Official OPPO BDP-103 Owner's Thread - Page 571 - AVS Forum | Home Theater Discussions And Reviews
 3146Likes
post #17101 of 24854 Old 05-28-2014, 01:30 PM
IanJohnston's Avatar
Ahhh, didn't realize Plex app could push also. Will try it.
Ian.
IanJohnston is offline
post #17102 of 24854 Old 05-28-2014, 01:44 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
As for your wish list:
1. No.
2. No.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #17103 of 24854 Old 05-28-2014, 04:24 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Originally Posted by IanJohnston View Post
Wish list (or maybe I haven't found these yet):
1. I have my SKY box on HDMI 1 and would prefer a shortcut on the HOME menu to get to it rather than hitting INPUT on the remote. Much more wife friendly!
2. Would also like to be able to rename the labels on the INPUT button menu.........i.e. rename HDMI IN BACK to SKY TV (again for the wife).
Ian.
I use a universal remote for those kind of features. A logitech One (and 650) programmed for "Sky" would select the proper input, turn on all of the required units, setting them to the right inputs all with one button.
Has worked wonders with my daughters and a long list of technology intolerant members of my family.
hernanu is offline
post #17104 of 24854 Old 05-28-2014, 04:39 PM
Changeover35's Avatar
My 103AU won't connect to server when I try to do a firmware update. Haven't had any problems with previous updates. Connection test is good and Youtube streams fine.
Since my last update the only change has been a new ISP and wireless router.
Changeover35 is offline
post #17105 of 24854 Old 05-28-2014, 04:43 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3403 Post(s)
Liked: 2658
The easiest workaround is to download a USB or optical disc version of the firmware and update that way.
It doesn't explain your network update issue, but how much time do you want to spend on it?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #17106 of 24854 Old 05-28-2014, 04:46 PM
JazzGuyy's Avatar
Quoted: 346 Post(s)
Liked: 345
Are you sure a new update has been released for Australia/New Zealand?
JazzGuyy is offline
post #17107 of 24854 Old 05-28-2014, 05:02 PM
-Bill
Many thanks for the prompt reply's.
The Aus/NZ version was released on the 23rd. I have already downloaded to my computer but I will have to go and buy a USB stick. I am puzzled as to why I am having this trouble.
post #17108 of 24854 Old 05-28-2014, 06:37 PM
David Aiken's Avatar
Quoted: 673 Post(s)
Liked: 1195
There seems to be a problem at present with connecting with the Australian server. I've been having the same issue. A friend who bought his Oppo 103D AU from the Oppo Shop gets e-mail notifications of firmware updates from them and the one he got for this update indicated that there were problems with updating via the server at present. I don't know what the problems are but it looks like it's nothing that you or I can do anything about. Just update via USB of disc, it seems to be the only option for us at present.
Mattyo1612 likes this.
David Aiken is online now
post #17109 of 24854 Old 05-29-2014, 06:47 PM
sirhc55's Avatar
I had the same problem with the Australian server. I just downloaded the USB version and updated within 5 minutes. The one thing that is a standout with the 103 is the ability to plug a USB stick into the front of the machine.
sirhc55 is offline
post #17110 of 24854 Old 05-31-2014, 10:00 AM
jake9's Avatar
Quoted: 20 Post(s)
Hey, guys. After upgrading to the latest firmware it seems my Oppo doesn't run like it used to. Changing inputs is very slow to respond, and today when I changed from HDMI in-back, to blu-ray player, the eject button would not work. Both on the remote and on the unit. I had to power cycle it off and on for the disc tray to open. Any thoughts?
Oppo BDP-105D | Parasound Halo A 21 | Parasound Halo P 5 | Rega Planar 3 | Martin Logan Theos | Martin Logan Dynamo 1000
jake9 is offline
post #17111 of 24854 Old 05-31-2014, 10:07 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
do a complete factory reset, restart it, and see if that helps..
wase4711 is offline
post #17112 of 24854 Old 05-31-2014, 12:04 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3792 Post(s)
Liked: 4929
OPPO Tech Support typically monitors their email even on weekends.
The suggestion above to do a full Reset is a good place to start.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #17113 of 24854 Old 06-01-2014, 04:07 AM
Holland108's Avatar
Quoted: 27 Post(s)
Hi,
I own an OPPP BDP-103EU and a SAMSUM F8000. After the latest firmware upgrade the Netflix GUI look great, but I have a problem that the picture freezes for a moment every 3 seconds. It is best noticed when the camera is panning, but it is there whole the time.
Also the sound for Youtube disappeared fully. No sound at all anymore.
My Samsung also has these apps, and these work without any problem. I just want to make use of the picture enhancement ability of the OPPO. And I think it just should work!
Anybody facing the same issues?
Holland108 is offline
post #17114 of 24854 Old 06-01-2014, 04:29 AM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
Originally Posted by Holland108 View Post
Hi,
Try resetting the player to factory default setting in the settings menu and see if that fixes the problems.
Smarty-pants is offline
post #17115 of 24854 Old 06-01-2014, 09:45 AM
Read the FAQ!
Liked: 4929
Hi,
First of all, welcome to AVS and to this thread!
The suggestion above to do a Reset Factory Settings on the OPPO is a good one. If that doesn't fix your problem you should email OPPO Tech Support with the details of what's happening. They may have additional suggestions.
While waiting to hear back, you could also try downloading a fresh copy of the firmware from the OPPO UK site and doing a re-install of the firmware via USB stick.
--Bob
post #17116 of 24854 Old 06-01-2014, 10:04 AM
Holland108's Avatar
Quoted: 27 Post(s)
Hi guys,
thanks, but all above I tried, including contacting OPPO UK support. My problem is currently, that they do not recongnize the issue. No other report.
JVB (my supplier) is also helping, but I just wanted to check, if someone else is also having the same problem.
Mark
post #17117 of 24854 Old 06-01-2014, 11:57 AM
Quoted: 751 Post(s)
Liked: 628
^JVB? Is it a modded player? That might be your problem then.
post #17118 of 24854 Old 06-01-2014, 12:11 PM
Holland108's Avatar
Quoted: 27 Post(s)
Not that I know. Just a standard BDP-103EU without any region modification.
Smarty-pants likes this.
post #17119 of 24854 Old 06-01-2014, 02:11 PM
Daffietje's Avatar
Quoted: 54 Post(s)
So if it is modded that is always the reason for the problems you have with the player? Kind of a strange conclusion IMO.
I guess the problems I had when first trying SMB were also due to the fact I have a modded player...
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #17120 of 24854 Old 06-01-2014, 02:39 PM
Quoted: 751 Post(s)
Liked: 628
His problems are not consistent with those of the average user when it comes to player/firmware issues.
If his player is modded from the original state, it is more likely that something could be wrong because of that modification.
Many people have had issues and realize after troubleshooting that the problem was do to a region mod kit.
It's a reasonable suggestion, but besides that, I never said it was definitely what was causing the issue, I said it "might" be the issue. wink.gif
post #17121 of 24854 Old 06-01-2014, 04:04 PM
Daffietje's Avatar
Quoted: 54 Post(s)
^I know and understand your reasoning.
But when he said JVB you immediately made the conclusion of a modded player and besides, JVB is one of the most experienced retailers when it comes to modding the Oppo's here in the Benelux.
Sure, if you go and do some stuff yourself with a region mod kit without the needed knowledge or experience I guess you could end up with issues.
post #17122 of 24854 Old 06-01-2014, 04:15 PM
Quoted: 751 Post(s)
Liked: 628
Didn't make any conclusions, just asked a couple questions, but it's moot anyway since he said it's not modded.
Maybe JVB is well known and respected, that's fine, but assuming any modded player will be immune to issues across all firmware revisions is simply wishful thinking.
post #17123 of 24854 Old 06-01-2014, 04:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2107
... and furthermore, any mod should always be included in a de-bugging check list. smile.gif
Members who try to help owners with their problems are frequently blind sided by "information not provided upfront." eek.gif
htwaits is offline
post #17124 of 24854 Old 06-01-2014, 04:40 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
My favorite is assuming that the cables, wires and connections are good.
As a tech, I would always assume my test equipment was good and the unit I was testing was bad. Leaned a lot from experience.
htwaits likes this.
Mongo171 is offline
post #17125 of 24854 Old 06-02-2014, 11:02 AM
Holland108's Avatar
Quoted: 27 Post(s)
Thanks for trying to help. But does his also mean that your picture via OPPO netflix app, is smooth?
I mean no hick-ups? at all?
post #17126 of 24854 Old 06-04-2014, 02:58 PM
gsbusch's Avatar
Input to OPPO 103 is a DVD.
Connecting  a newer TV/Projector via HDMI works fine.
Using OPPO's  7.1 analog output to an A/V receiver to feed my loudspeakers is a concern. What is the default or takes preference,  HDMI audio channel or 7.1 analog channel or are both channels being transmitted?
gsbusch is offline
post #17127 of 24854 Old 06-04-2014, 03:12 PM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
All of the outputs of Oppo Blu-ray players are active all the time - there is no switching between them. I have the analog outputs connected to my power amplifiers and the HDMI to my TV and they both output at the same time - which requires me to turn down the TV when listening to multi-channel music or sound tracks.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #17128 of 24854 Old 06-04-2014, 04:20 PM - Thread Starter
Neuromancer's Avatar
Quoted: 96 Post(s)
Liked: 370
Yes, the video will be very smooth. I have not had any playback issues with the latest Netflix interface and the BDP-103D I use at home.
Neuromancer is offline
post #17129 of 24854 Old 06-04-2014, 08:28 PM
dmusoke's Avatar
Quoted: 388 Post(s)
Liked: 192
I want to stream TV show videos(NBC "The Grimm") from my Android cell phone(Samsung Note 3) to my Oppo 105. Can this be done and if so, what app should i use?
jjwinterberg likes this.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #17130 of 24854 Old 06-05-2014, 03:28 AM
cvn74n2's Avatar
I am wondering the benefits of using a multi-channel AVR versus multiple two channel receivers. Reading through this thread and reviews, it seems to me many Oppo 103 owners prefer the sound quality coming from the unit's analogue output using its internal DACs over having it processed by the AVR's DACs.
Where I am going with this is figuring out whether it's better to buy multiple, inexpensive but well regarded stereo receivers (such as 3x Yamaha R-S201s) and allow the Oppo to do the heavy lifting of processing and outputting the audio signals. AVRs with multi-channel analogue inputs cost 2+ times what the three R-S201s combined cost would be and have duplicative audio processing features inherent in the Oppo.
My speakers are Pioneer 5.1 speakers (Andrew Jones first generation with two floorstanders, two bookshelfs, a center, and powered sub). I envision sending the video signal straight from the Oppo to my 2008 Panny plasma via HDMI.
All thoughts are welcome.
cvn74n2 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
