Official OPPO BDP-103 Owner's Thread - Page 550 - AVS Forum | Home Theater Discussions And Reviews
 888Likes
post #16471 of 24590 Old 04-26-2014, 10:58 AM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
Hopp, it really would be better if you just used the multi-channel analog outputs to make the setup easier.
You will also not get the reduced audio bandwidth that the manual describes.
You really shouldn't be getting dropouts though either way, so that is a separate issue.
It sounds like some kind of handshaking issue in your setup.
I would suggest trying to hook up the 5.1/7.1 analog connections and then see if the problem is still there.
If not, then you killed 2 birds with one stone so to speak and are better off.
Realize also, that all of the outputs on the player are active 24/7 unless you have settings prohibiting it to do so.
You could hook up the multi-ch analog output AND also use the coax/optical connections for something else, or as a comparison.
Honestly though, there's no reason not to use the multi-ch analog for all your audio.
Smarty-pants is offline
post #16472 of 24590 Old 04-26-2014, 12:12 PM
JazzGuyy's Avatar
Quoted: 304 Post(s)
Liked: 297
Originally Posted by bweissman View Post
I'm squinting at your photos, but those jacks by the red 3 on your receiver look like preamp OUTPUTs. You can't connect the BDP's output to those jacks.
Yep, looks to me like he has no analog inputs on that unit in which case he is sort of screwed for high-quality audio.
JazzGuyy is online now
post #16473 of 24590 Old 04-26-2014, 12:13 PM
Hopp's Avatar
Thanks for the quick feedback, I really appreciate your input and its help me gain a better understanding of this.
It's been a while since I had to think about anything AV related as my system was serving me well.  But all things must change.
The CRT went out a little while ago and I upgraded to a plasma (Panasonic VT60), got the Oppo on a recommendation from a trusted sales person and just made the simplest connections I could with the Oppo and B&K....  Only realizing I'm going to have to upgrade the AVR after I started hooking things up.
 Dooh!!!  I feel like a total noob - Thanks for pointing out OUTPUT's bweismann - I kept looking at it and it wasn't really registering... but I was thinking the B&K AVR 202 didn't have those separate analog inputs (as it was so "cutting edge" back-in-the-day with the fancy coaxial and digital inputs ;-)  ).
Well I guess I was asleep during 15-years of tech advances and I've got to start researching again for another AVR...
Don't even know where to begin that one, looks like B&K aint even on the radar anymore???  Emotiva?
Hopp is offline
post #16474 of 24590 Old 04-26-2014, 12:17 PM
JazzGuyy's Avatar
Quoted: 304 Post(s)
Liked: 297
Depending on your budget, there are lots of good AVRs these days. The good folks over on the AVR section of these forums should be able to help you get started in your quest. Unfortunately, 15-year-old AVRs just don't have what you need any more. You'll be amazed at what current ones can do.
post #16475 of 24590 Old 04-26-2014, 12:56 PM
SeeMoreDigital's Avatar
Quoted: 472 Post(s)
Liked: 197
That's what I see too... Might indeed be time to look for a new amp wink.gif
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #16476 of 24590 Old 04-26-2014, 01:10 PM
hernanu's Avatar
Quoted: 601 Post(s)
Liked: 1083
I don't know - this manual says that they can be used as inputs, but an internal switch has to be turned on, which you need to contact service for eek.gif
hernanu is offline
post #16477 of 24590 Old 04-26-2014, 01:21 PM
Quoted: 472 Post(s)
Liked: 197
That's very clever of B&K. This would increase the life of the amp. Nice find wink.gif
post #16478 of 24590 Old 04-26-2014, 01:27 PM
BobbyES's Avatar
The unit was set up correctly and worked shortly in a correct manner. All of a sudden you would give your tv a command and it would turn off. Then it started turning off just because. Now you can not even turn the volume of the TV up or down because it tells the crappy OPPO to a turn on or off. This is a piece of crap unit and no one at OPPO knows what to do about it. This may sound strange but at this time the only answer is to purchase another unit and not OPPO. This is one terrible company in which is making sub par units with now reduced warranties. I have it plugged into a power strip now because it turns on and off with the TV control volume. Nothing suggested in this forum has worked including technical support. They even told me it will cost more to repair than just buying a new unit. No labor warranty on the 103 after 30 days. When not using it it has to be powered down, no power to the unit.
Bob
BobbyES is offline
post #16479 of 24590 Old 04-26-2014, 01:35 PM
rdgrimes's Avatar
Quoted: 2133 Post(s)
Liked: 1446
Bob
Oppo didn't tell you that. The unit has a full 2 year warranty, no questions asked. I suspect you haven't spoken to Oppo at all. Whatever store you got it from is telling you a bunch of hooey.
Ricker62 likes this.
rdgrimes is offline
post #16480 of 24590 Old 04-26-2014, 01:37 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Lol. Is this guy for real?!
RayWK likes this.
Brian Fineberg is offline
post #16481 of 24590 Old 04-26-2014, 01:40 PM
JazzGuyy's Avatar
Quoted: 304 Post(s)
Liked: 297
Either that or someone is selling phony Oppo players. My bet would be we have a troll though since this guy posted earlier with the same complaints and was given a whole bunch of things to try that would probably fix all his problems and he has ignored them. I think we should now ignore him.
RayWK likes this.
post #16482 of 24590 Old 04-26-2014, 01:47 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1098 Post(s)
Liked: 1075
Dunno, but he's got 10 thumbs up for 3 posts, so he must be doing something right... biggrin.gif
gsr is offline
post #16483 of 24590 Old 04-26-2014, 01:59 PM
Quoted: 472 Post(s)
Liked: 197
This begs an 'off-topic' question... Why does this forum automatically award 10 thumbs to new members?
post #16484 of 24590 Old 04-26-2014, 02:01 PM
JazzGuyy's Avatar
Quoted: 304 Post(s)
Liked: 297
To make them feel good?
post #16485 of 24590 Old 04-26-2014, 02:13 PM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
Help. Has anyone had success using the 103 to upscale to 4k with the 39" Seiki 4k TV ? Bought the Seiki to use as a PC monitor. Seiki says "not supported" when sent 4k from Oppo. Tried 4k forced from Oppo and that didn't work either. Thought I would try here before contacting Oppo. Thanks
dsinger is offline
post #16486 of 24590 Old 04-26-2014, 02:41 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2049
Bob
Did you buy a second hand OPPO 103 that's over two years old? That's probably not possible unless you got a pre-production player.
Do you have proof of purchase from an authorized dealer? Would that be BB's Magnolia department?
Do you know that OPPO frequently repairs their players free even after the two year warranty has expired?
Are you actually in contact with OPPO?
Have you followed any advice that you've been provided?
Nothing you've posted is consistent with anything ever reported by an owner of any OPPO player. That's especially true of your claim that OPPO has reduced their warranty from two years to thirty days, and that OPPO don't know what to do with your problem. Based on how you've communicated with this OPPO owner's thread, it's hard for me to see how anyone will be able to help you.
Have you turned off CEC in your Sony display, your AVR, and the OPPO player? Do you need help figuring out how to do that?
Do you need help finding out which firmware version is installed in your OPPO?
htwaits is online now
post #16487 of 24590 Old 04-26-2014, 03:02 PM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
I have an Oppo 103 that won't play my VHS tapes. Oppo and BestBuy won't do anything! An I just supposed to throw this $500 player in the trash?!?!?!
jgambino likes this.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #16488 of 24590 Old 04-26-2014, 03:02 PM
Liked: 3515
Lmao
post #16489 of 24590 Old 04-26-2014, 03:08 PM
Quoted: 472 Post(s)
Liked: 197
Bummer... Surely you can use the Oppo's disc tray as a cup holder!?
Ricker62, RayWK and Musky45 like this.
post #16490 of 24590 Old 04-26-2014, 03:11 PM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
That's silly. I already use that little motorized tray on my PC for that.
Ricker62 and RayWK like this.
post #16491 of 24590 Old 04-26-2014, 04:06 PM
Phrehdd's Avatar
Quoted: 153 Post(s)
Liked: 208
Thank goodness for the coffee cup tray on my pc. I was up all night looking for the "any" key while reading instruction for a software install.
RayWK likes this.
Phrehdd is online now
post #16492 of 24590 Old 04-26-2014, 04:14 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2664 Post(s)
Liked: 3393
AVS gives you a "gift" of 10 Thumbs Up for signing up.
--Bob
RayWK likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #16493 of 24590 Old 04-26-2014, 04:16 PM
Quoted: 749 Post(s)
Liked: 627
gsr, pbarach, dmusoke and 1 others like this.
post #16494 of 24590 Old 04-26-2014, 04:20 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1075
--Bob
RayWK likes this.
gsr is offline
post #16495 of 24590 Old 04-26-2014, 04:23 PM - Thread Starter
Neuromancer's Avatar
Quoted: 86 Post(s)
Liked: 328
Ensure that the Seiki supports 4Kx2K at 24Hz. The player does not output 4Kx2K at 60Hz at the moment. This is likely to change in the future.
If you have not done so already, upgrade the firmware of the monitor. If the firmware is out of date, you may get an out of range signal error on the display.
Try another port on the display. Some ports are more reliable than others on this display.
Also, do not use the provided Seiki HDMI cable. It is crap. Use the OPPO cable.
ceat likes this.
Neuromancer is offline
post #16496 of 24590 Old 04-26-2014, 04:30 PM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
Originally Posted by Hopp View Post
but when I went to play Total Recall (new remake) the sound kept cutting out due to those bandwidth limitations (i.e. Dolby True format).
fwiw, Total Recall (new remake) blu-ray disc is defective (the original blu with the extended cut on it). What you would need to do (were you are connected via hdmi) is listen to it with Oppo first decoding the Dolby TrueHD soundtrack internally to multichannel PCM, as the Dolby TrueHD soundtrack is basically defective in terms of being able to stream it without dropouts. (Sony didn't bother to fix their disc, Oppo apparently didn't bother to issue a workaround fix.)
Not sure what the equivalent would be for analog output (or coax/optical), perhaps select a lossy version of the soundtrack instead (although I think that's what you are doing?).
Anyway, it's the disc, not your player. Mostly.
Other workaround is allegedly to get the Mastered in 4K version. No extended cut there, but I recall reading that the soundtrack is not screwed up on that one.
fmalczewski is online now
post #16497 of 24590 Old 04-26-2014, 05:18 PM
AYColumbia's Avatar
Quoted: 20 Post(s)
Just want to say thanks for the comic relief. I needed that (it was looking grim there for a while). biggrin.gif
pbarach likes this.
AYColumbia is offline
post #16498 of 24590 Old 04-26-2014, 07:13 PM
borninusa's Avatar
Anyone out there had an audio sync issues with the 103 and the movie Philomena?
I don't know if I have a setting wrong..or its a disc issue
I probably have a setting wrong....more than likey....but being that I am not overly technical...what are some key settings I should make sure are correct?
borninusa is offline
post #16499 of 24590 Old 04-26-2014, 07:52 PM
gwsat's Avatar
Quoted: 2406 Post(s)
Liked: 2716
If I could just find the Any Key and The Lost Chord, I would then only need to see Paris and die. smile.gif
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
post #16500 of 24590 Old 04-26-2014, 09:23 PM
117olddude's Avatar
Quoted: 21 Post(s)
Why would you want to spray this cute little guy?
117olddude is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
