Official OPPO BDP-103 Owner's Thread - Page 562 - AVS Forum | Home Theater Discussions And Reviews
 872Likes
post #16831 of 24492 Old 05-12-2014, 10:59 AM
rdgrimes's Avatar
Quoted: 2078 Post(s)
Liked: 1407
Originally Posted by MIIKE888 View Post
Hi!
why are OPPO not releasing an update on the Media control app it it so so broken after firmware update?!
//Mike
App updates require certification by the app gods, out of Oppo's control.
lanping09 likes this.
rdgrimes is online now
post #16832 of 24492 Old 05-12-2014, 04:19 PM
KTM300EXC's Avatar
Quoted: 21 Post(s)
Is there anyway I can get an Oppo 103 to upscale my Standard Def DirecTv signal?
I currently have the following:
Onkyo NR-809
Sharp Aquaos Quattron 60" 3D TV
Standard Def DirecTv Cable Box that only has RCA outputs, it has no HDMI output and the Oppo doesn't accept RCA as an input?
How can I connect all the above devices so that I can use the Oppo to Upscale the SD content to HD content?
KTM300EXC is offline
post #16833 of 24492 Old 05-12-2014, 04:27 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2546 Post(s)
Liked: 3210
^ You can't. The OPPO only has Digital video input (HDMI). Your DirecTV box only has Analog video output (the RCA cables).
You would need to replace the DirecTV box with one that has HDMI output.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #16834 of 24492 Old 05-12-2014, 04:52 PM
KTM300EXC's Avatar
Quoted: 21 Post(s)
Therein lies the problem, to get a DirecTv box that had HDMI output I need to order HD service, I was hoping to use the Oppo to upscale my SD service to something closer to HD without having to pay for it.
I currently have my Cable box hooked up to my AVR with the RCA cables, then my AVR outputs everything connected to it to the TV using a HDMI cable (Though I dont thin I am upscaling anything doing it this way?), could I not take that AVR HDMI output and put that into the HDMI input of the Oppo, then use the HDMI output 1 on the Oppo and send that to the TV? Then connect a Optical Audio cable back to the AVR?
This all shows my high level of ignorance.
Thanks for the replies./
post #16835 of 24492 Old 05-12-2014, 04:59 PM
Read the FAQ!
Liked: 3210
^ Sure, you can do that. Essentially you've come up with a more complicated way to make an HDMI output for your DirecTV box.
Don't expect miracles. Upscaling to HD resolution can't magically create content quality which was never in the original SD video to begin with.
On top of whatever quality limits are inherent in the SD stream DirecTV is sending to your DirecTV box, the Analog video output stage of your DirecTV box (what feeds those RCA cables) is most likely godawful. That can't be fixed by upscaling. The information (picture quality) is permanently lost.
--Bob
post #16836 of 24492 Old 05-12-2014, 05:12 PM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
Your TV is already upscaling the SD to your set's native resolution (I assume 1080X1920). Your TV has to upscale since it is a high definition TV with fixed pixel display and must upscale everything not in its native resolution that comes into the TV to whatever its native resolution is.
With an SD source (which may be iffy to begin with), I doubt an Oppo player would do significantly better. It may be time to bite the bullet and think about some sort of HD service, whether from satellite, cable, off-the-air, or streaming.
JazzGuyy is online now
post #16837 of 24492 Old 05-12-2014, 05:27 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
^How do you know his TV upscales all content?? My TVs don't do that unless I tell them to. Many are capable of displaying exactly what is fed to them.
I would also wonder what kind of AVR he is using. Perhaps his AVR could also be upscaling his throughput.
Smarty-pants is offline
post #16838 of 24492 Old 05-12-2014, 05:34 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1088 Post(s)
Liked: 1058
Unless SD content is displayed in a small window in the middle of the display with huge black borders on all 4 sides, something is scaling the image to the native resolution of the display.
gsr is online now
post #16839 of 24492 Old 05-12-2014, 05:35 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
What TVs do you have that display input resolutions without converting them to the TV's native resolution? If you are including computer monitors, they are not TVs. smile.gif
htwaits is offline
post #16840 of 24492 Old 05-12-2014, 07:41 PM
Quoted: 749 Post(s)
Liked: 627
Yep, true.
There are TVs that do it. I think my Sony that is several years old does it, and even my mother-in-laws el-cheapo Walmart TV does it.
I had to fix it for her so the pic would fill the screen. Not just to stretch-fit, it was letterboxing on the SD content.
post #16841 of 24492 Old 05-12-2014, 07:46 PM
Read the FAQ!
Liked: 3210
Digital displays (any fixed pixel panel or projector using a fixed pixel panel) have to scale. Otherwise your SD content turns into a postage stamp in the center of the screen.
Analog displays -- i.e., CRT based screens and projectors, can fill the screen without extrapolating extra pixels by basically magnifying the SD image -- i.e., splashing it across the same distance they use to show HD images. Instead of scaling (inventing intermediate pixels via extrapolation) you get "fatter SD pixels".
--Bob
post #16842 of 24492 Old 05-12-2014, 08:25 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Yep, true.
I would not advise people with scaling questions using old analog devices as a benchmark. wink.gif
htwaits is offline
post #16843 of 24492 Old 05-12-2014, 09:08 PM
Quoted: 749 Post(s)
Liked: 627
Old analog devices? The TVs I was referring to are 1080p capable LCD panel TVs.
Maybe I am misinterpreting what I saw.
post #16844 of 24492 Old 05-13-2014, 04:07 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
Originally Posted by Bob Pariseau View Post
Digital displays (any fixed pixel panel or projector using a fixed pixel panel) has to scale. Otherwise your SD content turns into a postage stamp in the center of the screen.
That having been said, in my experience my Oppo does a much better job of upscaling DVD resolution material to 1080 than my Sony Tv does. I think this is because the Sony just does a "geometric stretch" on each single frame to map input pixels to output pixels, whereas the Oppo does something more sophisticated that involves edge and contrast enhancement, and also does some interpolation of moving edges between frames. Anyway, IMHO it looks a lot better...
AndrewFG is offline
post #16845 of 24492 Old 05-13-2014, 08:22 AM
KTM300EXC's Avatar
Quoted: 21 Post(s)
I have a Onkyo NR 809 AVR
I have a Aquos 60" Quattron 3D 240Hz TV
I do have the Mohu Sky Out Door HD Antennea and Powered Splitter on its way to see what type of over the air HD I can grab. I do live high upon a hill hopefully I'll get half of what the Website predicts I will get with this device.
Ugh.
post #16846 of 24492 Old 05-13-2014, 08:34 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1058
Ugh.
Did you post in the wrong thread? I don't see anything in the above that's relevant to the BDP-103...
gsr is online now
post #16847 of 24492 Old 05-13-2014, 08:37 AM
KTM300EXC's Avatar
Quoted: 21 Post(s)
NO, I didnt post in the wrong thread. A few replies back someone was asking what TV I had, to provide a better repsonse to my initial questions regarding the Oppo.
post #16848 of 24492 Old 05-13-2014, 03:34 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Originally Posted by KC-Technerd View Post
From what I've read, and it makes sense to me, humans don't perceive slightly delayed audio as being out of sync. Anything from audio being about 20ms ahead to 95ms behind the image is all perceived as being perfectly in sync. Unless we are standing very close to what we are observing, the sound is lagging behind the image. Because of the differences in the speed of light and the speed of sound, If we are witnessing some activity, such as a person speaking, from 40 feet away the sound is about 45ms behind the image. I don't know anyone who perceives this as being out of sync.
The difficulty this presents is being able to accurately synchronize audio and video using a A/V synchronization pattern with our eyes and ears alone. The benefit of it is that if we can contain all the audio to image variation to within that roughly 20ms early to 95ms late range, we won't perceive it as being out of sync. There is room for error and variation.
I second this. Even a person speaking to you from 10 feet away will be 11 ms out of sync due to the speed of sound. A car door being closed 20 feet away will be 22 ms out of sync. Our brains are wired to accommodate this and combine out of sync audio and visual signal - we have built in AV sync! But only to a point. Those who claim to be able to set sync to the exact 10ms boundary by eye must have real problems operating in normal everyday life wink.gif
In addition, our brains detect when sound comes ahead of the image much easier, because that is not normal to us and doesn't occur in real life.
My method for finding sync is to use a pattern (Spears and Munsil) and go with low delays until I can tell that it is out of sync. Then I find the point with audio delayed a high value where I can tell it is out of sync. I used to then go half way between this, but now I use 1/3 of the way after learning how much more sensitive the brain is to early sound than late sound.
I've also found that the longer I watch these patterns over and over in one sitting, the more difficult it becomes for me to tell what's in sync.
BobearQSI is offline
post #16849 of 24492 Old 05-13-2014, 03:44 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Back to your initial question - the OPPO can't "directly" do the upscaling for you from a composite video source as there are no composite inputs. eek.gif There are, however, fairly inexpensive devices such as http://www.amazon.com/Etekcity%C2%AE-Composite-Converter-Upscaler-High-definition/dp/B00D68UXQE/ref=sr_1_2?s=electronics&ie=UTF8&qid=1400019805&sr=1-2&keywords=composite+to+hdmi+upscaler that can take composite to 720p or 1080p but I doubt it would do any better job of the upscaling than what your TV already provides. You could invest the $30 or so, use that to take it to 720p and let the OPPO do the rest. I am sure you can find more like that if you look around a bit.
On the other end of the spectrum there are devices like the Lumagen 2022, 2042, and the newest 2144 that WILL take your composite/component/s-video/stereo audio, upscale all the way to Ultra4K/60 (for the newest 2144) and output that over HDMI. This would likely do a much better job - they are expensive, but I would expect about the best upscaling job you might find considering the limitations of the 480i input they are getting from your DirecTV box. As I believe you said - you recognize garbage in/garbage out smile.gif I shudder to think what a 480i input scaled to 4K on a big TV/Projection screen might look like biggrin.gif Unless your future plans include some heavy duty calibration and such this would likely be way to much investment! The idea is there are many options in between.
i would think for a result you might be (more or less) happy with - you will need to consider biting the bullet and getting a HD provider for your programming. Have you looked at Netflix which is already supported by the OPPO in lieu of traditional cable/satellite services? That along with the OTA service you seem to be looking into might be more than enough - it all depends on your programming requirements.
Good Luck
Bill
bgoering is offline
post #16850 of 24492 Old 05-13-2014, 04:05 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2047
Probably what you saw was the "digital" LCD upscaling to it's native resolution if the input was anything other than 1080p.
htwaits is offline
post #16851 of 24492 Old 05-13-2014, 05:38 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
I have an older Plasma in the bedroom (only 720p / 1080i capable for HD!) with a native resolution of 768 lines, so 480i, 480p, & 720p gets "upscaled" to 768 lines, 1080i gets "downscaled" to 768 lines. But I love it because it has 6 alarm clocks!
LOL
bgoering is offline
post #16852 of 24492 Old 05-13-2014, 06:01 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1058
Sorry - the context of your post got lost in the shuffle smile.gif. But as others have said, don't expect any miracles deinterlacing and scaling DirecTV SD content. The best of it can certainly be made to look decent on a 60" display, but the worst quality channels still aren't going to look great no matter what you use for deinterlacing and scaling. But none of it is going to hold a candle to having a true HD source. Depending on what programming you watch, you may find that installing an OTA antenna (as you appear to be pursuing) will be a very worthwhile investment. If you're into sports, you really owe it to yourself to get a HD feed for it as it makes a HUGE difference.
gsr is online now
post #16853 of 24492 Old 05-13-2014, 08:24 PM
artur9's Avatar
Quoted: 563 Post(s)
Liked: 194
I believe that the Oppo can replace my media player, Sonos and current Blu Ray player but I'd like confirmation.
Right now I use XBMC to stream MKV with high res (TrueHD, DTS-MA) and other audio formats to a Lacie LacinemaHD (which doesn't do high res BD audio). It's very important to me that the media player handle subtitles in the MKV well. The Lacinema requires the subtitles to be in DVD format, which I'm fine with. Can the Oppo play subtitles in that format for a BD-quality MKV? Does the Oppo support chapter skipping in MKV?
XBMC also network-enables my music library. I get the impression that the Oppo can play just about anything directly but can it also convert everything to PCM so that my preprocessor can be the DAC?
I won't be using HDMI for anything other than video as my processor doesn't have that. (I'm trying to wait out all the HDMI changes cool.gif ).
artur9 is offline
post #16854 of 24492 Old 05-13-2014, 08:26 PM
jsmiddleton4's Avatar
Quoted: 614 Post(s)
Liked: 207
There is a thread in the Network Media Server section for using the Oppo 103 as a media server. Might find out more in that thread. My understanding however is if primary use is as a media server it is probably not exactly the recommended product.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #16855 of 24492 Old 05-13-2014, 09:05 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 224
There is no thread for using the Oppo as a media server. It is not a media server. It is not billed as a media server. It is not sold as a media server. You can use it with a media server, however. That thread is at the link below. There is also much discussion about it in this thread and the BDP-105 thread, both of which have had substantial discussions surrounding subtitles with MKV.
http://www.avsforum.com/t/1215071/oppo-bdp-83-93-95-103-105-dlna-upnp-thread
(sorry to be so insufferably-pedantic about it - but technology is all about the details - so getting them right when we talk about it is important for setting expectations)
As for the OP's original question - I use the BDP-103 almost-exclusively with a DLNA server (JRiver Media Center), and an iPad-based control app (JRemote). I rip each of my blu-rays and DVDs with only one audio stream, selecting the audio stream that is the best available on the disc (highest channel count, lossless if possible, etc) , so I have several hundred MKVs with audio in nearly every high-res lossy and lossless format out there. They all play great. I also routinely stream stereo and multichannel flac (24/48, 24/96) and stereo alac (16/44[.1]) audio with no problems (tens of thousands of files). Gapless playback for classical and/or concept albums over DLNA is still not supported - although it may be getting closer. There are work-arounds, however.
I don't stream DSD files. I don't have a way to rip them from my SACDs, so this is one of the few places where I still use the shiny-disk for playback. Others have made DSDs stream using several of the media servers, including JRMC and oShare (among others). I would do a thread search for "DSD DLNA" in the threads mentioned above and read-up. Here is ONE data point:
http://www.avsforum.com/t/1432162/official-oppo-bdp-103-owners-thread/14970#post_24351284
I don't use subtitles, and really can't speak to it. But many users appear to have had issues, and you might want to do a search on the threads mentioned above so you can read through it yourself.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #16856 of 24492 Old 05-14-2014, 04:03 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2788 Post(s)
Liked: 2012
The OPPO supports both standard def and hidef VOBSUB in MKV, as well as PGS which is native to Blu-ray. And text subtitles like SRT.
Yes.
Well...
Yes...
What audio connection are you going to use?
It's a long wait, and HDMI 2.0 will make the complexity and compatibility issues considerably worse.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #16857 of 24492 Old 05-14-2014, 04:53 AM
artur9's Avatar
Quoted: 563 Post(s)
Liked: 194
For movies I'll be using the 7.1 analog out. For music the digital outs. I expect my Cinema11's DACs and analog stage are superior to the 103's. Maybe not the 105's. But music is more my focus when it comes to audio quality.
But I think the 103 is still an upgrade over the analog of my DMP-500.
-Bill
I had success waiting out Windows, IMO, so I'm batting 1000 on the waiting strategy biggrin.gif
artur9 is offline
post #16858 of 24492 Old 05-14-2014, 04:55 AM
artur9's Avatar
Quoted: 563 Post(s)
Liked: 194
What do you lose if you just rip the album to one big file?
artur9 is offline
post #16859 of 24492 Old 05-14-2014, 05:07 AM
Quoted: 204 Post(s)
Liked: 224
Nothing- if that is the only way you listen to it.
Basically, doing that (or something similar) is the work-around.
I actually rip to individual files and then make a single combined track from those - so I can have it both ways. The redundancy is not a big deal, since (at least in my case) it is not enough albums to matter much. At most, a couple dozen of the >>1000 albums in my non-SACD collection benefit from the gapless treatment. This method also works for surround albums ripped from my DVD audio and Blu-Ray music collections, where the option to rip one big file is often missing from the tools.
post #16860 of 24492 Old 05-14-2014, 07:23 AM
kemiza's Avatar
Liked: 92
When you touch the info button the display pops up. I assume the number in the upper left hand corner is the video bit rate. Does the Oppo display audio bit rate too? I was looking for it.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
