Official OPPO BDP-103 Owner's Thread - Page 647 - AVS Forum
 287Likes
post #19381 of 19406 Old Yesterday, 02:22 PM
steviebstrummin's Avatar
Quoted: 22 Post(s)
Probably more of a question for Netflix, but thought I'd post here too.
I have my Oppo BDP-103 connected via ethernet to the Internet and HDMI to my 4K capable TV. The TV is also connected to the Internet via Ethernet. I use a 75/75 FIOS connection.
I just upgraded to the Ultra HD / 4K Netflix service and when I access Netflix via my (smart) TV I do get the 4K feed. However when I access Netflix via my Oppo I do not get the 4K feed.
Again both devices (TV and Oppo) are hard wired to my router running these high speeds.
Anyone understand why?
steviebstrummin is offline
post #19382 of 19406 Old Yesterday, 02:31 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 674 Post(s)
Liked: 389
The OPPO does not accept any 4K sources, it only upscales to 4K.
-Bill
Review older films here: 1979 and earlier | 1980s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #19383 of 19406 Old Yesterday, 02:49 PM
Quoted: 22 Post(s)
-Bill
Thanks Bill. So then from a PQ standpoint, is it a moot point as the Oppo upscales to 4K anyway?
post #19384 of 19406 Old Yesterday, 02:53 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2292 Post(s)
Liked: 678
Your smart 4K TV, a Samsung one? ...Or LG (Life's Good)?
NorthSky is offline
post #19385 of 19406 Old Yesterday, 02:54 PM
wmcclain's Avatar
Quoted: 674 Post(s)
Liked: 389
It gives you a choice as to which device does the scaling, the player or the display. One might be better than the other.
It's not moot in that a 1080 image upscaled to 4K cannot be the same as a quality 4K source. I haven't seen Netflix 4k so can't speak as to its quality.
-Bill
post #19386 of 19406 Old Yesterday, 02:55 PM
NorthSky's Avatar
Liked: 678
Not the 103...the 113 yes.
* My 103 doesn't upscale to 4K?
NorthSky is offline
post #19387 of 19406 Old Yesterday, 02:58 PM
NorthSky's Avatar
Liked: 678
By the way, Netflix is 480p or 720p (in most places)?
And to get "true" 1080p, do you need to live in New York, Los Angeles, or Miami?
Netflix 4K??? Really? What kind of Ethernet speed do you need, 10000Mbps?
Last, Netflix 3D, only available from some TV brands, right?
NorthSky is offline
post #19388 of 19406 Old Yesterday, 03:10 PM
Quoted: 22 Post(s)
Originally Posted by northsky View Post
your smart 4k tv, a samsung one? ...or lg (life's good)?
sony
post #19389 of 19406 Old Yesterday, 03:12 PM
NorthSky's Avatar
Liked: 678
sony
Ahhhh, the best!
* Did Sony just cancel a movie @ the theater recently, a comedy?
NorthSky is offline
post #19390 of 19406 Old Yesterday, 03:20 PM
Quoted: 22 Post(s)
Originally Posted by NorthSky View Post
Ahhhh, the best!
Thanks I agree.
Yes they did. Some would say it was a comedy but not my cup of tea.
post #19391 of 19406 Old Yesterday, 03:55 PM
NorthSky's Avatar
Liked: 678
'The Interview' ... 10/10 @ IMDb!
* Seth Rogen is Canadian.
NorthSky is offline
post #19392 of 19406 Old Yesterday, 04:08 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 218 Post(s)
Liked: 229
Let's try to stay on topic, please...
gsr is offline
post #19393 of 19406 Old Yesterday, 04:13 PM
Saturn94's Avatar
Quoted: 69 Post(s)
Liked: 384
Originally Posted by donottosmeok View Post
Hi, please forgive if I'm in the wrong forum. I just bought an OPPO BDP-103 as both a Blu-ray and CD/SACD player. For Blu-ray, the 103 is connected with HDMI to a Sony KDL-55W900A HDTV. For 2-channel analog CD/SACD, it is connected with analog cables to a Carver HR-752 receiver/preamp. (The Carver does not have HDMI inputs/outputs.)
Apparently the TV (or player?--one or the other) attempts random HDMI "handshakes" related to DHCP. These "handshakes" occur even when the TV is off.
As a result, every "handshake" results in a 4-5 second audio dropout...while I'm listening to 2-channel analog stereo!
OPPO tried to troubleshoot the issue with me by email for several days. However, the only recommended solution so far is to "always leave the TV ON...use Pure Audio to try to reduce energy consumption," or, "remove the HDMI cable completely from the player."
I'd rather not leave the TV on; that wastes electricity. I'd also rather not constantly remove/replace the HDMI cable each and every time I want to listen to 2-channel audio. For me, those are both very undesirable solutions...
Does any forum member have the same or very similar setup (OPPO connected to Sony TV with HDMI, and to analog receiver/preamp with analog cables)?
If you have a similar setup...have you figured out how to eliminate the "handshake" problem, without leaving the TV on, or without removing the HDMI cable? (For example, is there a setting on either the KDL-55W900A or BDP-103 to temporarily "turn off" HDMI handshakes?)
I like the player; but this characteristic prevents me from "loving" it. I would appreciate any tested, proven suggestions...
Originally Posted by rdgrimes View Post
Its not clear from your description whether this handshake occurs when you shut off the TV (normal) or if its happening randomly after the TV is off (not normal). If it the later, the TV is at fault and its a perplexing issue. See if the TV has settings for HDMI CEC that can be turned off, or any other standby settings that might be keeping the HDMI port active, You could also try switching the TV to a different input before shutting it off,
I have a setup like that; 103 connected to TV (Pioneer) via HDMI, audio from 103 is analog to my non-HDMI pre/pro. I have not experienced that issue.
I suspect like rdgrimes said it's likely the TV. Btw, I have CEC turned off.
Saturn94 is online now
post #19394 of 19406 Old Yesterday, 04:16 PM
NorthSky's Avatar
Liked: 678
I agree, particularly with this one.
NorthSky is offline
post #19395 of 19406 Old Yesterday, 04:23 PM
NorthSky's Avatar
Liked: 678
Very strange, even with his Sony TV turned off. ...Bad Sony TV?
NorthSky is offline
post #19396 of 19406 Old Yesterday, 07:50 PM
Tornado Red's Avatar
Quoted: 49 Post(s)
Liked: 46
Bill Mac and myself have discovered the following anomoly (though this may have been pointed out previously and we've missed it) with regards to some of the UMe HFPA blu ray music discs, when played via our Oppo 103s. I'll lay out the issues I've had personally, if anyone has had similar problems and have resolved them somehow, I'd like to hear about it. If not, perhaps I'll drop a line to Oppo. I'm running the current Oppo software into a Pioneer SC-61 receiver using HDMI. This receiver has been stellar and always plays what the Oppo sends it without fail. I have 13 HFPAs and have issues on 4 of them. The problem is in stereo mode only with 2.0 Dolby TrueHD and 2.0 DTS HD Master. Any 5.1 MC mixes play normally. The audio setting on the Oppo is bitstream, and the following happens: 2.0 DTS HD Master is being sent as Neo 6 :Cinema, and 2.0 Dolby TrueHD is being sent as ProLogic II: Movies. Any with 2.0 pcm are not affected. Here are the discs:
Bryan Adams "Reckless": 2.0 Dolby TrueHD = PL II: Movies
: 2.0 DTS HD Master = Neo 6: Cinema
Nat King Cole "The Extraordinary": 2.0 Dolby TrueHD = PL II: Movies
Genesis: "Selling England By The Pound": 2.0 DTS HD Master = Neo 6: Cinema
George Michael: "Symphonica": 2.0 DTS HD Master = Neo 6: Cinema
It was noted in another thread that changing the Oppo from bitstream to LPCM will solve this issue, but I would prefer to leave the setting on bitstream if possible. I believe Bill Mac is having a similar issue on his Rolling Stones: Grrr HFPA. I have a couple other blu ray players here which don't seem to have any problems sending the correct codecs through, so it doesn't appear to be a disc only issue. Any thoughts? Thanks....
Tornado Red is online now
post #19397 of 19406 Old Yesterday, 09:43 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 612 Post(s)
Liked: 1014
^ Check that you have Setup > Audio Format > Secondary Audio set to OFF.
--Bob
Bob Pariseau is online now
post #19398 of 19406 Old Today, 06:03 AM
Quoted: 49 Post(s)
Liked: 46
--Bob
Thanks for your reply Bob. Yes, secondary audio was already off.
post #19399 of 19406 Old Today, 07:13 AM
Read the FAQ!
Quoted: 612 Post(s)
Liked: 1014
OK, next check that the video output Resolution from the player is 720p or higher. Set Resolution to an explicit value -- not AUTO or Source Direct.
NEO 6: Cinema and Dolby Prologic II are not formats sent over the HDMI cable. They are something your AVR is applying to the input signal -- most likely because the player is sending lossy DTS and DD Bitstreams instead of the lossless Bitstreams you are expecting.
So just going down the list of possibilities here.
If you have both the HDMI 1 and HDMI 2 outputs cabled -- even with your TV turned OFF -- check that you have SPLIT A/V set.
--Bob
post #19400 of 19406 Old Today, 07:23 AM
Read the FAQ!
Quoted: 612 Post(s)
Liked: 1014
^ Also, if you also have either Optical or Coax cabling connected between the player and the AVR, temporarily unplug those to make sure you really are receiving the audio signal over the HDMI connection. (Optical/Coax can't carry the lossless Bitstreams.)
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
post #19401 of 19406 Old Today, 08:30 AM
SeeMoreDigital's Avatar
Quoted: 131 Post(s)
Liked: 77
So far all my 2 channel (stereo) UMe HFPA discs play correctly (ie: without any audio processing added to the bitstream). This morning I received Supertramp - Crime Of The Century, which plays fine too!
My Oppo BDP-103EU is directly to an Onkyo TX-NR609 via HDMI2. 'Direct' modes for all options are set on both devices...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #19402 of 19406 Old Today, 09:41 AM
rdgrimes's Avatar
Quoted: 399 Post(s)
Liked: 266
The Oppo does not alter bitstream output in any way (save for the secondary audio option).
Your issue is in the AVR and how it's handing 2-ch streams. Probably a simple setting, the AVR is applying those decoders to the respective inputs because they are that type stream. Your AVR also offers a way to see what the actual input type is. I'd suggest you ask about this in the appropriate forum for that AVR.
rdgrimes is online now
post #19403 of 19406 Old Today, 11:05 AM
Quoted: 49 Post(s)
Liked: 46
Video output is 1080p. I have no coax or optical connections. I run HDMI 1 to my display, HDMI 2 to the SC-61 and the Oppo is set for Split a/v. I've erased persistent storage and BD Live is off. I agree that it's the way my AVR is handling the 2 channel streams but...only these 4 discs and their streams. I have other HFPAs with 2.0 Dolby TrueHD and 2.0 DTS HD Master streams that the SC-61 decodes just fine. So it can read the stream well, there's just something about these 4 discs (so far) that is not arriving at the AVR like the other discs with the same encodes. I'm running 'stream direct' on the SC-61 which allows the stream to enter as is AND I can use my subs. I've even tried 'pure direct' mode without any improvement. I believe Bill Mac's issue with his HFPA involves his Denon AVR. Very curious.
post #19404 of 19406 Old Today, 11:19 AM
Read the FAQ!
Quoted: 612 Post(s)
Liked: 1014
^ I suggest you call OPPO Tech Support and see if they have any suggestions for you. I agree with RDGRIMES, at this point it looks like some sort of settings mistake in your AVR. It may be the characteristics of the 2.0 Bitstreams (e.g., 48Kz vs. 96KHz or whatever) may be what's triggering your AVR to do the processing you don't want. E.g., if it can't process at the higher rate.
If no easy answer, you could loan a disc to OPPO (they'll send it back of course), so they can check out what's going on with the authoring. Perhaps along with a disc that does NOT exhibit the problem.
--Bob
post #19405 of 19406 Old Today, 11:23 AM
rdgrimes's Avatar
Quoted: 399 Post(s)
Liked: 266
. So it can read the stream well, there's just something about these 4 discs (so far) that is not arriving at the AVR like the other discs with the same encodes..
Actually, you haven't demonstrated this. The AVR should be able to tell you what type stream its receiving. Likewise, the Oppo tells you what it is sending via the OSD. Not all 2-ch DTHD and DTS-MA is the same. Some are actually a 5.0 stream with 3 silent channels, others are just 2-ch. Older AVR decoders may have difficulty with the 2-ch type.
Nevertheless, there's no such thing as "Neo-6" or "PLII" streams, those are the decoders being applied in the AVR to a 2-ch stream.
post #19406 of 19406 Old Today, 12:34 PM
Quoted: 49 Post(s)
Liked: 46
I'm not sure I follow you here. What I've demonstrated is that I can put in an HFPA disc from UMe say, for example, Lionel Ritchie's Can't Slow Down. I choose 2.0 Dolby TrueHD from the screen menu and my AVR shows Stereo Dolby TrueHD. Ditto for the DTS HD Master 2.0 selection, my AVR will read it as Stereo DTS HD Master on the AVR display as it should. I know there is no such thing as Neo 6 and PLII streams, but whatever signal my AVR is receiving on the 4 discs I mentioned, the AVR is interpreting it in such a way as to broadcast it in Neo 6 or PLII. The Oppo is showing the correct selection on all discs, faulty or not at the AVR end. And I can see that the AVR will read the codecs correctly in most cases, but not all. It's like Something Happened On The Way To.....:roll eyes:
Thanks all for your input, I'll send a note to Oppo.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
