Official OPPO BDP-103 Owner's Thread - Page 671 - AVS Forum | Home Theater Discussions And Reviews
 874Likes
post #20101 of 24505 Old 02-04-2015, 08:26 AM
Jurgen's Avatar
Quoted: 13 Post(s)
Originally Posted by 80sGuy View Post
Believe it or not, the culprit can be from your HDMI cable. I once lived with the issue for many months until I discovered this (pictured below) and ultimately cured it.
Noticed the cable on the right (the culprit) had a much shorter connector/contact compared to the one on the left. Due to the flaw, it has been creating all sorts of problems from not recognizing a device from time to time, and above all - dropouts! Switched and replaced with a generic cable provided by my cable company and everything's history.
Check and compare your cables, because not all HDMI cables are the same.
I use both HMDI outputs of my Oppo (105): one goes to the AV-processor, the other one to the tv. Recently I had serious problems with the audio. I did many things, even replaced the HDMI cable from the Oppo to the AV-processor, but it didn't help.
Well at some moment I replaced the HDMI cable from the Oppo to the tv - and it helped: no more audio problems since then.
Jurgen is online now
post #20102 of 24505 Old 02-04-2015, 09:47 AM
drunkpenguin's Avatar
Quoted: 1244 Post(s)
Liked: 1214
Hey guys. I'm considering upgrading to this player from an Oppo 83. There have been some reports that some BD disks like John Wick are experiencing audio dropouts on the 83. I havn't experienced this yet, but it's scaring me away from it. Would the 103 be a major upgrade for me? I don't have a 3d or 4k projector, but I do use CIH. I have a couple of questions..
My receiver does not utilize auddsey settings when playing dts tracks. If I use this oppo to decode and then send to the receiver I could. Does this player handle that ok? My 83 has a ton of audio problems when I try to do this.
Also, does the 103 support itunes files from a usb drive?
Does the 103 support volume control over hdmi?
drunkpenguin is offline
post #20103 of 24505 Old 02-04-2015, 09:59 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2554 Post(s)
Liked: 3222
^ No volume control over HDMI (except for Mute which works for all audio outputs). Volume control is for the Analog audio outputs only. You'll need to use your HDMI-capable receiver for volume.
See the FAQ (link at the top of the first post of this thread) for info on supported media file formats.
Yes the 103 decodes DTS tracks (including DTS-HD MA from Blu-ray discs) into HDMI LPCM. So does your 83. What problems were you having doing this with your 83?
"John Wick" is a Dolby TrueHD 7.1 track (with extra, Atmos, chocolate sprinkles) authored with complex "seamless branching" -- and anti-piracy technique foisted by the studio. The 83 can't handle that for Bitstream output but it CAN handle it if you use HDMI Audio LPCM. I.e., switch to LPCM output and you should not have audio dropouts.
The 103 is quite a bit faster than the 83, has no fan, and supports many more media file formats and methods of streaming, as well as having useful, built-in internet apps such as Netflix, Pandora, and VUDU. You might also want to consider the 103D which adds Darbee video processing and some additional features (see the OPPO Digital web site). The 103 / 103D also have HDMI *INPUTS* so you can pass other HDMI sources through the video processing in the player.
The 103 / 103D provide vertical stretch support for CIH setups.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #20104 of 24505 Old 02-04-2015, 10:04 AM
Liked: 1214
I've been using bitstream for years with the Oppo 83. When I set it to lcpm it works about half the time. I get loud obnoxious blips and sounds introduced to the audio. Almost speaker breaking loud noises. I suppose the issue could be with the Marantz receiver, but I somehow doubt it. Marantz is pretty highly regarded. The Oppo 83 I have was a refurbed model so maybe my issue is unique.
I read about the darbee processing. Does it enhance if I am using an older projector that does not do 3d and all that? I have an JVC RS1 that is 1080p. Would I see a difference with it?
post #20105 of 24505 Old 02-04-2015, 10:27 AM
Read the FAQ!
Liked: 3222
Yes, on the Darbee questions.
You should talk to OPPO about your issue with LPCM output from the 83 and see if they have any history with your model of Marantz AVR. Audio corruption such as you describe is typically a symptom of HDMI handshake failures. This could be as simple as needing to upgrade your HDMI cables.
If you've not already done so, you should also check that your firmware is up to date on your 83. The firmware version number should end "60-1110".
--Bob
post #20106 of 24505 Old 02-04-2015, 10:45 AM
Liked: 1214
I took your advice and shot them off an email. We'll see what they say. Thanks.
post #20107 of 24505 Old 02-04-2015, 12:15 PM
Liked: 1214
Didn't take long to get a response...
Some Dolby Digital TrueHD soundtracks will not work with the BDP-83 as a Bit Stream (will result in dropouts) or LPCM (will result in audio corruptions) due to the lack of Seamless branching support. For these soundtracks where LPCM produces additional errors, you will need to enable Secondary Audio (to force the player to use the Dolby Digital core) or select an alternative soundtrack on the disc.
Maybe I'll pull the trigger on a new. I just dropped 2500 on speakers tho! What an expensive hobby.
post #20108 of 24505 Old 02-04-2015, 12:57 PM
lujan's Avatar
Quoted: 2015 Post(s)
Liked: 817
Yeah it is an expensive hobby 'cause I just spent $2k on a new Atmos receiver and some height speakers but I'm loving the better audio to where it feels like I'm watching the movies new for the first time.
lujan
138 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is online now
post #20109 of 24505 Old 02-04-2015, 06:56 PM
Liked: 1214
Thanks to everyone's input, but I won't be upgrading to another OPPO player unless they offer me one hell of a deal. We'll see how they respond to my email. I'll drop thousands on a completely new CIH setup before I spend 500 dollars to fix their bluray player that should be working. They are not the only way to achieve what I want.
post #20110 of 24505 Old 02-04-2015, 07:05 PM
Read the FAQ!
Liked: 3222
^ Which disc is giving you trouble, and have you tried it with LPCM output?
If it is one of the discs *KNOWN* to work with the 83 and LPCM output, then you really need to calm down and take the advice about checking your HDMI setup.
--Bob
post #20111 of 24505 Old 02-04-2015, 07:12 PM
Liked: 1214
I'm juggling too many threads on this subject to keep up. Long story short LPCM has never worked on my player and I think it's the reason my beta 50's cracked 2 tweeters! It gives me these loud scratchy popping noises so I've never used it. Infinity replaced the tweeters at no charge to me after owning them 4 1/2 years. To bad OPPO can't fix their ####.
Just 'cause you're right doesn't mean I'm wrong
post #20112 of 24505 Old 02-04-2015, 07:13 PM
Liked: 1214
And no I don't need to calm down. When OPPOs response is use dolby digital or buy a new model, people need to know that before making a purchase!
post #20113 of 24505 Old 02-04-2015, 07:28 PM
Read the FAQ!
Liked: 3222
Well this will come as quite a surprise to the people who use LPCM from their 83 without these problems.
Aren't you in the least curious as to why you are getting such generic problems with LPCM output? Without some details as to discs there's not much we can do here to help.
Atmos just came out, so your prior problems couldn't have been from Atmos tracks.
--Bob
post #20114 of 24505 Old 02-04-2015, 07:34 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3548
What we need is a trade-in program. ...Trade your older Oppo 83 for a 103, and pay something like $200-300.
Ok, it won't happen I'm sure...I just want you to be happy. Bob mentioned PCM (setting) but you don't like.
* You don't have five hundred bucks to buy a 103? ...Or $200 to buy a Sony BD player?
NorthSky is offline
post #20115 of 24505 Old 02-04-2015, 07:35 PM
80sGuy's Avatar
Quoted: 185 Post(s)
Liked: 35
ebay would be your best bet to unload. There will always be somebody looking for an Oppo..
80sGuy is offline
post #20116 of 24505 Old 02-04-2015, 07:38 PM
Read the FAQ!
Liked: 3222
It's called eBay. Have you checked resale prices on OPPOs recently? Even their SD-DVD players!
But I digress...
--Bob
post #20117 of 24505 Old 02-04-2015, 07:44 PM
Liked: 1214
I have 35,000 dollars sitting in my account that I don't know what to do with right now. It's either a nissan z or a bunch or random crap. I don't know yet. I can assure you this is not about the money right now. It's the freakin principal! I'm very tempted to post a youtube video of one of my guys throwing this thing off of a 500' tower! If AVS could assure me that they won't delete my post I'd love to share it!
Anyways I've said what I wanted to say. Nobody cares. Oppo don't care obviously. Half of you don't care. So I'm done. Thanks for listening.
post #20118 of 24505 Old 02-04-2015, 08:30 PM
NorthSky's Avatar
Liked: 3548
Not true man; I care a great deal. I care so much so that I'm willing to buy you a brand new Oppo BD player. ...Would that make you feel better about this world we all live in?
NorthSky is offline
post #20119 of 24505 Old 02-04-2015, 11:27 PM
Iron Maiden's Avatar
Quoted: 528 Post(s)
Liked: 201
Haters gotta hate! I've wanted an Oppo player for many years. Now that I finally do have one, the 103, I couldn't be happier. It really has been one the best upgrades I've made to my system. I'm actually shocked at what a difference it has made. I finally pulled the trigger mainly because I wanted one component to be used for all shiny discs. A convenience deal. But both audio and video has improved. The Oppo's fast loading sure is nice.
Signed, Happy Oppo owner.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #20120 of 24505 Old 02-04-2015, 11:36 PM
NorthSky's Avatar
Liked: 3548
I feel sad when I hate. I feel much better (happy) when I love.
* By the way, what is "hate" exactly?
NorthSky is offline
post #20121 of 24505 Old 02-05-2015, 12:59 AM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
It doesn't surprise me anymore when every couple of months someone drops by for drive by comments and isn't amenable to getting the help they were asking for in the first place. We really need a designated therapist in this thread for times like these......
gsr, Keenan, Smarty-pants and 1 others like this.
Chere is offline
post #20122 of 24505 Old 02-05-2015, 01:06 AM
NorthSky's Avatar
Liked: 3548
Does $200 an hour sound like reasonable?
Smarty-pants likes this.
NorthSky is offline
post #20123 of 24505 Old 02-05-2015, 01:25 AM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
What would help us more than your guys or the amount of money you have in your account is you giving us a basic idea of the hardware you're using in your chain including any discs and how they're all connected. We can go from there.
Short of that there isn't much we can do for you at this point. Should you decide to go it your way, I suggest that you find a 'healthier way' of getting rid of your player because if you really drop it from a 500 foot tower, 35k won't be enough to get you out of a serious criminal charge depending on who/ what it lands on. The irony is even after all this the player might still continue to function as we all know that "Oppos are built to last."
Chere is offline
post #20124 of 24505 Old 02-05-2015, 04:37 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1088 Post(s)
Liked: 1062
I think most of us do care, but what do you realistically want us to do for you? Does it suck that the BDP-83 has hardware limitations with Dolby True HD 7.1 combined with complex seamless branching that can't be resolved with a firmware update? Sure it does. It also can't be upgraded to support 3D playback. And guess what? Neither of those things were on the radar at the time the player was designed and built. The fact that some other players from the same period aren't having issues with the Dolby True HD 7.1 tracks with complex seamless branching is more a matter of luck than anything else as there's no way a manufacturer could have reasonably planned for or tested this at the time they designed their products. If you want to continue to rant about it, please do so in the BDP-83 thread as it's off topic in this thread.
Complaints really ought to be directed at the studios for constantly trying new tricks that only make things difficult for legitimate buyers and the standards committees that seem to be unable to define a proper specification that manufacturers can design against (which would minimize the need for firmware updates to address all these disc compatibility issues that are an ongoing problem with nearly every player).
If you want to throw your player from the roof of a tall building and destroy it, nobody is going to stop you, but there are more constructive ways to move on, one of which has already been suggested (sell it on eBay).
gsr is offline
post #20125 of 24505 Old 02-05-2015, 05:45 AM
lujan's Avatar
Liked: 817
What I take into account when buying an Oppo or anything else is not only the product itself but more importantly, the technical support that you get with it. Oppo has one of the best technical support staff of any consumer electronic company that I've ever had to call. This alone is worth the extra cost for the Oppo IMO.
Keenan and Mongo171 like this.
lujan
138 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is online now
post #20126 of 24505 Old 02-05-2015, 07:52 AM
buddywhite's Avatar
Quoted: 12 Post(s)
Originally Posted by buddywhite View Post
I connected my WDTV to the HDMI front in and everthing works fine, except that it won't play DTS HDMA. Can't the oppo pass through it?
Originally Posted by wmcclain View Post
buddywhite is offline
post #20127 of 24505 Old 02-05-2015, 10:54 AM
Liked: 1214
What does this mean? From Oppo:
"The newer players will be more compatible than the BDP-83, but the downside is that the newer players will not be able to zoom BD-JAVA if there is a Picture in Picture program on the disc. The BDP-83 bypassed this since the ABT VRS is doing all zooming, while the newer players are using the decoder for zooming, so it has to abide by the specifications on the disc to not allow for zooming if the disc is programmed to prevent it."
Vertical stretch doesn't always work on this player? Is this true? I was about to give in and order one but that would be an absolute deal breaker.
post #20128 of 24505 Old 02-05-2015, 10:57 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2792 Post(s)
Liked: 2015
They are saying you cannot zoom BR discs with Bonus View Picture-in-Picture content. Your disc covers should describe whether the feature is present.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #20129 of 24505 Old 02-05-2015, 11:00 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1062
Correct. Have you considered using an external scaler, such as a Lumagen, that supports CIH? Combine that with a player that supports source direct video output and it may provide you with a solution that works.
gsr is offline
post #20130 of 24505 Old 02-05-2015, 11:00 AM
Liked: 1214
Ok. So obviously I'm retarded but what is Bonus View Picture in Picture? Is this a special feature or an extra deal? Here's a random question. If I buy 100 random blurays how many of them likely won't stretch when I watch the movie?
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
