Official OPPO BDP-103 Owner's Thread - Page 602 - AVS Forum | Home Theater Discussions And Reviews
 891Likes
post #18031 of 24634 Old 09-01-2014, 08:29 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3090 Post(s)
Liked: 3987
Originally Posted by chauavs View Post
Bob i tried everything that you said but it's still the same. I accidentally pressed the disc tray open and everything was back to normal but when i close the tray it happens again. is any other ways to fix this issue.
As Bill says, it is time to talk to OPPO Tech Support. Your player likely needs hardware service.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #18032 of 24634 Old 09-01-2014, 08:32 AM
fzdolfan's Avatar
Liked: 0
Originally Posted by wmcclain View Post
Yes, APE is supported.
Are you using DLNA? It could be your server doesn't recognize that file type.
Try SMB, or copy sample files to USB storage and attach that directly to the player to make sure there is not a problem with the files themselves.
-Bill
It didn't even occur to me that it could be the server. That must have been the issue (Serviio), because when I plugged my external hdd in, it saw them just fine.
The only minor disappointment I see now is that it's not displaying the artwork (just the ape files. Shows fine on flac) which I confirmed was embedded in the tag via Tag Scanner. That's not a huge deal though. If it bothers me that much I'll just convert to flac.
Thanks for the help.
Sent from my Nexus 7 using Tapatalk
fzdolfan is offline
post #18033 of 24634 Old 09-01-2014, 08:48 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2982 Post(s)
Liked: 2238
I've never used Serviio, but DLNA servers sometimes have configuration files that allow new file types to be added. You might look at Serviio support forums to see if this is possible.
I'm presuming APE is possible over DLNA, but I don't remember testing it.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #18034 of 24634 Old 09-01-2014, 09:20 AM
bikinpunk's Avatar
Quoted: 34 Post(s)
Liked: 36
Originally Posted by muadikhan View Post
There are lot of posts complaining about hiss when BDP-103 used as preamp with the 7.1 analogue audio-out. Is the hiss only present when the digital volume control is used, I remembering reading somewhere that if the volume is 100% then there is no noise. Does this means the hiss is gone as well.
I am using HK AVR-635 but it lacks HDMI I/O ports as well as HD audio decoding. But it has 8 channel direct input and the direct input supports volume control. So I can keep the Oppo volume at 100%. I am planning to use BDP-103 as preamp to feed into 8 channel input.
Will I hear a hiss?
_Muadi.
I know this is old, but I'm going to bump it as it's relevant to what I've been going through.
First off here's my electronics gear list:
Oppo 103 (preamp) --> (2) Rane DSPs --> (5) Crown DriveCore XLS Amplifiers & (2) JL Audio E112s
Speakers are obviously after the Crowns.
I e-mailed Oppo some months back asking about potential noise issues when using the 103 as the sole pre-amp. This is the exchange:
Erin,
If you will be using the player as the pre-amplifier, then you will want to use the BDP-105. The BDP-103 has 24-bit DACs and has a low signal to noise floor, so it will likely produce audio truncations if you use the player's built-in volume controls and a hum will always be present as the amplifier will always be amplifying the noise floor.
If you are running through a pre-amplifier, or another device which will be doing the volume controls, then the BDP-103 will work in your configuration.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
Service@oppodigital.com
So, Oppo basically told me, "yes, you should expect noise". They didn't specifically say 'hiss' and they focused on the 'hum' (two things which are NOT the same; I'm not new to audio ). Understanding the warning, I figured I'd give it a shot anyway.
I've had the setup mentioned above for about 4 months now. After having some time to really live with the system, I've realized that, indeed, the noise floor of the Oppo is a problem if you expect to use it as a permanent pre-amp solution. Keep in mind I have (2) Rane DSP's that drive the inputs of my Crowns and even with the ridiculous output voltage capability of the Ranes and the superb A/D/A conversion within, it simply cannot make up for the Oppo's faults when used as the sole pre-amp.
Before people jump the gun on my post understand this:
Oppo stated I'd need to use a dedicated pre-amp; so I'm not bashing the company or product at all!
What I am saying is if you're going to be hardheaded like I was, don't expect much different than the results I had. I got it to work as a pre-amp, sure, but I'm fighting the noise vs volume tradeoff; and upping the output voltage via the software only induces clipping (audible clipping, I might add). I've decided I'm going to have to plunk down the cash for a dedicated pre/pro, unfortunately. I'm hoping something like the Emo UMC-200 will suffice.
This is just some real-world use from my experience. Hopefully it helps someone who was in the quandary I was a few months back.
- Erin
bikinpunk is offline
post #18035 of 24634 Old 09-01-2014, 09:33 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I don't think APE files contain any metadata/album art, etc. You need the corresponding ".apl" file to go with your ".ape" files. ".apl" will contain your metadata, including album art.
fzdolfan likes this.
DanF8500 is offline
post #18036 of 24634 Old 09-01-2014, 10:03 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ Bikinpunk, the owner whose post you quoted was completely in the wrong about allowing his 103 to be left at full volume to feed his HK AVR. At full volume, the analog outputs of the 103 put out 2.1 volts/RMS. The HK AVR only has an input sensitivity of 200 mV on its analog inputs. Leaving the 103 at 100% volume would overdrive his AVR, thus producing distortion. If you're going to use max volume on the 103 and utilize its analog outputs, you better make sure you're not overdriving your source input.
DanF8500 is offline
post #18037 of 24634 Old 09-01-2014, 10:22 AM
bikinpunk's Avatar
Quoted: 34 Post(s)
Liked: 36
Understood. Maybe quoting him wasn't the best idea, but the point of my post was to provide some real world experience wrt the Oppo's pre-outs. And provide the email from Oppo tech as some supportive evidence.
Where did you see the voltage output for the Oppo being 2.1vRMS? I looked around once but didn't find it. I can measure it myself tonight with the scope; been meaning to, just never think about it when I'm actually at my house. Go figure.
post #18038 of 24634 Old 09-01-2014, 10:45 AM
pbarach's Avatar
Quoted: 352 Post(s)
Liked: 206
Using oShare on my Windows 7 PC, I find that some of my file folders show up on Oppo as empty when they actually contain music files (mp3, flac, wav). I have tried restarting the server on the PC (has no effect) or rebooting the PC (works sometimes). Anyone have some suggestions? I'm sure this is an oShare problem, but they are freeware and without tech support--and Oppo recommended this program as a DLNA server.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #18039 of 24634 Old 09-01-2014, 11:11 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
You know what? I just assumed that the multi-analog rca outputs of the 103 had the same output voltage characteristics as that of the 105's. Not sure why Oppo didn't state the output voltages of it rca section in the 103 manual. I was quoting from the 105 manual.
DanF8500 is offline
post #18040 of 24634 Old 09-01-2014, 11:22 AM
bikinpunk's Avatar
Quoted: 34 Post(s)
Liked: 36
Yea, that's been my luck. I can't find the specs anywhere. My *guess* is it's something closer to 1vRMS, but that's unsubstantiated. If I remember tonight, I'll measure the pre-out and post back what they are.
post #18041 of 24634 Old 09-01-2014, 12:28 PM
rdgrimes's Avatar
Quoted: 2211 Post(s)
Liked: 1556
Windows 7 has SMB support built in. Suggest you look into getting shares working and be rid of DNLA.
Also, be sure you enter the DNLA server in the Oppo via the "music" pathway if you want to see audio files.
rdgrimes is online now
post #18042 of 24634 Old 09-01-2014, 12:29 PM
Read the FAQ!
Liked: 3987
^ By my SPL measurements (through the Analog inputs of my Anthem Statement D2v) the RCA jack Analog out voltage of the 103/103D and the 105D appear to be the same for Analog output Volume 100 (or Volume FIXED). Tested with the LPCM tracks from AIX Audio Calibration, Blu-ray.
That's not super precise of course, but it certainly precludes the 103 putting out less than half the voltage.
Keep in mind that the Analog output Volume adjustment step size is different for the 103/103D vs. the 105/105D. Also the XLR jacks of the 105/105D are, by design +6dB hotter.
--Bob
post #18043 of 24634 Old 09-01-2014, 01:08 PM
pbarach's Avatar
Quoted: 352 Post(s)
Liked: 206
I am entering the DLNA server through the music pathway, and I'm seeing nearly all of my 550 audio files, except for the occasional foldeer that shows up empty on Oppo. The files are nothing unusual and aren't corrupted, and they are supported by Oppo (e.g. wav, flac, mp3).
How do I set up SMB on my PC? I've only seen SMB referenced concerning NAS units, which I don't have. Can I play DSD files using SMB?
pbarach is offline
post #18044 of 24634 Old 09-01-2014, 01:44 PM
fzdolfan's Avatar
Liked: 0
You may be right about the artwork, but fwiw, the other info shows fine (artist, title, album, etc).
Admittedly, I'm not a metadata expert. I know how to use programs that make it easy (e.g. tag scanner).
Like I said, easiest solution (for me) might be to just convert to flac. Would probably take me less time. :-)
fzdolfan is offline
post #18045 of 24634 Old 09-01-2014, 01:47 PM
fzdolfan's Avatar
Liked: 0
Speaking of artwork, why doesn't artwork display/download for SACD (even hybrid)?
fzdolfan is offline
post #18046 of 24634 Old 09-01-2014, 02:28 PM
Liked: 0
Forgot to ask: is this a North American player with the North American firmware?
-Bill
My Device is North America. I bought it from amazon. I don't know if the firmware that i installed is North America or what. How can i find out? thanks.
chauavs is offline
post #18047 of 24634 Old 09-01-2014, 02:32 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
If you bought it in North America, it should be safe to assume you have North America firmware as you'll get an error message if you attempt to install firmware from another region. The question was asked mostly to make sure you get directed to the right Oppo location to contact. You should contact Oppo Digital in the US for assistance with the problem you're having.
gsr is online now
post #18048 of 24634 Old 09-01-2014, 02:56 PM
Gary16's Avatar
Quoted: 55 Post(s)
Lip Sync Issues
Recently I have noticed lip sync issues with my Oppo 103. This has not always been the case. Today for example I was watching a bluray disc and had to push the lip sync all the way to -100 but then later on I was able to back it off to -40 which is where it was usually set in the past to get good lip sync.
I run a separate feed to the display and the audio processor but I do the same thing with my Pioneer 09 and that has not shown any lip sync problems (even tried the same discs).
Any suggestions of what may be causing this (and forgive me if this was discussed at some point much earlier in this thread).
Gary16 is offline
post #18049 of 24634 Old 09-01-2014, 04:11 PM
Liked: 0
I really appreciated you guys for helping me. I contacted Oppo Customer Service and they're going to provide me a shipping label to get it check up.
chauavs is offline
post #18050 of 24634 Old 09-01-2014, 04:13 PM
Read the FAQ!
Liked: 3987
^ The fact that the sync error varied on a given disc suggests this is actually a problem in the content on that disc. This is more common than most people realize.
As for things to try, try turning off 1080p/24 output from the player. Some displays introduce gross amounts of video processing delay when fed 1080p/24.
--Bob
post #18051 of 24634 Old 09-01-2014, 04:21 PM
JazzGuyy's Avatar
Quoted: 309 Post(s)
Liked: 308
A lot of routers support SMB shares through a built-in USB 2.0 or 3.0 port to which you can attach an external hard drive. You can start by checking if yours does.
BTW, Windows 8.1 now supports SMB shares after the most recent major update.
JazzGuyy is offline
post #18052 of 24634 Old 09-01-2014, 05:01 PM
pbarach's Avatar
Quoted: 352 Post(s)
Liked: 206
Ok, so as I thought, SMB requires an external hard drive, and I continue to need DLNA to serve audio files from my PC.
pbarach is offline
post #18053 of 24634 Old 09-01-2014, 05:06 PM
broseanrichard's Avatar
Sorry if this has all ready been asked. is there any way to turn off the speaker setup settings on the oppo? My Yamaha receiver has better settings
broseanrichard is offline
post #18054 of 24634 Old 09-01-2014, 05:32 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
No, not at all. You can use the built in Windows sharing functionality to share any drive / folder on any drive on your PC (whether it's an internal or external drive doesn't matter) to get the SMB shares you're looking for. In Windows Explorer:
1) Right click on the folder you want to share and select Properties.
2) Go to the Sharing tab and click either the Share... or Advanced Sharing... button to configure the share name and who can access the share.
3) Once done with the Sharing features, go back to Properties and go to the Security tab.
4) In the Security tab, make sure the username you're going to use to connect to the share is given at least "List folder contents" and "Read" access to the folder. Note that there's a special user called "Everyone" that you can give access to, which won't require you to provide a username and password when connecting via the Oppo player.
If you did everything correctly, you should now have a SMB share you can access from the Oppo.
Keep in mind that it can sometimes be a PITA to get the shares configured properly so you can actually access them, but you don't need to purchase any additional hardware or software to use SMB shares in Windows.
Also keep in mind that using SMB shares doesn't necessarily give you anything you can't do with DLNA, which tends to be a LOT easier to get working. But since you're running into issues with some files not showing up, it's probably worth a try.
pbarach likes this.
gsr is online now
post #18055 of 24634 Old 09-01-2014, 05:36 PM
wmcclain's Avatar
Liked: 2238
How are you connected to the receiver? The speaker setups is not relevant for HDMI or other digital connections, only analog.
-Bill
post #18056 of 24634 Old 09-01-2014, 05:41 PM
So the speaker settings are only for analog hook up and don't effect HDMI hook up? Also what about the crossover settings etc from the audio processing menu do a need to match them to my receivers settings or are they for analog as well?
post #18057 of 24634 Old 09-01-2014, 05:46 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
All of the speaker setup options, including crossover settings are only for the analog outputs. If you're using HDMI, you don't need to worry about any of those settings on the Oppo.
gsr is online now
post #18058 of 24634 Old 09-01-2014, 05:48 PM
Ok thanks
post #18059 of 24634 Old 09-01-2014, 06:13 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Might be a crazy idea - but have you checked for a stuck playback/navigation button on the front panel of the unit itself?
bgoering is offline
post #18060 of 24634 Old 09-01-2014, 06:26 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
Originally Posted by Bob Pariseau View Post
105D as the main player at present, others used for Beta testing and comparisons.
--Bob
Thx Bob. May I ask you why the 105D over the 103D? ...TY
NorthSky is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
