Official OPPO BDP-103 Owner's Thread - Page 595 - AVS Forum | Home Theater Discussions And Reviews
 887Likes
post #17821 of 24590 Old 08-02-2014, 06:31 AM
Monkey_Man's Avatar
Quoted: 86 Post(s)
Liked: 48
Originally Posted by wmcclain View Post
No. The vertical stretch is the only zoom mode that changes aspect ratio. Retaining 1:1 pixel dimensions, there is a Full Screen mode that will crop images to 16:9, and it has a couple of zoom out levels to reduce image size.
-Bill
Didn't Oppo used to offer full aspect ratio control for A-lens scaling for folks that leave the A-lens in place all the time? I'm trying to avoid buying an external scaler. My new PJ coming on Monday doesn't do all the scaling that my old one did.
Monkey_Man is offline
post #17822 of 24590 Old 08-02-2014, 06:44 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2840 Post(s)
Liked: 2086
No, as far as I know full control is available only in video processor products. No OPPO player has had that.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #17823 of 24590 Old 08-03-2014, 08:06 AM
Liked: 0
Newbie Help
Dear All,
Would really appreciate if you can help me out with the following.
Just got and Oppo103 and am having some problems playing ripped Blu-Ray's and DVD's. For example I had used MakeMKV on CaptianPhillips Blu-Ray and then compressed it using Handbrake (down to about 8GB) - during this process i kept most of the surround sound tracks. Now it played fine on my WDTV Live box, but on the OPPO is stutters, speeds up and then slows down, these effects are greatly magnified when i switch from 2 channel to one of the surround sound tracks.
Any ideas?
John
johnallan44 is offline
post #17824 of 24590 Old 08-03-2014, 09:48 AM
rdgrimes's Avatar
Quoted: 2124 Post(s)
Liked: 1438
Originally Posted by johnallan44 View Post
Dear All,
Any ideas?
John
It would help immensely to know how it is that you are playing the file - how its accessed. If by network, what kind of network?
rdgrimes is online now
post #17825 of 24590 Old 08-03-2014, 10:17 AM
Liked: 0
Dear Rdgrimes
Sorry. Files on a WD NAS connecting to a ASUS Router then to OPPO, all wired cat 5 - I believe its all Gigabit stuff. On the oppo i access via 'TwonkyMediaServer'. I had thought it might be a network issues as well, but I'm running uncompressed Blu-Rays on the same network and they run with no problems at all.
John
post #17826 of 24590 Old 08-03-2014, 10:45 AM
hernanu's Avatar
Quoted: 601 Post(s)
Liked: 1083
Dear Rdgrimes
John
I've got the same setup (with a 103D), but running uncompressed and have had no problems. It might help if you use a tool like Mediainfo to post the particulars on the file(s) that are not running.
I've attached the information posted for an MKV file that shows fine on my setup.
hernanu is online now
post #17827 of 24590 Old 08-03-2014, 12:33 PM
Liked: 0
Dear hernanu,
I have posted a txt file from Mediainfo, I hope it makes more sense to you than it does to me.
John
post #17828 of 24590 Old 08-03-2014, 12:55 PM
wmcclain's Avatar
Liked: 2086
Dear hernanu,
John
Welcome to AVSForum.
I do the same as you except (1) I use MKV output, and (2) constant frame rate, where I see you have variable.
As an experiment, I would copy one of your files to local storage (a USB device, for example) and see if the behavior changes when attached directly to the player.
Then I would use mkvmerge to produce an MKV copy of your M4V and see if the container makes a difference. Try it both ways: network and local attachment.
Then I would try recreating the same file with constant frame rate.
-Bill
johnallan44 likes this.
post #17829 of 24590 Old 08-03-2014, 01:06 PM
hernanu's Avatar
Quoted: 601 Post(s)
Liked: 1083
I agree with Bill. I use MKV as a container as well.
post #17830 of 24590 Old 08-03-2014, 01:13 PM
rdgrimes's Avatar
Liked: 1438
Dear Rdgrimes
John
Aside from what others have suggested, its also possible that for some reason Twonky is trying to transcode the files. Transcoding should be completely disabled. However, you can also access the files directly using SMB and eliminate the DNLA server.
post #17831 of 24590 Old 08-03-2014, 01:22 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I've had zero issues doing the same thing, using Plex and/or Servio as my DLNA servers..maybe try installing one of those? You can actually install Servio on the WD directly, but plex goes on one of your networked PC's, as there is no way to install Plex natively on a WD as far as I know..
wase4711 is offline
post #17832 of 24590 Old 08-03-2014, 01:44 PM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
I am having constant trouble streaming music from my Windows 7 PC via the Oppo 103. I choose the network icon, and there is a list of the media servers on my network, including oShare. I choose oShare, and after the program is done indexing the files, I choose a folder and start to play the files in it. After the first file or two, the Oppo will jump back to the list of media servers. Sometimes it will jump back to that list in the middle of a song. And there are times when it locks up and shows "Loading..." on my display.
I am pretty sure the problem isn't caused by Oppo (the same thing happens when i stream music with my Denon AVR), but I can't figure out what to do about it.
I am using oShare as my media server. The Oppo 103 is connected to my home network via Ethernet, and the PC is wireless (in the next room, with a strong network signal). Oppo suggested disabling my antivrus software (doesn't consistently help, and I don't want to risk getting infected) or downloading a fresh copy of oShare (made no difference). My wireless router has the latest firmware installed.
When I asked this question here before, someone guessed that maybe packets were getting dropped--I don't know how to tell if this is true, but if there is nothing else accessing the network but the Oppo (or the AVR), why would this happen??
So I am open to any ideas you might have...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #17833 of 24590 Old 08-03-2014, 02:12 PM
Liked: 0
Dear all,
Thank you for you suggestions, I will try them and get back to you.
John
post #17834 of 24590 Old 08-03-2014, 02:39 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Have you adjusted any firewalls you have on the computer to let the oppo/DLNA server access everything? Have you tried a different DLNA server?
I would stream the music directly through the Denon; there is no reason to run music through the Oppo..
wase4711 is offline
post #17835 of 24590 Old 08-03-2014, 03:08 PM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
Yes, the firewall is set to let oShare access everything. Yes, I have tried a different DLNA server (Asset uPnp).
Streaming directly through the Denon does not stop the problem. And one reason to stream through the Oppo is that it will stream DSD files, the Denon won't.
pbarach is offline
post #17836 of 24590 Old 08-03-2014, 03:43 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
turn the firewall off completely, reboot EVERYTHING, especially your router and any switches, and see if that makes a difference. I think you said the computer is on wireless, but the rest of the equipment is wired; try Ethernet wiring your computer too, and see if that helps..
wase4711 is offline
post #17837 of 24590 Old 08-03-2014, 04:04 PM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
When I reboot everything, I generally get the problem again. It doesn't happen every time I stream a music file, but about 80% of the time.
I can't connect my computer to the network via ethernet without drilling holes in the walls--it's in the next room from the router and my music system.
If what's required is to turn off the firewall, then I give up. Do I really have to risk infecting my PC in order to stream music files? It doesn't seem worth the risk. And is everyone streaming music files from PCs with no firewall???
I would appreciate any suggestions for actually tracking down what is causing the problem instead of trying extreme solutions like eliminating internet security...
pbarach is offline
post #17838 of 24590 Old 08-03-2014, 04:11 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1098 Post(s)
Liked: 1075
Regarding drilling holes in the walls, there is the option of temporarily just running a long network cable between the rooms. After doing that, you could run some tests and see if the problem goes away or remains - that would help eliminate 1 possible culprit.
As far as turning off the firewall, you could temporarily disconnect your router from the Internet and then (temporarily) turn off your firewall software in order to run some tests with it turned off.
The point is that some of these suggestions are diagnostic steps to help figure out what is causing the problem rather than a permanent configuration. Once the problem has been identified, a permanent solution can be determined.
wase4711 and DanF8500 like this.
gsr is online now
post #17839 of 24590 Old 08-03-2014, 04:28 PM
dmusoke's Avatar
Quoted: 281 Post(s)
Liked: 147
Truly Hi-Rez Downloads???
For those of us who think Hi-Rez downloads are truly High Resolution(24b/96 kHz and 24b/192kHz) are in for a shock! The spectrograph of a music sample below shows a very sharp brick wall filter at 16kHz, then another at 22kHz implying that the original soundtrack was recorded as a low resolution MP3 then up-sampled to the CD sampling rate of 44.1kHz (hence the 22KHz filter).
The download website (HDTracks) says its not their fault and that they simply distribute whatever music they get from the recording studios. Fair enough I say, but this has put a clout on all music downloads labeled as high resolution. Buyers beware...
ultra high end review dot com / another-rip-off-from-hdtracks/
Sorry ...I seem to have trouble inserting links on this site.
ID:	195281   Click image for larger version
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #17840 of 24590 Old 08-03-2014, 04:50 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Agree 1000%; don't be afraid to turn off your firewall for an hour while you diagnose and trouble shoot this issue. What OS are you using on your PC? Have you turned on the appropriate permissions, in Windows itself?
wase4711 is offline
post #17841 of 24590 Old 08-03-2014, 07:07 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
It's off topic to this thread, but yes you are correct.
There are other forums out there where these things are discussed in more detail
and even rate thousands of recordings based on their quality so you hopefully don't make the mistake of paying
hi-res prices for up-sampled crap.
scott_bernstein likes this.
Smarty-pants is offline
post #17842 of 24590 Old 08-03-2014, 07:27 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3549
Thank you for sharing good info , even if some of us already knew it. ...Many still don't know.
* Ultra High-End Audio and Home Theater Review ... is banned.
NorthSky is offline
post #17843 of 24590 Old 08-04-2014, 01:38 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Would like to know where I can find this.
If it is too much off topic I would appreciate it if you can PM me the info.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #17844 of 24590 Old 08-04-2014, 03:57 AM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
I'm using Windows 7 64-bit, and the firewall I'm using is Norton Internet Security, with permissions set to allow the oShare program full access. I will try turning off the firewall for an hour to see what happens.
pbarach is offline
post #17845 of 24590 Old 08-04-2014, 05:13 AM
Daffietje's Avatar
Quoted: 54 Post(s)
You know what is even more shocking? They are double screwed !
http://xiph.org/~xiphmont/demo/neil-young.html
You will not hear the difference anyway when comparing the exact same master with full CD quality.
post #17846 of 24590 Old 08-04-2014, 09:24 AM
Liked: 0
Dear Bill (wmcclain),
Thank you very much for the advice I changed to mkv file using the program you suggested and it all seems to be working fine.
Do you have any idea why? Does Oppo not like M4V files.
John
post #17847 of 24590 Old 08-04-2014, 09:52 AM
SeeMoreDigital's Avatar
Quoted: 472 Post(s)
Liked: 197
If the .m4v files have been downloaded from Apples web site, it could depend on which video, audio formats along with other data has been placed within Apples proprietary .m4v container format. Indeed, they may be DRM protected!
Edit: If the .m4v files have been generated using HandBrake... Don't save to .m4v container. It's rubbish. Use the .mkv container instead. And never, ever generate video using 'variable' frame rates. Always encode video using a 'constant' frame rate!
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #17848 of 24590 Old 08-04-2014, 10:39 AM
wmcclain's Avatar
Liked: 2086
They are supported (and aren't they the same as .MP4 files?) but I have seen reports that the container is more troublesome in the codec specs that it supports. It could be OPPO's fault. You might contact Support, write up your experience and offer them a sample file.
But...I have no reason to use anything other than MKV, a well-supported and unencumbered standard. MP4 may be more popular on phones and such, though.
-Bill
post #17849 of 24590 Old 08-04-2014, 01:20 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Only reason I can think of is that Apple devices (iPad, iPhone, etc.) I believe you can stream M4V directly to without transcoding - so if OPPO can support that format natively you would only need one copy of the file for both devices. I am pretty certain the aforementioned Apple devices won't accept MKV format without some kind of transcoding going on.
bgoering is offline
post #17850 of 24590 Old 08-05-2014, 02:13 AM
Daffietje's Avatar
Quoted: 54 Post(s)
I had something strange yesterday.
I put in a Bluray Disc into my Oppo and when it began reading it made quite alot of noise while reading the disc (constantly).
I stopped playback, ejected the tray, took out the disc and put it back in. Now it was near silent again (like it always is).
Any idea what was going on here?
I had deja-vu from my Marantz UD7006 who made these kind of noises very often
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
