Official OPPO BDP-103 Owner's Thread - Page 597 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #17881 of 24634 Old 08-11-2014, 09:55 AM
ckronengold's Avatar
Quoted: 56 Post(s)
Any tips for searching this forum? Its gotten pretty darn difficult to find specific answers to questions.
I'm trying to nail down the current status of DVD-A or SACD iso support over a network. I'm pretty sure one of the firmware updates last year killed it, but I wasn't trying to play any isos over my network at the time.
Media Room: Epson 5030 / Marantz 7010 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #17882 of 24634 Old 08-11-2014, 10:46 AM
rdgrimes's Avatar
Quoted: 2208 Post(s)
Liked: 1553
The 103 has never supported SACD or DVD ISO over network or any other way.
ckronengold likes this.
rdgrimes is offline
post #17883 of 24634 Old 08-11-2014, 11:15 AM
Quoted: 56 Post(s)
That helps explain why I couldn't find it. Guess I'll try extracting the files from the ISOs.
post #17884 of 24634 Old 08-11-2014, 11:34 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2973 Post(s)
Liked: 2229
Originally Posted by Naiera View Post
I haven't touched them at all.
I've put subs on quite a number of Blu-rays and I don't think I've ever downloaded a subtitle track this intricate.
You're right, it is pretty complicated. I don't deal much with .ass format and I'm guessing it is more sophisticated than simple .srt files.
Your example:
  • Has some sort of X-Y postioning
  • Font spec
  • Multiple subtitles overlapping in time code and duration
You'll get the basic lower subtitle on the OPPO, but the not the fancy extra one. My only suggestion is to write up your tests for OPPO and offer them a sample file.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #17885 of 24634 Old 08-11-2014, 11:40 AM
Naiera's Avatar
If only I could get the basic subtitle, which in my head would be the dialogue translation. But no, I only get the fancy screen text translation...
Thanks very much for looking into it. If only there was some way to automatically delete everything that isn't standard subs, in these files. If I put them in SubtitleEdit in Windows (I'm on a Mac but have XP in VMFusion), they're divided into categories.
Naiera is offline
post #17886 of 24634 Old 08-11-2014, 11:46 AM
wmcclain's Avatar
Liked: 2229
I don't do much subtitle editing...I remember Aegisub being cross-platform and capable. Else, I think you'll have to find a fan-sub forum for help. Anime sites?
-Bill
Naiera likes this.
post #17887 of 24634 Old 08-11-2014, 03:04 PM
Coyote Waits
htwaits's Avatar
Quoted: 940 Post(s)
Liked: 2079
Originally Posted by seggers View Post
So I wish to speak of herasey for a while if I may. If someone, mentioning no names, had decided to chop in their Oppo (as in selling it on) and replace it with something else, what should they be looking at as a replacement?
Seggers
Find one of last year's Sony players. The new models won't be any better and the price will be a lot lower.
I hope you don't expect an analysis.
htwaits is online now
post #17888 of 24634 Old 08-11-2014, 07:02 PM
Kal Rubinson's Avatar
Quoted: 718 Post(s)
Liked: 495
Nope. Mine supports DSF/DFF over ethernet/SMB from my server. No ISO though.
Same for the 105.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #17889 of 24634 Old 08-12-2014, 02:49 PM
loop7's Avatar
Quoted: 12 Post(s)
Just bought a BDP-103 yesterday and had a question about video settings.
I watched part of two BR discs, a DLNA and local video files and I think I'm seeing what seems similar to the motion smoothing or interpolation effect seen on panels (I have this disabled on my VT60). It's not as bad as what I've seen on panels but did make me wonder.
Is this "clarity" I'm seeing with the Oppo simply the high quality video processing or should I be configuring something?
loop7 is offline
post #17890 of 24634 Old 08-12-2014, 03:00 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3082 Post(s)
Liked: 3975
^ There is no image interpolation in the OPPO. If you are seeing a less "filmic" picture quality it may be in the content -- e.g., stuff shot with digital cameras not intended to mimic film.
The best way to check your video settings is to spend some quality time with a video calibration disc, such as Spears & Munsil v2, Blu-ray, available from OPPO.
Be sure to double check your Display's settings really are what you think they are. Displays typically remember such settings "per input", so if you've plugged into a different HDMI input you may not have the settings you expected.
Checking settings in the OPPO itself is simple: All of the Picture Adjustment settings should be left on their factory default (0) values. Make any needed calibration adjustments using the controls in your Display.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #17891 of 24634 Old 08-12-2014, 04:49 PM
JazzGuyy's Avatar
Quoted: 309 Post(s)
Liked: 308
Note to those of you using Windows 8.1 who would like to use SMB with your Oppo player.
The documentation for today's (8/12/14) second Windows 8.1 update indicates that it addresses issues with SMB drives not working. I have not tested this since I don't currently have an SMB setup. Some of you who do and have this version of Windows might want to do the update and try it. I know that SMB has never worked with Windows 8.x. It may work with this update.
By the way, this is a second optional update in addition to the regular monthly windows updates. If you have automatic updates turned on, it should install automatically after the regular update are installed. If you don't allow automatic updates, use Check for Updates in Windows Update and be sure to install all pending security updates before installing this one (they are a prerequisite, it seems). You may need to reboot several times. You can also get the update file (and see what other issues it addresses) here: https://support.microsoft.com/kb/2975719
JazzGuyy is online now
post #17892 of 24634 Old 08-12-2014, 05:15 PM
eljr's Avatar
Quoted: 1067 Post(s)
Liked: 8082
Will an OPPO103 connect wirelessly to my NAS and stream my flac files to my theater system? If so, will it stream 24/192 flac files?
eljr is offline
post #17893 of 24634 Old 08-12-2014, 05:40 PM
Quoted: 718 Post(s)
Liked: 495
(Answered on another forum) Why not? I can do that with wired Ethernet. So, if your WiFi is up to snuff, it should work wirelessly (but I have not attempted it).
Kal Rubinson
post #17894 of 24634 Old 08-12-2014, 05:43 PM
eljr's Avatar
Liked: 8082
my thought was the dac difference not the streaming capability
eljr is offline
post #17895 of 24634 Old 08-12-2014, 07:22 PM
Quoted: 718 Post(s)
Liked: 495
??? I didn't see any mention of DACs in your post.
Kal Rubinson
post #17896 of 24634 Old 08-12-2014, 09:00 PM
eljr's Avatar
Liked: 8082
i just read on the JRivers forum that the oppo 103 can indeed stream 24/192 Flac wireless
eljr is offline
post #17897 of 24634 Old 08-13-2014, 03:40 AM
pbarach's Avatar
Quoted: 352 Post(s)
Liked: 206
It's true, if you have a media server program that will cooperate.
eljr likes this.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #17898 of 24634 Old 08-13-2014, 04:41 AM
Quoted: 718 Post(s)
Liked: 495
You do not need any media server program as the Oppo can pull those files from any shared drive on the network with SMB. DLNA/UPnP are not needed.
Kal Rubinson
post #17899 of 24634 Old 08-13-2014, 02:38 PM
dannybee's Avatar
Quoted: 203 Post(s)
Liked: 109
Hi.Just a question regarding the last firmware update for the 103/103D it states that it includes support for 4k50/60fps but only mentions this applies to the 103D model would this mean that the 103D is in someway different to the standard 103 apart from the darbee of course anybody have an idea.
dannybee is offline
post #17900 of 24634 Old 08-13-2014, 03:27 PM
David Aiken's Avatar
Quoted: 622 Post(s)
Liked: 1100
Yes, they are different. The 103D did not just add Darbee processing to a 103. The 103 has 2 video processing chips, the Mediatek chip and the QDEO chip. The 103D replaced the QDEO chip with a chip for Darbee processing and aSilicon Image VRS ClearView video processor. That means that there are some differences in video processing apart from Darbee between the 103 and 103D models. 4k50/60fps support is one of those differences.
David Aiken is online now
post #17901 of 24634 Old 08-13-2014, 06:03 PM
dannybee's Avatar
Quoted: 203 Post(s)
Liked: 109
Thanks David. I wonder if it might be better to just wait and see if oppo bring out a HDMI 2.0 version down the track in regards to 4k?
dannybee is offline
post #17902 of 24634 Old 08-13-2014, 06:08 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
Same for the 105.
If yours does mine can do too.
NorthSky is offline
post #17903 of 24634 Old 08-14-2014, 01:48 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Why is everybody so crazy about HDMI 2.0
Really, dont believe the hype man, this is no where near a standard and it will be quite some time untill it will be....
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #17904 of 24634 Old 08-14-2014, 05:52 AM
Liked: 0
Oppo HDMI: Best Connetion Method
Dear All,
I need some advice on the following issue(?) which I was advised is because of my OPPO103.
Firstly I have an OPPO103, an Anthem 310 MRX and a Panasonic TX-P60ZT65 Plasma TV. All of which I just got a few week ago and have been ironing out bugs ever since.
They were connected in the following manner, please see sketch [old.gif]. I had the OPPO set to split AV.
Now I was intermittently having problem with the Anthem saying 'No Signal' or going 'MUTE' when using the OPPO. Now the shop I got the stuff from said, the problem was most likely the way I had the HDMI cables connected, and effectively the Anthem was getting confused. They recommended this way to connect them all up, please see sketch [new.gif]. Oppo now set to Dual AV.
I tried this last night and it seems to work, there are certainly less HDMI cables.
So my questions are
(1) Will the video quality from the OPPO be less based on the new setup since the HDMI from the OPPO is now carrying video and audio?
(2) Should I turn video processing on the Anthem off and just let it passthru the video signal? For some reason I dont think I should let both the OPPO and the Anthem fiddle with the video quality.
Really sorry if this is all a bit 'old hat' but it can be a bit confusing for the poor newbie.
Any help appreciated
John
ID:	211441   Click image for larger version
johnallan44 is offline
post #17905 of 24634 Old 08-14-2014, 07:27 AM
Read the FAQ!
Liked: 3975
^ The second cabling method -- just one HDMI cable from the OPPO using its HDMI 1 output -- is the "normal" way to hook things up.
The Split A/V vs. Dual Display setting choice in the OPPO only takes effect when you have BOTH HDMI outputs of the OPPO in use. In the second cabling method, since only the HDMI 1 output is in use, that setting is ignored. Best quality audio and video are negotiated on the single, HDMI 1 output, without conflict since another HDMI connection doesn't also have to be satisfied. In the first cabling method, the Split A/V choice is the correct choice as it will insure best quality video on HDMI 1 to your display while also insuring best quality audio on HDMI 2 to your Anthem.
The main reason to use the first cabling method -- two HDMI cables -- is if your AVR won't pass a video signal you want to get from the OPPO to your Display.
The Anthem MRX does not do video manipulation (image processing). It does the basic video steps of de-interlacing, upscaling, and, as needed, color space conversion. But if you have the OPPO set to output 1080p the Anthem won't need to do any of that and so you don't need to worry about extra video processing. Setting he Anthem to Through mode for video will cause the OPPO to negotiate with the TV as to what to send the TV (through the Anthem). This is only valuable if you want *THE TV* to do your video processing.
So, I'd suggest you leave the Anthem set in its normal configuration and set the OPPO to send 1080p to it.
Again, the only reason to use the first cabling method (two HDMI cables) is if you discover you can't pass the desired video signal through the Anthem to the TV. E.g., 3D video or 4K resolution.
The audio muting you experienced with the first cabling method is likely due to the TV seeing the HDMI handshake coming at it from two directions at the same time -- direct from the OPPO and also from the Anthem. That's complicated by the fact that you are using ARC to send audio back from the TV to the Anthem. It's what's called an HDMI loop. There are some things you can try to address that, but again, if the single HDMI cable hookup gets what you want -- through the Anthem -- to your TV, there's no need to futz with that.
--Bob
post #17906 of 24634 Old 08-14-2014, 08:50 AM
Liked: 0
Dear Bob,
That's great...thank you very much for reply.
If i could get your opinion on one more thing...
The HDMI cables I was using cost about £5 each, I borrowed some more expensive ones from the shop where is got the kit from (audioquest Pearl) at £30.
Without starting a riot -are more expensive HDMI cables worth it - appreciate you might say it depends on personal preference, but just trying to get your opinion.
Sincerely
John
post #17907 of 24634 Old 08-14-2014, 09:07 AM
JazzGuyy's Avatar
Quoted: 309 Post(s)
Liked: 308
Originally Posted by johnallan44 View Post
Dear Bob,
Sincerely
John
No. HDMI cables either work or they don't. As long as the cable is reasonably well made and provides a solid fit when inserted, it will be fine. Some very stiff or heavy cables can be bad because they can put two much stress on the fittings or work loose.
post #17908 of 24634 Old 08-14-2014, 09:08 AM
Read the FAQ!
Liked: 3975
Dear Bob,
Sincerely
John
HDMI cables are sold in a few configurations these days: Normal, normal with Ethernet, High Speed, and High Speed with Ethernet. The "with Ethernet" will do nothing for you with the OPPO so you don't need those. HOWEVER, you DO need High Speed cables. So only use HDMI cables that are sold as "High Speed", or "For 1080p", or "Category 2" all of which mean the same thing.
The ideal length for an HDMI cable -- the length that will produce the most reliable results is 6 feet (2 meters), not shorter or longer. So don't buy short cables even if your gear is close together. Longer cables may work just fine (6 feet is a Rule of Thumb, not a Law), but the longer the cable the more problems you are likely to have. "Redmere" technology cables have an active circuit in the plug at one end which makes them act as if they are 6 foot cables regardless of the actual length. That makes them particularly helpful if you need a long cable run. This also means they are directional -- you have to plug them in the right way around.
Except for the above, paying for exotic HDMI cables is, in my opinion, a waste of money. Personally, I like the HDMI cables sold by Blue Jeans Cable and Monoprice -- both AVS Forum sponsors. The cable that OPPO ships with the player is also perfectly good.
HDMI plugs are friction fit, and it only takes a small shift of plug in socket to screw things up. This frequently trips up people who buy new HDMI cables. First, folks tend to buy thick, heavy cables for no good reason (the power of marketing compels you!) and the weight of the cables is enough to tug the plugs loose. Also, new cables have kinks in them from being folded up for packaging, and that too often causes them to tug on the plugs. Make sure all your HDMI plugs are inserted STRAIGHT into the socket with nothing tugging on them. If you have HDMI problems, first try reseating your plugs.
HDMI works best if there is only a single run of cable between each pair of devices. Anything else in the signal path -- daisy chained cables, HDMI switches or adapters, electronic gizmos, even wall plates -- is a likely source of HDMI problems.
--Bob
post #17909 of 24634 Old 08-14-2014, 09:14 AM
Gecko85's Avatar
Quoted: 157 Post(s)
Liked: 98
^^^ What Bob said.
Another nice benefit of Redmere HDMI cables (which are very inexpensive from Monoprice), is they're very thin and light, so they stay connected very well.
But yeah, you have to be careful to look at the markings on the end...otherwise you may think you have a defective cable. Not that I've done that.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is offline
post #17910 of 24634 Old 08-14-2014, 12:15 PM
Daffietje's Avatar
Quoted: 54 Post(s)
--Bob
What is wrong with shorter HDMI cables?
Most cables I am using (Audioquest Forest) are 1,5 meters.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
