Official OPPO BDP-103 Owner's Thread - Page 587 - AVS Forum | Home Theater Discussions And Reviews
 910Likes
post #17581 of 24720 Old 07-10-2014, 02:50 AM
mhobart's Avatar
Quoted: 59 Post(s)
Liked: 47
Originally Posted by Smarty-pants View Post
Honestly I have never heard of such a thing with Oppo BD players, and I follow all the posts very closely and do some beta testing for Oppo too.
I think the problem may be occurring in your display, possibly a cabling issue, or maybe even the player could need serviced.
I would try first checking your TVs settings to make sure there is not some kind of underscan setting or something similar turned on.
Then I would try a different HDMI cable to see if it's a problem with the cable.
What color is the line?... white? What display are you using? Is there an avr/pre-amp between the player and display?
Some of that info could be useful for further troubleshooting.
Other than those suggestions above I am a bit clueless what else it could be.
Perhaps someone else will have the answer.
Good questions, if the Oppo is connected directly to the display is the problem still present? Have you tried directly with both HDMI 1/2?
mhobart is offline
post #17582 of 24720 Old 07-10-2014, 05:48 AM
Wireless member
pepar's Avatar
Quoted: 1043 Post(s)
Liked: 544
^ I would try disconnecting everything except power cord and HDMI cable going directly to display.
Does it still have digital breakup? Try a different HDMI cable too. Also try a different display if you can too, as it could be the tv.
You also said a reset to default settings didn't cure it?
If all of that still yields a problem then you should contact Oppo support to see if it needs repaired.
Like htwaits said though, even the best products are going to fail sometimes.
If only 1 out of 500 units has a failure, that failure still has to fall on someone unfortunately.
The fortunate part is the Oppo has stellar customer and product support.
Hmmm, if the previews are NOT encrypted (and the main movie is), then I wonder if the descrambler is faulty ... or maybe needs a firmware update. Something to do with encryption ....
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #17583 of 24720 Old 07-10-2014, 06:50 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3526 Post(s)
Liked: 4525
Originally Posted by Bob Benson View Post
Have there been any premature failures of the video processor on these?
Tonight I went to watch a rental disc and immediately upon loading the disc was stuttering and half the picture was digital garbage. I thought it might be an issue with the display at first or a cable or my external darbee. But I was able to run my ps3 as a backup blu ray player through the oppo's hdmi input and it played everything correctly.
I tried several discs I recently played and they all came out garbled. One strange thing though the streaming previews the disc download from online played fine.
Also Netflix via the Oppo's app played garbled too. The menu and interface load and display fine. But the streaming video itself was garbled.
I've only had my unit since March so this is a little disconcerting.
I left a message with their support.
Oh and I tried a factory reset to no avail. I already had been on the newest firmware since as soon as it had been available and had been running fine.
First, bypass the external Darbee and connect via a single length of HDMI cable to your Display.
If the problem goes away, then check the HDMI connections via the Darbee.
If the problem still exists, then lower the output resolution of the player (Resolution button on the remote, plus Up/Down arrow -- use the Front Panel to see what you are selecting if the TV video is no good). Start with 480p (not 480i). 480p is the "simplest" resolution for HDMI. Then 1080i, then 1080p. If 480p and 1080i work but 1080p does not then that's good evidence the problem is marginal HDMI cabling. Make sure you are using HDMI cables sold as "High Speed" or "For 1080p" or "Category 2", all of which mean the same thing. HDMI plugs are just friction fit and it only takes a small shift of plug in socket to screw things up. Reseat each plug to check.
Simplify the HDMI handshake by turning Deep Color OFF, selecting an explicit choice for HDMI Color Space instead of AUTO (YCbCr 4:4:4 is the normal default), and selecting an explicit choice (LPCM or Bitstream) for HDMI Audio. Also turn HDMI CEC OFF in Setup > Device Setup.
Try a different HDMI input on your TV. Try both the HDMI 1 and the HDMI 2 outputs of the OPPO (only one connected at a time).
All of this is diagnostic stuff to try to get a handle on what's going on here. Odds are this is an HDMI handshake failure rather than a hardware fault, but we'll know more after you try these experiments.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #17584 of 24720 Old 07-10-2014, 06:56 AM
Read the FAQ!
Liked: 4525
Originally Posted by NorthSky View Post
When I put a Blu-ray movie in my 103 BD player, in the disc menu there is an annoying bright vertical line at the extreme left.
...Like the main disc menu is not filling my screen at 100% but at 98.5% or so.
Often it's not there from the get go, but after few minutes or so, or when in pause mode, etc. ..From standby to active to back to standby, and on the disc menu picture page and also on freeze frames. ...After few minutes.
What is that and how do I get rid of it? It is not normal because I have seven other Blu-ray players and none of them has that annoying vertical bar (not filling my screen at 100%) at the extreme left, from bottom to top.
I would love to resolve that issue; it's been present since the very beginning, more than a year.
* During normal playback all is fine. ...And everything else is ok.
I'll give a reward (kiss of love) to anyone able to help.
First check that you have the latest firmware. In Setup > Device Setup > Firmware Information, the "Main" firmware version number should end 0515.
If you've got older firmware, you should update now before spending any more time on nailing this down. There were bugs in older firmware (quite old, actually) which could cause what you are reporting.
--Bob
post #17585 of 24720 Old 07-10-2014, 07:48 AM
KC-Technerd's Avatar
Quoted: 97 Post(s)
Liked: 147
I'm fairly confident now that this is what was causing my issues with losing audio on HDMI 2 along with all the other odd behavior. I would emphasize that reseat means pull it out and push it back in. In my case, despite the plugs feeling completely and securely (as secure as HDMI plugs get) inserted I was still having intermittent issues that were ultimately corrected by pulling and re-inserting each HDMI plug. I'm liking HDMI less and less.
KC-Technerd is offline
post #17586 of 24720 Old 07-10-2014, 07:53 AM
Read the FAQ!
Liked: 4525
^ If the HDMI plug is angled as it is inserted, you can get a bad fit even though the result appears to end up fully seated, correctly.
You can also get a transient piece of dust (or whatever) on a pin that screws up the connection.
Both get fixed by removing and reseating the plug.
For stubborn problems, it is is wise to get a flashlight and carefully inspect both the plug ends and the sockets looking for bent pins.
Another approach to this is the "wiggle test". Grab the cable about an inch back from the seated plug. Gently push the plug straight in towards the socket and give the cable a gentle wiggle while doing so. This is most useful if you have a visible problem on screen (e.g., the "sparklies") so you can check if the problem goes away while you are doing this. You need to check both ends of each HDMI cable all the way from source to display.
--Bob
KC-Technerd likes this.
post #17587 of 24720 Old 07-10-2014, 10:34 AM
stash64's Avatar
Quoted: 277 Post(s)
Liked: 97
Get some good Blue Jeans cables... they have a nice snug fit compared to most other HDMI cables.
Sean
stash64 is offline
post #17588 of 24720 Old 07-10-2014, 12:30 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 628
I have never used Blue Jeans, they do get a lot of praise though.
One thing this reminds me of though, are also the Monoprice cables.
They have the Redmere style that are good for long runs, but I also got some of the short Redmere cables and
was surprised at how 'spaghetti thin' they are.
One thing this helps with is the stress that weighty cables can put on the socket connections of HDMI.
Even just using a standard cable (like the one that is included with the player), can still put pressure on the socket to the point of
allowing the connection to sometimes wiggle loose. Most of the time no, but the potential is still there.
With the Redmere cables, that potential is completely gone.
The cables are so light, there is ZERO potential for it to wiggle out of the socket, or cause any type of pressure damage.
Smarty-pants is offline
post #17589 of 24720 Old 07-10-2014, 12:33 PM
JazzGuyy's Avatar
Quoted: 323 Post(s)
Liked: 329
The Blue Jeans cables are fairly lightweight and flexible compared to most cables.
JazzGuyy is offline
post #17590 of 24720 Old 07-10-2014, 01:02 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3554
--Bob
Hi Bob,
I never updated my original firmware in my Oppo BDP-103 player; it is the very first original one.
...Simply because if it ain't broken why fix it, and if no needs to new features why use them.
When I first bought my player, about a year and half ago, I noticed this flaw quite immediately, and I knew that it was a flaw because I did everything; changing HDMI cables, HDMI 1 and HDMI 2 outputs, directly to my Samsung plasma TV, picture settings in my TV, connected to my pre/pro, ...EVERYTHING.
And I do have another seven Blu-ray players @ home (like I already mentioned), and none exhibits this flaw.
The only fix was to adjust manually my screen's picture shifting; by two clicks to the left (on my TV).
But I have to do this every single day that I'm watching a Blu-ray with my Oppo 103 - it is annoying.
But remember, it is mainly with the main menu page (frozen frame or animated on a loop) , and never while watching a movie normally. ...That's why I lived with it all that time.
And I knew that it wasn't a common flaw in Oppo BD players (I am an avid researcher).
Now, Smarty-pants, even him is not aware of that flaw (the thin vertical line at extreme left is only roughly 1% of the total screen's size): It's the behind of another picture menu, or frame. ...Definitely a flaw of my Oppo 103 player.
NOW! If I update my firmware of my player, is it safe for EVERYTHING else?
Because I don't want to fix an issue (annoying but I can live with) if I'm going to get something else which I wouldn't like, if you know what I mean.
Like I said, everything else is to my complete satisfaction, and I ain't looking for for additional/beneficial features. ...Sound and Picture quality are excellent, and that's all what truly matters to me.
Again, should I get the latest firmware from the very first original firmware (there has been roughly twenty of them since then!) in total confidence that nothing else would be impeding in my overall satisfaction on the aspects that are most important to me: watching Blu-ray movies, documentaries, music concerts, etc., with fabulous sound & picture quality?
Because, this annoying flaw is only present on the menu pages, and when I'm pausing my player and that after few minutes when I resume or go back to the main menu, that vertical bar is always there.
Will a firmware update, to the latest one (... 0515), fix this, and not introducing other anomalies that I might regret later on? ...A balance of safety mixed with courage.
Thanks Smarty-pants, mhobart, and you too Bob.
NorthSky is offline
post #17591 of 24720 Old 07-10-2014, 01:07 PM
SeeMoreDigital's Avatar
Quoted: 487 Post(s)
Liked: 207
I don't think my Oppo came with the original firmware. Which firmware version do you actually have installed?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #17592 of 24720 Old 07-10-2014, 01:12 PM
m00n's Avatar
Hey all... I hate to ask this, but with over 17598 messages in this thread alone, it would be very hard to read through it all to find what I'm looking for.
My 103D just arrived yesterday. I have it all hooked up. However, internet apps like Netflix wont stream. I have the network setup properly. The unit can see my network, my computer and what not. It will even launch netflix, but I keep getting an error... Something to do with the netflix servers. Also, I tried some of the other browser based apps, they did not want to connect properly either.
I have netflix on my Visio TV and it can connect to the service just fine. Wondering if there might be a step I'm missing?
Oh and one more thing... I just wanted to verify that there is NO Bluetooth capabilities right? I didn't even think about that when I was purchasing the unit.
m00n is offline
post #17593 of 24720 Old 07-10-2014, 01:18 PM
Quoted: 750 Post(s)
Liked: 628
Hi Bob,
Well that was the major flaw in my previous response. I assumed you had the latest firmware installed.
If the flaw you are seeing was there a couple years ago and quickly fixed with a firmware revision,
that may be why I do not remember it, but at this point, I think it's a fairly safe assumption that updating your player will probably fix it.
I think you are safe to update the firmware. I say go for it.
You may also like some of the features that have been added since the player was first released.
post #17594 of 24720 Old 07-10-2014, 01:22 PM
Quoted: 750 Post(s)
Liked: 628
Are you using a wired or wireless method for the network connection?
For wireless you must use the included wifi dongle and choose the wireless setting in the menu of the player.
post #17595 of 24720 Old 07-10-2014, 01:23 PM
NorthSky's Avatar
Liked: 3554
Check the very first post of this thread; the very first original firmware version, that's the one.
...When the first players were sold to the general public. I never touch, or try to update (install) anything.
NorthSky is offline
post #17596 of 24720 Old 07-10-2014, 01:23 PM
m00n's Avatar
Hi Smarty,
I am using WIFI and I have got the WIFI dongle plugged in. As mentioned, the unit can see the network just fine. It was able to scan and has seen my computer.
m00n is offline
post #17597 of 24720 Old 07-10-2014, 01:28 PM
Quoted: 750 Post(s)
Liked: 628
Hi Smarty,
Have you tried rebooting your system?
Try shutting off all network devices, including PCs, players, and TVs.
Then shut down / unplug / reboot your router and modem.
Give it a few minutes to acquire the proper signals and such, then turn your other components back on and see if the player apps now work.
If you are also trying to use some kind of custom DNS and such, that's a whole nuther can of worms.
post #17598 of 24720 Old 07-10-2014, 01:32 PM
NorthSky's Avatar
Liked: 3554
It wasn't a 'flaw'; we both forget to mention.
"... at this point, I think it's a fairly safe assumption that updating your player will probably fix it.
You may also like some of the features that have been added since the player was first released."
Closing Quote
Thanks Dave mate, smart reply.
* Bob is still my guru-man-to-go-to. ...Hopefully he thinks less and knows more.
Bob, I'm waiting for your reply; you always have (almost) the recipe for most sensitive subjects of your own expertise. ...Making sense without assuming.
P.S. Inexperience with breaking down a quote, yet. ...Is there a special trick that I'm not aware of?
NorthSky is offline
post #17599 of 24720 Old 07-10-2014, 01:38 PM
m00n's Avatar
Hi Smarty, I will try bouncing the router when I get home later.
Also I did a firmware update yesterday as well. I was unable to pull from the web directly from the oppo, I had to download it onto a thumb drive... but I got it installed none the less.
Oh... One more question. Anyone know of Oppo would be in the works to add Spotify support?
m00n is offline
post #17600 of 24720 Old 07-10-2014, 01:45 PM
Quoted: 750 Post(s)
Liked: 628
Closing Quote
Umm, nothing is ever absolute. I guess one of my faults is trying to never present opinion as fact.
Many others do and that's not a very ethical way to present things IMO.
If you want the "just the facts ma'am version", the ONLY way to know if a firmware update will fix your problem is to try it and find out.
It's only going to better your player and you should have updated it long ago.
Even you said, "if it ain't broke, why fix it". Well it's broke, so fix it.
post #17601 of 24720 Old 07-10-2014, 01:47 PM
Read the FAQ!
Liked: 4525
Hi Bob,
Stop worrying and do the update.
Copy down your settings first -- all of them as some defaults have changed since your firmware. AFTER the install, do a Reset Defaults -- the player should offer to do a Recommended Reset on the first power up after the install. Then re-enter your settings.
Since your firmware is so old, check that all the pieces of firmware are up to date after the install: Main, Loader, Sub/MCU. If any were not updated, repeat the install until you've got all of them. Check the version numbers in Setup > Device Setup > Firmware Information against the ones on OPPO's support page for the 103:
http://www.oppodigital.com/blu-ray-b...e-75-0515.aspx
By the way, you only have to do that 0515 install -- not each of the one's you skipped. It incorporates all those as well.
Bugs will always be with us, but there are NUMEROUS important fixes in the firmware releases since the one you are running, as well as new features -- one of which is the added ability to save and restore settings via a USB stick, which makes doing future Reset's a snap.
The only significant feature that has been dropped is the ability to play SACD-R discs that you burn yourself.
--Bob
post #17602 of 24720 Old 07-10-2014, 01:56 PM
Read the FAQ!
Liked: 4525
First of all, there's a separate thread for the 103D, so if you have additional questions, you might want to move to that thread as, of course, there are some differences between the 103 and the 103D.
There is no BlueTooth capability in the player.
The networking stuff depends upon details of how you have your home network set up. Evidently the player can see things within your home network, but not the outside Internet.
The most likely reason for that is that your Router, or perhaps a Firewall device, is limiting which devices in your home network are allowed to go out on the Internet.
The first thing to do is to try Setup > Network Setup > Connection Test. If that fails, but you can still access files on your in-house systems, then the player is blocked from getting to the Internet.
Check in Setup > Network Setup > Connection Information to see if the IP address, Gateway address, and DNS server address(es) make sense. It may be as simple as that your Router has a limit set on how many devices it will service at one time, and the player bring you up one past that.
--bob
post #17603 of 24720 Old 07-10-2014, 01:59 PM
Bob Benson's Avatar
Quoted: 23 Post(s)
Thank you. I was finally able to reseat all the cables in the chain and that solved the problem.
I just couldn't do that obvious bit of troubleshooting right off the bat because its tough to get at all the cables in the chain.
It also threw me that the same video (1080p24 and 1080p 3d) played via the ps3 via the back input of the Oppo played fine.
Oh well I will just strike this up to the sensitive nature of hdmi.
XBL Gamertag - PVT Hicks
Bob Benson is offline
post #17604 of 24720 Old 07-10-2014, 02:01 PM
m00n's Avatar
Hi Bob... off hand, I don't think it's a router limitation as in the number of devices, reason I say that is because I can connect wireless with my Visio TV to Netflix. And that's fine, but I would also like to have that functionality from the Oppo as well so that I can get the audio from the Oppo to the receiver.
m00n is offline
post #17605 of 24720 Old 07-10-2014, 02:02 PM
NorthSky's Avatar
Liked: 3554
--Bob
I have to quote you because this is important info for me, and I want to save it. Thx a bunch Bob, will do!
By the way, I wasn't worry for a single bit; I assume that you assumed.
And your last sentence is interesting: Cannot play SACD-Rs that people burn themselves. I did not know that either. ...Why is this Bob?
NorthSky is offline
post #17606 of 24720 Old 07-10-2014, 02:02 PM
Read the FAQ!
Liked: 4525
I continue to be amazed when HDMI works at all. The next step after reseating the cables would have been to try drawing a chalk pentagram around the player.
--Bob
KC-Technerd and jskang like this.
post #17607 of 24720 Old 07-10-2014, 02:06 PM
Read the FAQ!
Liked: 4525
That feature was dropped at the behest of The Powers That Be in the industry. It's best not to ponder why they do what they do -- they tend to get grumpy.
However it was replaced by the ability to play DSD files as media files either from an attached hard drive or streamed from a server on your house network. Both Stereo and Multi-channel DSD files are supported. (DSD is the digital audio format used on SACD discs.)
--Bob
post #17608 of 24720 Old 07-10-2014, 02:12 PM
NorthSky's Avatar
Liked: 3554
We live in interesting times with interesting business minds...
NorthSky is offline
post #17609 of 24720 Old 07-10-2014, 02:13 PM
Read the FAQ!
Liked: 4525
Network devices reserve a service slot in your Router for a period of time -- typically 1 day or longer. I.e., they don't necessarily get a new slot each time you turn them on. Your Vizio may simply be using its previously reserved slot. And if the Router is limiting which devices get access to the outside, the Vizio may simply be on the list.
The point is, if the OPPO can play things over your house network, then the networking in the OPPO is *FUNCTIONING*. So either the OPPO has not been given appropriate set up addresses from the Router or something in your house network is blocking the OPPO from getting outside.
By the way, I'm assuming you have a US model player, and that you are physically located in the US. If that's not correct, then you may be trying to access services which are not available in your area from your model of player.
Start by seeing if a Connection Test works.
--Bob
post #17610 of 24720 Old 07-10-2014, 02:33 PM
Coyote Waits
htwaits's Avatar
Quoted: 947 Post(s)
Liked: 2099
Good for you.
Here is something that might help you in the future. I used 28AWG HDMI cables in a relative's installation. After about three years gravity effected one cable enough that it wouldn't stay perfectly connected. If you run into trouble like this in the future, try to eliminate gravity as one cause of the problem. I used plastic ties on a few of my nephew's HDMI connections, but I've also used short (1.5' - 3') passive 36AWG cables and a 15' Redmere active 36AWG cable in my own installation. Either way, gravity hasn't much to work with.
htwaits is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
