Official OPPO BDP-103 Owner's Thread - Page 586 - AVS Forum | Home Theater Discussions And Reviews
 891Likes
post #17551 of 24634 Old 07-07-2014, 11:49 AM
Wireless member
pepar's Avatar
Quoted: 1029 Post(s)
Liked: 534
I am assuming from what I got from reading the 1st post that the native MCH DSD playback from attached USB storage has not been undone by any subsequent firmware?
Is attached USB storage still the only way for the 103 to bitstream MCH DSD to my Onk 5508 over HDMI? Or has that been enabled/introduced with some other network scheme?
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #17552 of 24634 Old 07-07-2014, 11:58 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Jeff
You can play back DSD audio via attached usb, or via network (DLNA or SMB shares). The Oppo only sends out a DSD stream via its hdmi 2 output if the proper 103 settings (SACD Output) are selected and the device on the other end of the hdmi cable can receive DSD streams.
DanF8500 is offline
post #17553 of 24634 Old 07-07-2014, 12:33 PM
Wireless member
pepar's Avatar
Liked: 534
Originally Posted by wadeh911 View Post
Thr jriver wiki has a thread on pushing DFF and DSF and they seem to think this is current limitation of the 105 as jriver handles both DSD formats.
Pardon me for jumping in here, but a recent demo by a local fellow AVS'er showed that jriver does "handle" DSD, but it does so by converting it ... IN SOFTWARE ... to PCM. Personally, I do not consider that "handling" it.
Jeff
pepar is offline
post #17554 of 24634 Old 07-07-2014, 12:35 PM
Wireless member
pepar's Avatar
Liked: 534
Thanks Dan. I stress MCH (multichannel) DSD as that has *always* been the catch for networked connections.
Jeff
pepar is offline
post #17555 of 24634 Old 07-07-2014, 12:41 PM
Wireless member
pepar's Avatar
Liked: 534
Just saw this ... so I would need to connect HDMI 1 for BDs, DVD and DVD-A, and HDMI 2 for DSD?
Jeff
pepar is offline
post #17556 of 24634 Old 07-07-2014, 12:49 PM
SeeMoreDigital's Avatar
Quoted: 479 Post(s)
Liked: 200
Jeff
My Oppo (not D version) is permanently connected to my Onkyo amplifier via HDMI 2. It passes all 'multi-channel' bit-stream audio formats on any disc format just fine
EDIT: It's also pretty good at playing multi-channel FLAC and PCM.wav files via SMB and UPnP too
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #17557 of 24634 Old 07-07-2014, 12:52 PM
Wireless member
pepar's Avatar
Liked: 534
So there is NO downside to simply using HDMI 2 for everything? I do not use the player's vid processing.
Jeff
pepar is offline
post #17558 of 24634 Old 07-07-2014, 12:53 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Jeff
Jeff, unless I'm mistaken, I believe JRiver can "push" DSD audio(.dsf/.dff) "as is" to the Oppo players.....no transcoding is necessary....and there is no container reformatting (DoPE) taking place either. The DLNA server settings in JRiver show that the "original" DSD file is pushed to the Oppo 10x players. In fact, I know it is because the only way the Oppo can illuminate its front panel SACD indicator is if it is receiving a DSD audio stream (or playing an SACD disc), and I see the indicator illuminated when pushing DSD audio to it.
DanF8500 is offline
post #17559 of 24634 Old 07-07-2014, 12:59 PM
Quoted: 479 Post(s)
Liked: 200
Jeff
Not that I've noticed... My Oppo is set to 'Source Direct' and I don't have any of its fancy video post-processing options enabled...
post #17560 of 24634 Old 07-07-2014, 01:34 PM
Wireless member
pepar's Avatar
Liked: 534
Now that I think about it, it was probably that the custom-PC/media server could not output MCH DSD over HDMI. The pre/pro clearly showed PCM and not DSD. This is in spite of the setting you mention that jriver is supposedly outputting DSD.
Do you have such a server that will output DSD over HDMI?
Thinking about it further, my research into jriver showed that it would output 2-ch DSD but only over whatever-dem-fancy-cables-are connections ... to an external DAC. That was very early this year or maybe late least year that I dug into this.
I was never able to find a "sound card" that could output MCH DSD over HDMI.
Jeff
edit: MCH DSD over HDMI, the only way our gear can received DSD, is not an option with JRiver. So it is the 103 Oppo and attached USB storage.
pepar is offline
post #17561 of 24634 Old 07-07-2014, 01:38 PM
Wireless member
pepar's Avatar
Liked: 534
Thanks, then that is one less detail I need to worry about.
thanks everyone for putting up with my single-minded purpose!
Jeff
pepar is offline
post #17562 of 24634 Old 07-07-2014, 01:48 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 225
Jeff
Was he using JRiver as a DLNA server or as a media player?
Properly configured when functioning as a DLNA server, it will do no such thing. It will serve up the file exactly as-is and all of the unpackaging, decoding, and everything else will be done at the endpoint - the 103 in this case.
Now - give that there are few PCs that can output DSD from their SOUND (TosLink, HDMI, etc. - but not network) interfaces, it would not surprise me at all if JRMC, when being used as a native media player in an HTPC, would convert DSD to PCM before output.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #17563 of 24634 Old 07-07-2014, 03:18 PM
Wireless member
pepar's Avatar
Liked: 534
Probably the latter.
For multi-channel DSD? The Oppo accepts mch DSD over its ethernet connection when connected to a DLNA server?
Well, exactly NO PCs output mch DSD over TosLink or HDMI.
pepar is offline
post #17564 of 24634 Old 07-07-2014, 03:25 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I thought I told you it did in my first reply to you? I guess I wasn't specific about multi-ch vs 2-ch dsd, but the 103 is capable of receiving .dsf/.dff file formats (stereo and multi-ch) via the ethernet (DLNA or SMB).
DanF8500 is offline
post #17565 of 24634 Old 07-07-2014, 03:37 PM
Kal Rubinson's Avatar
Quoted: 718 Post(s)
Liked: 495
JRMC will output what you tell it to output and whatever the attached cables/devices can handle. I can send DSD or PCM, stereo or multichannel, from it via USB or HDMI depending on what my needs are. Coax and toslink are much more limited.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #17566 of 24634 Old 07-07-2014, 03:44 PM
Wireless member
pepar's Avatar
Liked: 534
Thanks, Kal. On what hardware are you running JRiver?
pepar is offline
post #17567 of 24634 Old 07-07-2014, 03:47 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
haha...Jeff, I've been on the 10x forums for the past year...I've lived through each and every firmware upgrade....I know what it can and cannot do....I will say there's been much more discussion about what you're inquiring in the 105 forum, where I hang out more. There is no online document/manual to get answers some times....I guess you'll have to test it out yourself if you don't believe me....or get more responses from other users who have successfully been playing DSD audio via the 10x player's network interface....
DanF8500 is offline
post #17568 of 24634 Old 07-07-2014, 03:49 PM
Quoted: 718 Post(s)
Liked: 495
I have a pair of Win/PC-based servers (C.A.P.S. Zuma).
Kal Rubinson
post #17569 of 24634 Old 07-07-2014, 03:55 PM
Wireless member
pepar's Avatar
Liked: 534
Thanks, I guess this boundary has been pushed a lot in the last year or so. The Oppo interface for DSD on attached USB storage is very crude, and with hundreds of titles becomes fairly worthless. So now I guess I need to research DLNA. I'll go to the 105 thread, read the first post, and the last two months and then do some searching for the relevant discussion.
Jeff
pepar is offline
post #17570 of 24634 Old 07-07-2014, 04:15 PM
Wireless member
pepar's Avatar
Liked: 534
Thanks again, Kal. Googling that is a quick trip down the rabbit hole and not one that can be done quickly. But I will do my due diligence....
Jeff
pepar is offline
post #17571 of 24634 Old 07-07-2014, 04:58 PM
Quoted: 718 Post(s)
Liked: 495
Here's a link: http://shop.smallgreencomputer.com/C...CAPS3-Zuma.htm
I will also have a review on a complete package product, the Baetis XR2 http://www.baetisaudio.com/Baetis_XR2.php
Kal Rubinson
post #17572 of 24634 Old 07-07-2014, 10:39 PM
KC-Technerd's Avatar
Quoted: 95 Post(s)
Liked: 146
My strange little anomaly has now occurred a fourth time. This time the AVR was selected to the Oppo's HDMI 2 output and given several (roughly 10) seconds to compete the handshake before switching the video display to the Oppo's HDMI 1 output. I've also now had the Oppo off for more than 30 minutes and the issue still hasn't cleared. I can correct the video oddities by using explicit rather than automatic settings. The one issue I can't correct that way is that the Oppo will not output any audio on HDMI 2 while it is in this state. I also cannot get the Oppo to output anything other than RGB Full on HDMI 2 regardless of setting.
I have a hard time believing that I haven't accidentally performed what ever sequence of input changes that is triggering this event before the BDP10X-75-0515 firmware, so I'm suspect that this is a vulnerability of this firmware version.
I just performed a Reset Factory Defaults to no avail. I'll be sending an email to customer support about this as soon as I have time to write a clear explanation of all this. This is complex enough that it will probably be a fairly long email.
I turned off both units (BDP-103 and AVR) and reseated all the HDMI plugs. Magic. Everything is back to normal. UGH! Could this all be the result of an HDMI pin that is not making a consistently good connection between the 103 and the AVR?
KC-Technerd is offline
post #17573 of 24634 Old 07-08-2014, 12:41 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3083 Post(s)
Liked: 3977
^ Yes. The key here is your report that you can't get anything but RGB PC Level on the HDMI 2 output. How do you know that? By the OPPO's on-screen Info display (plus Page Up/Down to switch to showing output status), or by some status display on your AVR? If there is disagreement between those two then that's a handshake failure and reseating the plugs would be a common fix. For example, if the AVR thinks it is connected to a DVI device (like a computer) then it would expect RGB input and NO AUDIO on that connection.
--Bob
Bob Pariseau is online now
post #17574 of 24634 Old 07-08-2014, 01:33 AM
Quoted: 479 Post(s)
Liked: 200
Jeff
For somebody like me who accesses all their media stored on a (Synology) NAS using the Oppo's GUI, I don't have a problem finding and playing (.dff and .dsf) DSD files via UPnP and SMB.
But from what I'm able to determine, if you want to find and play your (.dff and .dsf) DSD files using a 'smart remote control' (or what-ever the correct expression is), it seems to be a more complicated issue
post #17575 of 24634 Old 07-08-2014, 03:57 AM
Quoted: 95 Post(s)
Liked: 146
--Bob
RGB was indicated by the Oppo's on-screen info display for HDMI 2 and RGB FULL was indicated by my AVR for the 103's input regardless of any explicit Color Space (HDMI 2) setting I made in the Oppo's HDMI Options sub-menu (so there actually was no disagreement between the two, just a disagreement with the setting). I had previously noted that the apparent reduction of resolution of the Oppo's menus during these occurrences (despite my video display indicating 1080p input) could be eliminated by using an explicit setting of 1080p rather than the AUTO setting. So I decided to see how many of the issues occurring could be eliminated by using explicit settings. RGB video and no audio on HDMI 2 were the only 2 issues that I couldn't eliminate. The first time this occurred I thought I had reseated all the HDMI plugs (particularly on the HDMI 2 cable) without correction, but perhaps I missed one. I had once before lost audio on HDMI 2 and found that the cable (which is an Oppo supplied HDMI cable) had partially unseated itself from the AVR due to the weight and stiffness of the cable, so it was suspect and I'm sure I at least made sure it was fully seated into the plugs on both ends. Last night when this occurred I again checked to make sure it was fully seated (which it was) before I pulled it out and reseated it.
post #17576 of 24634 Old 07-09-2014, 10:22 PM
Bob Benson's Avatar
Quoted: 23 Post(s)
Have there been any premature failures of the video processor on these?
Tonight I went to watch a rental disc and immediately upon loading the disc was stuttering and half the picture was digital garbage. I thought it might be an issue with the display at first or a cable or my external darbee. But I was able to run my ps3 as a backup blu ray player through the oppo's hdmi input and it played everything correctly.
I tried several discs I recently played and they all came out garbled. One strange thing though the streaming previews the disc download from online played fine.
Also Netflix via the Oppo's app played garbled too. The menu and interface load and display fine. But the streaming video itself was garbled.
I've only had my unit since March so this is a little disconcerting.
I left a message with their support.
Oh and I tried a factory reset to no avail. I already had been on the newest firmware since as soon as it had been available and had been running fine.
XBL Gamertag - PVT Hicks
Bob Benson is offline
post #17577 of 24634 Old 07-09-2014, 11:24 PM
Coyote Waits
htwaits's Avatar
Quoted: 940 Post(s)
Liked: 2079
No, but any electronic device can fail at any time. There are others in the OPPO threads who are expert at diagnosing setup problems. It's probably a long shot that it's your player. The calvary will arrive soon.
htwaits is online now
post #17578 of 24634 Old 07-09-2014, 11:48 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 627
^ I would try disconnecting everything except power cord and HDMI cable going directly to display.
Does it still have digital breakup? Try a different HDMI cable too. Also try a different display if you can too, as it could be the tv.
You also said a reset to default settings didn't cure it?
If all of that still yields a problem then you should contact Oppo support to see if it needs repaired.
Like htwaits said though, even the best products are going to fail sometimes.
If only 1 out of 500 units has a failure, that failure still has to fall on someone unfortunately.
The fortunate part is the Oppo has stellar customer and product support.
Smarty-pants is offline
post #17579 of 24634 Old 07-10-2014, 12:04 AM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
When I put a Blu-ray movie in my 103 BD player, in the disc menu there is an annoying bright vertical line at the extreme left.
...Like the main disc menu is not filling my screen at 100% but at 98.5% or so.
Often it's not there from the get go, but after few minutes or so, or when in pause mode, etc. ..From standby to active to back to standby, and on the disc menu picture page and also on freeze frames. ...After few minutes.
What is that and how do I get rid of it? It is not normal because I have seven other Blu-ray players and none of them has that annoying vertical bar (not filling my screen at 100%) at the extreme left, from bottom to top.
I would love to resolve that issue; it's been present since the very beginning, more than a year.
* During normal playback all is fine. ...And everything else is ok.
I'll give a reward (kiss of love) to anyone able to help.
NorthSky is offline
post #17580 of 24634 Old 07-10-2014, 12:48 AM
Quoted: 750 Post(s)
Liked: 627
Honestly I have never heard of such a thing with Oppo BD players, and I follow all the posts very closely and do some beta testing for Oppo too.
I think the problem may be occurring in your display, possibly a cabling issue, or maybe even the player could need serviced.
I would try first checking your TVs settings to make sure there is not some kind of underscan setting or something similar turned on.
Then I would try a different HDMI cable to see if it's a problem with the cable.
What color is the line?... white? What display are you using? Is there an avr/pre-amp between the player and display?
Some of that info could be useful for further troubleshooting.
Other than those suggestions above I am a bit clueless what else it could be.
Perhaps someone else will have the answer.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
