Official OPPO BDP-103 Owner's Thread - Page 538 - AVS Forum | Home Theater Discussions And Reviews
 904Likes
post #16111 of 24674 Old 03-30-2014, 05:50 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by LairdWilliams View Post
so what happens when you use the JRiver DLNA server (with transcoding off) instead of the one built into the Synology?
I get a "file type not supported" message, on both the converted BR movie and the DVD tracks.
edorr is offline
post #16112 of 24674 Old 03-30-2014, 05:56 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by wmcclain View Post
Could we see the mkvinfo or mediainfo results for both types of file?
-Bill
I cannot get s screenshot somehow, but they both say the exact same thing:
First Audio Stream
English 48.0 KHz, 6 channels AAC (LC)
edorr is offline
post #16113 of 24674 Old 03-30-2014, 06:34 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3013 Post(s)
Liked: 2288
First Audio Stream
I think both tools allow text output.
The fact that you get the same behavior on USB is revealing, meaning network servers are not the issue (yet).
Contact OPPO support, send the text output of one of the tools, and offer them sample files.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #16114 of 24674 Old 03-30-2014, 07:42 AM
mcleanda's Avatar
Has anyone used the Superdisc software mod to make their player DVD multi region with the latest firmware upgrade from Oppo.
Main Version: BDP10X-70-0218
Loader Version: 6U1000 or 7B1300 (BDP-103), 7B1300 (BDP-105, BDP-105D, BDP-103D)
Sub Version: MCU103-05-0916 (BDP-103), MCU105-04-1113 (BDP-105), MCU13D-01-0618 (BDP-103D), MCU15D-01-0930 (BDP-105D), DB10X 131030 (BDP-103D, 105D)
I have a 103 and would like to try this but would like some feedback before I do.
David
mcleanda is offline
post #16115 of 24674 Old 03-30-2014, 08:10 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
A file type not supported message received from the DLNA server would generally mean that the player/renderer (the Oppo in this case) has told the DLNA server that it can't handle the encoding or format of the file you are attempting to play. This would explain why every attempt by you to use the Oppo to play the file, whether over the network or on locally-attached (USB) storage, is failing.
A) Note than in all of the following cases, the Oppo is actually unpacking, decoding, and "playing" the file:
1) Play file over network through Synology NAS (DLNA)
2) Play file on USB drive attached to Oppo USB Port
3) Play file over network through JRiver Media Center's DLNA subsystem. ("Media Network")
B) Meanwhile, when you play the file on your PC using JRiver, it works. Please note that this is not the same operation as 1-3 above. In this mode, it is JRiver on the PC that is doing the unpacking, decoding, and playback - not the Oppo.
So, from (B) above, we can conclude that there are no problems with the file itself. It is not a problem with encoding or formatting errors of any kind, since this would result in failures for both (A) and (B). Since we do not see a failure in (B)...
So the problem must be some basic incompatibility between the file being used and the playback mechanism in the Oppo. Sounds like you need to send the detailed information to Oppo (as others have recommended) and see what Oppo has to say about it.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #16116 of 24674 Old 03-30-2014, 08:25 AM
rdgrimes's Avatar
Quoted: 2237 Post(s)
Liked: 1573
David
It should work just fine.
rdgrimes is offline
post #16117 of 24674 Old 03-30-2014, 09:15 AM
mcleanda's Avatar
Thanks will try it today and post the results on the forum
mcleanda is offline
post #16118 of 24674 Old 03-30-2014, 09:39 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Bit more troubleshooting with weird results.
If I rip a track from a Blu Ray with PavTube bytecopy to MKV / AAC it plays MCH just fine. If I rip with the exact same settings from a DVD the track shows the same codecs (AAC), but it plays 2 channel.
If I rip a track from that same DVD to MKV / AAC using handbreak, it will play in 2 channel as well. If I set handbreak to DTS Pass Thru, the track plays MCH. All this is in Oppo. In Jriver everything plays MCH.
Problem is, ripping individual tracks with Handbreak is a lot more work than in PavTube, because you have to create a queue one track at a time, but it may be the only way to get MCH playable individual tracks from DVDs.... Half a days work gone to waste ..... Oh well.
edorr is offline
post #16119 of 24674 Old 03-30-2014, 10:25 AM
mcleanda's Avatar
Just made my Oppo 103 multi region for DVD playback using the Superdisk software mod and the latest Oppo firmware no issues
mcleanda is offline
post #16120 of 24674 Old 03-30-2014, 10:30 AM
JazzGuyy's Avatar
Quoted: 314 Post(s)
Liked: 314
Just made my Oppo 103 multi region using the Superdisk software mod and the latest Oppo firmware no issues
You do realize that that is multi-region for DVD only and not for Blu-Ray. Multi-region Blu-Ray requires a hardware mod.
JazzGuyy is online now
post #16121 of 24674 Old 03-30-2014, 10:33 AM
mcleanda's Avatar
Yes I do was really only interested in multi region for DVD, should have been more specific in my post
mcleanda is offline
post #16122 of 24674 Old 03-31-2014, 12:42 PM
Oscar Berke's Avatar
Will this player support and play the AVCHD 2.0 3D format that Sony, Canon and Panasonic camcorder shoot their native files in (.MVC), without having to convert them to SBS .mkv and lose quality in doing so?
Oscar Berke is offline
post #16123 of 24674 Old 03-31-2014, 12:46 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
google search brings this answer
http://wiki.oppodigital.com/index.php?title=BDP-103
wase4711 is offline
post #16124 of 24674 Old 03-31-2014, 04:51 PM
ronton3's Avatar
Quoted: 56 Post(s)
I have my satellite receiver going to the rear HDMI. I unplugged to reset the receiver and inadvertently, (stupidly) shorted across the plug. Took out the dedicated fuse for the home theatre, crashed the receiver, and took out the HDMI on the 103. The other aspects of the 103 do not seem to be affected. I have an 83 that I use for a vintage audio system where I do not need the HDMI's. I collect and refurbish tube gear but know little about digital. It looks like the HDMI,s are the same in both, can I remove one from the 83 and place it in the 103, is it a soldering job or a plug in. Would I be able to just buy another HDMI and Install it (preferred). Any advice would be appreciated, another option is that if OPPO is soon to come out with an updated model, I would give this one to a family member, who doesn't need two HDMIs, and buy a new one, any rumors. Thanks ron
ronton3 is offline
post #16125 of 24674 Old 03-31-2014, 05:07 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3187 Post(s)
Liked: 4095
^ OPPO has reasonably priced flat-rate service for non-warranty repairs. Your best bet may be to simply let them fix it for you.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #16126 of 24674 Old 03-31-2014, 06:01 PM
ronton3's Avatar
Quoted: 56 Post(s)
Thanks I am considering that, but if it is a simple exchange for the HDMI I would like to try that first.
ronton3 is offline
post #16127 of 24674 Old 03-31-2014, 06:12 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 628
^Yep, contact Oppo directly, and tell them what happened and I'm sure they will work with you on a repair or parts. Best customer support on the planet.
Smarty-pants is offline
post #16128 of 24674 Old 03-31-2014, 08:12 PM
I read this entier thing and did not see anything about AVCHD 2.0 3D, (.MVC file extension) .  I saw only AVCHD, which is 2d as far as I know.  Does this mean this player will not play it?
post #16129 of 24674 Old 04-01-2014, 03:55 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I would contact Oppo directly and ask them then..
wase4711 is offline
post #16130 of 24674 Old 04-01-2014, 05:50 AM
3DFREAK's Avatar
More information, please.
Is this on local USB, network SMB or DLNA?
There are free utilities mediainfo and mkvinfo. Post the text report from either one for one of your problem files.
-Bill
From mediainfo:
Matroska:4.37 GiB, 1hr 45 mn
1 video stream: AVC
1audio stream: DTS
2 text streams: UTF-8 / UTF-8
Writing application:mkvmerge v6.6.0
English, 4 442 Kbps, 1280*720 (16:9) at 23.976 fps, AVC (High@L4.1) ( CABAC / 5 Ref Frames)
From the Oppo:
Shows file on the menu for movies, but no time or resolution info.
Will not play from a shiny disc, but same file will play from a flash drive.
Here is my current gear: Emotiva UMC-200 AND XPA-5, Sony EX55-720 3D TV, Oppo BDP-103 3D Blu-Ray Player, Oppo BDP-93 Blu-ray Ray Player (for Cinavia encrusted copy playback), Polk RTI-12 Fronts, Polk LSiM703 Rears, Polk DSW Pro600, Polk CSI5 Center.
3DFREAK is offline
post #16131 of 24674 Old 04-01-2014, 06:02 AM
wmcclain's Avatar
Liked: 2288
It plays from a USB device but not from an optical disc?
That sounds like a file system issue on the optical disc. What are using to burn the disc, and with what parameters?
I have found that once you cross a certain file size, care must be taken to author the disc correctly or the player won't read them properly.
See recent discussion in the BDP-93 thread:
-Bill
post #16132 of 24674 Old 04-01-2014, 08:42 AM
3DFREAK's Avatar
-Bill
Yes the files play fine from a flash drive.... but not from a disc. I use imgburn and always have. I'll put like 5 or 6 mkv movie files 3-4 GB each on a blank blu -ray disc and the Oppo will see the files and list them, but I'll get the "unsupported file format" message for some of the files. Like it may play the first file and the 3rd but not all.
Now, I'm wondering if the mkv file was made from a region restricted disc. Is it possible these mkv files won't play from a disc but will from a usb flash drive?????? That could be the reason?
3DFREAK is offline
post #16133 of 24674 Old 04-01-2014, 08:47 AM
wmcclain's Avatar
Liked: 2288
No, I would first look at the file system parameters on the optical disc. See the links I posted previously.
-Bill
post #16134 of 24674 Old 04-01-2014, 10:02 AM
rdgrimes's Avatar
Liked: 1573
Its not impossible that the BD disc is simply being burned poorly, making some files unreadable. Suggest you try burning at a lower speed and see if that helps.
rdgrimes is offline
post #16135 of 24674 Old 04-01-2014, 12:03 PM
emmat2011's Avatar
Quoted: 42 Post(s)
I just got cable installed and was wondering how do I hook up the cable box to the Oppo so it can convert the 1080i signal to 1080p? Thanks.
Emmat2011
emmat2011 is offline
post #16136 of 24674 Old 04-01-2014, 12:10 PM
wmcclain's Avatar
Liked: 2288
The manual has a section "HDMI Input to BDP-103". Ask here if anything is not clear.
-Bill
post #16137 of 24674 Old 04-01-2014, 12:19 PM
Mongo171's Avatar
Quoted: 912 Post(s)
Liked: 1344
HDMI from the cable box to the HDMI Input port on the back of the 103. On top of the remote, there is a button for Input. You will need to push the button and select HDMI In Back (#3) for TV viewing.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
post #16138 of 24674 Old 04-01-2014, 12:19 PM
emmat2011's Avatar
Quoted: 42 Post(s)
-Bill
I appreciated , thank you.
Emmat2011
post #16139 of 24674 Old 04-01-2014, 12:24 PM
hernanu's Avatar
Quoted: 638 Post(s)
Liked: 1130
  1. Connect your cable box HDMI output to the HDMI input in the back of the Oppo (103? ) using an HDMI cable.
  2. Connect the Oppo (if it's not already) either to one of your receiver's HDMI inputs or to the TV's HDMI inputs if no receiver using an HDMI cable.
  3. Select the HDMI back input as the source on the Oppo
  4. Select the right HDMI input on your receiver or TV
  5. Kick back and enjoy.
hernanu is offline
post #16140 of 24674 Old 04-01-2014, 12:49 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
The oppo needs to be on correct?
Brian Fineberg is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
