Official OPPO BDP-103 Owner's Thread - Page 574 - AVS Forum | Home Theater Discussions And Reviews
 3145Likes
post #17191 of 24852 Old 06-10-2014, 12:16 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Is there a way on the Oppo 103 to see the AVERAGE video and audio bitrates of a Blu-Ray disc ?
When hitting the info button I can only see the CURRENT video bitrate (audio bitrate is not even visible)
jjwinterberg likes this.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #17192 of 24852 Old 06-10-2014, 12:24 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2655
No. I don't recall anyone asking for this before. Wouldn't you have to read the entire disc to find that average? Or do you mean "average to this point"?
That's really more of an HTPC analysis issue, such as you find in other title specification threads here.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #17193 of 24852 Old 06-10-2014, 12:40 PM
Daffietje's Avatar
Quoted: 54 Post(s)
I dont have a Bluray reader on my PC, otherwise I could just see this info with "Media Player Classic" for example.
Was wondering if the Oppo had this option...
post #17194 of 24852 Old 06-10-2014, 01:08 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Wouldn't you have bitrate 'til this point then? You'd have to scan the entire presentation to get the real average.
Could also project it via the total size of the main feature vs. the elapsed time, giving you an overall average.
hernanu is offline
post #17195 of 24852 Old 06-10-2014, 02:05 PM
jcg
jcg's Avatar
Quoted: 22 Post(s)
I've had my oppo 103 for awhile and have never had any issues, but I mostly just play Bluray disks. Today I tried playing a .mkv file using a usb flash drive in the front usb port. There was some major lipsync, so I'm wondering if this is normal when using a flash drive or if something else might be going on?
jcg
jcg is offline
post #17196 of 24852 Old 06-10-2014, 02:09 PM
wmcclain's Avatar
Liked: 2655
jcg
No, they should be the same. Have you tested the file on other devices?
-Bill
wmcclain is offline
post #17197 of 24852 Old 06-10-2014, 02:36 PM
Daffietje's Avatar
Quoted: 54 Post(s)
"Media player classic" just gives the average bitrate of a digital file. I have not been able to test this with a Blu-ray disc yet, since I don't have one in my PC.
How can I find out the total size of the main feature?
post #17198 of 24852 Old 06-10-2014, 02:42 PM
wmcclain's Avatar
Liked: 2655
Try this thread: http://www.avsforum.com/t/1155731/new-unofficial-blu-ray-audio-and-video-specifications-thread
-Bill
wmcclain is offline
post #17199 of 24852 Old 06-10-2014, 02:52 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Thanks Bill, I know that thread, but my version is not included in that list (I have the Dutch version from RCV)
post #17200 of 24852 Old 06-10-2014, 03:51 PM
jcg
jcg's Avatar
Quoted: 22 Post(s)
-Bill
I just installed VLC on my computer so I could play the .mkv file, and it looks like it has some lip sync delay too. I guess I'll try a different .mkv file in the Oppo, as it looks like there isn't anything wrong on the Oppo's side.
jcg
jcg is offline
post #17201 of 24852 Old 06-12-2014, 03:18 AM
pbarach's Avatar
Quoted: 373 Post(s)
Liked: 221
dvdbeaver.com reviews new DVDs and BluRays, often comparing versions from different reguions. Their reviews show graphs of the bitrate through the length of the main feature, e.g. this review of The Grand Budapest Hotel:
http://www.dvdbeaver.com/film4/blu-r...el_blu-ray.htm
Daffietje likes this.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #17202 of 24852 Old 06-12-2014, 08:24 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by JazzGuyy View Post
I have a 105 with a region mod and I have never seen any firmware upgrade either affect it or be affected by it. I wouldn't expect any difference with a 103 since their basic circuitry is the same.
There are a couple of things you should probably do as part of a firmware update when you have a region mod. First, make sure your player is set to its 'home' region and not to some other one. So, if you live in Region A territory, be sure you have set your player to that Region. Second, it is probably advisable to do a factory reset after the firmware update and then re-enter your personal settings. Finally, I have found that sometimes after a firmware update the region mod seems particularly sensitive to the timing of the entry of the key presses on the remote necessary to change regions. The first time I make a region change after a firmware update sometimes takes a couple of tries. It will subsequently be fine. The experience may be different on your particular mod.
You do know that you can backup and restore your settings? That is made so you dont have to re-enter your settings everytime after a factory reset.
post #17203 of 24852 Old 06-12-2014, 09:05 AM
JazzGuyy's Avatar
Quoted: 346 Post(s)
Liked: 345
Settings backup
Yes, I am aware of it. Some people, though, have not updated their firmware to a version that supports it.
JazzGuyy is offline
post #17204 of 24852 Old 06-12-2014, 09:15 AM
runnerlk's Avatar
Question BDP-103 SACD/DSD play back issue
I have a 103 with the latest firmware connected via HDMI to an Integra DHC 80.3. Redbook cd and Blu-ray play fine SACD and DVD-A do not. This did play fine at one time and I don't listen to digital music much, I'm a vinyl guy.
When I view the disc through the OSD it appears to be playing and is recognized as a SACD via DSD but no sound.
Any input would be greatly appreciated.
runnerlk is offline
post #17205 of 24852 Old 06-12-2014, 09:56 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3789 Post(s)
Liked: 4928
^ The most likely explanation is that you are mistakenly listening to audio on the Optical or Coax digital audio output instead of via HDMI audio. Check your audio input selection in the Integra.
For SACD playback, also set SACD Output PCM and see if you get audio via HDMI to the Integra.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #17206 of 24852 Old 06-12-2014, 12:35 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Thanks, Will bookmark it, unfortunately we were soldiers is not included
post #17207 of 24852 Old 06-12-2014, 01:11 PM
lujan's Avatar
Quoted: 2765 Post(s)
Liked: 1279
I know this doesn't belong on this Thread but I don't like the new version of AVS. I don't know why they keep having to mess up a good thing? I had my AVS link setup to go directly to the subscribed threads and then the latest unread post. I can't seem to find a way to do that with this new version. I used to have it setup to read the latest posts at the top as well and can't find that as well in order to change it. Maybe they want us to start paying for AVS 'cause I see the "Get Premium" all over the place. I may not be reading these posts as often because of all these changes?
lujan
234 Ultra HD
780 HD
18 HD DVD
4 SD
lujan is offline
post #17208 of 24852 Old 06-12-2014, 01:15 PM
wmcclain's Avatar
Liked: 2655
Then don't post it here, please.
The Operations Center has non-stop reports of the issues, and the forum behavior has been improving every hour.
Please take your concerns there, not here.
-Bill
wmcclain is offline
post #17209 of 24852 Old 06-12-2014, 01:19 PM
Read the FAQ!
Liked: 4928
^ The Forum Operations Center forum has threads with folks discussing this stuff. Changes / fixes / corrections / improvements in the new site are being done in real-time -- without taking the site down -- as issues are noted.
So go check it out there and be patient for a bit.
This link should take you to your current list of Subscribed Threads:
http://www.avsforum.com/forum/subscr...ewsubscription
--Bob
post #17210 of 24852 Old 06-12-2014, 04:19 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
OT topic posts removed. If you have suggestions on how to improve the forum software, please take them to the Operations Center. Everyone is working hard to improve everyone's experience.
http://www.avsforum.com/forum/43-for...ations-center/
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #17211 of 24852 Old 06-13-2014, 02:49 PM
johnnywyoming's Avatar
I have super slow satellite internet at home but dsl at work. Can I download movies, Netflix etc at work and play them through my Oppo? What would I use? Flash drive? How can I store those movies to watch later?
Samsung HL61A750
Harman Kardon AVR520
Oppo BDP-103
Dynaco A35 fronts
Wharfedale WH-2 Center with dipole rears
Wharfedale Diamond 10.SX sub
johnnywyoming is offline
post #17212 of 24852 Old 06-13-2014, 02:50 PM
Read the FAQ!
Liked: 4928
^ Nope. Live streaming only. No downloading of Netflix for later playback.
--Bob
post #17213 of 24852 Old 06-13-2014, 11:21 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Hy, I have a Oppo103eu, and want to buy an external 3 o 4TB hardrive but would like to know if the Oppo has no problems with this sice, for example my previous Dune HD Smart D1 only suported 2TB.
Regards.
NeogeoG is offline
post #17214 of 24852 Old 06-14-2014, 05:08 AM
rdgrimes's Avatar
Quoted: 2482 Post(s)
Liked: 1785
Regards.
No problem. FWIW the Dune also supports 3-4 TB drives with current firmware.
NeogeoG likes this.
rdgrimes is offline
post #17215 of 24852 Old 06-14-2014, 05:24 AM
JazzGuyy's Avatar
Quoted: 346 Post(s)
Liked: 345
Regards.
There should be no problems with a 4TB external drive.
NeogeoG likes this.
JazzGuyy is offline
post #17216 of 24852 Old 06-14-2014, 05:29 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I'm not sure if this has been covered before, but I was hoping someone who's tackled it more extensively might be able to give me a pointer. With my IR-prone ZT60, I absolutely need a way to rely upon a screensaver when using Netflix. I've heard that some products (AppleTV, Roku) have screensavers that activate independently of the app currently loading, Netflix included (I've also read about problems where it works for every app but Netflix on these same devices). Is a Roku stick my only means to attaining this functionality on the Oppo BDP-103 and for those who have the Roku, are you able to use a screensaver while Netflix is running? If I could simply disable video output with the push of a button on the Oppo remote without the need of Roku, that would also be a suitable alternative (I'm thinking that's not possible based on past experience with Netflix and Oppo).
vinnie97 is offline
post #17217 of 24852 Old 06-14-2014, 05:34 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
The screensaver in Netflix works on my 105. Not sure, but you might be able to blank video with the Pure Audio button.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #17218 of 24852 Old 06-14-2014, 05:57 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
That's interesting. The Pure Audio button doesn't override the Netflix output unfortunately. Haven't reset the settings on the latest firmware update, so maybe I'll try that first.
vinnie97 is offline
post #17219 of 24852 Old 06-14-2014, 07:40 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
To be absolutely clear, are you referring to the Netflix screensaver, one that shows a red screen with the Netflix logo randomly bouncing around, or the Oppo screensaver (I have mine set to default to no video output). I have not had the chance to reset and test again (I am currently doing an exhaustive slide/pixel flipping session to get rid of longstanding IR). If anybody with a 103 on the latest firmware can confirm or deny these results, it would also be helpful.
vinnie97 is offline
post #17220 of 24852 Old 06-14-2014, 08:23 PM
rdgrimes's Avatar
Liked: 1785
The new Netflix app has no screensaver at all, nor is one available or possible in the Oppo. Previous Netflix app had a 1/2 brightness screensaver that kicked in after a while, but not this one. So you're best off to just hit the Home button and exit Netflix, then let the Oppo screensaver kick in. I guess Netflix decided that plasma TVs are unworthy of consideration.
vinnie97 likes this.
rdgrimes is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
