Official OPPO BDP-103 Owner's Thread - Page 599 - AVS Forum | Home Theater Discussions And Reviews
 686Likes
Old 08-25-2014, 04:30 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1760 Post(s)
Liked: 756
Originally Posted by Duck05 View Post
Recently the 103 when playing some Netflix rental DVDs (NOT Blurays) has not been able to backup during playback. These are Showtime disks of some series we are catching up on....
When trying to back up a chapter or even a few frames the player just freezes and in order to get it going again (since none of the regular transport commands work when in this state) I have to go to either the main disc menu or the Oppo Home screen.... Most times the player takes you right back to where it was before you tried to issue the command(s) but not being able to back up is a pain....
Anyone else experienced this condition?
Do you have DVD 24p turned on? Try turning it off if so. There is a known bug with rewinding DVDs when that setting is on. We expect it to be fixed in future firmware.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 08-25-2014, 02:44 PM
easyjacks's Avatar
Quoted: 13 Post(s)
Hello, Ive got the 103 and it is fully updated.
Has anyone had a problem with accessing the BD Live content on Blu ray Discs ??? The Pandora and You Tube app work flawlessly. My Oppo is connected by Ethernet cable.
I did all the usual protocol. Turn the player on/off
Unplugged Ethernet cable and plugged it back in
Tried about 5 different Blu Ray discs and they all say "check if internet connection is available"
I went into settings and turned Ethernet off then back on. Nothing worked.
Just wanted to see if there's anything else to try before I call Oppo, thanks !!
easyjacks is offline
Old 08-25-2014, 02:56 PM
wmcclain's Avatar
Liked: 756
The player has a BD-Live setting which is off by default. Did you turn it on?
Setup -> Network Setup -> BD-Live Network Access
-Bill
Old 08-25-2014, 03:45 PM
easyjacks's Avatar
Quoted: 13 Post(s)
Lightbulb
-Bill
Of Course !! I will try this when I get home. Thanks !
Old 08-25-2014, 06:24 PM
deewan's Avatar
Quoted: 188 Post(s)
Liked: 192
Hello. I've tried searching for any posts regarding my question/problem, but have been unable to find anything. Please forgive me if I missed the answer in this very long thread.
I have a media player plugged into the rear HDMI input of the Oppo 103D. When I watch a MKV file using the media player and pass it through the Oppo I seem to loose the DTS Master Audio soundtrack and my processor plays 2 channel and displays the audio track as such. If I plug the media player directly to the processor, DTS Master Audio works just fine. If I watch the MKV file using the Oppos, the DTS Master Audio file works just fine.
My question is: Does anyone know if the Oppo's hdmi input(s) will not pass through lossless audio such as DTS Master Audio?
I was hoping to find someone with a PS4 or some other video device that may be plugged into the Oppo and passes lossless audio, but with all my searching I've been unable to find any mention of someone doing this.
Thanks in advance for any and all help.
deewan is online now
Old 08-25-2014, 06:47 PM
Smarty-pants's Avatar
Quoted: 449 Post(s)
Liked: 293
That is correct, the player's hdmi input won't accept DD and DTS lossless codecs. I think it will accept 192khz PCM though.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
Old 08-25-2014, 07:00 PM
Duck05's Avatar
-Bill
Thanks, Bill. I had not seen that issue being discussed and I absolutely have that option engaged so I will disable it until the bug is fixed. Thanks again.......
Duck05 is offline
Old 08-25-2014, 07:01 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1293 Post(s)
Liked: 1317
^ The specs for what's accepted on the HDMI Inputs are on the Specifications page at the back of the User Manual. Up to date versions of the User Manual for each player are available for download (PDF Files) from OPPO's Support page for each player.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 08-25-2014, 07:06 PM
deewan's Avatar
Quoted: 188 Post(s)
Liked: 192
Thanks for the info. That's very disappointing to hear. Oh well.
Old 08-25-2014, 07:41 PM
DanF8500's Avatar
Quoted: 616 Post(s)
Liked: 296
Send your high-def, lossless movies to your Oppo player via your home network. That way, you can let your 103 decode the hd audio formats, or let it pass the lossless digital audio out to your AVR for decoding.
DanF8500 is online now
Old 08-25-2014, 08:18 PM
donut, the's Avatar
Does anyone have any comments on the functionality of the unofficial so-called jailbreak firmware, specifically as it relates to BD iso playback and Cinavia? Hypothetically, of course.
donut, the is offline
Old 08-25-2014, 08:26 PM
easyjacks's Avatar
Quoted: 13 Post(s)
-Bill
Just checked. The BD-Live Network Access is ON........hmmmmmm
Any other suggestions ??
Old 08-25-2014, 08:29 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 780 Post(s)
Liked: 594
Discussion of such firmware isn't allowed here (it's against AVS rules)...
gsr is online now
Old 08-25-2014, 08:31 PM
donut, the's Avatar
I'll take the philosophical inquiries elsewhere. Thanks.
Old 08-25-2014, 08:38 PM
Read the FAQ!
Liked: 1317
Check Setup > Network Setup > Connection Test. If that works, and if BD-Live is enabled in Setup then there are not many possibilities. Either the discs you are trying (all of them) don't actually have active BD-Live servers at the studios, or something in your house network (such as a firewall) is blocking access.
If you are playing a disc intended for a Region other than the one for your player, you may not have access to the studio's servers.
--Bob
Old 08-25-2014, 09:13 PM
easyjacks's Avatar
Quoted: 13 Post(s)
--Bob
It must be server support from the studios. I just put in The Bourne Legacy and it worked right away. it streamed new previews instantly. All Blu-Rays are Region 1 and bought at Amazon or Target.
Blu-Rays that said BD-Live support and nothing happened :
Jumanji
Hook
Zombieland
(Did a Robin Williams marathon, Mrs Doubtfire did not have a BD-Live mark)
Old 08-25-2014, 11:29 PM
Read the FAQ!
Liked: 1317
I run into BD-Live nonsense like this from time to time during testing. I always pop the disc into a PS3 I keep handy for just such purposes. If the same BD-Live failure happens there, I chalk it up to stupid studio programming tricks and stop worrying about it.
For example, if the studio changes the Internet name for their server older discs won't find it any longer.
The most recent example was a Sony disc just 2 years from its release date. Studios don't really care about BD-Live any longer.
--Bob
Old 08-26-2014, 02:26 AM
Daffietje's Avatar
Quoted: 54 Post(s)
^Thats why I never use it anyway
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
Old 08-26-2014, 04:54 AM
deewan's Avatar
Quoted: 188 Post(s)
Liked: 192
I've considered doing that, but the media player I have has a very easy to navigate and clean looking interface as well as the ability to play the movie trailer and give movie facts. Opposed to the Oppo's file folder look and lack of movie info or search functions. I'm considering right now which I want more... the Darbee and upscaling of the files when passed through the Oppo 103D but without lossless audio, or the easy of use, movie trailers, movie info and lossless audio when the Oppo isn't in the chain.
I have an hdmi splitter, I'm half tempted to see if I can wire a way to send the audio directly to the processor and the video to the Oppo and then to the projector. That way I could get the best of both worlds.
Old 08-26-2014, 06:41 AM
DanF8500's Avatar
Quoted: 616 Post(s)
Liked: 296
You could have the best of both worlds if you use a DLNA media server on your home network. You would "push" digital media files to your Oppo player. No need to use the Oppo interface. Use a very intuitive DLNA media player/server, such as JRiver, and never have to settle for something less.
Old 08-26-2014, 06:50 AM
quad4.0's Avatar
Quoted: 132 Post(s)
Liked: 88
--Bob
The BD live is just previews and ads anyway is it not? I tried it once and all I got was lots and lots of BS
quad4.0 is offline
Old 08-26-2014, 06:55 AM
deewan's Avatar
Quoted: 188 Post(s)
Liked: 192
Could you give me an example of a DLNA media player that would give me the same performance as a Mede8er 600X3D and the Oppo's video processing?
My media player does stream HD audio and video, a perfect bit-for-bit version of my BluRay discs. I was simply sending those rips from my media player through my Oppo 103D to use the Darbee chip and letting the Oppo to upscale to quasi 4K. Unfortunately with the HDMI inputs on the Oppo, I am unable to pass-through the lossless audio.
Old 08-26-2014, 07:17 AM
DanF8500's Avatar
Quoted: 616 Post(s)
Liked: 296
I'm unfamiliar with your Mede8er 600X3D, but just a quick search of its features tells me it doesn't seem to support DLNA. Like I mentioned earlier, check out the JRiver media player/server software. It's more stable/robust running on a Windows platform. If you have an iPad/iPhone, then you can use JRemote also, which allows you to push digital media to your Oppo player via your home network. Even without JRemote, you can still push media files to any DLNA supported renderers in your home network from your home pc.
Old 08-26-2014, 07:18 AM
SeeMoreDigital's Avatar
Quoted: 407 Post(s)
Liked: 165
You'll probably find some useful information within this dedicated Oppo BDP-83/93/95/103/105 DLNA/UPnP thread...
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
Old 08-26-2014, 08:26 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 780 Post(s)
Liked: 594
If your media player can convert the Dolby and DTS lossless formats to LPCM (which is still lossless - it's essentially the same as unzipping the contents form a zip file), you could send that through the Oppo's HDMI inputs. If you're otherwise happy with the user interface and such, that should give you a very usable solution. You just won't have the Dolby True HD and DTS HD Master Audio lights lit on your receiver.
gsr is online now
Old 08-26-2014, 08:31 AM
deewan's Avatar
Quoted: 188 Post(s)
Liked: 192
We all like to see those lights though... don't we.
Thanks for everyone's input and help. I'll begin some more research
lanping09 likes this.
Old 08-26-2014, 08:37 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 780 Post(s)
Liked: 594
We do, but what really matters is how it sounds. The lights being lit or not shouldn't make a difference in the final sound quality. Given that it wouldn't cost you anything and should be really easy to configure, it's worth giving it a try.
gsr is online now
Old 08-26-2014, 09:33 PM
easyjacks's Avatar
Quoted: 13 Post(s)
--Bob
Yes, I agree. It's basically just BS. I never thought about the server issue. But like you said I really won't be using it.
mhobart likes this.
Old 08-27-2014, 02:30 AM
lasab's Avatar
Quoted: 20 Post(s)
Liked: 7
A few questions about the updated Netflix app on the Oppo 103
Do you get the option to Start at the Beginning or just Resume like Roku3 app?
What is the maximum bit rate? Does it go to 5800kbps 1080pHD?
How does the Oppo process the Non 5.1 sound which I think is mostly Dolby Pro Logic
Is it better to feed a Roku3 into a HDMI in? If it is, how will the Oppo treat the non 5.1 sound?
lasab is offline
Old 08-27-2014, 03:26 AM
pbarach's Avatar
Quoted: 245 Post(s)
Liked: 146
You just have Resume. Don't know about the bitrate. Oppo processes the non 5.1 sound as STEREO, whatever the source. Your AVR can get the stereo signal from the Oppo and process it as Dolby Prologic IIx if you like.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
taboola here
