Official OPPO BDP-103 Owner's Thread - Page 561 - AVS Forum | Home Theater Discussions And Reviews
 891Likes
post #16801 of 24634 Old 05-10-2014, 04:04 PM
TrickyT's Avatar
Ok, I must be missing something obvious. Why can't I see any files from the Oppo MediaControl App on my iPhone. I shows my Mac and PC on the network, but no files on either. Both are running DLNA servers and I can play music from the fine using the Oppo UI going to network. But I'd like to use my phone to play files so I don't have to turn the TV on. What's the trick to sharing a folder so this app can see them?
TrickyT is offline
post #16802 of 24634 Old 05-10-2014, 04:07 PM
TrickyT's Avatar
Never mind, figured it out. I created a share outside of the DLNA server, but it didn't show up on the app. While reading the help for the 20th time, it showed up.
TrickyT is offline
post #16803 of 24634 Old 05-11-2014, 03:46 AM
Daffietje's Avatar
Quoted: 54 Post(s)
The AV Sync setting on the 103, you can set the value negative (to the left) and positive (to the right). If you set it negative you are delaying the audio or are you making it faster ?
Can not seem to find it in the manual.
I now have a certain value lip sync correction set in the Oppo and a certain value lip sync correction in my AVR, thats why I need to be sure about the negative/positive thing.
Or you guys recommend just putting one correction in one of the two devices is better? If yes, which device?
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #16804 of 24634 Old 05-11-2014, 05:18 AM
tyler webb's Avatar
Quoted: 125 Post(s)
Liked: 41
Originally Posted by Odessey View Post
Hey Tyler, Is that the RX-V375 5.1 Chanel or 7.1 ? I have the 5.1.  and are you hooking up HDMI  out directly to your AV receiver , or HDMI out to  your  TV ?
Thanks man
The RX-V375 is only a 5.1 Chanel Reciver. I send my 103, Xbox One and DTV to the V375 all threw there HDMI outs. And let the Yamaha do the HDMI switching out to my F8500. The only issue I have had was watching blu rays with my old HDMI cables. Audio and video would play for 5 minutes or so and them drop out. And it was all because my cables could not handle all the info being sent threw them. Ordered some new 28 AWG high speed cables from Monoprice and they solved the issue immediately.
tyler webb is offline
post #16805 of 24634 Old 05-11-2014, 05:22 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
Negative will delay the audio. You should only make adjustments in more than 1 device if you can't make enough adjustment in 1. And you certainly shouldn't make opposite adjustments as you'll end up back where you started. wink.gif
gsr is offline
post #16806 of 24634 Old 05-11-2014, 08:02 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3083 Post(s)
Liked: 3977
^ Hang on, that's backwards.
A positive value of the A/V Sync setting ADDS Audio Delay. This is the normal use, i.e., to add delay to the audio to compensate for slow video processing in your Display.
An A/V Sync setting of +40ms will delay the audio an additional 40ms.
The default setting of 0ms means that audio and video are in sync -- aligned in time -- at the player's outputs, regardless of the combo of inputs, outputs, formats, and processing settings in use.
To accomplish that, the player has its own, built-in audio delay adjustments which match audio to the video processing time needed inside the player itself for the combo in use. This is complicated stuff, but you don't need to know the details. It is OPPO's job to do this correctly regardless of your choice of connections, formats and settings.
Audio delay is accomplished by buffering the digital audio stream. Video processing is always the thing that takes longer, so delaying audio is the only correction needed. This is a good thing, since attempting to buffer video (i.e., to delay video) would take way too much memory.
OK, so what about the NEGATIVE A/V Sync setting choices?
A negative valued A/V Sync setting REDUCES the default audio delay built into the player to match audio and video at the player's outputs. It makes audio come out earlier.
Now think about that. I just said you can't delay video, and obviously you can't make the audio play ahead of what's coming in as content. So the only way to make audio come out earlier is to reduce the DEFAULT delay the player is providing!
So a negative A/V Sync setting will make audio come out earlier only SO FAR. Once you have eliminated all of the default delay built into the player for your combo of inputs, outputs, formats, and processing settings, making the A/V Sync setting even MORE Negative will make no further difference.
The things to keep in mind are:
1: A/V Sync of 0ms is the default. Audio and Video are IN SYNC, by design, at the player's outputs.
2: A/V Sync greater than 0 adds audio delay. This is the normal adjustment to correct for uncompensated video processing time in your AVR or Display.
3: A/V Sync less than 0 reduces audio delay, but only up to the built-in delay the player needs to accomplish (1), above, according to your current usage. If you find you need to use a negative value, that usually means your AVR is mistakenly applying too much audio delay ITSELF.
Again, video processing is ALWAYS the time consuming thing, so how could the AVR screw this up? First the AVR may be set for automatic lip sync correction, and the requested delay value it is reading from your Display to accomplish that (it's really just that simple-minded) may be BOGUS.
Another common way this happens is when you use both HDMI outputs and thus bypass the AVR for video. The AVR doesn't know that's happening, and so it may be adding an unneeded chunk of audio delay all on its own -- i.e., even if you SET IT to zero added delay -- to compensate for its own (unused!) video processing time. I call this the "helpful AVR" problem. Cure that by disabling video output from the AVR, or setting it to "video pass through" so the AVR can know it is not expected to process the video.
The more normal case, where you need to ADD audio delay (A/V Sync greater than 0) may be curable by turning off unnecessary or cumbersome video processing in your Display. Common time wasters in many displays are video "enhancement" processing and "motion smoothing". Some Displays also take too long when fed 1080p/24. Set 1080p/24 Output OFF in the OPPO for those. And it is almost always best to disable video "enhancements" in Displays. These are designed to make poor quality video more tolerable and just get in the way when playing high quality video as from the OPPO.
-Bob
Daffietje and daimler2015 like this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #16807 of 24634 Old 05-11-2014, 08:11 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
Oops - that's what I get for posting too early in the morning smile.gif.
gsr is offline
post #16808 of 24634 Old 05-11-2014, 08:15 AM
Read the FAQ!
Liked: 3977
^ To complete this picture, a few more items.
First, you talked about transferring an audio delay setting from your AVR to the OPPO. Although that may be just what's needed (zero it out in the AVR and let the OPPO do it), that may also give INCORRECT results. Why? Because if you have a "helpful AVR", its true audio delay will be the combo of the setting you set yourself and whatever it is imposing as its own, built-in, default delay to compensate for its own video processing time.
Which basically means, you have to check and see whether you are getting the correct result.
And to do THAT, the important thing is to be sure you check with test material of known sync quality. And THAT means using a calibration disc, as it is way too common for audio and video to be out of sync in actual movie content. If you see sync errors that vary by scene for example, you are almost certainly seeing inherent error in the content, which may date all the way back to errors in the original theatrical release!
Good A/V Sync test charts are available on "Spears & Munsil version 2", Blu-ray, available from OPPO, and Disney's "WOW World of Wonder", Blu-ray, available from Amazon.
Generally speaking it is best to keep things simple and have one device do any needed sync adjustment. If your AVR is accomplishing that -- as confirmed by checking with a calibration disc -- then there's no point in transferring that job to the OPPO. Leave the OPPO at A/V Sync 0ms and let the AVR do the job.
If the AVR is NOT doing it correctly, for whatever reason, or if the AVR does not offer sync adjustment, then you can use the setting in the OPPO as needed. Again, set this with a calibration disc.
--Bob
Daffietje likes this.
post #16809 of 24634 Old 05-11-2014, 08:39 AM
Read the FAQ!
Liked: 3977
^ An additional thought on the the math here:
The A/V Sync setting in the OPPO provides fine control -- a step size of +/- 10 ms -- but some people think they need even finer control than that.
Not true. It's all in their mind!
At 24 frames per second, each frame of video takes 41 2/3 ms. That means 10ms is less than 1/4 of ONE FRAME TIME. The eye and ear can not really detect an error smaller than one frame time because there is no video to compare against except this frame, the frame just before it, and the frame just after it. I.e., the brain is EXTRAPOLATING the error from the frames available, and extrapolating an error as small as 1/4 frame time is a neat trick.
(It's also well beyond the standard for sync quality the studios are trying to achieve when they make the films in the first place!)
At 60 frames per second, each frame of video takes 16 2/3ms. Again 10ms is less than one frame time.
The usual reason people think they need a finer step size is that they are having observational trouble checking the sync -- even with a calibration chart. The brain likes things to be in sync. If given half a chance it will fool you. It actually takes a bit of practice, and a good deal of focus, to use these sync charts without getting fooled.
One good trick is to deliberately set a substantial amount of error -- say 50ms -- either side of correct. First, see if the chart shows the same amount of error either side, and with the error in place, gauge where the CORRECT setting should be. Then try that again with 40ms either side, then 30ms, then 20ms, then 10ms. It should be come significantly harder to see the difference as you reduce the error either side of CORRECT. If you lose track of that, go back to a larger error number and work in again.
You may discover it is easier for you to see the error in one direction than in the other. This is normal. You can probably train yourself to see the error equally in both directions by concentrating while using larger error values and then pinching in on correct with smaller error values. But if you find you are more adept at seeing the error in one direction, then use that by sneaking up on the correct setting from that side.
And it's also good not to spend too much time using a sync chart. Take a break and come back to it to make sure your brain can focus on the task at hand.
Also be aware that your Display may react differently when fed different video formats. So for example, if you use both 1080p/24 and 1080p/60 video output, check sync both ways to be sure your Display isn't screwing up one way compared to the other.
--Bob
post #16810 of 24634 Old 05-11-2014, 11:31 AM
Daffietje's Avatar
Quoted: 54 Post(s)
--Bob
Thanks for the detailed explanation Bob !
Too bad Oppo is not shipping the S&M 2 Bluray to Belgium though. But I see it is also available on amazon. I wish there was some other way to just test the AV sync. Isn't there any good video on the net which you can download to test this?
Bit expensive to buy the S&M just for the sync test... I know it also has alot of other tests, but i already have AVS HD 709 for that.
post #16811 of 24634 Old 05-11-2014, 12:34 PM
SeeMoreDigital's Avatar
Quoted: 479 Post(s)
Liked: 200
I use the 'BBC HD Audio sync test'... I've just uploaded it to my OneDrive. You can find it here...
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #16812 of 24634 Old 05-11-2014, 12:37 PM
AudiophileWalt's Avatar
Quoted: 12 Post(s)
A/V synch issue with FIOS and upsampling..
Before the firmware upgrade from September 2013, I had an intermittent a/v synch with the Cisco HD recorder hooked directly to the 105 and simple analog audio out to a soundbar. I would get around it for awhile by switching to another input for a few seconds and then returning. It was gradually getting worse as I was watching US Open tennis and the ball would be passing the net before I heard the racket hitting the ball. The firmware upgrade then completely cured that problemhttp://files.avsforum.com/images/smilies/wink.gif. It was an unannounced upgrade that did the trick for me.
Another insight I have regards upsampling with the Cisco recorder and FIOS. I just leave the Cisco to upsample to 1080i and let the OPPO just upscale to 1080P I have the OPPO connected to a Panny 50GT50 and I could never discern any difference from the Oppo doing the upsampling from SD content or 720P than the Cisco doing it to 1080i and you don't get the delay- Importand on NFL Sundays if you constantly switch from FOX(720p) to the Red Zone (1080i).
AudiophileWalt is offline
post #16813 of 24634 Old 05-11-2014, 12:54 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Cheers
post #16814 of 24634 Old 05-11-2014, 03:42 PM
ron hawaii's Avatar
How good are the dacs in the 103? Is there that mich of a discernable difference when running CD's and streaming lossless files thru apple tv? Compared to 105 and other stand alone dacs? I don't use HD music or SACD. I can listen thru hdmi to my cambridge or bypass cambridge dac with analogs from oppo so utlize oppo 103 dac. BUT main question, with music I am using, will a "better" dac make a difference?
Thx
ron hawaii is offline
post #16815 of 24634 Old 05-11-2014, 05:41 PM
Super Moderator
teachsac's Avatar
Quoted: 733 Post(s)
Liked: 1202
Links to sites selling hacked firmware are not allowed.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #16816 of 24634 Old 05-11-2014, 05:55 PM
rdgrimes's Avatar
Quoted: 2208 Post(s)
Liked: 1554
Thx
You won't hear much, if any, difference between the player and a decent AVR. The DAC is better than any player in the <$1000 price range. Comparing to the 105 or a high-end DAC isn't really fair, but it is fair to say that you'd need a pretty high-end setup to hear the differences between any of the above.
rdgrimes is offline
post #16817 of 24634 Old 05-11-2014, 07:03 PM
KC-Technerd's Avatar
Quoted: 95 Post(s)
Liked: 146
My latest A/V synchronization measurements with firmware version BDP10X-70-0218 are attached below. This appears to be a significant improvement over what I measured on a previous firmware version, but when I made those measurements I was unaware of the variance caused by new HDMI handshakes, and I was using a less precise measuring device.
I only consider the differences between each of the configurations noted in red, and each of the configurations noted in blue completely attributable to the Oppo BDP-103. Differences in results between any other configurations could be a result of differences in processing times for each video configuration at the video display, or audio processing in the AVR.
The Spears & Munsil 2nd Edition disc was used for these measurements.
I have not yet made any measurements with firmware version BDP10X-75-0430B to see if there are any differences.
KC-Technerd is offline
post #16818 of 24634 Old 05-12-2014, 01:41 AM
Daffietje's Avatar
Quoted: 54 Post(s)
^Nice testing, I have noticed the same behaviour but I have not done any measurements to support it.
I have the same setup as you (HDMI 1 directly from Oppo to TV, HDMI 2 from Oppo to AVR for the audio).
You should really do the test again with the latest BETA firmware, Oppo told me there were some changes made regarding the AV sync, which are not mentionned in the changelog.
In regards to your screenshot : I dont really understand these results. How are you measuring this?
Blue is incorrect due to the Oppo? And red is?
The new HDMI handshake you mention, how do you do this?
Because when I used some lip sync videos (one is posted here above) for testing it seemed that every setting was the same. But I guess that is due to the fact I have to make a new HDMI handshake...
post #16819 of 24634 Old 05-12-2014, 02:53 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Can you please explain this exactly? Is the following a correct summary?
Taking for example the DTS HD 24p LPCM test: your AVR has a fixed delay of 80mS programmed in (80mS ~= 2 frames @ 24Hz); and -- after successive HDMI handshakes -- you measured deviations of -50, -35, -40, -20, -20, -40mS to be subtracted from this fixed 80mS ??
If this is true, then frankly I am horrified, since your table implies that the Oppo is making two mistakes as follows:
  1. That the delay is variable dependent on HDMI handshakes. Insofar as the Oppo does not support the HDMI A/V sync handshake protocol, this should not be the case.
  2. That the delay is variable dependent on the source audio & video encoding format. The Oppo should internally process source related issues and always output in the same A/V time relationship.
AndrewFG is offline
post #16820 of 24634 Old 05-12-2014, 06:51 AM
KTM300EXC's Avatar
Quoted: 21 Post(s)
When I arrive to work I will try and read through the 561 pages of this thread to get this and other questions answered, for the time being I'm just going to ask and hope for kindness.
I am seriously considering purchasing the 103, mainly for the up-scaling ability.
Here is my gear:
Standard Def service from DirecTv, my Cable Box/DVR does not output using HDMI, just RCA R/W/Y cables.
Onkyo NR809 AVR
60" Sharp Aquos Quattron 3d
Looking at pics of the back of the Oppo 103 it has HDMI inputs but no RCA inputs? It does have (2)Orange/White looking Coaxial inputs?
How would input my Std Def DirecTv Cable Box into the Oppo so that I can upscale the Std Def Cable service to HD content?
I am very much a rookie at AVR/Home Theater stuff and the little I do know I've learned from asking questions here.
I'm pretty sure my current TV and AVR cannot upscale the Standard Def to HD Def., but I could be wrong on that?, that's the main reason I am thinking of purchasing the 103 as it can do this?
I'm a cheap bastard and don't want to pay for HD Content from DirecTV just yet thus with a potential Oppo purchase and awaiting arrival of a Mohu Sky Outdoor Powered HD antenna I'm hoping to get some HD content without the huge monthly fees. With the upscaling though I am familiar with the term "Garbage in Garbage out", hopefully with the AMAZING reviews of the Oppo I can get the results I seek.
Any advice, comments, suggestions are certainly welcomed, hell even criticism, I need to hear it all.
KTM300EXC is offline
post #16821 of 24634 Old 05-12-2014, 07:08 AM
KTM300EXC's Avatar
Quoted: 21 Post(s)
Opps, after looking at the manual and running through the wiring of my current set up in my head I think I figured out how to hook it up.
Cable Box RCA's currently run into my AVR
AVR currently outputs to TV with HDMI
I can run that outputted AVR HDMI feed into the Oppo HDMI IN, then run an HDMI from the Oppo HDMI out to the TV HDMI In.
So I guess the only question now is, will the upscaling give me a good looking HD fed on my TV?
*ARGH*
After thinking a bit more on this, if I go Cable Box>AVR>Oppo HDMI In>OppoHDMIOut>TV......Will that give me the audio through the AVR or will it come out only through the TV speakers as I am feeding the TV with the upscaled content, not the AVR?
Will I have to hook up like the following CableBox>AVR>OppoHDMI In>OppoHDMI Out1>TV...OppoHDMIOut2>AVR>.....?
Dammit am I stupid.....Please help.
post #16822 of 24634 Old 05-12-2014, 07:12 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Lets say that if one certain x value of lip sync in the AVR is not always correct due to the Oppo or due to the source audio & video encoding format.
Would it be a solution if by setting the Oppo at any different value than ZERO results in the Oppo DISABLING the internal syncing of the audio and video and only using the value you have specified in the av sync setting of the Oppo ?
post #16823 of 24634 Old 05-12-2014, 08:08 AM
Quoted: 95 Post(s)
Liked: 146
I'm using an iPhone 5s camera (120fps frame rate) with an app that shows me both the video capture and a graphical representation of the audio in a way that I can measure the time difference between the two in ms.
The testing is fairly time consuming, in making the HDMI handshakes occur between each sample, and making sure each configuration is properly setup, and then in evaluating the results. I took 5 samples last night for DTS HD-MA bitstream (on the new firmware). On that configuration there doesn't seem to be any significant difference from the previous firmware.
The lines in red can be compared with each other (in my opinion) to evaluate whether the Oppo is delivering LPCM output in the same A/V synchronization for both Dolby True HD and DTS-HD MA. On both the red lines the AVR is receiving LPCM, and the TV is receiving 1080/24p. Since in both cases the outboard devices are receiving identical input, this should eliminate those devices as a possible source of any changes in audio or video delay.
The same is true for the blue lines, where the AVR is receiving LPCM, and the TV is receiving 1080/60. Comparing them with each other makes it appear the BDP-103 takes about 20ms longer to process DTS-HD MA to LPCM than it does to process Dolby True HD to LPCM.
I switch the video between 24p and 60i to force a handshake. On the Spears & Munsil disc, I do this by momentarily playing the 2.3.2.3 pattern between each sample I take on the 24p pattern. When sampling the 2.3.2.3 pattern, I simply go back to the menu which appears in 24p.
post #16824 of 24634 Old 05-12-2014, 08:20 AM
Quoted: 95 Post(s)
Liked: 146
1. The variable delay dependent on the HDMI handshakes may not be the Oppo at all. I consider my oldest component in the chain as being the more likely source of that, which is my 2008 Sony TV. It may not be consistently synching its display to the incoming HDMI signal to that level of precision. The AVR also can't be positively eliminated as being a source of that variation.
2. I suggest not trying to draw any conclusions about the Oppo itself from these results other than comparing the blue lines to each other, and comparing the red lines to each other. In comparing any of the other lines to each other, variations in the processing time of different audio formats by the AVR, and different video formats by the video display have to be considered as a possible source or contributor to the variation.
post #16825 of 24634 Old 05-12-2014, 08:27 AM
rdgrimes's Avatar
Liked: 1554
Looks to me like what's actually being measured is the video lag in the display, which might be expected to change based on the type of input. Most displays have settings which can eliminate that type issue and related delays. 24p processing is infamous for causing lag.
rdgrimes is offline
post #16826 of 24634 Old 05-12-2014, 08:33 AM
Daffietje's Avatar
Quoted: 54 Post(s)
I agree you can only really look at the red & blue lines since that is LPCM. But even in these cases the differences are quite huge.
I would suggest doing another test with the new beta firmware to be sure that there is no recent improvement.
@rdgrimes : ''24p processing is infamous for causing lag''
Well for me it is not really an option to watch Blu-ray in any other framerate than 24p since that will cause judder due to the interpollation when for instance watching it at 60fps.
post #16827 of 24634 Old 05-12-2014, 08:45 AM
Read the FAQ!
Liked: 3977
^ Hang on. "The differences are quite huge"??? Uh, no.
We are talking about SUB FRAME TIME differences here.
Again, at 24 frames per second, each frame of video takes 41 2/3ms.
So 5ms is less than 1/8th of a frame time. 20ms is less than 1/2 of a frame time.
Each frame is, in and of itself, a static image. So, umm, which 1/8th of a static image is the sound supposed to align with? The first 1/8th? The middle 1/8th?
These are fun results to ponder, but I wouldn't rush to act upon them. Results like this beg several questions.
First, what was the quality standard in the production of those two tracks on the test disc? I.e., how close to identical were they AUTHORED to be in the first place? 1/8th of a frame time? I doubt it. Half a frame time? More likely.
Second, how does the capture app trigger? What is its delay in triggering? Presumably the trigger has to cross some threshold. Is the slope of the change (a function of the authoring) the same for both tests? I.e., even if the authored timing is truly identical, does the capture app trigger at the same point for both?
I think it's nifty to see test results like this, but don't read more into them than the methodology truly supports.
There may actually be a timing difference here in the OPPO. It wouldn't be a "processing" time difference -- those are small. It would be in the table of default timing corrections. But we are talking about differences here which are essentially unobservable in real-world content.
--Bob
post #16828 of 24634 Old 05-12-2014, 09:26 AM
Quoted: 95 Post(s)
Liked: 146
I will try to complete my measurements on the beta firmware as I have time.
The difference averages out to about 20ms, and I wouldn't call that huge. I am quite skeptical of the idea that audio and video can be synched to 10ms or less from a test pattern without using some type of measuring device. I would like to see the results of those who believe they can determine the correct audio delay based on eyeball and eardrum alone measured with an accurate device. I'm curious what the results would be.
From what I've read, and it makes sense to me, humans don't perceive slightly delayed audio as being out of sync. Anything from audio being about 20ms ahead to 95ms behind the image is all perceived as being perfectly in sync. Unless we are standing very close to what we are observing, the sound is lagging behind the image. Because of the differences in the speed of light and the speed of sound, If we are witnessing some activity, such as a person speaking, from 40 feet away the sound is about 45ms behind the image. I don't know anyone who perceives this as being out of sync.
The difficulty this presents is being able to accurately synchronize audio and video using a A/V synchronization pattern with our eyes and ears alone. The benefit of it is that if we can contain all the audio to image variation to within that roughly 20ms early to 95ms late range, we won't perceive it as being out of sync. There is room for error and variation.
post #16829 of 24634 Old 05-12-2014, 09:57 AM
Quoted: 95 Post(s)
Liked: 146
I have been using the first instant that the frame image appears as the point to synchronize the audio to. On a plasma or CRT each frame image is not displayed for a full 30th or 24th of a second, while on LCD or LCOS it is (or may not be depending on dark frame insertion). In other words, I base the measurement on the audio starting the same time as the image from the frame regardless of how long the frame is displayed by the display.
That is a good question. Based on the quality of the rest of Spears & Munsil work, I am assuming that the quality standard is pretty high, but how high I don't know.
There isn't a trigger on the capture app other than stopping and stopping the recording. It captures video at 120fps and audio. 120fps is 8.33ms per frame. I can interpolate to be a bit more accurate than that if the frame transition of the source occurs between frame transitions on the capture. Sorry, but it's a bit difficult to explain. I've attached a video demo of it below that might better illustrate the basics of how it works. While there may be some error in the capture between audio and video any error appears to be consistent. If I put up the S&M test pattern, and take several samples of it while it's playing continuously, the indicated results from each sample are all identical with no variation.
The app does have an adjustment for distance from source to compensate for the audio delay, which I have set to 5 feet, the distance I use the iPhone at. The app developer says to allow an error window of +/- 8ms.
Of course the iPhone app isn't the most ideal way to measure A/V synchronization, and has its limitations. Unfortunately better ways of measuring the synchronization are considerably more expensive, and I'm convinced this iPhone app is better than eyeballs and eardrums alone.
post #16830 of 24634 Old 05-12-2014, 10:14 AM
MIIKE888's Avatar
Quoted: 21 Post(s)
Hi!
why are OPPO not releasing an update on the Media control app it it so so broken after firmware update?!
//Mike
MIIKE888 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
