Official OPPO BDP-103 Owner's Thread - Page 669 - AVS | Home Theater Discussions And Reviews
 372Likes
post #20041 of 20061 Old Yesterday, 04:33 PM
alettiere's Avatar
Quoted: 44 Post(s)
For those of you who have the Roku Stick (purchased directly from Oppo):
I noticed that the stick was set to 720P as default. I switched it to 1080P and noticed that when I use the Netflix app, there's a subtle stutter to the picture that occurs maybe once a minute. It's very subtle, but very annoying. I know it's not my Wifi speed. The Amazon app (which I'm pretty sure can only stream at 720P regardless) does not have this issue. I couldn't figure out why this was happening. Turning the 24fps option on or off did nothing to alleviate this glitch, nor did resetting the stick.
Just out of curiosity, I switched the stick back to 720P output and sure enough, the stutter is gone and Netflix streams smoothly at the expense of slightly inferior picture quality, of course.
Has anyone else noticed this issue? The stick doesn't seem to like streaming 1080p content. At least not through Netflix.
alettiere is offline
post #20042 of 20061 Old Yesterday, 05:17 PM
lujan's Avatar
Quoted: 86 Post(s)
Liked: 29
I just watched a Netflix movie this morning using the Roku stick purchased through Oppo and noticed that it was outputting only 720p and just thought that this is the way Netflix was sending it? I'm going to have to check my settings on it. I'll watch another tomorrow changing it to 1080p and let you know if I see a subtle stutter. It may be too subtle for me to notice.
lujan
733 Blu-ray
19 HD DVD
7 DVD
lujan is offline
post #20043 of 20061 Old Yesterday, 05:50 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 725 Post(s)
Liked: 1070
Although the ROKU Streaming Stick is a good way to ADD apps, I recommend you always use the native apps in the player instead of their matching apps in the ROKU.
--Bob
Bob Pariseau is online now
post #20044 of 20061 Old Yesterday, 08:28 PM
jmacari's Avatar
I noticed the stutter also....I have had the stick since I purchased the unit (2 yrs ago), but always used the native app for Netflix; but then I read that the stick could output 1080p/24, so decided to try it again.....but after the stutter situation, I am back to the native app. I just figured the stutter was from the stick being Wi-Fi (my Oppo is hard-wired to my network).......
jmacari is offline
post #20045 of 20061 Old Yesterday, 09:44 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 2991 Post(s)
Liked: 995
DVD 24p Conversion: On or Off? ...And why?
NorthSky is online now
post #20046 of 20061 Old Yesterday, 10:24 PM
Josh Z's Avatar
Quoted: 610 Post(s)
Liked: 468
Originally Posted by milacqua View Post
I followed the instructions which seemed to indicate that sending the supposedly better Marvel processor directly to the display (Epson projector in my case) would result in the better picture because it would carry only video and no audio. The HDMI 2 output contains the lessor processor and in split mode would provide virtually no video processing to degrade the audio. Accordingly, you were suppose to get the best of both worlds and was the main reason the split mode was designed.
The Marvell chip is only "superior" if you're the type of person who uses its various optional settings to tinker with your picture, or if you use the Blu-ray player to upconvert 1080p to 4k. If you don't use any of those settings (and you shouldn't - calibration should be done in the display) or 4k upconversion, the Marvell chip has no advantage at all.
Keep in mind that the OPPO player has two processing chips. The MediaTek processor does the bulk of the gruntwork for both HDMI outputs, including deinterlacing or upconverting standard-definition content to 1080p. The Marvell chip is only used for the optional picture control settings and for upconversion from 1080p to 4k.
So, for example, if you play a DVD to watch on a 4k TV, the MediaTek chip upconverts from 480i to 1080p and then the Marvell chip takes over and does the rest of the upconversion from 1080p to 4k.
Frankly, when I go back and forth in dual mode, I can't tell much difnferece.
The Marvell chip applies some measure of DNR to everything on HDMI 1, regardless of whether you have the optional DNR setting turned on or off. The filtering is mild on Blu-ray content, but much stronger on DVD.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #20047 of 20061 Old Yesterday, 11:50 PM
Iron Maiden's Avatar
Quoted: 58 Post(s)
Liked: 7
Discovered a pretty cool feature on my 103 today. I use the 7.1ch analog outputs for surround and SACD/DVD-Audio playback. 2ch, I send bitstream through a toslink to my Tri-Vista tube dac.
Added a new pair of speakers to my system and was setting up the speakers and trim levels in the Oppo. Then started to play Dark Side of the Moon on SACD. While playing the SACD, I discovered I could open up the speaker settings in the Oppo and make changes to speaker size, distance, trim level, crossover... on the fly as the music is playing. I had the new towers in the rear set as large and they were a tad too boomy for me. While the track was playing, I could switch them to small and hear the difference. Thought this was a pretty cool feature. In fact, setting the trim level with my spl meter and the test tones, I thought I had the front left/right dead on. But during the music, the imaging was a hair to the left. I was able to bump the right speakers trim level up a half db and instantly it centered the image. Great feature.
I wish you could set different crossover points for each speaker but can't have it all.
60" Panasonic Plasma ~ BenQ HT1075 / 92" fixed Dragonfly Screen ~ Parasound Halo C2 Pre/Pro
Earthquake Sound Cinenova Grande Amplifier ~ Crown X1000 ~ Oppo BDP-103
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas 2.2i (mains) & Veritas 2.0c (center) ~ Energy RC-70 (side surrounds)
CAT Tiburons(rear surr) ~ Sub... custom 15" Diamond Audio Technology ~ Xbox One
Iron Maiden is online now
post #20048 of 20061 Old Today, 03:58 AM
milacqua's Avatar
Quoted: 64 Post(s)
Thanks, I did not realize that at all but it makes sense now.
shortspark
milacqua is online now
post #20049 of 20061 Old Today, 06:22 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 775 Post(s)
Liked: 400
See this in the BDP-93 FAQ: Is DVD 24hz conversion supported?
The feature is the same in the -103 players.
I leave it off so I don't have to pause, adjust the setting and explain the issue to other viewers when encountering problem DVDs. I'm not sensitive to pulldown judder anyway, although I leave 1080p24 on for Blu-ray.
-Bill
Review older films here: 1979 and earlier | 1980s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #20050 of 20061 Old Today, 08:14 AM
lujan's Avatar
Quoted: 86 Post(s)
Liked: 29
Watched another Netflix movie (1080p) via the Roku stick sold by Oppo and didn't notice any stutter at all but maybe it's so subtle that I can't notice it?
lujan
733 Blu-ray
19 HD DVD
7 DVD
lujan is offline
post #20051 of 20061 Old Today, 11:51 AM
bweissman's Avatar
Quoted: 59 Post(s)
Liked: 42
Originally Posted by egrady View Post
I'd like to upscale my image to 4K using the Oppo and send it to my Sony VW600es via HDMI 1
Have you tried this yet? I'm curious about your results. I always assumed the 600 would natively upscale better than the 103, the picture looks fabulous, and I've always left it with the 103 set to 1080p output. Do you see a difference?
By the way, I wonder how many of us AVSers all have the same equipment.
bweissman is online now
post #20052 of 20061 Old Today, 12:19 PM
alettiere's Avatar
Quoted: 44 Post(s)
Ahh...so I'm not crazy then. It's some kind of weird glitch which is probably some relationship between the Oppo and the Roku. I doubt it's the Roku stick itself, or the issue would have been more widely reported.
Not that it's a big deal. The native Netflix app works fine. I only bought the Roku stick for the occasional Amazon streaming video.
post #20053 of 20061 Old Today, 01:55 PM
bgoering's Avatar
Quoted: 64 Post(s)
Liked: 25
Put your equipment list in your sig - makes it easier to find commonalities.
bgoering is offline
post #20054 of 20061 Old Today, 02:45 PM
bweissman's Avatar
Quoted: 59 Post(s)
Liked: 42
Oh, yeah. Forgot about that. I have been noticing a lot of folks with the same BDP, pre/pro, and PJ as me.
OPPO BDP-103, Comcast DVR, Sony FMP-X1 4K server
Marantz AV8801 pre/pro, Yamaha MX-A5000 amp
Sony VPL-VW600ES projector, Stewart StudioTek130 103" diag screen
7 Thiel speakers (3 SCS4, 2 PowerPoint, 2 PowerPlane), 2 JL Audio E112 subs
Harmony Ultimate remote
post #20055 of 20061 Old Today, 02:45 PM
SeeMoreDigital's Avatar
Quoted: 164 Post(s)
Liked: 91
Ahh...so I'm not crazy then. It's some kind of weird glitch which is probably some relationship between the Oppo and the Roku. I doubt it's the Roku stick itself, or the issue would have been more widely reported...
I'm not familiar with the Roku device but if it runs on Android, it's quite common for Android based devices to display a micro stutter every 41.666 seconds when playing 23.976 fps content at 24Hz
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #20056 of 20061 Old Today, 03:21 PM
egrady's Avatar
My unit is a 103D which may make a difference with 4K upscaling, but to my eye letting the Oppo do all the work looks a little sharper. I've gone back and forth, its pretty close. But when I get very close to the screen, closer than anyone would ever sit, splitting hairs I prefer the Oppo.
egrady is offline
post #20057 of 20061 Old Today, 03:27 PM
NorthSky's Avatar
Liked: 995
Very cool and usefully handy.
* We all have a decent SPL meter in our ears.
post #20058 of 20061 Old Today, 03:33 PM
NorthSky's Avatar
Liked: 995
-Bill
Thanks Bill.
* I might watch one or two DVDs per year, but it's still nice to have a reassurance on a good setting. ...I was @ On, now I'm @ default; Off.
-> BR no sweat, @ 24p.
post #20059 of 20061 Old Today, 05:30 PM
bruman's Avatar
Originally Posted by pentium7 View Post
Quote:Originally Posted by mjordan123456
The Cinevia stuff is serious, as in the future most of us will be backing up our bluray discs and to be able to play them when we don't have our original disc, But with Cinecia enabled bluray player that wont be possible. But bdp-93 will play them.
"Most" do not "Backup" Blu-ray discs.... There's a reason you buy the disc and that's to use it. So if you legitimately buy the blu-ray disc there really is not reason to be hiding it away in an airtight safety deposit box 6 miles underground with airconditioning and a generator backup. Anyway exaggeration aside I think it is pretty ridiculous to take away anything from a player just because it is conforming to the copyright standards.
Before there are replies about how you are entitled to "backup" so your original is safe etc don't bother I've heard the arguments for longer than media has been around. I'm a supporter of being able to do what you want but face it there's NOT a problem with using your original disc is there? How often do you really think your original is going to get damaged unless you let your 2 year old load your $30 bluray disc or use it as a frisbee for your dog.
One last question do you know how much a 50GB Bluray disc costs right now? $4 seems like which isn't too bad and they'll come down but that's extra time "backing up" discs when it is far more likely you'll never need these "backups"
A bit more to it than that.
For people like me who own a NAS, I like the convienence of DL the mp4 online so I can stream it to my vacation home.
I buy the bluray, some have vudu and that is great. But some don't and for me, it is legal for me to own a digital copy to stream as I please since I legally own the bluray.
Keep an open mind, bro!
bruman is online now
post #20060 of 20061 Old Today, 06:19 PM
Quoted: 58 Post(s)
Liked: 7
I use one of the analog spl meters Radio Shack used to sell. Same one all the older magazine reviews raved about.
post #20061 of 20061 Unread Today, 07:23 PM
NorthSky's Avatar
Liked: 995
Yes, same here; the RS analog model. ...And after that I use my set of ears to fine tune.
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
