Official OPPO BDP-103 Owner's Thread - Page 565 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #16921 of 24577 Old 05-18-2014, 12:24 PM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
I wonder also if using the bdmv modify after I make the folder and before burning would improve the chances
detroit1 is offline
post #16922 of 24577 Old 05-18-2014, 12:37 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Originally Posted by _Jack_ View Post
Do you mean factory reset of Oppo or of the TV set ??
Factory reset the OPPO..
wase4711 is offline
post #16923 of 24577 Old 05-18-2014, 01:33 PM
rdgrimes's Avatar
Quoted: 2109 Post(s)
Liked: 1426
Originally Posted by detroit1 View Post
these were personal videos of mine. I have used Quantum BD-R and also Memorex BD RE
they will end up gong to the home screen after you put the disc in
I thin one avchd disc did that as well and these same avchd discs play fine on all Sony, Panasonic, Samsung, NAD, etc
If you insert one of those discs in the Oppo, what happens if you go to the "movie" pathway? Does the disc show up as a data disc? If so you could browse the disc.
If the player truly can't read a disc you should see a "no disc" message on the player. That said, you're using some cheap media so anything is possible.
rdgrimes is offline
post #16924 of 24577 Old 05-18-2014, 02:03 PM
kemiza's Avatar
Liked: 92
I received an email from Oppo on how to reboot my player. My instructions were to unplug it from the wall wait for a while then press and hold the power button down for 5 seconds then release. Connect the plug back into the outlet and power on. Why do I need to press and hold the power button for 5 seconds then release? Especially when it's not even plugged up.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #16925 of 24577 Old 05-18-2014, 02:28 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2630 Post(s)
Liked: 3348
This is to discharge any residual power retained in the power supply, and in particular to make sure that the portion of the hardware that controls the most basic functions of the player performs a complete reboot on the next power up.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #16926 of 24577 Old 05-18-2014, 02:29 PM
kemiza's Avatar
Liked: 92
--Bob
Oh.....
kemiza is offline
post #16927 of 24577 Old 05-18-2014, 02:36 PM
kemiza's Avatar
Liked: 92
So what's the reason for doing a factory reset after a firmware update?
kemiza is offline
post #16928 of 24577 Old 05-18-2014, 02:38 PM
Read the FAQ!
Liked: 3348
^ It's considered "good luck". Seriously, it shouldn't matter, but it puts the player into a known state as close as possible to how OPPO tests the player, which means you are less likely to encounter unexpected behavior.
--Bob
post #16929 of 24577 Old 05-18-2014, 02:39 PM
kemiza's Avatar
Liked: 92
--Bob
That's what I thought. Thx bro...
kemiza is offline
post #16930 of 24577 Old 05-18-2014, 02:57 PM
_Jack_'s Avatar
I will try that.
Thank you for the hint.
_Jack_ is offline
post #16931 of 24577 Old 05-18-2014, 03:34 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Hi there guys,
I have a strange problem with 3D films viewing from BDP-103D EU.
A movie is send to TV and plays in ex. side-by-side,
but the TV shows an info, that it does not recognise a 3D signal and does not swith the signal
into 3D 8/
TV is SONY X9 (KD-65X9005A) 4K Ultra HD
Same movies works fine in BDP-93EU (that problem persists in many MKV-movie cases)
What can that be ???
If you are seeing SBS - you will likely to manually press the 3D button on the TV remote (or whatever Sony uses) and manually put the TV in 3D mode. I have to do that on my Sharp.
bgoering is offline
post #16932 of 24577 Old 05-18-2014, 03:37 PM
_Jack_'s Avatar
I know. Have already done that, but got a message on the TV screen that TV does not recognise (=receive) 3D-signal.
That is strange and that is why I asked the question here.
I will do the factory reset of the Oppo and see what happens.
_Jack_ is offline
post #16933 of 24577 Old 05-18-2014, 05:08 PM - Thread Starter
Neuromancer's Avatar
Quoted: 86 Post(s)
Liked: 328
The player can also do 2D to 3D conversion. Just press the 2D->3D button on the player's remote control.
The display may not know that the signal is SBS or TB because the signal from the player is 1080p/60Hz, and the cable box likely does 3D at 720p/60Hz or 1080p/30Hz., so the display is not recognizing the 3D information.
Neuromancer is offline
post #16934 of 24577 Old 05-18-2014, 05:25 PM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
I just tried to play an avchd disc burned on a TDK DVD +R and it played perfectly on the Sony Playstation but on the Oppo it said avchd in the display and then the player gets stuck and you see the OPPO Blu-Ray on the tv screen and it doesn't do anything
you can't even eject the disc without turning the player off first
TDK is on of the leading brands for blank media so that is no excuse especially when the Sony played it fine
I also had a Quantum BD-R Blu- Ray disc with the correct BDMV structure, etc and the OPPO will say BD on the display but then get stuck again with the OPPO Blu-Ray Screen and you can't do anything
I also tried an HP DVD +RW with an iso file of blu-ray folder burned onto it and and it did not work
this is unacceptable for a player of this price.
the first 2 discs I mention here will play on most any brand blu-ray player
also , all discs were burned with image burn, which is probably the best thing to use
is any specific brand of disc that has worked in the OPPO ? most all cheap players play these discs with no problems
detroit1 is offline
post #16935 of 24577 Old 05-18-2014, 06:17 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2823 Post(s)
Liked: 2073
I've already explained that's not allowed by the licensing authorities.
You need to contact OPPO and tell them you're not accepting it. Offer them some sample discs. This helps diagnose the problem.
I use Taiyo Yuden DVD+R for single layer. and Verbatim for dual layer. Buy from a reputable source; Taiyo Yuden is sometimes counterfeited.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #16936 of 24577 Old 05-18-2014, 06:20 PM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
yes but which specific BD-R have people used? I am more concerned with Blu-Ray than DVD.
I will be trying memorex bd-r as well
it can't be licensing issue because Sony, Panasonic, Samsung, etc are playing these discs and there are many softwares available to make blu-ray discs the correct folder structure to play on blu-ray players
that is what those softwares are for; if you can't play it on a blu-ray player, it is useless
detroit1 is offline
post #16937 of 24577 Old 05-18-2014, 06:26 PM
wmcclain's Avatar
Liked: 2073
I don't burn Blu-ray.
BDMV on DVD is not supported. It's just not. Maybe OPPO is being specifically punished and the big companies have special rules. .
It's been years since we've heard of media support issues. What seems most likely is the problem is you or your player. Contact OPPO, they have people paid to help you.
-Bill
wmcclain is offline
post #16938 of 24577 Old 05-18-2014, 06:31 PM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
I am talking about burning a blu-ray using normal blu-ray folders; forgot about the dvd
the blu-ray is not working and it is useless to contact OPPO since they will blame every other reason other than their player. I have already been thru that with them regarding the 4TB hard drive support, time stamp issues, etc; I will get nowhere contacting them
the avchd on dvd is absolutely supposed to be supported and is listed on every brand of blu-ray player out there
and making a blu-ray on a blu-ray disc is also supported for sure, even OPPO told me that some time ago
I would rather ask other users about their experience and what brands of media worked
detroit1 is offline
post #16939 of 24577 Old 05-18-2014, 06:38 PM
quovadis123's Avatar
Quoted: 46 Post(s)
Liked: 41
Well...a few things not going well at all. It could be linked to the Oppo 103.
I have apple TV and Comcast box going through the Oppo first. Most of the time when I change HDMI inputs on the Oppo, my Sony 4k TV screen goes crazy.
Sometimes the screen is half black and half bright red (from left to right). Sometimes it's totally green.
I have to reboot the Oppo and the sony to make things go away.
Tonight I had the biggest shock ever. Both the Apple Tv , and comcast were displaying normally, then screen goes black for a few seconds...then picture comes back on for a few seconds, then goes black.
I have no idea what this is, but Monday I'm calling Oppo to get a replacement.
The actual Oppo screen on the TV does not do this, only the Comcast and Apple which are going through the Oppo.
I tried plugging in the ATV directly into the HDM1 port on back of Sony tv and all was OK...
Has anyone else experienced weird stuff when changing HDMI selections with the Oppo remote?
thanks
quovadis123 is offline
post #16940 of 24577 Old 05-18-2014, 07:45 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
thanks
Could be a simple fix.
Do you have the latest firmware installed on the player?
Have you tried doing a reset to factory default settings of the player?
Have you tried swapping out the hdmi cable(s) to see if your current one(s) are bad?
Do you have Deep Color turned ON?
Smarty-pants is offline
post #16941 of 24577 Old 05-18-2014, 08:52 PM
rdgrimes's Avatar
Liked: 1426
Its not useless at all, they will try to help you. I've burned many BD discs and played them in the 103D without issue. I do know that Oppo uses the same process to create test discs in their lab. I suspect you have an issue on the disc creation side with formatting, but you haven't provided enough information about what the player actually does with the discs, so its impossible to say. Getting in touch with Oppo support might help you walk through the process and find the problem. Getting mad and screaming about it on this forum won't help at all.
RayWK likes this.
rdgrimes is offline
post #16942 of 24577 Old 05-19-2014, 03:36 AM
_Jack_'s Avatar
The problem was setting "Output resolution" to 4K.
The player was forcing the TV to display full picture, even if divided side-by-side or over-and-under.
Changing to auto resolved the problem.
Thanks a lot for your hints.
_Jack_ is offline
post #16943 of 24577 Old 05-19-2014, 03:36 AM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
so if you have burned "many" blu-ray discs, what software was used to create the folder and what software to burn? the ones I am using, multiavchd and also image burn are proven and I have also burned and played them on other players; never tried the OPPO until now
give me specific examples what software was used and also what media? I already have tried Memorex, Quantum and on the DVD side, TDK
detroit1 is offline
post #16944 of 24577 Old 05-19-2014, 07:33 AM
artur9's Avatar
Quoted: 575 Post(s)
Liked: 199
I've got two more questions about the 103.
One: Does it come in silver? The 105 does but I didn't see a silver one on the Oppo's website.
Two: My DMP-500 has a "Reformat audio" option where it expands 5.1 source material into 7.1. I like it for the additional feeling of envelopment. Can the Oppo do something similar? This isn't the same as using Dolby PLIIx, which I don't like.
artur9 is offline
post #16945 of 24577 Old 05-19-2014, 07:36 AM
Read the FAQ!
Liked: 3348
^ No. And no.
--Bob
lanping09 likes this.
post #16946 of 24577 Old 05-19-2014, 08:05 AM
rdgrimes's Avatar
Liked: 1426
This isn't the place for tutorials on disc burning. The suggestion to discuss this with Oppo support is a good one. If you want help with the player, please describe exactly what happens when you load one of your problem discs in the player. Does it say "no disc"? If not, is the disc visible in the "movie" pathway from the home screen?
rdgrimes is offline
post #16947 of 24577 Old 05-19-2014, 08:37 AM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
I just tried to burn 2 Memorex BD-R and those worked in the oppo
the Memorex BD-RE did not work from a couple days ago
it seems certain media is recognized and others are not
I would recommend to people to use Memorex bd-r if you are burning blu-ray discs for the Oppo
all other software I used was the same as before; only difference was the discs
detroit1 is offline
post #16948 of 24577 Old 05-19-2014, 09:07 AM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
just made avchd disc on DVD, TDK DVD +R and also Memorex DVD DL +R; both played fine on Sony
BOTH failed on the OPPO; you see avchd in the display but then the player gets stuck and nothing happens
detroit1 is offline
post #16949 of 24577 Old 05-19-2014, 10:23 AM
Quoted: 46 Post(s)
Liked: 41
Yes to all the above.
I called Oppo and they told me this was a common problem. Something related to HDMI handshake.
They told me to reboot all equipment and change HDMI inputs on TV, then change HDMI input back to original input.
To tell you the truth I was nearly in tears last night thinking there was something wrong with My tv, which costs over 5k.
The oppo is replaceable it's only a few hundred dollars...I was in a panic last night...
post #16950 of 24577 Old 05-19-2014, 10:24 AM
Quoted: 46 Post(s)
Liked: 41
By the way
Oppo is releasing a new software today they said...
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
