Official OPPO BDP-103 Owner's Thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
post #1801 of 24395 Old 11-06-2012, 10:29 AM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
The reported lip sync issues are disconcerting as I wait for my 103 to show up. Are fixes via firmware fully expected or could there be hardware involved? My guess is FW but??
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #1802 of 24395 Old 11-06-2012, 10:31 AM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
I used to have a Denon AV receiver always had problems, sold it and switched to Yamaha no problems smile.gif
wse is offline
post #1803 of 24395 Old 11-06-2012, 10:35 AM
wse
wse's Avatar
Liked: 739
Problems of early adopters, I know the felling
wse is offline
post #1804 of 24395 Old 11-06-2012, 11:33 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Been using the 103 since the first pre-production testing, never once saw any synch issues. (Bitstreaming to a Yamaha AVR). Issues like this must first be demonstrated in Oppo's lab, then fixes are usually pretty quick in coming. It's not a hardware issue. Every setup has a dizzying array of possible settings and processing which can and do cause synch issues, the player is just one part of the big picture.
lanping09 likes this.
rdgrimes is online now
post #1805 of 24395 Old 11-06-2012, 11:47 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2253 Post(s)
Liked: 2819
It will undoubtedly get fixed in firmware. The test matrix on this is daunting (the number of combos of source, content format, output, and settings), and evidently a few combos have slipped through. There were similar teething pains when the 93 first shipped. OPPO is on the case.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #1806 of 24395 Old 11-06-2012, 12:17 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Originally Posted by Don Borvio View Post
Unless you have a defective cable, or have interference that's interrupting the signal - I don't see how one HDMI cable could be that much better than another. Either the 1s and 0s go through or not.
To add to this, there is a simple test anyone can do to see if their cable is adequate for their Oppo to their system, etc. Because DTS-MA and Dolby TrueHD are lossless, compressed formats. On top of that, the audio stream is HDCP encrypted when sent out by the Oppo. If even one bit is screwed up during transmission, the encryption and the compression will cause a huge error in the audio signal, and likely you'll get an audio dropout.
So you can test it like this: Set the Oppo to bitstream, and play a Blu-ray with a DTS-MA audio track. If your audio sounds fine, you know the cable works with your Oppo to deliver bit-for-bit perfect transmission.
But the summary is this: HDCP encrypts the video too. If something changes during the transmission, the decryption is not going to work. Therefore, all HDMI cables that work are guaranteed to be delivering the same exact digital data to the display which does the decryption after receiving it.
BobearQSI is offline
post #1807 of 24395 Old 11-06-2012, 12:24 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
One potential cause for the sound to be different with different cables is that furniture got rearranged while running cables and didn't get put back.
Selden
Selden Ball is offline
post #1808 of 24395 Old 11-06-2012, 12:31 PM
Ali is mental's Avatar
The two posts above stating that Yamaha AVR's are having no lip-synch issues make me feel better as I have a Yamaha AVR. Picking my 103 up tomorrow, can't wait.
Ali is mental is offline
post #1809 of 24395 Old 11-06-2012, 12:34 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
--Bob
Thanks! I was torn enough about 103 vs 95 for the possible use of stereo analog without adding lip sync to the internal debate.
post #1810 of 24395 Old 11-06-2012, 12:54 PM
CatBrat's Avatar
Can't lip sync issues be temporarily dealt with using the correction feature for this that's built into most receivers, until OPPO has a FW fix for it?
CatBrat is offline
post #1811 of 24395 Old 11-06-2012, 12:58 PM
CatBrat's Avatar
Originally Posted by hernanu View Post
I don't think the 105 will give you any benefit for straight sound, since your receiver doesn't have analog multi channel inputs. If you want some of the other features (headphone amp, optical inputs) that the 105 provides but the 103 doesn't, then that may be worth your while.
As far as sound, since you're talking HDMI sound, the 93 or 103 is your choice, I would think the reason to upgrade would be features, since the sound quality, while probably better may not blow away your 93. The features here are prompting me to upgrade, but for me it's easier since I'm upgrading from an 83. The ability to source other components through the 103 for video and sound, etc... all sound like what I want.
Soundwise though, I think your best bet is to audition one, compare it to your 93 and see if it's worth the upgrade.
Thanks. This helped plug up some holes in my knowledge. That leaves me with the following choice. Go down that slippery slope of higher costs for little added benefit, or be satisfied with a much smaller upgrade to the 103. I choose the less costly 103 upgrade instead.
CatBrat is offline
post #1812 of 24395 Old 11-06-2012, 01:04 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
This depends on the receiver. Some receivers have a global Audio Delay, so any alteration of the delay would cause other sources to now be out of sync. If the receiver has Audio Delay capabilities which are source dependent, then you can add a delay just to the player's input to a generic level which works best for all sources. Bob uses something like 150ms in his configuration, where I have found as little as 35ms to as much as 90ms has been required in some instances in my configuration (on a whole, I use 0ms delay).
Neuromancer is offline
post #1813 of 24395 Old 11-06-2012, 01:54 PM
Read the FAQ!
Liked: 2819
^ OK, since we are talking about workarounds now, I guess I'll need to lay out my current findings.
First of all, I'm using a Beta sample 105 at the moment, so it is not absolutely certain that what I'm seeing actually applies to the 103. I suspect it does, but I can't confirm that.
Second, I'm on newer, Beta firmware than you folks with 103s. So I'm going to try to recall my set of results that match the 1018 firmware currently on the 103. The answers for the Beta firmware I'm using are DIFFERENT. I.e., firmware changes are in process to address this stuff. (I can't talk about Beta firmware beyond that.)
Third, some of the errors we are seeing now appeared late in the Beta test cycle. That's unfortunate of course, but it is what gives me complete confidence OPPO can fix this stuff in firmware. I.e., it used to work!
So here goes:
I have only HDMI 1 cabled. Folks who are using both HDMI outputs will likely see different results. This is one of those matrix of testing items I alluded to above.
I use a variety of calibration discs to check this stuff. It is vitally important that you use test content of known quality regarding sync. Real movies *OFTEN* have inherent sync errors that may even date back to their theatrical release (i.e., it was that way in movie theaters, too!). Such inherent errors typically change scene by scene. There are lots of ways for such errors to creep into movies, and as many reasons why the errors were never corrected. How it happens is not as important as recognizing that it DOES happen.
One of the best, readily available, tests right now is on the Disney "WOW World of Wonder" calibration discs, which are available in both SD-DVD and Blu-ray. I use both of those and other test charts as well.
For the 1018 firmware:
Shiny disc playback (either SD-DVD or Blu-ray):
1) HDMI 1 video lags HDMI 1 audio by 150 ms. You need to add 150ms audio delay external to the player.
2) HDMI 1 video lags multi-channel Analog audio by 75ms. You need to add 75 ms audio delay external to the player.
Netflix streaming (native app):
1) Audio / Video sync is *CORRECT* for HDMI 1 video vs. either HDMI 1 audio or multi-channel Analog audio. This is based on using Netflix' test streams of known quality.
HDMI Inputs:
1) HDMI 1 video is AHEAD of both HDMI 1 audio and multi-channel Analog audio by 150ms. Since video is already ahead of audio, adding audio delay will just make matters worse. Since there is no way to speed up the audio or delay the video external to the player, there is no workaround. We'll just have to await a firmware fix.
NOTE 1: At one point, the answers above were different depending on whether the player was set to 1080p/60 or 1080p/24 output, specifically for the multi-channel Analog results. I'm sorry, but I can't recall whether that was true for the 1018 firmware. There's that matrix of test combos again....
NOTE 2: I don't test media file streaming, so I do not know if there's a different result for that. My expectation would be that audio / video sync for media files would match the Shiny Disc results.
NOTE 3: As should be obvious from Neuromancer's post above, different Beta testers are seeing different results on this. My assumption is that this is simply due to variations in configuration (e.g., 2 HDMI cables instead of 1, etc.) But that's yet to be confirmed.
--Bob
post #1814 of 24395 Old 11-06-2012, 03:02 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
>>> It's based on fact, not theory...
Uh, theory is fact. In spite of repeated misuse of "theory". Hypothesis is an educated but unproven "guess" at the how something works. Theory is tested and proven to be true... fact. "Theory of Operation" of some complex equipment, for example, is not speculation. It is the factual description of how the device operates. Pythagoras' Theory (or Theorum if you prefer) is geometric "truth" not a guess or possible explanation.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #1815 of 24395 Old 11-06-2012, 03:12 PM
Quoted: 188 Post(s)
Liked: 352
HDCP does not encrypt video data. HDCP is code passed during the handshake transaction before video is transmitted. If both devices complete the HDCP portion of the handshake, you get video. If either of the devices fails to complete the HDCP portion of the handshake, you don't get video. For video to be stopped, some new non-HDCP compliant device would have to be inserted in the signal path... disconnecting the HDMI cable will require a new handshake before the stream will re-start. If the new non-compliant device is not in the path, you won't get video.
THX -- ISF -- HAA
post #1816 of 24395 Old 11-06-2012, 03:38 PM
danieljoseph's Avatar
--Bob
The video lags behind HDMI1 audio on mine. The Denon 4810 only allows up to 100ms adjustment. I used 90ms as advised by Oppo. It fixes most lip syncs on my BDs but not all. For these I extended to 100ms and there is still a problem although less than without the adjustment. Will have to wait for the firmware fix.
danieljoseph is offline
post #1817 of 24395 Old 11-06-2012, 03:43 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
It most certainly does. The entire purpose of HDCP is so that video and audio data is never sent 'in the clear' so that a device eavesdropping could easily record the video. The handshake is to exchange keys between devices so that the encryption can occur in real-time, with the keys used to encode each frame changing on a frame-by-frame basis.
Here's the Wikipedia page: http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
And here's the actual specification itself: http://www.digital-cp.com/files/static_page_files/8006F925-129D-4C12-C87899B5A76EF5C3/HDCP_Specification%20Rev1_3.pdf
Key parts (emphasis mine):
Encryption of the data sent over DisplayPort, DVI, HDMI, GVIF, or UDI interfaces prevents eavesdropping of information and man-in-the-middle attacks
Encryption is done by a stream cipher. Each decoded pixel is encrypted by applying an XOR operation with a 24-bit number produced by a generator. The HDCP specifications ensure constant updating of keys after each encoded frame.
And straight from the spec:
both HDCP Devices to generate a shared secret value that cannot be determined by eavesdroppers ... the shared secret can then be used as a symmetric key to encrypt HDCP Content intended only for the Authorized Device. ... occurs during the vertical blanking interval preceding each frame for which encryption is enabled, and provides an initialization state for the HDCP Cipher for encrypting the HDCP Content within that frame
And the most obvious undeniable statement from the spec that video data is encrypted:
HDCP Encryption is applied at the input to the T.M.D.S. Encoder and decryption is applied at the output of the T.M.D.S. Decoder
post #1818 of 24395 Old 11-06-2012, 03:46 PM
Read the FAQ!
Liked: 2819
Yes that would be consistent with what I saw with the 1018 firmware. By putting in 90-100ms of audio delay in your receiver you are fixing most of the problem which will make it more difficult to spot the remaining error in real content. Generally speaking your brain will pretty much ignore up to about 50ms of error unless you are really focussed on looking for it. The calibration charts make it easier to spot the residual error.
--Bob
post #1819 of 24395 Old 11-06-2012, 04:05 PM
--Bob
Thanks Bob. The firmware I hope will fix the whole problem without me having to enter an audio delay in my receiver.
post #1820 of 24395 Old 11-06-2012, 04:09 PM
Read the FAQ!
Liked: 2819
^ Sure! That's the goal. The design intent is that the sync is correct at the player's outputs for all combos of settings/cabling -- assuming the sync was correct to begin with in whatever content you are playing.
As I said above, some errors got out in the early firmware for the 93/95 as well. OPPO is on the case.
--Bob
post #1821 of 24395 Old 11-06-2012, 04:20 PM
wse
wse's Avatar
Liked: 739
First of all, I'm using a Beta sample 105 at the moment, Bob
Bob,
Cool how does it sound did you compare it to the BDP-95?
wse is offline
post #1822 of 24395 Old 11-06-2012, 04:21 PM
Read the FAQ!
Liked: 2819
^ It sounds Great! But I never used a 95, so I can't offer a comparison. (I used a 93 in OPPO's last round.)
--Bob
post #1823 of 24395 Old 11-06-2012, 05:35 PM
wse
wse's Avatar
Liked: 739
Originally Posted by Neuromancer View Post
Have you compared the BD-95 with the 105 for sound and does the 105 sound better than the 95?
wse is offline
post #1824 of 24395 Old 11-06-2012, 05:48 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
I personally can't really tell a difference, but I am using a very modest sound system so I was not expecting any difference in audio performance.
post #1825 of 24395 Old 11-06-2012, 05:58 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
^^ In my listening so far, the differences are pretty subtle between the 95 and 105. But in the end I generally prefer the results with Audyssey XT32 engaged as my room really benefits from it, so I generally use HDMI for audio except for when I'm testing analog audio or just want a change of pace.
If I were in the situation of owning a 95 and considering upgrading to a 105, the new features would be the reason to upgrade, not the difference in sound.
gsr is offline
post #1826 of 24395 Old 11-06-2012, 06:14 PM
wse
wse's Avatar
Liked: 739
Originally Posted by gsr View Post
^^ In my listening so far, the differences are pretty subtle between the 95 and 105. But in the end I generally prefer the results with Audyssey XT32 engaged as my room really benefits from it, so I generally use HDMI for audio except for when I'm testing analog audio or just want a change of pace. If I were in the situation of owning a 95 and considering upgrading to a 105, the new features would be the reason to upgrade, not the difference in sound.
wse is offline
post #1827 of 24395 Old 11-06-2012, 06:26 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
Originally Posted by wse View Post
There are other new features, such as SMB support, HDMI inputs, and DLNA DMR (among others) to also consider.
gsr is offline
post #1828 of 24395 Old 11-06-2012, 07:03 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I know this was mentioned many pages ago, but does anyone remember how to get past the login nag screen that keeps me from accessing my added SMB folder shares? The default folders are fine. I will try a reboot if no one recalls the trick.
EDIT: Nevermind, creating an account made for an easy enough workaround. Now I'm in.
vinnie97 is offline
post #1829 of 24395 Old 11-06-2012, 08:08 PM
willshaw's Avatar
Hi, 103 owners, has anyone tried to connect 103 with computer directly with ethernet cable without hub or router? Is it possible? Such that 103 can access the shared folder in computer using just one rj45 cable. No router involved. Thanks.smile.gif
willshaw is offline
post #1830 of 24395 Old 11-06-2012, 09:23 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
I haven't tried it, but it would most likely work. You would need to use static IP addresses on both the PC and the 103 and would most likely need to use a network crossover cable (you could also hook them both up to a network switch and not need to use a crossover cable). The big question is why would you want to do that?
gsr is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
