Official OPPO BDP-103 Owner's Thread - Page 588 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
post #17611 of 24398 Old 07-10-2014, 03:33 PM
m00n's Avatar
Hi Bob, yes I live in the States. I will try bouncing the router as well as doing a network connection test when I get home from work. Thanks for the tidbit about the router and how it reserves slots. I didn't realize that.
m00n is offline
post #17612 of 24398 Old 07-10-2014, 05:33 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Originally Posted by NorthSky View Post
Hi Bob,
NOW! If I update my firmware of my player, is it safe for EVERYTHING else?
Because I don't want to fix an issue (annoying but I can live with) if I'm going to get something else which I wouldn't like, if you know what I mean.
If you play BD ISO or BD Folder Structure from Network or USB I believe (would have to check) that one of the firmware updates broke that capability. Or I may be thinking of the OPPO BD-93 - perhaps someone more knowledgeable can confirm or correct.
Bill
bgoering is offline
post #17613 of 24398 Old 07-10-2014, 05:56 PM
Coyote Waits
htwaits's Avatar
Quoted: 920 Post(s)
Liked: 2030
Bill
The OPPO BD-93 with firmware from 2011 is the only model that can play .ISO files from an externally connected storage device.
mhobart likes this.
htwaits is online now
post #17614 of 24398 Old 07-10-2014, 08:45 PM
Liked: 6
I'm setting up a new BDP-103 with a Sony W850A LED and a Pioneer VSX-9040TXH receiver. I'm currently trying to use the Dual HDMI set-up with HDMI-1 going to the tv and HDMI-2 going to either the receiver's BD HDMI input or just an HDMI input; tried both.
I'm not getting any audio with either a BD or with streaming Netflix. I've gone through the manual and believe I have made all recommended adjustments for video/audio. Regular tv works fine with audio.
Anyone have suggestions on why the audio is not coming through? Will appreciate any help.
fjnaz is offline
post #17615 of 24398 Old 07-11-2014, 07:05 AM
Aliens's Avatar
Quoted: 1310 Post(s)
Liked: 1702
Looking at your Pioneer manual, you will not get any audio input from an external source if you have selected PCM on your receiver. Do you have PCM selected?
RUSaved likes this.
Aliens is online now
post #17616 of 24398 Old 07-11-2014, 11:52 AM
Liked: 0
Need Help
On 6/28/14, I tried to make my BDP-103 region free via the Superdisk route. Current Firmware # BDP10X-75-0515. I burned the ISO file on to CD-ROM, loaded disc into Player, disc loaded and then the player opened tray by it self. Put in Region 2+4 Colour PAL UK DVD and audio came through loud and clear but no video. Any thoughts/suggestions on how to proceed?
Thanks in advance.
broy471 is offline
post #17617 of 24398 Old 07-11-2014, 12:14 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2691 Post(s)
Liked: 1921
Thanks in advance.
Welcome to AVSForum.
Do you get no message on the display?
What are your settings for Resolution and TV System?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #17618 of 24398 Old 07-11-2014, 12:15 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2267 Post(s)
Liked: 2842
Thanks in advance.
Check Setup > Video Setup > TV System. You may need to specify NTSC if your TV doesn't support PAL format. The player will do the necessary conversion. In addition, make sure you are using an explicit Resolution choice (e.g., 1080p, not Source Direct) if that's the case.
--Bob
mhobart likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #17619 of 24398 Old 07-11-2014, 12:22 PM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 97
My 103 is on the truck and will be delivered today.
I've been reading through the forums and also looking at the online manual. I have a question about best way to set things up.
I have a Pioneer AV receiver (model in the sig) and the plan was to run most things through the AV receiver, but run the cable box into the Oppo to take advantage of its better video processing.
I've seen some posts about people worried that the AV receiver will do its own video processing so suggesting to run the Oppo directly to the TV using HDMI 1, then run HDMI 2 to the AV receiver for the audio. But it seems to me that if I set the Oppo to always output video at 1080P, the AV receiver won't need to touch it (try to upconvert), so will just pass it along to the TV. Is that correct?
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #17620 of 24398 Old 07-11-2014, 12:37 PM
RUSaved's Avatar
Quoted: 18 Post(s)
Liked: 7
Smile check me too
Ive bought a Denon AVR S900W and am tring to do the same thing .help pleas thankyou.
RUSaved is offline
post #17621 of 24398 Old 07-11-2014, 01:08 PM
Read the FAQ!
Liked: 2842
That is correct. If there are video "enhancement" options in the AVR you can turn those off.
--Bob
post #17622 of 24398 Old 07-11-2014, 01:22 PM
copene's Avatar
Quoted: 37 Post(s)
Liked: 69
I wish they would make it so that you could adjust +/- lip sync issues in real time on the screen while the video plays.
copene is offline
post #17623 of 24398 Old 07-11-2014, 01:33 PM
Aliens's Avatar
Liked: 1702
Oppo HDMI 2 out to Denon BD input, which will be #3 .
Page 167: Settings
Input mode to HDMI. Decode mode to DTS.
To play the Oppo, press the Blu-ray input on the Denon remote.
If that is what you were asking.
post #17624 of 24398 Old 07-11-2014, 01:59 PM
Read the FAQ!
Liked: 2842
Uh, they do. Is it not working for you?
Also be aware that it is rather common for movies and other content to have inherent A/V sync error. In particular if you see error which varies by scene that is almost certainly in the content itself. It's really not worth it trying to chase such varying content errors.
As always, it is best to check/adjust sync using content of known sync quality -- i.e., a calibration disc. Good sync tests can be found on Spears & Munsil v2, Blu-ray, available from OPPO, and on Disney's "WOW World of Wonder", Blu-ray, available from Amazon.
--Bob
post #17625 of 24398 Old 07-12-2014, 01:28 AM
Liked: 6
Thank you for the suggestion. I didn't have time to re-wire things today but will try to get at it by tomorrow night. Will advise if this was the problem.
fjnaz is offline
post #17626 of 24398 Old 07-12-2014, 04:59 PM
boe
boe's Avatar
Quoted: 889 Post(s)
Liked: 413
Xbox through HDMI in on Oppo 103
I realize this is a long shot but has anyone tried hooking an xbox through their Oppo? I have a friend who is an hdmi input short and I think you can run other hdmi items such as cable boxes through oppo's hdmi in but I've never actually used it and I don't have an xbox to text with.
boe is online now
post #17627 of 24398 Old 07-12-2014, 05:11 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1060 Post(s)
Liked: 990
It should work, but it generally isn't recommended to add extra video processing to game consoles as it will introduce lag in game play (what you're seeing and hearing isn't in sync with the game controller) which will render some types of games unplayable.
gsr is online now
post #17628 of 24398 Old 07-13-2014, 07:36 AM
xhattan's Avatar
Quoted: 49 Post(s)
Hello kind people:
I finally did the update a few days ago. However, now when I use the fast rewind button on control, I can't stop the player from rewinding when I push the Play button or any button, except the Power to shut it off.
Any input on this issue? Any ideas?
xhattan is offline
post #17629 of 24398 Old 07-13-2014, 07:40 AM
wmcclain's Avatar
Liked: 1921
Originally Posted by xhattan View Post
Hello kind people:
Is this for DVDs only, or for Blu-rays as well?
If DVDs only, do you have DVD 24p turned on? If so, try turning it off.
-Bill
post #17630 of 24398 Old 07-13-2014, 05:28 PM
davehale's Avatar
Location: US, Earth, Milky Way Galaxy, Virgo SuperCluster
Quoted: 320 Post(s)
Liked: 279
Netflix Issues Again?
I hate to bring up Netflix again but I haven't been able to get into Netflix for 3 days. I chalked it up to Netflix being down over the weekend multiple times but even while it is back up I am getting the obligatory Check your connections and reset everything. I am getting to the Internet and have gone thru the problem solving but cannot connect to the Netflix servers. The only thing that I have not done is Reset my Oppo. I will do this next but want to hear from others as resetting my Oppo is a little heavy handed if it is on the Netflix end.
davehale is offline
post #17631 of 24398 Old 07-13-2014, 06:51 PM
Read the FAQ!
Liked: 2842
^ Netflix is working fine here.
If you've not updated to the latest firmware you should definitely do so, as it comes with a new Netflix app which works better.
Check Setup > Device Setup > Firmware Information. Your "Main" firmware version number should end "0515".
--Bob
post #17632 of 24398 Old 07-13-2014, 07:46 PM
johnny tuna's Avatar
I am also having internet connection issues. It started after the latest firmware update, which was done via wireless internet connection just fine. The Oppo is not reading the Gateway for some reason. I changed the Oppo to manual setup and it still reads the IP address and the Subnet Mask, but even when I type the Gateway in myself, it does not connect to the internet. Have had an email exchange with support on this, but am waiting for latest reply.
johnny tuna is offline
post #17633 of 24398 Old 07-13-2014, 08:39 PM
davehale's Avatar
Quoted: 320 Post(s)
Liked: 279
Thanks Bob but I am always on top of the latest firmware.
Dave
davehale is offline
post #17634 of 24398 Old 07-13-2014, 09:02 PM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1330
The best step is to de-authorize the Oppo for Netflix (its in the setup menu in the Oppo). Then start over and re-authorize. If you can't get to that re-authorize step, then there really is an issue with your network or ISP.
rdgrimes is offline
post #17635 of 24398 Old 07-14-2014, 01:14 AM
davehale's Avatar
Quoted: 320 Post(s)
Liked: 279
Thanks rdgrimes,
I had to deauthorize and then reauthorize to get it to work. Resetting the Oppo and following the Netflix recommendations did not work.
davehale is offline
post #17636 of 24398 Old 07-14-2014, 04:23 AM
Daffietje's Avatar
Quoted: 54 Post(s)
When watching a Blu-Ray disc on my Oppo yesterday I noticed for a second a small green line in the screen. Like a small visual glitch.
When going backwards to the same point on the disc it did not happen again, so it is definitely not an error on the disc.
Is this something I should be worried about? What could be the cause of this?
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #17637 of 24398 Old 07-14-2014, 05:49 AM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
Impossible to know what it could be. So many possibilities for any tiny piece of hardware to fail in a player, or AVR, or display.
Could have been something as slight as a one-off handshaking error which can and does happen from time to time.
Not much you can do except not worry until it happens again, then at that point start troubleshooting what the problem could be.
Daffietje likes this.
Smarty-pants is offline
post #17638 of 24398 Old 07-14-2014, 07:09 AM
Read the FAQ!
Liked: 2842
Where was the line located on screen? Was it horizontal or vertical or what? Did it stretch from edge to edge or was it shorter than that? Did it look multiple pixels thick or only 1 pixel thick? Did it stay at one location or did it move while it was visible?
All of these might be clues as to what happened, but of course if it doesn't repeat it's not really worth worrying about.
--Bob
post #17639 of 24398 Old 07-14-2014, 07:46 AM
Daffietje's Avatar
Quoted: 54 Post(s)
--Bob
Sorry, should have been more complete when describing the problem.
It was horizontal and it appeared to stretch from edge to edge. It was a small line so I guess only 1 pixel thick?
It appeared to move a little, but I am not very sure about that.
Does that help?
post #17640 of 24398 Old 07-14-2014, 07:58 AM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
Capture a still image of your encode using a software player and provide a MediaInfo file report...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
