Official OPPO BDP-103 Owner's Thread - Page 594 - AVS Forum | Home Theater Discussions And Reviews
 737Likes
Old 07-29-2014, 06:56 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1907 Post(s)
Liked: 832
Originally Posted by ecsobar61 View Post
Can you explain what you mean by analog-digital-analog conversion here? I basically want to play CDs (digital) on the Oppo and hear them on the headphones (DVD and BD a plus).
Since your questions about connecting your headphones are not specific to the OPPO, I'm going to ask that you pursue this in the 2-channel forum: http://www.avsforum.com/forum/173-2-channel-audio/
They deal with headphones and amps all the time there and will be able to help you. What you're asking for applies to any player with analog outputs so is off-topic here.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 07-29-2014, 07:00 PM
NorthSky's Avatar
Quoted: 6796 Post(s)
Liked: 3367
Originally Posted by NorthSky View Post
Next, compare the analog stereo outs of the Oppo 103 perfectly volume matched with the analog outs of an Emotiva ERC-2 (or ERC-3) CD player, and playing through the exact same pair of loudspeakers and playing the exact same music recording(s).
Originally Posted by swspiers View Post
Okay- I'll bite. Why would I want to do this?
Hey, look who's biting!
Because, experimentation and comparison is good for the soul. ...Are you now happy that you bit?
~ Bob
"And it stoned me to my soul"
- Van Morrison
NorthSky is offline
Old 07-29-2014, 07:09 PM
Quoted: 18 Post(s)
Liked: 0
Sure, but this question was simply asking for clarification of something someone added to the mix. I didn't mean to go off-topic. I only have the Oppo. But I'll check out that thread. I think I have almost got my answer, anyway.
ecsobar61 is offline
Old 07-29-2014, 07:58 PM
Coyote Waits
htwaits's Avatar
Quoted: 866 Post(s)
Liked: 1942
You'll get the clarification you want, along with more information in the thread that Bill linked for you. Good luck.
htwaits is offline
Old 07-29-2014, 08:15 PM
NorthSky's Avatar
Liked: 3367
Atmos?
~ Bob
- Van Morrison
NorthSky is offline
Old 07-29-2014, 09:22 PM
dannybee's Avatar
Quoted: 140 Post(s)
Liked: 77
Anybody heard anything on the upcoming hdmi 2.0 specs for the oppo players.
dannybee is offline
Old 07-30-2014, 02:38 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by Partyslammer View Post
I asked about this subject regarding a solution to create playlists for media, notably music files for an external drive plugged into the Oppo 103 via USB on the "other" BD forum and figured I'd also try here. I've spent time searching through various forums but haven't found a real solution.
I know how to use the Oppo's clunky playlist function in the on screen media menu (remote's Green button adds files in order of selection to create ONE playlist) but I have an external drive with literally thousands of individual WAV files and the Oppo has no problem reading the drive and playing the files.... but I want to make multiple playlists ideally on my PC where it's easier to drag, drop and arrange numerous files say, of various ambient songs, another playlist of soundtrack music, another one of hard rock, and so on. Basically like anyone can do in any basic media player like iTunes, Windows Media Player, etc.
I thought I could just copy the file that the Oppo player writes it's playlist to and edit it in notepad to at least tediously add, link and arrange the files to a custom playlist but the Oppo must write and save that file internally on the player's HD instead of on my external drive's "Oppo" folder the player creates when you first access it. I don't even know what type of doc the Playlist file is to create one from scratch.
It was suggested to make CUE playlists so I fiddled around with CUE Master today to try and put together a test playlist but it couldn't accept a file over 6MB w/drag n' dropping. No good as I'm dealing with 16-bit @ 44,100Hz WAV files. Even more muddled results using the "Import/Scan" feature (clumped together files into 30+ minute groups).
It seems like such a simple thing, I'm a bit floored that as versatile as the Oppo players are, importing and editing Playlists doesn't appear to be a doable option. Even an iPad/iPhone App as part of or separate from the Oppo Media Control App that could approximate dragging and dropping files into multiple playlists on a USB-connected Hard Drive to the Oppo player similar to what can be done with iTunes would be a huge step.
Why dont you just make playlists in foobar for example? If you save the playlist you made as a .m3u file, I am sure the Oppo can read that?
So just add all the music files you want in the playlist in foobar and save as a playlist file with a name of your choice.
Do the same for the next playlist, and so on.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
Old 07-30-2014, 05:50 AM
JeffR714's Avatar
HI all!
Just an update on my experience with the 103. After about 5 months of comparing the analogue out of the 103 into a Burson Soloist headphone amp, and comparing it to the Schiit Bifrost Uber DAC, I finally concluded that there is no audible difference. My final evaluation with a demo pair of Grado GS1000e headphones, which are brutally detailed, was the last straw. Volume matched, I could not tell one from the other.
This darn blu-ray player is something else!
Good thing I read this post now I'll just get the Vali and hook it up to the 103 analog jacks Thanks
JeffR714 is offline
Old 07-30-2014, 07:18 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1345 Post(s)
Liked: 1346
The OPPO has both Analog and Digital audio outputs. Headphones (like regular speakers) need Analog audio. The content you are playing (e.g., CDs) is Digital audio.
The hardware that converts Digital audio to Analog audio is called a DAC -- a Digital to Analog Converter. More expensive DACs do this job better.
When you listen to the Analog audio outputs of the OPPO, the high quality DACs built into the OPPO are doing that conversion. So all you need between the player and the headphones is cables and, possibly, an Analog audio headphones amp.
When you listen to the Digital audio outputs of the OPPO (HDMI, Optical or Coax), the conversion to Analog must be done external to the player. Volume control ALSO must be done external to the player -- the Volume adjustment in the OPPO only applies to its Analog audio outputs. So to connect to your headphones you need cables and a device which is *BOTH* a DAC and a headphones amp. The point made above is that INEXPENSIVE boxes like that probably don't include particularly good DACs.
So since you want to save money, but still get high quality audio, use the Analog outputs of the OPPO, either cabled directly to your headphones, or, even better, through a good quality Analog headphones amp, perhaps like the one I cited above.
RDGRIMES post was pointing out that you DON'T want to get an inexpensive "digital" amp, which takes Analog audio output from the player, converts that BACK to digital on input, amplifies it using digital audio circuitry, and converts THAT result back to audio with its own DACs. You've thus got two conversion steps being done by that inexpensive hardware and that's just asking for poor quality.
Discussion of particular headphones amps should be taken to the other thread, cited above, where people hang out who follow such stuff.
--Bob
lanping09 and ecsobar61 like this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 07-30-2014, 12:43 PM
chronoclast's Avatar
Quoted: 21 Post(s)
Are the Oppos really sensitive to scratches on discs? I have a new DVD that has a couple very light surface scratches that when I play it on my 103 it skips every few seconds during certain times, then it freezes up and the 103 becomes unresponsive for like 20-30 seconds while the drive clicks. Resuming from the same times on the disc also causes the same unresponsive freeze up and the drive clicks.
My PS3 plays the same disc perfectly without issue so I don't think it's the disc.
Vizio M502i-B1, Ideal-Lume Bias Light, Chromapure, i1 Display 3 Pro, Harmony 700 Remote
Lumagen Radiance 2020, Oppo BDP-103, Marantz CD5004
Marantz SR7008, Polk Series II Monitor 70s Fronts, CS2 Center, 30s Surrounds, BIC America F12 Dual Subs
chronoclast is offline
Old 07-30-2014, 12:46 PM
wmcclain's Avatar
Liked: 832
I've found their players to be rather good on scratched DVDs.
-Bill
Old 07-30-2014, 01:17 PM
Audiguy3's Avatar
Quoted: 120 Post(s)
Liked: 65
Originally Posted by EdBag4 View Post
I did a search but did not see this issue listed. For about a week, my Oppo 103 has been starting in Pure Audio mode, I have to push the "P" button twice to see the screen. This also happens when the source is changed. Has anyone else experienced this issue? I updated to the latest firmware after this issue started thinking something may have happened to the firmware, but it is still coming up in Pure Audio mode.
Any help is appreciated.
Best,
Ed
I find the Oppo (103 and 105) to be way more sensitive to smudges and scratches to my previous players - PS3 and Sony Blue-ray players
Reggie
Family Room:75" 4K HDR Sony 940D/Marantz AV8802A/MM8077/GoldenEar:Triton Ones (superseding Triton 2s),/SuperCenter XXL center channel/ SuperSat 60surrounds/Oppo BDP-105/Directv C61K/Roku 4K
Basement: 70" Sharp Elite/Marantz AV8801/Marantz MM8003/PSB Stratus Gold Front,Center,Left, Surrounds/ Directv Genie HR-54/Roku 4K
Audiguy3 is offline
Old 07-30-2014, 08:08 PM
rdgrimes's Avatar
Quoted: 1353 Post(s)
Liked: 653
Damaged discs will always behave differently in different drives, its the nature of the beast. You might well be able to find a different damaged disc that generates the opposite results. But the fact remains that the problem is the disc.
rdgrimes is offline
Old 07-31-2014, 01:51 AM
Quoted: 18 Post(s)
Liked: 0
Thanks, Bob. That is such a helpful, clear explanation. I'll start looking at the other thread regarding headphone amps. I've just bought the Y-cable, so I may just comment on that when I try it out.
Old 07-31-2014, 06:09 AM
detroit1's Avatar
Quoted: 57 Post(s)
Liked: 32
FYI, I used a Toshiba 5tb External Drive with the Oppo and it works fine
detroit1 is online now
Old 07-31-2014, 08:25 PM
Quoted: 18 Post(s)
Liked: 0
Just to confirm this: if anything, the sound is slightly clearer with the jack going straight into the TV rather than using the Y-cable, which does work, except that the volume is limited with the latter. Time to switch to that other thread!
Old 07-31-2014, 09:47 PM
KC-Technerd's Avatar
Quoted: 36 Post(s)
Liked: 115
Thumbs up
I received a replacement HDMI cable from Oppo yesterday. It was shipped within 24 hours of my contacting Oppo, at no charge. Prior to that I was requested to do some different diagnosis steps beyond the several I had already performed, more along the lines of verifying that using a different cable would restore normal service rather than confirming the failure of the existing cable. I installed the cable tonight and normal Split A/V operation has resumed. Hopefully this will be the end of my troubles.
KC-Technerd is offline
Old 08-01-2014, 06:13 AM
dfarina's Avatar
New 103 owner,tried going through this thread but it's very loooong.Would it be beneficial to run my 720p cable box through the 103 before my 1080p (Benq W7000) projector TV?I tried experimenting with it,but in the process of getting behind there and changing the wires it's hard to get a fresh "before and after" to see any improvements.One benefit would be the ability to watch cable TV in simulated 3D,but I am sure that novelty would wear quickly.Thoughts?
dfarina is offline
Old 08-01-2014, 06:47 AM
Daffietje's Avatar
Quoted: 54 Post(s)
The Oppo has a very good upscaler on board, so yes this would be beneficial.
Old 08-01-2014, 06:02 PM
stash64's Avatar
Quoted: 96 Post(s)
Liked: 44
Anyone else experience video "stuttering" on DVD's with DVD 24p conversion set to on ? I've noticed it on 2 DVD's recently though it didn't start until 15-30 minutes into the movie. I switched off the DVD 24p conversion and the movies played fine from there. Aren't most DVD's, like BD, recorded at 24 fps ?
Sean
stash64 is offline
Old 08-01-2014, 06:10 PM
antennahead's Avatar
Quoted: 227 Post(s)
Liked: 160
The stuttering may be related to this:
antennahead is offline
Old 08-01-2014, 06:26 PM
stash64's Avatar
Quoted: 96 Post(s)
Liked: 44
Thanks... I think that is it. I believe the stuttering started after a rewind or pause each time. I've also had a lock up a couple times when rewinding and needed to stop the disc to get it playing again. Hopefully Oppo will have a fix with the next firmware update.
Sean
stash64 is offline
Old 08-01-2014, 06:36 PM
Rustolem's Avatar
Just got my 103 and can say its awesome best picture and sound I have heard.
But have a question and tried to search for answer but not much luck without reading every post.
This will probably be a dumb question but here goes.
I have connected my Sony 400 Bluray to the HDMI in Rear on my Oppo and when playing back a disc and selecting either the True HD or DTS HD Master audio tracks it only shows as PCM on my receiver which is a Yamaha CX-A5000.
Is this right? Is the Oppo decoding the audio and that's all the receiver will display? It sounds like it is the full audio just thought it would show the chosen Decoder on my Yamaha display.
Like I said may be a dumb question but any help would be appreciated.
And I can't believe how much better the video looks from my Sony going through the Oppo.
Rustolem is offline
Old 08-01-2014, 06:49 PM
NorthSky's Avatar
Liked: 3367
Is this right?
- Sony BD player Audio HDMI Out = Bitstream.
- Oppo BD player Audio HDMI In = ...
- Oppo BD player Audio HDMI Out = PCM (converted uncompressed).
I think it's right.
~ Bob
- Van Morrison
NorthSky is offline
Old 08-01-2014, 07:37 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
The Oppo 10x players can't decode Dolby True-HD or DTS-HD on their hdmi inputs.
lanping09 likes this.
DanF8500 is offline
Old 08-01-2014, 07:46 PM
Smarty-pants's Avatar
Quoted: 462 Post(s)
Liked: 298
^ Dan is correct.
If the Sony has an option to send PCM instead of bitstream, that would be the option you want to use for lossless codecs into the Oppo's hdmi input.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
Old 08-01-2014, 07:48 PM
Read the FAQ!
Liked: 1346
^ You can use the on-screen Info display on the OPPO to see what's coming in from the Sony. Since the OPPO can't accept that Bitstream typically the source Blu-ray player would decode that into LPCM and send that to the OPPO. Which also means the OPPO will output LPCM.
The trick here is figuring out if the Sony is decoding the full, lossless track into LPCM, or whether it is decoding the lossy "compatibility" track. That choice is based on how the Sony is designed, along with possibly some user settings in the Sony such as whether Secondary Audio mixing is enabled in it.
The easiest way to tell is to play a TrueHD or DTS-HD MA track which is 7.1, because the compatibility tracks are always no more than 5.1.
If the Sony is sending LPCM 7.1, then it is decoding the full, lossless track. If instead it is sending LPCM 5.1, then it is not. Again the OPPO's Info display will show what is coming in from the Sony.
--Bob
Old 08-02-2014, 06:09 AM
Monkey_Man's Avatar
Quoted: 82 Post(s)
Liked: 48
Hey guys, I know the 103 does a vertical stretch for an anamorphic compression lens on a 2.35:1 screen.
My question is does the 103 do a horizontal squeeze for 16:9 content through an A-lens on a 2.35:1 screen?
Monkey_Man is offline
Old 08-02-2014, 06:17 AM
Read the FAQ!
Liked: 1346
^ It does not. Of course a squeeze like that throws away horizontal resolution.
--Bob
Old 08-02-2014, 06:18 AM
wmcclain's Avatar
Liked: 832
No. The vertical stretch is the only zoom mode that changes aspect ratio. Retaining 1:1 pixel dimensions, there is a Full Screen mode that will crop images to 16:9, and it has a couple of zoom out levels to reduce image size.
-Bill
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
