Official OPPO BDP-103 Owner's Thread - Page 605 - AVS Forum | Home Theater Discussions And Reviews
 850Likes
post #18121 of 24340 Old 09-03-2014, 07:01 PM
kellybob's Avatar
Pure Audio turns the back light off on my TV while the Energy Saver screen saver does not.
Current firmware, HDMI 1.
Explanation?
kellybob is offline
post #18122 of 24340 Old 09-03-2014, 07:03 PM
pbarach's Avatar
Quoted: 304 Post(s)
Liked: 192
Originally Posted by NorthSky View Post
PLII probably needs at least stereo to be able to process, I guess. If it is two-channel (mono) audio, then you'll get sound only from one channel, the center one. ...And nothing @ all from the other four, or six, or, eight, or ten other channels.
So, no good with PLII, PLIIx, PLIIz, all dts audio mode flavors, and all THX audio mode flavors.
...Only with some DSP audio modes: Full Mono, All Ch Stereo, and Mono Movie. ...And nothing else.
Yes, the Dolby PLII and similar "flavors" will work with two-channel signals to use differences between right and left channels to generate simulated surround channels. If the channels are identical, the Dolby system apparently figures that this is supposed to be a signal appearing from the center of a movie, like dialog, and everything comes from your center channel speaker. In contrast, the DSP modes add echo (sometimes multiple echos) and manipulate signals out of phase to give the illusion of spatiality. If you happen to have the Avia II calibration DVD, there are some sonar-like "PING" sounds that let you hear exactly what those DSP modes are doing.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #18123 of 24340 Old 09-03-2014, 07:07 PM
pbarach's Avatar
Quoted: 304 Post(s)
Liked: 192
Originally Posted by rdgrimes View Post
Try turning off the Gracenote look-up feature and see if that cures the issue.
Tried that...it didn't make any difference. After navigating to the sound file I wanted to play using SMB (and this is an ordinary 16/44.1 WAV file), I selected it. The little colored arrow didn't appear in the file list, and the Oppo stopped responding to any commands from the remote for about five minutes. The next time I tried to play the file (after power-cycling the player), now I got the little arrow next to the file when I selected it. Then I got the PLAY screen for that file showing 00:00 elapsed, and again the player locked up for about five minutes. The third time I tried to play the file, it worked without a hitch.
pbarach is offline
post #18124 of 24340 Old 09-03-2014, 07:30 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by pbarach View Post
Tried that...it didn't make any difference. ...
Something just doesn't seem right with your network. I've been following your posts on this subject since 8/3/14, when you first brought it up. Are you still running your PC wireless? GSR suggested you try a direct ethernet connection to your router by running a temporary cable (no holes drilled in your wall required) to see if your network problems go away. GSR's reply to you was post #17845 . You never replied back to him. The 103 manual states: For the fastest and most stable network connection, we recommend using an Ethernet cable whenever possible.
Your network is not stable....sometimes it works...sometimes it doesn't. Very suspect.
DanF8500 is offline
post #18125 of 24340 Old 09-03-2014, 07:38 PM
pbarach's Avatar
Quoted: 304 Post(s)
Liked: 192
I was having problems related to Norton Security causing the network access being shut off from the player in the middle of a song. Norton tech support had me change some of their firewall's settings, and that problem is gone.
I never tried using a long Ethernet cable to connect my PC to my router (which the 103 is wired to) because if it worked, the solution of wiring the PC to the router in the next room would require drilling holes in the wall--that's out if the question.
BTW I have no problems accessing my PC media files from a wireless PC on another floor, and they play flawlessly. Seems to me that the problem is likely to be in the 103.
pbarach is offline
post #18126 of 24340 Old 09-03-2014, 07:51 PM
NorthSky's Avatar
Quoted: 7001 Post(s)
Liked: 3538
Thank you for confirming what I thought. ...And yes I got that AVIA disc, and a whole bunch more of audio/video test discs. ...At least a dozen (BD), ...more if I count my DVDs.
By the way, Mono Movie DSP audio mode (with reverb) is the best.
...For me anyway, and over Full Mono and All Channel Stereo DSP audio modes.
After trying them all that's what I came to prefer.
Second best is Full Mono, then last is All Channel Stereo DSP mode.
The straight Mono audio listening mode, with two-channel mono audio soundtracks, is just without life, too blend. It is only coming from the center channel speaker.
And the straight Stereo audio listening mode is mono sound coming from the front L and R speakers.
...No imaging whatsoever, so it feels real weird.
<<>> ...All of this from my USB stick connected to my Oppo 103's USB front panel port.
...And with both AAC and MP3 2ch. @ 48kHz audio codecs, but actually in 2-channel mono sound.
And that is why I was confused because there is no mention of Mono in the display info menu of both my Oppo 103 and pre/pro.
Thx again.
~ Bob
"And it stoned me to my soul"
- Van Morrison
NorthSky is offline
post #18127 of 24340 Old 09-03-2014, 07:53 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Pbarach, If you truly believe your 103 is at fault, then you should contact Oppo, and send in your player for repair. You're not suggesting there's a bug in the Oppo firmware, are you? I haven't been reading lots of reports from Oppo owners that their players are locking up while playing audio via network. You should at least load some of your audio files on a usb drive, then plug that into your 103, and see if you can get a crash/lockup. You'll know whether your wifi network is not stable by doing that. Not doing the test GSR suggested because even if it did solve the problem, you still would ignore that solution, seems a bit odd to me. The goal is to find a solution....you can decide how you will act after you find "the solution".
DanF8500 is offline
post #18128 of 24340 Old 09-03-2014, 08:04 PM
Jamo8's Avatar
Quoted: 17 Post(s)
Ok guys, before I pull the trigger buying the Oppo, I need a bit of advice.
I'm planning to buy either the Oppo-103 or Oppo-103Darbee edition. Before I pull the trigger, is it day & night difference between them ?
I have Sony 55es projector and Onkyo TX-NR1010 AVR, if that matters.
Also, since the oppo has dual hdmi outputs ,I'm thinking to configure like this, Option 1hdmi 1 output goes directly to projector and hdmi 2 output goes to AVR. Option 2 just hdmi 1 output to avr and Avr output to projector . Any advantage going with option 1 ?
Also, sorry if these questions asked before.
Jamo8 is offline
post #18129 of 24340 Old 09-03-2014, 09:47 PM
RodChester's Avatar
Hey there. I'll do my best to give you my opinion as a recent 103D owner. I too was debating between a 103 and a 103D and ended up getting the 103D. As for the Darbee I have mine set at 45%. While watching video I don't notice any big changes but flipping the Darbee on and off I can see the improvement that it is making. It is one of those things that doesn't jump out at me, but I know it's there and enhancing my picture.
As for your set up choices, I chose to have HDMI 1 go directly to my tv and HDMI 2 going to my AVR. Then the video out goes to the HDMI in on the Oppo so that all of my components can have Darbee applied to them. The only hiccup with this set up is that when switching inputs on my AVR I occasionally have an issue where the video will drop out every ten seconds or so. Powering off the Oppo and turning it back on fixes this though. With your AVR it may work out differently though.
Overall I am very happy that I went with the 103D. I would rather spend the extra $100 now then decide I want a Darbee later and have to spend $300 on a standalone into.
RodChester is offline
post #18130 of 24340 Old 09-04-2014, 02:44 AM
David Aiken's Avatar
Quoted: 377 Post(s)
Liked: 633
Explanation?
The job of the screen saver is to prevent burn in problems from a stationary image on your screen. It replaces the stationary image (a paused movie or the home screen for example) with a moving image.
Pure audio turns off video output when you don't want it, such as when you are listening to music from a CD or streamed from your computer, and some think that it may improve sound quality.
So they do different things because they are intended to serve different purposes. Your Oppo is behaving correctly. The reason the backlight on your TV turns off when you engage Pure Audio is because there is no video signal so nothing to display and the only way your TV can display a black screen is by turning the backlight off. The reason the backlight stays on with the screen saver is because the screen saver is an image and the backlight has to be on to display the image.
David Aiken is online now
post #18131 of 24340 Old 09-04-2014, 03:37 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Well, thanks to Oppo for that.
* Which AV receiver do you have; a Denon/Marantz one?
Marantz SR5004 (see my sig)
About AIX bluray disc : I decided to buy it used for less than 10 British Pounds. Can't go much wrong for that price I guess.
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #18132 of 24340 Old 09-04-2014, 04:46 AM
kellybob's Avatar
Energy Saver – Video output will be turned off after 3 minutes of inactivity. Many projectors and LCD TVs will go into a standby or sleep mode and turn off their projection lamp or LCD backlight lamp, thus saving energy and prolonging the lamp life. When you press any button on the OPPO remote control or the player’s front panel, the screen saver will be canceled and video output will be restored. If your TV is already in standby or sleep mode, you may need to wake up the TV by pressing a button on its remote or control panel.
You can enjoy higher quality audio by turning off the video processing and output. The Pure Audio mode reduces any potential interference between the video and audio signals.
1. Press the PURE AUDIO button on the remote control to turn off video and enter Pure Audio mode. Video output will cease, the power light will dim and the front panel displays will turn off.
2. Press the PURE AUDIO button again to resume video and cancel Pure Audio mode.
Both say video output will turn off. Perhaps should say blank or black video signal. Anyway, there seems to be a difference in black level between the two.
kellybob is offline
post #18133 of 24340 Old 09-04-2014, 04:55 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1032 Post(s)
Liked: 948
As Dan mentioned, the ultimate solution wouldn't necessarily have to be drilling holes in the wall. The whole point of the exercise is to determine if your current wireless networking solution is the problem or not. If it turns out that running the temporary network cable resolves the problem, then there are a number of options that can be considered.
One would, of course, be to drill the needed holes and run a permanent network cable. If that's not an option, other options include getting a better wireless router, adding a wireless access point (hardwired to your router and located closer to your PC) to extend the wireless range in your house, powerline network adapters (these use your house AC wiring to carry your network signal), and various other options.
But until you've done some diagnostics to help narrow down the scope of the problem, it's going to be difficult to come up with a solution.
gsr is offline
post #18134 of 24340 Old 09-04-2014, 07:04 AM
Ejs71's Avatar
Quoted: 38 Post(s)
Does anyone use their 103 for SACD? I was thinking about buying some. I just a little confused on the difference besides the 24-bit on SACD.. Do they actually play in Surround? Do only certain sounds/instruments come from certain speakers? If so, that sounds pretty cool...
Also.. Besides Pink Floyd DSOTM, are there any SACD's that are a MUST HAVE??
(Please let me know if I should post this in a different forum.. I couldn't find the proper one, so I figured I'd try this one.)
Ejs71 is offline
post #18135 of 24340 Old 09-04-2014, 08:23 AM
LairdWilliams's Avatar
Quoted: 197 Post(s)
Liked: 223
Agree - and another possibility...
Examine the channel and/or frequency band being used by your router. If you are on the same channel/band as your neighbors then you are effectively sharing bandwidth with them. Finding a channel that is not being used nearby can make a big difference in reliability and throughput.
If you have an android phone, there is a very nice app called "Wifi Analyzer" that lets you see what wireless networks are active on what bands and channels. It also shows you signal strength for each network it sees - so you can walk around your house and get a good feel for signal strength and channel crowding in different locations in your home. I would guess that there are similar iPhone apps as well.
<<said the guy who's motto is "wireless sucks for streaming">> ;-p
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #18136 of 24340 Old 09-04-2014, 08:30 AM
rdgrimes's Avatar
Quoted: 1934 Post(s)
Liked: 1244
True, this is a topic best left to other forums. SACD uses a DVD-like technology that allows both a redbook CD layer and a SACD layer. That's called a hybrid SACD. SACD also allows 2 different sets of files on the SACD layer, one for stereo and one for 5.1. The player chooses what to play off the disc. Not all SACD are hybrid, not all SACD contain both stereo and 5.1 files. Buyer beware. Not all 5.1 is actually sourced from multichannel masters, sometimes its matrixed from stereo masters.
There are a number of threads in the multichannel audio forum with discussions of the "best" discs to start with for noobies.
SACD uses a DSD file which is single bit, not 24. When converted to LPCM, DSD is generally converted to 24 bit.
rdgrimes is offline
post #18137 of 24340 Old 09-04-2014, 12:46 PM
Quoted: 197 Post(s)
Liked: 223
The Oppos do a great job with multichannel SACDs. While such CDs are rare, many of them are phenomenal. Some of the best are pretty expensive though.
In addition to the multichannel audio forum here, check out www.quadraphonicquad.com for LOTS of multichannel music discussion (that board is pretty much dedicated to multichannel music). www.sa-cd.net also has a pretty comprehensive catalog of SACDs of all types and some reviews as well - and they are starting to catalog Blu-Ray audio releases too.
ntculenuf likes this.
post #18138 of 24340 Old 09-04-2014, 02:27 PM
Smarty-pants's Avatar
Quoted: 721 Post(s)
Liked: 600
^forgot the "c" in the link.
LairdWilliams likes this.
Smarty-pants is offline
post #18139 of 24340 Old 09-04-2014, 03:43 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by Bob Pariseau View Post
^ How are you set up to play audio, and are you sure you were playing the lossless track from that disc?
In the OPPO, check that you have Dynamic Range Control OFF and Secondary Audio OFF.
Check your speaker levels -- particularly your Subwoofer level -- using a calibration disc.
--Bob
Bob, just wondering something here. Why would you give the advice to turn OFF Secondary Audio?
I mean : if he would have enabled it by accident he would notice it quite fast anyway when watching the movie...
In other words : how can ENABLING Secondary Audio create the problems he is describing?
post #18140 of 24340 Old 09-04-2014, 03:50 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2156 Post(s)
Liked: 2726
^ It's quick advice without first surveying the details of his setup. if you use HDMI Bitstream output with Secondary Audio ON, and play a disc with Secondary Audio content (even if you've not chosen to play that content), then by the rules of Blu-ray decoding the OPPO has to decode the audio track you select as preparation for POSSIBLE Secondary Audio mixing. Then (possibly after mixing) that audio has to be RE-encoded back into a Bitstream for output. No consumer electronics has the horsepower to re-encode a lossless track on the fly, so in the case of the OPPO that's done using maximum bit rate, but still lossy, traditional DTS 5.1 or DD 5.1
And you can get a loss of dynamics due to the re-encode.
There's no such problem if you use HDMI LPCM or multi-channel Analog audio output.
--Bob
Daffietje likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #18141 of 24340 Old 09-04-2014, 08:58 PM
NorthSky's Avatar
Liked: 3538
Can't see no sig with a smartphone. ...But I knew it was a Denon or a Marantz one anyway.
~ Bob
- Van Morrison
NorthSky is offline
post #18142 of 24340 Old 09-04-2014, 09:01 PM
Quoted: 377 Post(s)
Liked: 633
OK, in your original post you said "screen saver" and not that you were using the "energy saver" mode.
I don't know what the issue is but you are incorrect in summarising the 2 modes when you say "Both say video output will turn off". The energy saver passage says "video output will cease" and the pure audio passage says "video output will turn off" which isn't quite the same wording and I wonder whether there is anything in that. Perhaps with pure audio the video connection is seen by the TV as the player actually turning off while in energy saver mode it sees the player as still sending a signal but one with no video content. What you're seeing may depend on your TV and the energy saver passage does say "Many projectors and LCD TVs will go into a standby or sleep mode and turn off their projection lamp or LCD backlight lamp…". Many projectors and LCD TVs" is not *all* projectors and LCD TVs.
I have a plasma and my screen goes equally black in both modes but plasmas don't have a backlight so what happens with my screen means nothing in relation to your screen.
Sorry I can't help any more.
post #18143 of 24340 Old 09-05-2014, 01:17 AM
B 26354's Avatar
Quoted: 41 Post(s)
Liked: 157
Explanation?
Well... I definitely do not have the technical expertise to give much of an answer, but just to add to the discussion....
On my 103 -- in order to prevent burn-in on my plasma when I'm listening to music (CDs, or WAV files on an attached USB hard drive) -- I have HDMI 1 out connected to an HDMI splitter, which branches to HDMI inputs on both my 58" 1080p plasma and a 10" backlit 1080p LED monitor. The splitter allows either one of the two monitors to be on individually, or both can be on at the same time.
Obviously, I'm using the Oppo in "split" mode, with its HDMI 2 output going to my AVR.
Regardless of which monitor or monitors happen to be in use, once I've selected the music and started it playing, I always activate the Oppo's Pure Direct button, which "blackens" the monitor(s). Along with helping to prevent burn in, I do this simply because I find the music playback-screen to be far too distracting.
In the case of the plasma, Oppo Pure Direct causes the screen to go completely dead black, as though it were actually turned off. By way of comparison -- because of the way I have the plasma calibrated -- when the Oppo Screen Saver is on (or when the black-backgrounded Oppo Home Screen is being displayed), its black background is not quite as black as when the plasma is turned off.
The little LED monitor's screen, however -- while it does go "black" -- remains "backlit", causing it to actually be a fairly bright "dark grey"... and that grey is the same intensity, whether what's being displayed is the home screen, the screen saver or the Pure Direct "blank" screen.
I'll leave it to the experts to explain what, if anything, this actually means.
I don't ever use the Energy Saver function, incidentally, so I can't address that issue at all.
B 26354 is offline
post #18144 of 24340 Old 09-05-2014, 04:12 AM
kellybob's Avatar
In my original post I stated Energy Saver screen saver as it is a screen saver that turns the video output off. The Pure Audio section states "to turn off video" and also "video output will cease" which I agree are not necessarily the same things.
Thanks for the feedback.
I did send a request to Oppo before I went out of town, but I think I deleted the response when I deleted all the bulk e-mail when I got back. I will ask the question again.
kellybob is offline
post #18145 of 24340 Old 09-05-2014, 04:26 AM
kellybob's Avatar
My TV will state No Cable Connected I believe when it does not see 5V on the HDMI hot plug detect line. It will state No Signal when it sees 5V and no video signal at all.
Both Pure Audio and Energy Saver screen saver both go to a black screen with Pure Audio also shutting off the backlight. I assumed that neither one is actually turning of the video output as this would result in the No Signal message. I expected that that Energy Saver screen saver might actually turn off the video output rather than black it as the only way my TV will auto shutoff is if it receives no signal for a certain amount of time, not a black signal. But the backlight does turn off with a black signal.
If I change the black level in the Oppo or in the TV, I can also change when/if the backlight goes off. Oppo is at default values and the TV is calibrated. One click lower on the black level in the TV gets the backlight going on and off during movies in some fade to black transitions within the movie and also in the transitions between content. I do not like this happening, but do like Pure Audio turning off the backlight mainly becasue the sound improves with the backlight off. It was hoping the Energy Saver also allowed the backlight to go off for the same reason although it sounds slightly better with the standard screen saver setting when the screen saver is not activated.
kellybob is offline
post #18146 of 24340 Old 09-05-2014, 11:27 AM
Read the FAQ!
Liked: 2726
^ Email OPPO Tech Support with what you've discovered and they can look into it. What happens on the HDMI in either case is a little complicated, and there could be a difference.
--Bob
post #18147 of 24340 Old 09-05-2014, 06:40 PM
spawnofwar1600's Avatar
Quoted: 62 Post(s)
I'm sure this questions has already been asked a lot but does the av receiver effect the video signal in any way when hdmi split is active?
I'm asking this because when ever i switch on my av reciever the image on the tv flicks for a second like when an hdmi handshake is made.
Does this suggest that av reciever is interfering with video signal in av split mode?
spawnofwar1600 is offline
post #18148 of 24340 Old 09-05-2014, 06:59 PM
Read the FAQ!
Liked: 2726
Not quite. Turning the AVR on or off forces a new handshake. The way HDMI works, that means BOTH outputs re-handshake.
But once the new handshake completes, the AVR on HDMI 2 does not impact the video going to the Display on HDMI 1 (with Split A/V selected).
--Bob
post #18149 of 24340 Old 09-05-2014, 08:55 PM
Quoted: 62 Post(s)
--Bob
Thanks for clearing that bob
post #18150 of 24340 Old 09-05-2014, 09:11 PM
FernandoF's Avatar
Greetings,
I own a BDP-103 with the latest firmware (great player and great forum !). It is connected to a pre-HDMI Rotel RSX-1056 receiver via both Coaxial Digital and Analog outputs. My front speakers are set to large on both devices. I was playing a stereo redbook CD to compare the sound quality between those two connections (comparing the DACs, I suppose), when I noticed something I can't explain...
According to the Oppo's user manual : "Speaker Configuration mainly applies to the multi-channel analog audio outputs. However, when Coaxial/Optical Output is set to LPCM in the Setup Menu, its signal becomes a down-mixed stereo version of the multi-channel signal that is sent to the multi-channel analog audio outputs. As a result, the LPCM signal from the coaxial and optical output is affected by the settings in Speaker Configuration."
However, based on what I'm hearing (and measuring with an SPL meter), it seems the speaker trims on the Oppo's Speaker Configuration screen DO affect the volume level via the Coaxial Digital connection even if Coaxial/Optical Output is set to Bitstream in the Oppo's Setup Menu. I can clearly demonstrate that with reedbook CDs, although DD/DTS movie soundtracks don't seem to be affected (as expected).
I'm a bit puzzled with the above behavior... Any thoughts ?
Thanks in advance for any feedback.
FernandoF is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
