitstream setting works fine in this case.
Any takers?
Why are you complicating things by using dual cabling since you don't have a 3D display? You should have no problem passing video through your D2v.
--Bob
I don't understand your quesiton Bob. I only have one hdmi cable from the D2v to my plasma display. I have 1 hdmi cable input to the BDP-105, namely the cable box hdmi cable. The 2 HDMI outputs of the 105 go to 2 HDMI inputs of the D2v. I use one for 24p movies and the other for 30i movies. Should my Oppo setting change from "Split A/V" to "Dual Display"? As you know, i can only pick or the other:)...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #15688 of 24422 Old 03-05-2014, 10:57 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 141
3D settings are irrelevant in this case as i had it to OFF before the recent FW upgrade and it behaved the same. My cables are high speed as i have a redmere cable to my display.
The video and audio paths are the same for the HDMI inputs and the BD/DVD functions, so why does bitstream work fine on HDMI inputs (albeit with lossy DD from my cable box) and doesn't work fine when BD/DVDs are playing?
I will try setting DC to OFF but all this used to work just fine back in the day...
If it's a band width problem, each source can have different requirements. I'm not sure what Bob will suggest but here is one of his HDMI posts. Think of his suggestions as a diagnostic guide line. One part of diagnosis is to simplify the setup as much as possible. The suggestions I made were for simplification. Remember that all devices in the HDMI chain communicate with each other as a part in establishing a working connection. Your Redmere cable is only one part of the total HDMI path that must function correctly.
Bob Pariseau Suggestions
HT:
I appreciate Bob's suggestions which i read when you posted them earlier yesterday. It seems another poster has the same problem as i have except that he has the AVM50v processor. I will try to force a handshake as he suggested.
dmusoke is offline
post #15689 of 24422 Old 03-05-2014, 11:00 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 141
- Mark
Mark...thanks for the headsup:)!
dmusoke is offline
post #15690 of 24422 Old 03-05-2014, 11:19 PM
Read the FAQ!
Liked: 2900
During playback, Copy Protection kicks in every few minutes to recheck things. Normally this happens in the background and you don't even know it is going on. But if it fails, then an HDMI retry is triggered -- meaning loss of audio and video for at least 2 seconds. If you have failures that repeat periodically -- minutes apart -- each lasting for a couple seconds, that would be strong evidence of cabling problems. (Copy Protection is finicky; it LIKES to fail.)
--Bob
Auldian likes this.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
