Official OPPO BDP-103 Owner's Thread - Page 607 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #18181 of 24634 Old 09-09-2014, 06:30 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 225
Originally Posted by boe View Post
I'm streaming from a Windows 8 machine running Mezzmo. I'm not sure what gracenote is.
If you are streaming from a DLNA server, then the metadata for MKVs comes from the DLNA server. If Mezzmo has a media management app, then you can use that to update Mezzmo's database with the correct information. If Mezzmo is just a stripped-down server with no media management app, then I am not sure what you can do.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #18182 of 24634 Old 09-09-2014, 06:33 AM
boe
boe's Avatar
Quoted: 929 Post(s)
Liked: 424
Thanks. It must be mezzmo.
boe is offline
post #18183 of 24634 Old 09-09-2014, 08:36 AM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
A quick question - What happens if I bitstream 7.1 content using the dual HDMI out into AVR1 7.1 capable, and AVR2 5.1 capable.
As a follow up question, what would happen if I am sending PCM (decoding bitstream in the OPPO)? Just trying to get this set up
  1. Does each negotiate separately and my AVR1 will play 7.1 and AVR2 play 5.1?
  2. Will AVR1 be limited to 5.1?
  3. Does it not make any difference because the entire bitstream gets sent to both and it is up to the AVR to decide what to do with it?
For HDMI I think the last scenario is most likely - but want to make sure that the 2nd doesn't happen. I should mention that AVR2 is 7.1 capable (Denon X3000) but will only be setup for 5.1 + Zone 2 on the amps.
Bill
bgoering is offline
post #18184 of 24634 Old 09-09-2014, 08:59 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3078 Post(s)
Liked: 3969
^ Read the Manual and check the Knowledge Base articles on OPPO's Support page for the Split A/V vs. Dual Display setting choices. This choice only makes a difference when both HDMI outputs are live.
With Split A/V, audio is Muted on HDMI 1 and best audio is negotiated on HDMI 2. Best video is negotiated on HDMI 1 and a "safe" video is used on HDMI 2 -- sufficient for carrying the embedded audio.
With Dual Display, a compromise audio is negotiated which the devices on HDMI 1 and HDMI 2 can *BOTH* accept. If AVR 2 can only accept HDMI 5.1, then you would get 5.1 on both outputs. The same applies to video.
If only one HDMI output is live, then this settings choice is ignored and best audio/video are both negotiated on the live connection. With two AVRs cabled, it may be sufficient to turn one of them off to have only one connection live. The problem is that some devices keep their HDMI inputs "live" even when the device is supposedly "off" -- for HDMI CEC remote control over the HDMI cable for example. In THOSE cases, switching the problem AVR to a different input may suffice to shut down the input connection from the OPPO.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #18185 of 24634 Old 09-09-2014, 09:17 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ So, Bob, regardless whether hdmi audio is set to LPCM or Bitstream, your above statements still apply? I assumed that a media player wouldn't need to negotiate with the receiving device if bitstream audio is transmitted.
DanF8500 is offline
post #18186 of 24634 Old 09-09-2014, 09:37 AM
Read the FAQ!
Liked: 3969
LPCM and Bitstream always have to be negotiated. HDMI devices vary in the channel count, sample rate, sample size, and formats they accept in both cases.
--Bob
post #18187 of 24634 Old 09-09-2014, 09:51 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ That I did not know. Thanks, Bob. So, for example, if the receiving hdmi device can't decode Dolby True HD from bitstream audio, the 103 will transcode the bitstream to some lower format that is acceptable to the receiving device?
DanF8500 is offline
post #18188 of 24634 Old 09-09-2014, 09:55 AM
Read the FAQ!
Liked: 3969
^ By spec, every Blu-ray that offers a lossless Bitstream track ALSO has to offer a lossy "compatibility" track which is used for just such purposes.
--Bob
DanF8500 likes this.
post #18189 of 24634 Old 09-09-2014, 10:33 AM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Hi Bob,
Not what I was wanting to hear, but I am guessing if I configure my AVR2 to operate as 7.1, and turn off the rear surround channels speakers that AVR will likely negotiate 7.1 and all will be good. I should probably go ask that in the Denon thread on the 2013 AVRs.
Thanks for all the good information
Bill
bgoering is offline
post #18190 of 24634 Old 09-09-2014, 12:01 PM
Read the FAQ!
Liked: 3969
Typically, if you disable speakers in an AVR, it will still accept input up to the max, but then down-mix that.
I.e., if AVR 2 can accept HDMI 7.1 input, but you have it configured for only 5.1 speakers, then it will STILL accept 7.1 input, and down-mix that for you.
If you play 7.1 content into an AVR that only accepts 5.1, the down-mix on HDMI happens automatically according to the rules for each format.
--Bob
post #18191 of 24634 Old 09-09-2014, 03:18 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Thanks again Bob, I kind of got confirmation of that over in the Denon thread so it sounds like I should be good to go with the X3000 which is 7.1 capable.
My initial setup trying to get a little more life out of an old Marantz sr5000 AVR used only as a power amp for my 5.1 speakers upstairs was less than a stellar experience. Trying to use the new AVR (Denon 4520CI) to power the 7.1 system in the theater room and send zone 4 to the 2nd zone did not work well at all. In order to get audio and video to the 2nd room involved a device that would take the zone 4 HDMI out and split into its video component over HDMI to the 2nd room, and this particular device would split out the audio to either coax or optical to go to the Marantz but only as DD 5.1 max.
Long story short - if I selected the OPPO for both the main zone and zone 4 it forced a handshake and reduced it to the lowest common denominator of DD 5.1 to both zones, which isn't ideal for the theater room. In the end I will be sending the theater HDMI output through a Lumagen 2041 first and let the Lumagen split the audio and video.
Wish me luck... If I wasn't so cheap I would probably just get a 2nd OPPO for the 2nd room
bgoering is offline
post #18192 of 24634 Old 09-09-2014, 05:01 PM
spawnofwar1600's Avatar
Quoted: 62 Post(s)
The Tv screen size input in the 3d settings, does it really do any thing?
I've heard that it has no apparent effect?
spawnofwar1600 is offline
post #18193 of 24634 Old 09-09-2014, 11:14 PM
rexdragon's Avatar
^already been discussed before...
and here..
I personally haven't tried it myself, but guess it wouldn't hurt to experiment around with the setting.
rexdragon is offline
post #18194 of 24634 Old 09-10-2014, 12:53 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
I tried it on the 103 with Tangled, toggling between 999 and my real screen size (121), and noticed no difference whatsoever. Back in the 93 threads, Oppo confirmed it did nothing other than report the number to any BD-Java on the disc that asked for it.
I'll bet if you e-mailed Oppo and asked them what effect the number has on the 103, you would get a response back pretty quick . . .
BobearQSI is offline
post #18195 of 24634 Old 09-10-2014, 01:21 PM
rdgrimes's Avatar
Quoted: 2208 Post(s)
Liked: 1553
I think I heard also that the 3D setting is required for licensing. In any case it should be set for your actual screen size. If the disc JAVA asks for it you want it to be right.
lanping09 likes this.
rdgrimes is online now
post #18196 of 24634 Old 09-10-2014, 02:23 PM
Paul H's Avatar
Quoted: 36 Post(s)
Liked: 30
It may look like there is no effect if you don't know what to look for. The difference is very subtle if at all.
The purpose of the "screen size" setting is to help correct for ghosting if it is present. The setting subtly changes the left and right images convergence. If the distance between your eyes and the screen is 1.5x the screen size, the setting will basically have no perceivable difference.
LG 65" 4K/UHD E6P (Direct-view OLED Full HD Passive-3D)
Oppo UDP-203
Avatar: IMAX Header
BD 3D, BD, HD DVD, DVD collection
Paul H is online now
post #18197 of 24634 Old 09-11-2014, 03:30 PM
nickanderson's Avatar
Oppo BDP-103 with direct tv?
Hello,
Is anyone using the HDMI pass through with direct tv genie? I am just wondering if the picture quality improvements the image processor provides is significant?
nickanderson is offline
post #18198 of 24634 Old 09-12-2014, 08:45 AM
Bill Mac's Avatar
Quoted: 1420 Post(s)
Liked: 1634
I have a question regarding the analog volume control on the 103. I was going to try using the 103 as a preamp when playing SACDs. It would just be a quick unscientific comparison between the 103 as a preamp and my Parasound 2100 preamp. But I wanted to make sure I had the volume level on the 103 set at a low enough level so that my speakers or amp wouldn't be damaged.
So I tried lowering the volume level and it did not make any difference in the volume level till I reached "0" and the sound output was muted. This is when using the analog outputs (FL and RL) of the 103 to the 2100. I didn't quite understand why the volume was not decreased but then I thought it was because I was using DSD for SACD output. When I swapped the setting to PCM the volume level decreased when I lowered the volume from 100 down.
Is it true due to the way the volume control is setup with the 103 in that when DSD is selected that the volume control is bypassed? If so does the 105 function the same? If it does it seems odd that if one uses the 103 or 105 as a preamp that one could not use the DSD setting. But maybe the 105's volume level is configured differently. Any thoughts on this would be appreciated .
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D/205, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #18199 of 24634 Old 09-12-2014, 09:01 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
Bill
Correct, the volume control on the 103 will only function for DSD when you tell the player to convert it to PCM (as you found). The 105's volume control will adjust the volume either way. The volume control is in the DAC, the DAC in the 103 can't perform volume control on DSD.
Bill Mac likes this.
gsr is offline
post #18200 of 24634 Old 09-12-2014, 10:08 AM
Bill Mac's Avatar
Liked: 1634
gsr,
Thank you for your thoughts .
Bill
post #18201 of 24634 Old 09-12-2014, 11:31 AM
rdgrimes's Avatar
Liked: 1553
Also note that the player's setup must be set to "variable volume" as opposed to "fixed".
post #18202 of 24634 Old 09-12-2014, 11:34 AM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
This may have been covered already and I just didn't see it in my search... but can anyone tell me if the Oppo can take the video from my HTPC and improve quality?
Right now I am using an media player (talking about the HTPC software now) which is MPC-HC and MadVR which has a bunch of scaling/PQ enhancements, but I was thinking may be I just take the video from the software player (MPC-HC) and feed that to the HDMI of the Oppo and let that do the PQ enhancements? I am playing DVD and Blu-ray content if that matters, MadVR is using high quality settings.
I ask as I always seem to get a better picture from playing the physical disk in the Oppo than from the HTPC
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
post #18203 of 24634 Old 09-12-2014, 01:10 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 627
^ Should work fine running it through the player to see how the player makes it look,
as long as your HTPC is outputting a codec that the player recognizes and is compatible with.
Smarty-pants is offline
post #18204 of 24634 Old 09-12-2014, 01:31 PM
rdgrimes's Avatar
Liked: 1553
That's not too surprising. Does your video card cost as much as an Oppo?
The Oppo can also access media files directly on your HTPC via SMB or DNLA. So unless you're watching DVD/BD, ISO or folder rips on the PC, there are other options besides routing the PC video through the Oppo.
post #18205 of 24634 Old 09-12-2014, 03:24 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
And those options would take better advantage of the video processing in the Oppo as the HTPC will most likely be sending 1080p into the Oppo if connected to 1 of the HDMI inputs.
gsr is offline
post #18206 of 24634 Old 09-12-2014, 05:21 PM
JohnAV's Avatar
Quoted: 323 Post(s)
Liked: 483
Latest Public Beta Test Release
Release date: September 12, 2014.
Category: Latest Public Beta Test Release
Main Version: BDP10X-77-0827B
Loader Version: 6U1000 or 7B1300 (BDP-103), 7B1300 (BDP-105, BDP-105D, BDP-103D)
Sub Version: MCU103-05-0916 (BDP-103), MCU105-04-1113 (BDP-105), MCU13D-01-0618 (BDP-103D), MCU15D-01-0930 (BDP-105D), DB10X 131030 (BDP-103D, 105D)
Click here to download the BIN file for firmware version: BDP10X-77-0827B.
Click here to download the firmware CD image file BDP10X-77-0827B-CD-Image.iso.
Warning: Although firmware upgrade is an easy and usually trouble-free process, it is important to ensure that the power supply to the player is stable, and the upgrade process is not interrupted. A failed firmware upgrade can render the player unusable.
This release is still a beta test version, not an official release. Use it only if you would like to experiment with the new features and improvements. There is a very small chance of the new features and improvements not working properly. If that happens, please report any issue to us.
Release Notes:
This release is for the OPPO BDP-103, BDP-103D, BDP-105 and BDP-105D Blu-ray Disc players.
Special Notice:
  1. Once this Public Beta firmware is installed on the player, you can revert back to the previous Official release via a USB thumb drive. There will be no issues upgrading to any future official or beta firmware release.
  2. It is recommended that the user performs a "Reset Factory Defaults" operation after the firmware is installed. Please write down your special settings before doing this, and remember to re-apply your settings and adjust the proper volume level (if applicable) before you play any content. You may experience stability issues if this step is not performed.
  3. This Public Beta firmware is designed to work with new versions of Apple iOS and Android media control applications, which add new features like DMS (digital media server), DMC (digital media controller), virtual keyboard, player settings, and disc playback controls. The Media Control V3.0 will be available in the Apple Store and the Android Play Store shortly.
Comparing to the current Official release version BDP10X-75-0515, the major changes included in this version are:
  1. Resolved a Color Space issue for the HDMI 1 Out in BDP-103D/105D. Customers reported that if the Resolution was set to Source Direct and the Color Space was set to RGB Video Level, the actual color space sent out was RGB PC Level. This issue has been fixed in this firmware.
  2. Resolved a Picture Adjustment issue found on 75-0515 firmware. Customers reported that after changing the Picture Adjustment parameters for HDMI 1, the value of Contrast Enhancement would automatically go back to 0. It has been fixed in this firmware.
  3. Resolved a playback issue with regular DVD discs found on 75-0515 firmware. Customers reported that if the "DVD 24p Conversion" was set to "On", pressing the REV (rewind) button within the DVD playback could cause the player to immediately freeze up. This issue has been resolved in this firmware.
  4. Resolved a HDMI Audio issue with some 2L Blu-ray Music discs. Customers reported that if the AV Sync was set to 90ms and above, there might be no audio signal from both HDMI outputs.
  5. Modified the RS-232 serial control protocol: we eliminated the "#APP FFR" due to the removal of Film Fresh service, added the "#APP BER" to enable access to the Berlin Philharmoniker concert service, also fixed an issue with "#SZM" that could not change the Aspect Ratio.
  6. Added support for the “Pandora Premiers” station in Pandora.
  7. Improved the Gapless Playback feature, and resolved an issue where the gapless mode could not be enabled for some 96 kHz / 24-bit WAV files.
  8. Improved support for CUE files, specifically for CUE files that point to multiple WAV files.
  9. All features and improvements of the previous firmware are also included in this version.
Oppo Beta Group
JohnAV is online now
post #18207 of 24634 Old 09-12-2014, 05:50 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
I was looking for something more technical - and actually one of my NVidia cards cost over $1000 so yes a lot more that my 103 but that doesn't have much to do with my post
I wanted to know if the Oppo 103 would be comparable to using MadVR on the HTPC - I can do some real world tests but wanted to try and find out any technical info before I start messing with my set up.
post #18208 of 24634 Old 09-12-2014, 05:52 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
Amazing! ...That is almost twenty firmware updates since first released. ...Talk about constant support! ...Extremely cool.
NorthSky is offline
post #18209 of 24634 Old 09-12-2014, 05:52 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
I have the HTPC output to 1080p already via HDMI to the receiver but I wasn't sure how much processing the Oppo would do to that vs. having MadVR running on the PC?
post #18210 of 24634 Old 09-12-2014, 06:01 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
My point was that if the signal is already 1080p, there isn't much processing for the Oppo to do as the video is already decoded, deinterlaced (if needed), and scaled (again, if needed) to 1080p. All that's left is any noise reduction you have enabled. If you had the Darbee model, then Darbee could be applied.
If you find the picture quality better on the Oppo than on your HTPC when you play Blurays, then the answer seems pretty clear that the video processing in the Oppo is better than the MadVR processing that's running on your PC. In order to take best advantage of that, you would want to play the files directly on the Oppo rather than playing them on the HTPC and then sending the HDMI output of the HTPC through the Oppo. You can do that by:
1) Playing the physical disk (DVD, Bluray, etc.) on the Oppo instead of on the HTPC.
2) Playing media files via DLNA, either using the Oppo UI to select files or by using the Oppo as a DLNA renderer and some method to send the file to the Oppo (JRiver running on the PC and JRemote on an iOS device is a great way to do this).
3) Playing media files via SMB using the Oppo UI to select files.
4) Playing media files from a locally attached USB external storage device.
gsr is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
