Official OPPO BDP-103 Owner's Thread - Page 556 - AVS Forum | Home Theater Discussions And Reviews
 907Likes
post #16651 of 24703 Old 05-03-2014, 09:29 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
where I was a little confused was there are 2 kinds of "factory resets"; one does the settings only, and another one does settings, and logins/passwords of all the apps;
once I did the complete factory reset, my problem went away, but not sure why deleting the logins/passwords made any difference on a firmware update; I was NOT prompted to do any factory reset after upgrading to the beta firmware..
Oh well, as with anything electronic, you can never be sure how any update/upgrade will affect your equipment until you actually do it!
wase4711 is offline
post #16652 of 24703 Old 05-03-2014, 09:31 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 44
Originally Posted by Bob Pariseau View Post
OPPO Tech Support frequently monitors their email even on weekends and holidays.
For your 3D issue, double check your settings and wiring. Make sure you are using the HDMI 1 output as your video path for 3D. If using both HDMI outputs check that you have Split A/V set. It is easy to get the two outputs backwards. Also try setting 3D Output FORCED.
If you fiddled with the cabling at all during the firmware install, also check that you are plugged into the INPUT you think you are using on your Display. And since it's been a while since you tried 3D, double-check your 3D input settings on the Display, particularly as regards the expected 3D format.
--Bob
Bob why the recommendation of using HDMI 1 for 3D output when the manual states that both outputs are 3D compatible?
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #16653 of 24703 Old 05-03-2014, 10:06 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3350 Post(s)
Liked: 4297
^ "juat in case". More 3D testing has been done using HDMI 1.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #16654 of 24703 Old 05-03-2014, 12:50 PM
Bryan Beckman's Avatar
I've tried playing a 3D MKV file (output by MakeMKV) using the official firmware and the 103 plays it back as a 2D program. (No issues playing 3D Blu-rays -- the TV automatically detects and displays the intended 3D image.)
  1. Are the 3D MKVs produced by MakeMKV at fault?
  2. Do 3D MKVs play correctly over DLNA? I use the DLNA server built into my Synology NAS and never had issues with 2D content.
  3. Is it required to put the player into Forced 3D mode when playing 3D MKVs? How do you know you're seeing 3D from the file and not a 3D effect imposed by the player?
Bryan Beckman is offline
post #16655 of 24703 Old 05-03-2014, 02:07 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
1. not sure about make mkv; never used it
2. 3d MKV's play perfectly from a NAS on this player; I have a WD dx 4000, and it works very well. I use Serviio as the front end for the NAS box; maybe you need to install some different software on your Synology?
3.You should NOT have to put it into "forced" mode; when you start a 3d .mkv, you should just have to switch your TV into 3 d mode, and it should play in 3d.
you will DEFINITELY be able to tell the difference between "real" 3d, and "simulated" 3d...what kind of TV are you watching it on?
wase4711 is offline
post #16656 of 24703 Old 05-03-2014, 02:27 PM
rdgrimes's Avatar
Quoted: 2269 Post(s)
Liked: 1620
Originally Posted by Bryan Beckman View Post
[*] Do 3D MKVs play correctly over DLNA? I use the DLNA server built into my Synology NAS and never had issues with 2D content.
That's up to your DNLA server, odds are it doesn't support 3D streaming. You should try the same file using direct SMB access.
rdgrimes is offline
post #16657 of 24703 Old 05-03-2014, 02:53 PM
kriktsemaj99's Avatar
Quoted: 650 Post(s)
Liked: 371
What kind of 3D? If it's full resolution frame-packed 3D (e.g. a 3D Blu-ray rip) then the display should switch into 3D mode automatically. If it's side-by-side 3D then you have to tell the TV to switch.
I have the exact same issue with MakeMKV and the BDP-103D. I'll try playing back from an SMB share instead of my DLNA server and see if that changes anything.
kriktsemaj99 is offline
post #16658 of 24703 Old 05-03-2014, 03:14 PM
Bill Mullin's Avatar
I just got the full "Hill Street Blues" series on DVD. I'm hard-of-hearing so was very happy to read that it had closed captions. But, it has only CC (I think) and no subtitles. I was unable to get my BDP-93 to display the captions, although it did a nice job with the 1.33 DVD video.
So my question is this - if I get the 103 will it be able to display the captions in Hill Street Blues?
While I'm asking questions, I see that the 103 is also advertised as having subtitles with Netflix On Demand. This also interests me as On Demand subtitles are not available with my BDP-93. How good (or bad) is the 103 doing with Netflix On Demand Subtitles?
Thanks, Bill
Bill Mullin is offline
post #16659 of 24703 Old 05-03-2014, 03:59 PM
rdgrimes's Avatar
Liked: 1620
Thanks, Bill
That set has subtitles for the hearing impaired, so you should be fine. "CC" is a broadcast standard that's not entirely relevant to DVD, subtitles are.The Netflix app on the 103 does support the subtitles that Netflix offers, though not all titles have them.
rdgrimes is offline
post #16660 of 24703 Old 05-03-2014, 04:02 PM - Thread Starter
Neuromancer's Avatar
Quoted: 91 Post(s)
Liked: 354
Originally Posted by JohnnieBGoode View Post
1) Does it support Dolby Digital Plus pass-through?
Yes, the player supports Dolby Digital Plus pass-through.
2) Is a clean 1080p23.976 or 1080p59.94 output with the Netflix app possible?
60Hz.
3) Are the credits rolling normally or do they get minimized as soon as the main content is over?
This depends on the source, but everything I have watched shows the full credits then kicks back to the Netflix Main Menu.
Neuromancer is offline
post #16661 of 24703 Old 05-03-2014, 04:04 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
my tv never goes into 3d automatically, I always have to put it into 3d mode..
wase4711 is offline
post #16662 of 24703 Old 05-03-2014, 04:10 PM
Actually, the Hill Street Blues is advertised as having closed captions, not subtitles, which makes this the first DVDs I've purchased that have closed captioning instead of subtitles. FWIW, my 93 shows that there are no subtitles. So do you think the BDP-103 will handle the captions?
While at it, are ALL the Netflix English speaking movies subtitled (or captioned) or just a select few? Does anyone have a feel for this?
post #16663 of 24703 Old 05-03-2014, 04:29 PM
Read the FAQ!
Liked: 4297
^ Bill, just to be sure, don't trust the on-disc menus. Instead press the Subtitles button on the remote and see if any Subtitle choices show up.
As for Netflix, there's a new law on this, effective this year I believe, stating that all streaming content has to offer Subtitles. It may be there's some leeway given to implement this, but it's headed that way.
--Bob
post #16664 of 24703 Old 05-03-2014, 05:33 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3098 Post(s)
Liked: 2373
I still find TV series and some older movie DVDs that have CC without subtitles. NCIS seasons 1-2 and 4-5 for example.
I don't know of any Blu-ray player that supports CC over HDMI. HTPC software like VLC will do it.
It's a bit of work, but I have:
  • converted DVD to MKV container
  • extracted the CC and converted them to SRT text subtitles
  • merged them into the MKV container, which the OPPO will then play
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #16665 of 24703 Old 05-03-2014, 06:55 PM
This is from Oppo support today (read from the bottom up):
Bill,
Yes, these players have built in Closed Captioning decoding capabilities so you can use the HDMI output and get Closed Captioning.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
****@****.com
Tel: 650-961-1118
Fax: 650-961-1119
________________________________________
Sent: Saturday, May 03, 2014 3:22 PM
To: OPPO Service
Subject: RE: Message From Bill Mullin (****@****.com)
Will the BDP-103 support closed captions in a DVD or BD via an HDMI connection?
- Bill
post #16666 of 24703 Old 05-03-2014, 06:58 PM
wmcclain's Avatar
Liked: 2373
That's news to me, I suspect they mean subtitles, not Closed Captions.
Anyone who can show otherwise gets the Triwizard Cup and Eternal Glory.
-Bill
post #16667 of 24703 Old 05-03-2014, 06:59 PM
--Bob
I did that, the BDP-93 did not recognize the subtitles (or captions) from the Hill Street set.
BTW - I can understand a movie's dialog if I use headphones and turn the volume LOUD. I'm 6 episodes into the 144 episode series . . . it's outstanding so far!
post #16668 of 24703 Old 05-03-2014, 07:51 PM
Read the FAQ!
Liked: 4297
^ True Closed Captioning is an Analog video thing. You might try the Component Video outputs of the 93. (There are no such outputs on the 103.) You will need to enable Closed Captioning on the Component Video input of your TV.
--Bob
post #16669 of 24703 Old 05-03-2014, 08:40 PM
pbarach's Avatar
Quoted: 354 Post(s)
Liked: 206
I wonder if you can get closed captions by turning on that feature on the tv if the player won't show them.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #16670 of 24703 Old 05-04-2014, 01:22 AM
Kanvas's Avatar
Originally Posted by SeeMoreDigital View Post
It's a shame the European version of the new beta firmware has not been released yet... As there's a 'Spring bank holiday' on Monday in the UK and Ireland wink.gif
It is very sad. It looks like the European customers are B customers rolleyes.gif
Kanvas is offline
post #16671 of 24703 Old 05-04-2014, 01:39 AM
SeeMoreDigital's Avatar
Quoted: 483 Post(s)
Liked: 201
Well I wouldn't go that far... But it be preferable if the North American and European firmwares were released at the same time wink.gif
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #16672 of 24703 Old 05-04-2014, 04:35 AM
wmcclain's Avatar
Liked: 2373
When this worked it was with (a) analog video only, (b) 480i output only.
All that work creating CC was more or less trashed when the industry went to HDMI, which is a shame. See http://en.wikipedia.org/wiki/Closed_captioning#Incompatibility_issues_with_digital_TV.
Also http://en.wikipedia.org/wiki/Hdmi, where we have:
The HDMI standard was not designed to pass closed caption data (for example, subtitles) to the television for decoding.[57] As such, any closed caption stream must be decoded and included as an image in the video stream(s) prior to transmission over an HDMI cable to be viewed on the DTV. This limits the caption style (even for digital captions) to only that decoded at the source prior to HDMI transmission. This also prevents closed captions when transmission over HDMI is required for upconversion. For example, a DVD player that sends an upscaled 720p/1080i format via HDMI to an HDTV has no way to pass Closed Captioning data so that the HDTV can decode it, as there is no line 21 VBI in that format.
A player could employ a CC decoder and generate subtitle overlays, but I don't know of any that do. It would be for DVD only because Blu-ray doesn't (ever?) use that encoding technique.
As said above, CC can be extracted and converted to media file text subtitles, but that's a bit of effort.
-Bill
post #16673 of 24703 Old 05-04-2014, 05:41 AM
Read the FAQ!
Liked: 4297
Why? The firmware release is built and tested in the US, then rebuilt and retested in Europe prior to release in the European version. The amount of work involved in that varies according to what's changed in the new firmware. Sometimes 3rd party certification also has to be done separately.
Why hold up the US release artificially until that extra work is done for Europe? The goal instead is to get each version out as quickly as possible.
--Bob
post #16674 of 24703 Old 05-04-2014, 06:13 AM
I had also asked Oppo support about that. I was told this would work but only if I was viewing the analog picture. Between the time it would take setting up the system for analog viewing and the subsequent loss of picture quality, I decided this wasn't worth it!
post #16675 of 24703 Old 05-04-2014, 07:47 AM
Jurgen's Avatar
Quoted: 13 Post(s)
--Bob
Agree.
By the way. The recent fw updates of the EU versions were made available rather fast after the US versions.
Jurgen is offline
post #16676 of 24703 Old 05-04-2014, 01:45 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Hello, can I use the Oppo-103 as a preamp directly connected to the amp? Does the Oppo 103 allow volume control like the 105? Thanks.
NAIM101 is offline
post #16677 of 24703 Old 05-04-2014, 01:53 PM
Read the FAQ!
Liked: 4297
Yes the 103 offers Analog output Volume control, although that's more limited than what's available on the 105. The step size is bigger for example, and there's no volume control AT ALL when using DSD-Direct-to-Analog Conversion. The Volume control in the 105 is also higher quality.
Although you can attach the 103 direct to amps, it is really designed to be used as a digital output player, or for Analog output via a pre-amp which handles the Volume control.
--Bob
post #16678 of 24703 Old 05-04-2014, 04:44 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by globalnomad View Post
Ok, I've screenshot all of the relevant settings screens (I think I got them all at least). My SMB has been working wonderfully with Win 7 x64, so hopefully this helps!
Control Panel --> Network and Sharing Center --> Change advanced sharing settings (in left sidebar)
"Properties" dialog of the folder you want to share --> "Security" tab (follow images clockwise from upper left)
"Properties" dialog of folder you want to share --> "Sharing" tab
Hoping someone can help me with SMB on W7 Enterprise SP1 x64.
This "Log in Error" is driving me insane !!
I have all the exact settings as you described here, tried logging in without a password like user "davehale" did with success, I tried with a password (and changing of course the setting "password protected sharing" every time) but no luck frown.gif
I don't know what to do anymore... I did in the past use my DUNE to connect to my PC (with SMB) and that worked without a problem.
I have to mention I am using Windows Live Essentials 2011 (only installed "Mail") but I can not for the life of me believe this has anything to do with it. And since I am using this mail program everyday uninstalling is not an option really.
Other thing I have not tried yet is creating a guest account without a password, but since this is very insecure that is not an option anyway.
Suggestions welcome !!
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #16679 of 24703 Old 05-04-2014, 04:47 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
--Bob
Thank you Bob. I have a Job 225 Amp and its going to be another 2 months until they come out with their own preamp. I guess the Oppo103 can be used for preamp until then..biggrin.gif
NAIM101 is offline
post #16680 of 24703 Old 05-04-2014, 05:21 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Unless you are using Homegroup I would try turning that off and just use user accounts and passwords to access the shares.
bgoering is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
