Official OPPO BDP-103 Owner's Thread - Page 577 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #17281 of 24577 Old 06-17-2014, 11:28 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2823 Post(s)
Liked: 2073
Originally Posted by thebishman View Post
Quick ? As I don't have time to read all 577 pages:
I already own one 103 and am looking to buy another but will wait until they become equipped with the HDMI 2.0 spec parts. Any info on when this might occur?
TIA
No info.
I expect HDMI 2.0 to be a long, troubled rollout for the industry. And they'll be doing a new HDCP at the same time.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #17282 of 24577 Old 06-17-2014, 11:37 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2630 Post(s)
Liked: 3348
Originally Posted by sharok View Post
Good Afternoon Bob,
Yes, my laptop HDMI passes 1080p.
If Oppo is being used as a processor (analog outputs going to amp) and my laptop is connected to Oppo via HDMI, is it possible to pass the video to my TV from Oppo while Oppo is playing SACD?
I'd like to play my SACDs and high quality CD (MFSL) using Oppo and also use my laptop visualization at the same time.
No. As I said above, when viewing an HDMI Input of the OPPO you can't *ALSO* play any other content.
To do what you want to do, you will need to connect the laptop to your AVR as well as the audio connection from the OPPO (presuming your AVR allows you to mix inputs like that -- check for how it tells you to connect a "DVI" source device for example).
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #17283 of 24577 Old 06-17-2014, 11:43 AM
sharok's Avatar
Quoted: 249 Post(s)
Liked: 74
--Bob
Thanks Bob.
So using a capable (using two inputs simultaneously) AVR/proc is my only option for that usage.
sharok is online now
post #17284 of 24577 Old 06-17-2014, 01:41 PM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
Originally Posted by NeogeoG View Post
Hy, I have a Oppo103eu, and want to buy an external 3 o 4TB hardrive but would like to know if the Oppo has no problems with this sice, for example my previous Dune HD Smart D1 only suported 2TB.
Regards.
I have a new 5TB Toshiba HDD hooked up to my 103D without any issues. You'll be fine.
Chere is offline
post #17285 of 24577 Old 06-17-2014, 02:06 PM
rdgrimes's Avatar
Quoted: 2109 Post(s)
Liked: 1426
TIA
Currently there's no practical use for HDMI-2 hardware in a disc player, nor is there likely to be in the near future. That said, there's no doubt it will become the next big "check-off" item for hardware marketing to brag about. You're waiting for a dream. (or a nightmare as Bill suggested)
rdgrimes is online now
post #17286 of 24577 Old 06-17-2014, 02:28 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Thanks Bob.
You could also do what I've done many times before, if your setup allows it.
Oppo->AVR, play music.
Laptop->TV - Skip the AVR, just plug your laptop directly into your TV. Just change the input on your TV to your laptop while you let the music play.
BobearQSI is offline
post #17287 of 24577 Old 06-17-2014, 02:43 PM
johnnywyoming's Avatar
Originally Posted by wmcclain View Post
DVDs only, not Blu-ray? There is a known problem with DVD rewind when DVD 24p is turned on. If you have that set, try turning it off. We expect this will be fixed in future firmware.
-Bill
Thanks Bill. Only dvds so far but will check Blu-rays tonight and check the dvd24p which I believe I have set to on.
Samsung HL61A750
Harman Kardon AVR520
Oppo BDP-103
Dynaco A35 fronts
Wharfedale WH-2 Center with dipole rears
Wharfedale Diamond 10.SX sub
johnnywyoming is offline
post #17288 of 24577 Old 06-17-2014, 06:12 PM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
Originally Posted by johnnywyoming View Post
Updated to the new firmware over the weekend and still have an old problem and a new one.
After muting or pausing Directv I get an audible "pop" when I turn the volume back on or hit the play. I thought that this problem was corrected two firmware versions ago but apparently it is back. I run analog 5.1 outs to my AV receiver.
I recently tried to use my directv box through the 103 again, but for me the miniscule, random audio glitches common to their DD feeds were multiplied to second(s) long every time they happened, so lost too much additional audio than normal via a direct audio feed through my receiver.
I did pay more attention to the picture though, and for the most part it did seem to be an improvement overall compared to my direct feed the the tv.
(It's my understanding that even the newest directv boxes have similar audio issue, but I could be wrong. Don't really want to make a 2 year additional commitment to find out.)
fmalczewski is offline
post #17289 of 24577 Old 06-17-2014, 08:05 PM
rdgrimes's Avatar
Liked: 1426
DirecTV has always had issues with DD 5.1 streams, which are much worse via HDMI. No doubt, any glitch will force the Oppo to re-handshake on the downstream side.
post #17290 of 24577 Old 06-17-2014, 09:10 PM - Thread Starter
Neuromancer's Avatar
Quoted: 86 Post(s)
Liked: 328
This happens all the time with my cable box I use with Comcast direct to my receiver as well. Just sounds like the HDMI outputs on these devices are pretty terrible.
Neuromancer is offline
post #17291 of 24577 Old 06-17-2014, 10:43 PM
Quoted: 102 Post(s)
Liked: 39
Ok, some things never change I guess. Actually in order to avoid my dvr locking up occasionally while fast forwarding or rewinding, I ended up early on limiting the hdmi to video only and using optical for the DD. Maybe that helps make the DD audio glitches less of an issue during my normal use.
post #17292 of 24577 Old 06-17-2014, 11:31 PM
Changed the dvd24p setting to off and that cured the rewind freeze problem. From the above posts it looks like I'll have to live with the directv audio glitches until a work around is accomplished.
Samsung HL61A750
Oppo BDP-103
Dynaco A35 fronts
post #17293 of 24577 Old 06-18-2014, 09:53 AM
Manic_D's Avatar
Quoted: 13 Post(s)
I've not had issues with RW/FF of DirecTV going through my Oppo. I have, however, had a couple of lockups during resolution changes after deleting a program, but never when just channel surfing. No issues at all with audio, although I used to have them with my previous AV receiver. My DTV receiver is an older model HR21-700, and current AVR is Denon 3311, FWIW.
sorry for all of the abbreviations!
Manic_D is offline
post #17294 of 24577 Old 06-18-2014, 10:15 AM
Quoted: 102 Post(s)
Liked: 39
I think things went screwy with the HR24 (new model when I started subscribing), so hold on tight to your HR21. I'll be sticking with my Denon 5805mk2 for as long as it will have me... it works great with everything else I've thrown at it, including the Oppos.
post #17295 of 24577 Old 06-18-2014, 03:53 PM
Liked: 0
There's a few potential issues here, none of which are the player's fault. Your router has the job of presenting the shares, and that's where you should start looking for settings. If the drives were formatted using the MAC, there may be additional issues there. Suggest you look for solutions in the various forums for networking and MACs. As for the Oppo, if no user or password is required on the share, just enter past that password screen, leaving it blank.
So the discs were formatted as FAT, because anything else the 103 did not recognise (my popcorn hour did recognise extended journal format, which was the original formatting, which I had to redo). Since the 103 can read the discs when connected directly with USB that is not the problem.
Also, it can see the drives via the network when those are connected to the router, but it just cannot access it. Someone in another forum suggested this was because the 103 only does SMB1, and Apple uses SMB2 (as a note on that, the Airport extreme is supposed to use SMB1 for USB disc sharing, but the fact that the 103 asks for a username and password means it probably works in SMB2).
I probably should try without the USB hub. As a note the hub is a powered hub, because non-powered hubs don't work on the AEBS...
ksporry is offline
post #17296 of 24577 Old 06-18-2014, 07:37 PM
johnny tuna's Avatar
re: Oppo not passing through signal
I have had some issues with the Oppo since I bought it. The most recent one is that it has stopped passing through my cable signal from my cable tv box. It was working, then it started to get fussy about it, taking longer than normal to handshake, now nothing. The other settings work fine. Thoughts?
johnny tuna is offline
post #17297 of 24577 Old 06-18-2014, 08:23 PM - Thread Starter
Quoted: 86 Post(s)
Liked: 328
Try the HDMI IN FRONT instead of the HDMI IN REAR on the player.
Try an alternative HDMI cable between the player and the cable box/player and the television.
Try HDMI 1 direct to the television and remove any HDMI 2 cable and see if the same errors persist.
post #17298 of 24577 Old 06-18-2014, 09:32 PM
PGunstone's Avatar
A thank you to everybody that has posted here as it answered most of my questions and convinced me to upgrade, so I picked myself up a 103.
Great upgrade from my older BDP. It's been able to play everything I've thrown at it (via DLNA) that lives on my NAS and PQ from blu-rays are certainly better that what I had expected. Only downside is I can't use any of the movie streaming apps due to my geographic location..
I haven't really touched the settings but without going through all 577 pages (I've been through most) of posts, any quick "best config" for PQ tips?
Thanks all.
PGunstone is offline
post #17299 of 24577 Old 06-18-2014, 09:44 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
You might look at this unofficial "recommended settings" document for the 103.
PGunstone likes this.
DSperber is offline
post #17300 of 24577 Old 06-18-2014, 11:07 PM
PGunstone's Avatar
Cheers DSperber. I'll have a look through it.
post #17301 of 24577 Old 06-19-2014, 07:35 AM
poolratt's Avatar
Hey guys and gals, Iv'e got a question. I'm having a problem with either my Oppo BDP-103 or my Onkyo PR-SC886 so I'll post this in both threads. When I'm playing a BD disc with DTS HDMA 7.1 audio it shows on the 103's display that It's reading the correct format but my Onkyo only shows DTS in it's disply and I do have the 103 set to bitstream. The thing that"s confusing is I can hook up my Panny, Sammy & Sony players to the Onkyo and have no problem getting the Onkyo to display DTS MA. What am I doing wrong? Thanks!!!!!!!
poolratt is offline
post #17302 of 24577 Old 06-19-2014, 08:03 AM
Read the FAQ!
Liked: 3348
^ Set Secondary Audio OFF.
--Bob
lanping09 likes this.
post #17303 of 24577 Old 06-19-2014, 05:08 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
Just received my BDP-103. A couple of quick questions.
1) Wasn't there some sort of first time setup wizard? When I powered mine up for the time, it just took me to the home screen.?
2) It's telling me that a new firmware is available (connected via wired ethenet). When I select yes to upgrade, it just takes me back to the home screen.? It's done the 3X now...
3) What state does the player need to be in to have it's networking (UPNP/DLNA) started (ie the player shows up on the network). Do I have to browse to the Network source? I would think it would show up as soon as the player is turned on, and it has had time to connect to the netowork? However, I can only seem to find it, when I go to the home screen, and then select the Network Icon. Is this the case?? If so, is there a command to take it to the Network Source/Browser?
barhoram is offline
post #17304 of 24577 Old 06-19-2014, 05:08 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
barhoram is offline
post #17305 of 24577 Old 06-19-2014, 05:17 PM
wmcclain's Avatar
Liked: 2073
1. Past players have had setup wizards. It's not required anymore.
2. Are you in the US with a US player? If no go, download the USB or CD version and update that way the first time.
3. Is DLNA not working for you? Can you see the servers on your network from the player's network browser?
Pulling DLNA from the player will work even if the player is not visible from other devices. If you are trying to push files to the player as a renderer then we will have to investigate why it doesn't appear.
-Bill
post #17306 of 24577 Old 06-19-2014, 05:18 PM
JazzGuyy's Avatar
Quoted: 297 Post(s)
Liked: 292
Have you done the network test in the setup menus to see if you are actually connecting to your menu?
JazzGuyy is offline
post #17307 of 24577 Old 06-19-2014, 07:10 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
-Bill
Yep. US with US Player.
DLNA seems to be working. I can browse and playback .MKV files fine through the player's network browser.
Pushing DLNA is what I'm trying to do. Is there a specific state the player needs to get to where it shows up for other network devices to see? I had to enter into the player's Network Browser before I was able to see it and push a file to play. On a similar note, does it need to be in a specific state to allow playback to being (stopped, etc)? What happens if playing a local blu-ray disk, and you push a file?
When I was able to finally push a file, it seems to playback well. However, I can't get it to chapter forward or reverse. These are all .MKV rips of my blu-ray collection. Chapter forward and reverse work well if I start a file from the player itself through Oshare. Is this a known issue for pushing an .MKV file?
barhoram is offline
post #17308 of 24577 Old 06-20-2014, 05:01 AM
poolratt's Avatar
--Bob
That worked Bob. Thank you!!!
poolratt is offline
post #17309 of 24577 Old 06-20-2014, 06:19 AM
Read the FAQ!
Liked: 3348
Good. Just so you understand what's going on, when Secondary Audio is ON, and a Secondary Audio track is available anywhere on the disc you are playing, the Blu-ray specs require the player to act as if you are using a Secondary Audio feature on the disc, even though you aren't. That's tied up in how BD-Java programming on the disc can initiate things like Secondary Audio without giving the player prior warning. Secondary Audio is usually found as menu sound effects or as commentary track audio for some picture-in-picture commentaries.
Now, Secondary Audio can't be mixed into the Primary audio track while that's still a Bitstream. So when Secondary Audio is engaged, the Bitstream Primary track first has to be decoded into LPCM in the player. Then, if you've set Bitstream output, the result after mixing has to be RE-encoded back into a Bitstream for output. But no consumer device has the horsepower to re-encode a lossless Bitstream on the fly like this. So a lossy Bitstream format is used instead. In the case of the 103, what's used for the re-encode is the highest bit-rate form of DD or DTS -- at 5.1 channels -- according to whether the original Bitstream was Dolby TrueHD or DTS-HD MA.
The upshot is that while using HDMI Audio Bitstream, you should leave Secondary Audio OFF unless you actually want to use a feature on disc requiring it.
Note that if you use Analog audio output, or use HDMI Audio LPCM, you can leave Secondary Audio ON all the time without any such potential loss of quality to the Primary track when there's no actual Secondary Audio mixing happening. The full quality of the Primary track -- including channel count, sample rate and bit size per sample -- is preserved. (While Secondary Audio is actually present and selected, the Primary track is usually attenuated as part of the disc's audio mixing programming.) This is one reason why I suggest people use HDMI Audio LPCM.
When you bring up the on-screen info display, the audio format being read off disc is shown in the lower left. That's preceded by an icon. The overlapping discs icon indicates Secondary Audio processing is NOT engaged. The wavy line icon indicates Secondary Audio processing IS engaged -- again, whether or not you've actually selected to use a Secondary Audio feature on the disc.
If you press Page Up/Down to change what's shown on the on-screen Info display, the bottom line will now show what's going out on the HDMI outputs.
--Bob
Daffietje likes this.
post #17310 of 24577 Old 06-20-2014, 07:44 AM
Daffietje's Avatar
Quoted: 54 Post(s)
So Bob, I have my Oppo 103 set to PCM. In that case I can set Secondary Audio safely to ON without the risk of any audio quality loss in the primary stream. Correct?
Because when reading your line : ''(While Secondary Audio is actually present and selected, the Primary track is usually attenuated as part of the disc's audio mixing programming.)'' this sounds like there is still some quality loss in the Primary track when Secondary Audio is selected.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
