Official OPPO BDP-103 Owner's Thread - Page 670 - AVS | Home Theater Discussions And Reviews
 376Likes
post #20071 of 20091 Old Today, 11:02 AM
DanF8500's Avatar
Quoted: 348 Post(s)
Liked: 227
Originally Posted by NorthSky View Post
Question: Why did it take over a year and half to discover the issue of calculating acoustic propagation delay with "Speaker Distance" parameters from the Speaker Configuration setting on the multichannel analog output?
It took the right person at the right time to discover there was even an issue in the first place. I'm not certain what led to me investigating and testing the speaker distance setting, but I was the one who discovered that something wasn't correct. Most on this forum didn't believe me, but Bob listened and did some testing on his end, and verified/validated my findings.
DanF8500 is online now
post #20072 of 20091 Old Today, 11:46 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 731 Post(s)
Liked: 1071
Clearly, it was a test, to see if any users were paying attention.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #20073 of 20091 Old Today, 11:48 AM
Read the FAQ!
Quoted: 731 Post(s)
Liked: 1071
Two: Why the Volume Bar appears @ the screen's bottom after you start your player?
As a safety check (speaker protection) in case you have the Volume cranked up when you don't really want that.
--Bob
post #20074 of 20091 Old Today, 11:52 AM
donottosmeok's Avatar
Originally Posted by rdgrimes View Post
OK, well same advice: turn off HDMI CEC in all devices. Try switching the TV to another input before shutting it off.
rdgrimes, thanks again; but no luck--no matter which HDMI port on the TV I connect the OPPO to, I still get an occasional dropout. CEC was already off on the OPPO; I don't believe CEC can be switched on the TV. I'll have to live with dropouts. Either that, or disconnect HDMI from the OPPO entirely, if I want two-channel analog music without dropouts. The BDP-103's video is exceptional; it seems a real shame it has this "handshake" gremlin. Oh, well.
donottosmeok is offline
post #20075 of 20091 Old Today, 12:01 PM
rdgrimes's Avatar
Quoted: 562 Post(s)
Liked: 300
You may have misunderstood the instruction. Leave the Oppo plugged into the same input on the TV. Before turning the TV off, switch it to an unused HDMI port.
rdgrimes is offline
post #20076 of 20091 Old Today, 12:10 PM
SeeMoreDigital's Avatar
Quoted: 165 Post(s)
Liked: 91
Just-so-as-you-know... If you have an Android device connected to your TV, it can cause weird CEC connectivity problems. As even when powered down it could still be passing a signal to your TV. If you have such a device connected, either disconnect the power cord or disconnect the HDMI lead
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #20077 of 20091 Old Today, 12:54 PM
pbarach's Avatar
Quoted: 130 Post(s)
Liked: 118
Originally Posted by Bob Pariseau View Post
Check that you have the latest firmware installed. In Setup > Device Setup > Firmware Information, the "Main" firmware version number should end "0827".
Check your network throughput. One good way to do this is to set up a VUDU account -- which is free until you actually rent some content. With a VUDU account, you can now go into the VUDU app to My VUDU > Info & Settings > Network Speed Test. See what sort of speed you are getting, and also whether it is constant or keeps bopping up and down in speed. If you see a problem here you know there's still some issue in your network setup that you've not yet addressed.
--Bob
I have had the same issues the OP reports, and my network speed is always over 12 Mbps. My 103 is connected to the cable model/router via Ethernet, as is a Roku 2--and I have zero problems accessing Netflix with the Roku even when Oppo repeatedly tells me "this title cannot be played." Also, the Roku required me to sign on exactly once, the day I hooked it up. In contrast, I have had to do this a number of times with the 103. No, there is definitely something screwy with the Oppo's Netflix app, and erasing and then resetting to factory defaults didn't fix this. I have no issues with Vudu, YouTube, or the Berlin Phil apps on the Oppo--it's just Netflix
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #20078 of 20091 Old Today, 01:22 PM
Trevor78's Avatar
--Bob
I have been very good about updating firmware. Will check to confirm, and will also check the speed test. Thanks!
Trevor78 is offline
post #20079 of 20091 Old Today, 01:24 PM
Trevor78's Avatar
Just saw this- sounds like you have the same thing I have. Glad to know it's not just me! I'll still try some basic resetting to see if it helps, but not worried about it. The player's shiny disc features are perfect and that's what is important. Just trying to explain to my wife why the player isn't operating Netflix very well…
pbarach likes this.
Trevor78 is offline
post #20080 of 20091 Old Today, 02:00 PM
Hi again. In fact, I did misunderstand your instruction...lol. However, even after trying to switch to unused inputs (I use HDMI 4 for DVD) before turning the TV off, I still got dropouts. I tried switching to them all: HDMI 1, turn TV off. HDMI 2/MHL, turn TV off. HDMI 3, turn TV off. I even tried Video 1, Video 2/Component, and PC--no difference--still got dropouts. My walls have dents in them from where I've been banging my head lol.
(Note: To clarify--I never disconnected the OPPO from the HDMI 4 port, before selecting different inputs, before turning the TV off.)
Sometimes, when the TV is off, I hear a faint "click" from behind it. It's then that I get a dropout. At one time I thought maybe the TV's Automatic Software Update was responsible, so I turned that off--still got dropouts. I disconnected the LAN cable from the TV to my router--still got dropouts. At this point I can only assume that switching inputs, then turning the TV off, does not disable the other HDMI ports; they apparently "look" for connected devices all the time.
When listening to analog audio, a dropout happens within a few minutes after turning the TV off. Then, at random times thereafter (still with the TV off). If the TV is on, I don't get dropouts; but do need to mute the TV's volume.
That option is undesirable--I don't need the TV on, unless I'm using Gracenote, which is basically "never." So, it was suggested that I leave the TV on and use the TV's Picture Off function "to save electricity." But my position is, why require having an unnecessary device on at all? Maybe I'm looking at this issue wrong... But my point is, that "fixing" an issue by creating another issue--having to unplug HDMI or leaving the TV on when listening to analog music--isn't really a "fix" at all.
Carver HR-752 ~ Carver TFM-35 ~ Sony KDL-55W900A (Terk HDTVa OTA) ~ OPPO BDP-103 ~ AQ Cinnamon HDMI video & Diamondback analog audio ~ Monster Z2 biwire ~ Polk Audio LSi15
Waste not, want not. Well, except 4K OLED...that, I want.
Last edited by donottosmeok; Today at 02:17 PM. Reason: To clarify what action I took before turning the TV off--I only switched inputs; I did not switch OPPO-to-HDMI 4.
post #20081 of 20091 Old Today, 02:09 PM
SeeMoreDigital, thanks. I have an HTC One; but it's not physically connected to the TV. The One is "visible" to my TV as a Wi-Fi direct and Screen mirroring supported device; but I wouldn't think that would cause an issue like this, would it? I heard dropouts long before the One was even added to the Device List.
post #20082 of 20091 Old Today, 02:29 PM
toddman36's Avatar
Liked: 2
Hi guys, Im in the market for a new Blu Ray player and would like to get the 103! My concern is since this was a 2012 release will a newer model be hitting the market anytime soon? Thanks
toddman36 is online now
post #20083 of 20091 Old Today, 02:36 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 776 Post(s)
Liked: 400
We've got no indications of anything soon. I'm guessing (without inside info) nothing this year.
We suspect OPPO is waiting for components to become available for the new standards: 4k Bu-ray, HDCP 2.2, Rec 2020 color space, etc.
-Bill
Review older films here: 1979 and earlier | 1980s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20084 of 20091 Old Today, 02:38 PM
JazzGuyy's Avatar
Quoted: 85 Post(s)
Liked: 102
No one is expecting a new model until Ultra HD Blu-Ray players come along. Since Oppo tends to be conservative, they probably will not have one of the first of these players on the market. The consensus seems to be that there will most likely not be a new Oppo player before 2016.
JazzGuyy is offline
post #20085 of 20091 Old Today, 02:52 PM
toddman36's Avatar
Liked: 2
-Bill
Ok, thank you both...
post #20086 of 20091 Old Today, 03:57 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3018 Post(s)
Liked: 1006
Well, I did not verify since quite a while now; but I was extremely disappointed with the multichannel analog performance over a year ago and I abandonned it completely, as an annoying nuisance and an abso!ute obso!ete defective feature on my 103 universal BD player.
Sometime I'll do another retest, to see if it did actually improve.
It took me a long time to even mention it, and it wasn't my own lead, but it was in reply to another member having an issue with his subwoofer performance from his Oppo 105's subwoofer output. ...That's when I decided to share my own experience. ...Because I never had that issue before with all my other universal players from their multichannel analog outputs; with multichannel DVD-Audio, DVD-Video, Blu-rays, SACDs. ...So I just thought that my Oppo 103 wasn't simply up to the task, unlike my other players, some costing less, and others more. ...I simply dismissed it all together as an inferior multichannel analog feature; and I was sad of course.
Then I realized that there was a fix in a very recent firmware update, almost two years after the Oppo 103 was first released to the Oppo's team of beta and omega testers.
I guess testers don't test everything...
But you sir, it seems that you were right, and confirmed my long ago discovery about something really amiss.
It's people like you that I have the most confidence in. ...Thank you, and thank you to Bob too for verifying your discovery.
I shall share some more in the near future on this feature, on its true audio performance; the multichannel analog output, which to me is a very important feature as it is always one of the main reasons I buy a Universal DVD and BD player. ...The internal bass management has to be properly implemented, @ least with the minimum essentials.
As it turned out my oppo 103 was the worst performer from its multichannel analog out from all my other players. ...@ least eight of them.
I shall see (hear) again soon. And I'll share my findings again.
My best regards to you Dan,
Bob
DanF8500 likes this.
NorthSky is online now
post #20087 of 20091 Old Today, 04:00 PM
NorthSky's Avatar
Liked: 1006
--Bob
Funny that you mentioned that Bob; it did cross my mind, if only for a short moment.
post #20088 of 20091 Old Today, 04:02 PM
NorthSky's Avatar
Liked: 1006
--Bob
Ha, thx. ...I see now (mine is always @ 100). ...That, I can live with.
post #20089 of 20091 Old Today, 04:06 PM
NorthSky's Avatar
Liked: 1006
Maybe Netflix wants their customers to pay $8.99 each time they use their service?
post #20090 of 20091 Old Today, 06:59 PM
Read the FAQ!
Quoted: 731 Post(s)
Liked: 1071
--Bob
Yep, there aren't many this egregious that slip past the testing regime OPPO has set up. Not to mention all the reviewers. To OPPO's credit, once spotted it was quickly fixed.
Does make you wonder, though, about the bugs we Beta Testers DID catch! *SHUDDER* Like "The Giant Rat of Sumatra", there are some stories for which the world is not yet prepared.....
NOTE: No bugs were harmed in the testing of these products. They were all led away and returned to their natural habitats.
--Bob
post #20091 of 20091 Old Today, 07:35 PM
NorthSky's Avatar
Liked: 1006
When I was a teenager, in the summer, after college, I worked @ a large psychiatric hospital, as an assistant nurse.
We had a stage first, and they told us that what we saw there should not be revealed to the outside "normal" world.
It's the same when you work for the government as an elected candidate.
...And you can smell it too on some audio forums.
________
* I love my Oppo 103, I use it 90% of all time (I have several hi-res/hi-def BD/HD DVD players). Not all files play on it; that's when I use another one of my players.
As long as Oppo is going to make players I am a customer for life. My next one I just can't wait; Ultra high-def universal BD player (4K).
I'm ready, when the Blu-ray 4K software is. I'm also keeping track with HDMI 2.0 with HDCP 2.2 ... the real 4K deal, plus the transfer of more and precise object rendition in real 3D space for optimal Dolby Atmos and DTS:X surround elevated spatial 3D sound experience. ...OLED 4K and 3D glasses-free too. ...And on the front projection side as well; 4K/3D laser light 70mm film/digital all-in-one. ...Below $50,000 and no less than 120" across the front wall. ...Oppo will be the main source generator/locator/revelator.
______
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
