Official OPPO BDP-103 Owner's Thread - Page 628 - AVS Forum | Home Theater Discussions And Reviews
 3146Likes
post #18811 of 24854 Old 11-02-2014, 10:34 AM
sal9000's Avatar
Originally Posted by ed1 View Post
I see others are having similar audio issues with the latest firmware.
My 103 is connected to an Integra 80.3 with a single HDMI cable from HDMI1. No second cable is being used.
I had a similar problem some time ago with my 103 and a 7 year old Panasonic where I would periodically have audio drop outs. Oppo replaced the unit with one that was worse. Everybody said to change the HDMI cable which did nothing. Oppo basically told me 'too bad'. Their support system is very good up until they reach the point that they tell you that their latest firmware is your problem. They wouldn't help me go back to the firmware that didn't cause the problem.
Most of the people here said it was a handshake problem and that I should use HDMI-2. This resolved the problem. I used to praise Oppo to everybody because of their extraordinary support. I don't do this anymore. They create problems for their customers and then say 'sorry'.
sal9000 is offline
post #18812 of 24854 Old 11-02-2014, 10:40 AM
ed1
ed1's Avatar
Quoted: 17 Post(s)
Just wanted to follow up my earlier posts regarding an audio problem. After further diagnosis of audio and network issues of other components in my setup, it appears that the problem may be caused by a widely-known part failure issue with the Integra 80.3.
Integra has agreed to replace the part at its expense. I think this will resolve my issues, which appear to be unrelated to the Oppo 103.
ed1 is offline
post #18813 of 24854 Old 11-02-2014, 11:08 AM
retate's Avatar
Quoted: 40 Post(s)
Liked: 44
Originally Posted by fmalczewski View Post
Last thing I noticed was that DHCP connections via my router seem to have a timeout of 1440 minutes (24 hours), which would explain a lot if router is reassigning addresses every 24 hours for idle equipment and the idle equipment is oblivious to their addresses being reassigned out from under them.
A device that has been assigned an address via DHCP should request a renew of the DHCP lease typically at half of the timeout value. This should happen even if the equipment is idle. If a device has been offline in some fashion, when it wakes up it should either request a new address or attempt to renew its current address. The reason for the timeout is that in large networks where devices come and go the address space available for assignment would be exhausted quickly if there were not timeouts. As others have mentioned the most likely source of your problem is a second device that is responding to DHCP requests. If there is a second device acting as a DHCP server, that function either needs to be disabled or the address pools for the two DHCP servers need to not overlap address ranges. An aid to troubleshooting a rogue DHCP server is on Windows systems the command line "ipconfig /all" will include a line that gives the IP address of the DHCP server. Other platforms may or may not have a way to report the DHCP server.
For devices that I want to have a fixed IP address (outside of the DHCP pool) many DHCP servers (including routers) provide a mechanism where you can specify the MAC address of the device and the IP address to be assigned for a specific device. I find it better to have all IP address management in one place than to configure static addresses on each device. I typically only assign static addresses on devices to switches and routers so that basic network functionality will be available even if the DHCP server is down or unreachable.
jskang likes this.
Bob
retate is offline
post #18814 of 24854 Old 11-02-2014, 12:18 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
1) I tend to configure the DHCP servers that I use to only make use of about half of the address range. On my network (192.167.1.x), the DHCP server manages ONLY addresses at x>=100.
2) If it stays in the house and supports wired connections then it gets wired to the network with a static address (x<100) - period. This includes all AV devices that can be wired.
3) If a device must use wireless, then the preference is 5gHz wireless connections wherever possible. Channel chose to minimize overlap with other 5gHz networks in range. 2.4gHz is last resort only.
3) The only devices directly connected to the gigabit LAN ports on the router are gigabit switches.
We have about as complex a home network as you will see. This is with 2 network printers, 2 workstations, 4 laptops, 5 servers, 2 iPads, 4 smartphones (3 android and 1 iPhone), 2 network printers, 3 streaming BD players, a roku-3, a networked TV and AVR, and a HTPC simultaneously connected to the network on many weekends. Many of those times there are 2-3 VPNs plus 3-4 media streams (internal and netflix/vudu/youtube, etc) active simultaneously - sometimes with file downloads going too.
... and no problems. No streaming issues except those issues that originate outside our home. No wireless congestion problems. No DHCP collisions. No flow control problems. Nada.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #18815 of 24854 Old 11-02-2014, 12:25 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ Good for you, Laird, however I would expect zero problems of the "electronic" nature in your house....termites, maybe!
DanF8500 is offline
post #18816 of 24854 Old 11-02-2014, 02:43 PM
FernandoF's Avatar
Originally Posted by rickydenim View Post
These were the steps - (I copied it to a doc and can't remember original poster sorry)
1) power on player with cable in HDMI2
2) open PP and put sharpness to +16
3) power off player
4) change cable to hdmi 1
5) power on player
'in this way i have the qdeo channel not with invasive and overshooted sharpness of hdmi1 but with well detailed sharpness of HDMI2 channel.'
I definitely noticed an increase in sharpness/clarity, absolutely love the PQ right now. Cautious on updating FW in case this no longer works.
Although I can't directly answer your question as I'm still using the beta, Oppo states on their website that both firmwares are "the same". In addition, if I remember correctly, someone also confirmed Oppo hasn't taken any action with regards to the trick a couple of posts after the latest FW announcement. Please check a few pages back for confirmation.
On the other hand, you don't have to go through steps 1-5 for the trick to work!!! If you're only using HDMI 1, just go to the picture adjustment menu for HDMI 2 and set Sharpness to +16. You should be able to see the subtle but very welcome improvement on the HDMI 1 picture right away.
audiofan1 likes this.
FernandoF is offline
post #18817 of 24854 Old 11-02-2014, 03:30 PM
paperthin567's Avatar
Quoted: 14 Post(s)
Hey guys. I have a question (2 parts):
Part 1: I currently own a Panasonic DMP-BD80 and I've been very pleased with it. I also have a Darbee Darblet hooked up to it, which has done wonders. However, I keep reading that the Oppo BDP-103 is the best player you can get in terms of audio fidelity/quality and picture. Is this true? If I upgraded to the Oppo, would I see and hear a difference from what I currently have?
Part 2: I've also read that this player (Oppo--BDP-103) has a video processor built in--Qdeo. However, Qdeo is not present in the BDP-103D, as Darbee seems to have been used in lieu of Qdeo. With that being said, will the results not be good in terms of picture quality if I'm using a separate Darbee unit on top of a bluray player with Qdeo?
Please help!
paperthin567 is offline
post #18818 of 24854 Old 11-02-2014, 03:49 PM
sworth's Avatar
Quoted: 388 Post(s)
Liked: 184
Easy answers.
Part 1: It's doubtful that you will see a significant upgrade in image quality. Most blu-ray players put out an HDMI signal to blu-ray and digital audio spec, so the reason to pick one over another is mostly a matter of features, not image quality.
Part 2: The difference between the 103 and the 103D is that the QDEO is replaced by the VRS ClearView processor. They are both very good. Adding an outboard Darblet to your Panasonic will most likely look just as good as the 103D unless you are using the image adjustment features that the ClearView processor controls. (sharpness, color, brightness, etc)
There are plenty of other reasons to choose the 103D though. It's a full featured player and is very well designed.
sworth is offline
post #18819 of 24854 Old 11-03-2014, 11:20 AM
audiofan1's Avatar
Quoted: 1886 Post(s)
Liked: 1958
I'll admit to my shame not visiting the Oppo threads as much but read this and tried this tweak on my 105 and subtle but very , very nice and I do have the current new firmware running
Big Thanks
audiofan1 is offline
post #18820 of 24854 Old 11-03-2014, 11:39 AM
MIIKE888's Avatar
Quoted: 21 Post(s)
Big Thanks
Sorry guys!
But what the hell are you talking about here?!
//Mike
MIIKE888 is offline
post #18821 of 24854 Old 11-03-2014, 11:49 AM
drgn95's Avatar
Quoted: 34 Post(s)
I just emailed Oppo about loss of audio on port 2 after firmware install. Anyone have any more input or heard anything?
drgn95 is offline
post #18822 of 24854 Old 11-03-2014, 12:04 PM
audiofan1's Avatar
Liked: 1958
Originally Posted by MIIKE888 View Post
Sorry guys!
//Mike
Its described above in the post
post #18823 of 24854 Old 11-03-2014, 01:37 PM
firthent's Avatar
FIOS HDCP and the OPPO bdp-103
I am having trouble with the OPPO BDP- 103 getting in HDCP Sync with the ON DEMAND menu selection using the FIOS set top box 7232. The STB output runs thru the HDMI in Back of the OPPO. The ON DEMAND menu always comes up in SD and will not download in anything but SD. All other FIOS Menu requests work in HD. OPPO tells me they don't have FIOS service in California and have no way to test this. The ON DEMAND menu selection works in HD if the STB output goes directly to my Yamaha receiver. Has anyone had a similar problem or found a solution?
Lamont Cranston
firthent is offline
post #18824 of 24854 Old 11-03-2014, 02:09 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3792 Post(s)
Liked: 4929
^ You are just having a problem with their On Demand content? Regular HD channels with copy protection (e.g., the premium channels like HBO) play OK?
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #18825 of 24854 Old 11-03-2014, 06:10 PM
Quoted: 14 Post(s)
Originally Posted by sworth View Post
Easy answers.
Thank you very much.
One final question: which is better on this unit for sound? HDMI or analog inputs?
post #18826 of 24854 Old 11-03-2014, 06:33 PM
sworth's Avatar
Quoted: 388 Post(s)
Liked: 184
That depends on your amp. You probably have an AV receiver with many options for handling the sound itself. If that is the case, use HDMI audio/video together. If your amp is bare bones with no way to adjust the surround channels or process the sound with DSPs, use analogue and do all that within the Oppo. That option is probably not the option you will end up choosing though. It's so much simpler to just have one cable from the player to the amp and one cable from the amp to the TV.
It really doesn't make any difference to sound quality. It's more of an issue of practicality. I have my Oppo hooked up to my Yamaha AV receiver using HDMI.
sworth is offline
post #18827 of 24854 Old 11-03-2014, 08:38 PM
Quoted: 14 Post(s)
Perfect. Thank you! I actually have my blu-ray player hooked up to a Pioneer Elite SC-05.
post #18828 of 24854 Old 11-03-2014, 09:12 PM
pwiss's Avatar
I tried this and while the sharpness was better it may come with consequences. I checked the brightness pattern on the AVS 709 patterns and it was showing response about 5 clicks lower on brightness in the 17 box than without. Not sure why HDMI 2 affects HDMI 1 in the first place but it seems to be messing with more than just sharpness at that setting.
pwiss is offline
post #18829 of 24854 Old 11-04-2014, 12:17 AM
A.Person's Avatar
Liked: 0
Preview images finally!
I apologize if this has been mentioned before, but I just noticed something cool has been added with the latest firmware release. There's no mention of it in the release notes.
I was watching some videos on a USB stick and discovered that if there are image files with the same name as the video files (I mean the same name before the extension), then those image files will show up in the preview area on the left as you browse through your videos. So far I've only tried this with .png files, but I assume it will work with .jpg also.
A.Person is offline
post #18830 of 24854 Old 11-04-2014, 02:26 AM
rickydenim's Avatar
Quoted: 17 Post(s)
Thanks for confirming! Interesting about the change to brightness however...will run some tests when I have a chance. Haven't noticed anything on content however..except for a very sharp detailed picture!
Has anyone tried this new firmware with the dk pro mod chip? Always a bit concerned this will stop when a new FW is released.
rickydenim is offline
post #18831 of 24854 Old 11-04-2014, 02:32 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Question for the experts in SMB sharing.
I use SMB on my W7 SP1 Enterprise to access certain folders on my PC with my Oppo-103 via the network feature.
Now I want to DISABLE the DNS Client service (cause I wanne use a HTTP proxy for browsing which needs this service disabled)
When I disable this I know that the ''Network discovery'' will not work anymore. Also maybe files and printers sharing?
Long story short : will my SMB sharing still work on the Oppo-103 if I disable the DNS Client service?
Thanks for any advice!
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #18832 of 24854 Old 11-04-2014, 05:56 AM
bd6675's Avatar
Quoted: 13 Post(s)
Originally Posted by Bob Pariseau View Post
Poor performance in wired Ethernet when you add a Gigabit device is usually due to not having Flow Control enabled in the relevant devices.
What happens is that the Gigabit hardware overruns the slower hardware causing resends. No data gets lost but throughput suffers.
If you use a Wifi connection, Flow Control is enforced automatically, so a typical symptom indicating this problem is when a Wifi connection works better than a wired Ethernet connection.
--Bob
So after some additional troubleshooting, I have determined that my BDP-103 can't stream from anything with a gigabit connection (at least with how my Oppo is currently configured). I have proven this with 100% certainty. I initially noticed the problem when I purchased a gigabit wireless router (Asus RT-N66U) and had my NAS (Synology DS413j - which has a gig port), the Oppo and my desktop hard wired to it. Audio and video would drop in and out. I changed the firmware on the router and that had no effect. I purchased another new router just to prove to myself that the router was not the issue..of course that didn't work either...same issue. Finally, I got a 10/100 switch and plugged that into my new gigabit router and then plugged my Oppo and the NAS into the 10/100 switch. That worked perfectly. This explains why with my old router (Linksys wrt54gl) I was able to stream from my NAS and my computer just fine. I also tested trying to stream from my computer: first from the gigabit port on my router while the Oppo was in the 10/100 switch and that did not work...I then plugged my computer into the 10/100 switch and it worked perfectly.
So, this begs the question, is there a setting I am missing on my Oppo BDP-103 that prevents me from streaming from anything connected via a gigabit connection? I thought I read on this forum that others were able to do this...any ideas what is going on?
Thank you,
BD6675
bd6675 is offline
post #18833 of 24854 Old 11-04-2014, 06:33 AM
Quoted: 204 Post(s)
Liked: 226
Thank you,
BD6675
Sounds like a flow control problem with the switching inside the router that you effectively buffered with the switch.
What you have will work.
So would a decent 10/100/gig switch. The only reason to go there though is if you have other (gigabit-capable) devices that use the NAS. You are really choking the NAS by having it plugged into a 10/100 switch. That won't matter much if all you ever do with the NAS is stream to the Oppo and occasionally use a computer to transfer music to the NAS. If, however, you are moving large files to/from the NAS regularly (ripping BD movies, doing backups, etc.) then you might want to try this topology, which should also work fine:
Nas --> Router (Gigabit connection)
10/100/1000 switch --> Router (Gigabit connection)
Oppo --> 10/100/1000 switch (100Mb connection)
Any properly-implemented 10/100/1000 switch will be able to handle a mix of traffic speeds. For some reasons, the switch implementations inside many routers are notorious for having flow control problems with mixed traffic - which is why I let switches handle the mixed-mode flow-control on my network and then have the router running gigabit for everything. Think of the router and uplinks from the switches as the "backbone", and then everything else connects to that.
I use this one in my AV cabinet, which has a mix of 100Mb and Gb devices connected (including my 103), with a 1GB uplink to the router - and everything works without a hitch.
http://www.amazon.com/NETGEAR-8-Port...+switch+8+port
post #18834 of 24854 Old 11-04-2014, 06:49 AM
bd6675's Avatar
Quoted: 13 Post(s)
Thank you for the reply. I did try using a 10/100/1000 switch at some point during the troubleshooting process (Netgear ProSafe GS108) and that did not work....but now I am not certain how I had it connected. I think I had the NAS, the OPPO and my computer plugged into the switch and obviously the switch into the router...
bd6675 is offline
post #18835 of 24854 Old 11-04-2014, 07:50 AM
quad4.0's Avatar
Quoted: 132 Post(s)
Liked: 88
think this issue may have been addressed previously for the 103 -I looked but could not find a thread, anyway- I was listening to a dvd audio last night and every song started 1-3 seconds in. I admit I did not try another disc that I should have done-but it was "Gaucho" if that is any help. This is new have all firmware current-is there an easy fix? I've also told Oppo, but I'm sure there is a fix.
quad4.0 is offline
post #18836 of 24854 Old 11-04-2014, 10:53 AM
rdgrimes's Avatar
Quoted: 2482 Post(s)
Liked: 1785
I have a copy of that DVD-A and am unable to reproduce any playback issues on my 103D. Perhaps if you provide more detail. The opening track is truncated a bit, but that's it.
rdgrimes is offline
post #18837 of 24854 Old 11-04-2014, 11:05 AM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
I use 3 computers (one of which serves as the NAS) and various other devices (Oppo, XBox, Wii, other HT devices, etc.) all plugged into a 10/100/1000 switch, with one connection to the router, and it streams just fine (using SMB).
And others here are doing the same thing successfully. I wonder if it might be related to your NAS. If possible, you should see if you can set the NAS port to 100 Mbps (set somewhere in the NAS configuration) when plugged into the gigabit switch, and see if that fixes it.
The other thing you could try to get the same behavior is: Connect everything up with the gigabit switch in the configuration that you want, but is failing. Then between just the NAS and the router, hook up the 100 Mb switch (NAS -> 100 Mb switch -> Gigabit Switch). This effectively leaves everything else like it is, but limits just the NAS connection to 100 Mb. If this works, then it's likely your NAS where the problem lies (or the gigabit switch, but since you've tried multiple now, not as likely).
BobearQSI is offline
post #18838 of 24854 Old 11-04-2014, 03:57 PM
Daffietje's Avatar
Quoted: 54 Post(s)
Let me answer my own question : SMB sharing still works when setting the service DNS Client to DISABLED.
LairdWilliams likes this.
post #18839 of 24854 Old 11-04-2014, 06:36 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3557
I never mentioned this before, but now I'm going to.
When I first inserted 'Live - Die - Repeat' on 3D Blu-ray into my Oppo 103 player; instead of bringing me to the main menu, or to play other trailers (none on this 3D BD), it started to play automatically into the film (a further chapter, 3 or 4, I don't know exactly).
This was a brand new 3D disc of that film, and the first time ever I experienced that.
Anyone else?
NorthSky is offline
post #18840 of 24854 Old 11-04-2014, 06:40 PM
Read the FAQ!
Liked: 4929
Sounds like it picked up data left by another film in Persistent Storage. Perhaps from the same studio.
--Bob
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
