Official OPPO BDP-103 Owner's Thread - Page 676 - AVS Forum | Home Theater Discussions And Reviews
 907Likes
post #20251 of 24703 Old 02-12-2015, 09:05 AM
kellybob's Avatar
^ Did you try 1080/24 "On"?
kellybob is offline
post #20252 of 24703 Old 02-12-2015, 09:13 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
I haven't owned an Oppo player since the model 83 years ago. I loved that player and the only reason I moved on from it was my desire to play my media files (ISO and MKV) from a single video playback device with content stored on a server. Many years and many different combinations later, I am still in search of an ideal solution. I recently fell in love with the XBMC/Kodi interface for media playback and cover art which I am running on an Amazon FireTV an also an ASUS Chromebox. Content is via an SMB share on my unRaid server which has been running beautifully for years now. Through many different media players I have always missed the assurance in top notch video playback that the Oppo used to give me. These little players do so much more than any BD player but they are not always the best at processing video and handling it correctly. I know that there was an Oppo player a while back that handled ISO files through an older firmware which was later removed and I see those players going for a premium when sold with the ISO firmware. I have also read about the last few Oppo players being able to access SMB shares and playback some MKV files. While much of my collection is full BD-ISO, I have moved on from that format and use MKV exclusively now. I am wondering if any Oppo player or combination of Oppo player and other device or app does this while also being able to scrape media content and display cover art similar to the way XBMC/Kodi does.
dropzone7 is offline
post #20253 of 24703 Old 02-12-2015, 10:03 AM
Iron Maiden's Avatar
Quoted: 533 Post(s)
Liked: 204
Originally Posted by 80sGuy View Post
It is recommended that 2-channel (rca) analog are used when listening to music CD. They have a higher output decibel and sounds much better compared to using digital; be it HDMI, Coax S/PDIF, or Optical.
If you are asking what the difference is between connecting the Oppo up to the A/V receiver with HDMI/Optical/Dig Coax vs analog rca....
Difference is with a digital connection to the AVR (HDMI/Optical/Dig Coax) you are using the AVR's DAC. If you connect the Oppo with analog cables, you are using the Oppo's Dac. Both methods work, it will just be a personal preference as to which dac sounds better to you.
I use an outboard dac as it sounds better than the Oppo dac and the Pre/Pro's dac to me.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #20254 of 24703 Old 02-12-2015, 10:35 AM
80sGuy's Avatar
Quoted: 189 Post(s)
Liked: 36
Originally Posted by rdgrimes View Post
Attempting to clear up some misinformation here:
The Onkyo is going to convert those stereo analog inputs to digital (LPCM), process as designed, then back through its DAC.
So what you're actually listening to is the Onkyo's DAC, not the Oppo's. This is true of most AVRs with the exception of those that offer a true analog bypass (a rare and expensive feature that bypasses all processing) Those AVRs that have multi-channel analog inputs do not convert that to LPCM.
Not sure where this is coming from, it sounds pretty goofy to me, but see above
Again see above. Once converted to LPCM, stereo inputs are passed through whatever DSP the AVR offers.
As goofy as it may sound, it comes from here: Cambridge Audio Azur 752B (page 12). I use this manual as a cross-reference due to its similar build/design to the Opp BDP-103/D except for the Wolfson DACs, and with a price tag costing almost three times more.
Pg. 12
1
Separate analogue stereo
The analogue stereo outputs should be used for play back of CDs,
DVDs etc in stereo through a conventional amplifier or AV receiver with
analogue stereo inputs.
Analogue stereo is also usually the best connection method for listening
to CDs and other stereo discs for best possible sound quality. It is often a
good idea to connect both the analogue stereo outputs (for CD playback)
and digital audio outputs or HDMI (for surround sound decoding) at the
same time.
To connect an analogue stereo system to the 752BD, use stereo phono cables (stereo 2RCA-2RCA)
As you can see, the buttons on the front, the rear deck, and innards layout are almost identical to the BDP-103.
80sGuy is offline
post #20255 of 24703 Old 02-12-2015, 10:38 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3080 Post(s)
Liked: 2362
Yes on MKV and SMB, no on an interface as sophisticated as XBMC. It does Gracenote lookup for some art and descriptive info, but this not very reliable for media files because it depends solely on the file name, which is not enough for Gracenote.
I have a little book-sized HTPC running XBMC which I connect to the OPPO's HDMI input, but that is optional. It could just as easily be connected to the TV itself, or a receiver.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20256 of 24703 Old 02-12-2015, 10:51 AM
DSperber's Avatar
Quoted: 235 Post(s)
Liked: 191
Originally Posted by Tgterm View Post
Pretty sure I do. In the DTV box, I have Native set to on, and all the resolutions checked -- I assume that will then pass them all unadulterated.
You can tell for sure what the 103 is receiving from the DTV box, by pushing the INFO ("i") button on the 103's remote. This will present a status bar at the top and bottom of the screen showing what is being received into the 103 and sent out of the 103, and you can also use PAGE-UP/PAGE-DOWN to present additional information. Press the INFO button again to toggle away the displays.
The show I was watching, however, had been recorded before I changed to Native On. Dumb question -- would the DVR have recorded an upscaled (in the DVR) version of the show, and that is why I was noticing these artifacts?
Not likely. Recordings are simply recordings, at the original native resolution. Conversions if requested would occur at playback time from the DTV box, not at recording time. So if you have NATIVE set, it should be working fine.
I don't think the 103's 1080p/24hz setting affects external HDMI input, but rather is only relevant to DVD playing. I think.
Anyway, if you've got your DTV box in "native" than I don't have any additional explanation for the "judder" you may be seeing, which is mostly caused by multiple conversions from the native format prior to arriving at the 103 where it gets the final upconvert to 1080p for delivery to your AVR/display.
DSperber is online now
post #20257 of 24703 Old 02-12-2015, 10:55 AM
rdgrimes's Avatar
Quoted: 2264 Post(s)
Liked: 1609
Not relevant to the OP's situation. SEE ABOVE. His AVR will convert stereo analog inputs to LPCM for processing. Cambridge is referring to a pure analog pathway.
rdgrimes is online now
post #20258 of 24703 Old 02-12-2015, 10:58 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1189 Post(s)
Liked: 1218
Pg. 12
1
same time.
Their advice is waaaaaaaaay too generic. It's not as simple as "analog sounds better than digital" because the audio in the player starts out as digital and has to be converted to analog before it comes out of the speakers. Where that conversion should be done depends on where the better DAC is in any given system. The better DAC might be in the player, but it might also be in the AVR, pre-pro, or external standalone DAC. In the case of the Cambridge Audio player you're referencing, the analog outputs are more on a par with Oppo's BDP-105 than the BDP-103, so there are going to be more cases where using the DAC in the player makes more sense, but even then it doesn't always make sense.
Now, if the user wants to apply room correction or speaker configuration (bass management, distance corrections, etc.) to the audio in the AVR or pre-pro, then it doesn't make any sense at all to use the DAC in the player, because the analog signal will have to be converted back to digital, have the room correction applied in the digital domain, and then converted back to analog again using the DAC in the AVR or pre-pro. In such a situation, that's a lot of extra processing that's completely unnecessary - just send the signal digitally to the AVR or pre-pro if using room correction.
Iron Maiden likes this.
gsr is offline
post #20259 of 24703 Old 02-12-2015, 11:10 AM
warrian's Avatar
I did not. I will give it a go. Thanks!
________________________________________
Sony Bravia KDL-55BX520 / Pioneer VSX-54TX
OPPO BDP-103D / Xfinity X1 / Klipsch Speakers
warrian is offline
post #20260 of 24703 Old 02-12-2015, 11:14 AM
stash64's Avatar
Quoted: 266 Post(s)
Liked: 91
Nice explanation "gsr". I was trying to give the short version.
To add to above, if you do use analog out from the Oppo or any source it probably makes sense to engage any "pure/direct" circuitry in your pre-amp or receiver. My Marantz has 2 options (pure and pure direct, I think) to avoid sending the analog signal back to the digital domain.
Sean
stash64 is offline
post #20261 of 24703 Old 02-12-2015, 11:33 AM
80sGuy's Avatar
Quoted: 189 Post(s)
Liked: 36
This is all preference as it sounded good to my ears. I listen to a lot of vinyls and the same applies even though 'phono' hookup is somewhat limited in terms of connection method. Two of my CD/R decks are connected via both analog and s/pdif, optical. As pure in digital as they are but I find it too 'flat' sounding and lacking frequency response - unless I turn it up to a certain level. Yes you can apply all sorts of room correction, bass management and what not, but listening in 2.0 stereo mode (as in the case with vinyl) is suffice. Again, this is just personal preference. Of course, we are referring to music CDs here and by no means I would recommend this for DVD/BD.
80sGuy is offline
post #20262 of 24703 Old 02-12-2015, 11:37 AM
Tgterm's Avatar
Quoted: 190 Post(s)
Liked: 27
I'm glad you mentioned this...I did press Info on the Oppo and saw 720p at the top of the screen (I believe it said IN) and 1080p for HDMI 1 (Out) at the bottom. So, it sounds like the Oppo is receiving the Native resolution and upconverting correctly. I have not tried the page up and down when in INFO -- I will tonight and see what else it is saying.
Just a hopeful theory...oh, well...
I had switched this to OFF, Auto, and On trying to discern a difference last night -- don't think I saw any. That said, I may play with it again a bit more...
The judder was only noticeable in that one program. I watched live HBO and FoxNews configured this way, with no discernible artifacts. In fact, it looked really good...
The true test is when I get my splitter configured to reduce the HDMI Outs to one. Then I can properly assess overall performance, I think.
Thanks for your help!
Tgterm is offline
post #20263 of 24703 Old 02-12-2015, 11:55 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1218
Ultimately, which way to go is a matter of personal preference, but there's some amount of logic that should be considered in the decision process. The same applies whether it's music or movies. Any degradation in sound quality may be a bit less important to some people for movies, but if you want the best sound quality possible, it makes sense to minimize the number of times the signal is converted between digital and analog.
Matt2026 likes this.
gsr is offline
post #20264 of 24703 Old 02-12-2015, 12:35 PM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
-Bill
Thanks for the reply.
So the Oppo is acting as a sort of video processor by accepting the HTPC as a video source? I assume your HTPC is sending RGB over HDMI. How does the Oppo handle that? Do you output something other than RGB from the Oppo to your display? 4:2:2 or 4:4:4?
post #20265 of 24703 Old 02-12-2015, 12:50 PM
wmcclain's Avatar
Liked: 2362
Yes, the input is RGB over HDMI. I don't know if XBMC allows other color spaces; I'd have to dig into the setup and configuration options.
I also output RGB, but that is just my preference for the display I use. You can output either type of YCbCr instead.
-Bill
post #20266 of 24703 Old 02-12-2015, 01:35 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3331 Post(s)
Liked: 4276
^ For anyone who has the option in their Source device(s), I recommend you send YCbCr -- either 4:4:4 or 4:2:2 -- to the HDMI Inputs of the 10x players instead of RGB.
The OUTPUT of the player can be selected as RGB or YCbCr at your preference. (RGB PC Level output, however, should only be used if that's the only choice your Display can handle -- typically only true if using an older style, Computer Monitor as your Display.)
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #20267 of 24703 Old 02-12-2015, 01:41 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
--Bob
I've heard Roku 3's only output RGB, but that discussion should be in a different thread. Why would you recommend that the color space for an hdmi input to an Oppo player be in YCbCr instead of RGB? Even for HTPC's? (if the Oppo players have selectable color space options on the output to your tv)
DanF8500 is offline
post #20268 of 24703 Old 02-12-2015, 02:15 PM
Read the FAQ!
Liked: 4276
^ It's a bit more technical than I want to get into right now, but the bottom line is, odds are good you will get better picture quality if you send YCbCr to the HDMI Inputs.
--Bob
post #20269 of 24703 Old 02-12-2015, 03:36 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
Here's a workaround that you can try. Works for me....
The later versions of the Oppo have the ability to act as a UPNP player that XMBC can see.
1) From your XBMC machine, use the "play using" UPNP functionality and select the Oppo player on the network. MKV should start to play throgh the Oppo.
2) Once you get this working set the Oppo UPNP device as the XBMC default player (sear how to do this if needed)
3) Connect the XBMC to the Oppo HDMI input. You will then be viewing the nice front end of XBMC though the Oppo input.
4) When you start playback of a movie, it starts it on the Oppo vs the XBMC machine.
5) Here's the cool part...the Oppo will automatically switch inputs to play the network movie that you just selected via XBMC.
I don't really like talking about my flair
barhoram is offline
post #20270 of 24703 Old 02-12-2015, 03:44 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
--Bob
I'd love to hear your technical overview of this when you have time, as I think a lot of other Oppo owners would. I know quite a few have Roku 3 devices, and if they're using them on an hdmi input of an Oppo player, they may be unaware that the picture quality may not be the best that is possible via those devices if you say YCbCr color spaces will generally produce better picture quality on the Oppo's hdmi inputs.
Keenan likes this.
DanF8500 is offline
post #20271 of 24703 Old 02-12-2015, 06:46 PM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Wow, now that sounds genius! Wish I could get my hands on a player to test.
post #20272 of 24703 Old 02-12-2015, 07:10 PM
Read the FAQ!
Liked: 4276
I don't use XBMC myself, but I believe I've followed what you just suggested. And I'd say this is definitely worth a Cookie!
Do you happen to know what version of XBMC is required to include the OPPO push playback support?
--Bob
post #20273 of 24703 Old 02-12-2015, 07:24 PM
Read the FAQ!
Liked: 4276
OK, some more detail. First you definitely do not want to use a Source which is sending what is misleadingly called "Extended" RGB format -- what OPPO more accurately calls "RGB PC Level". Why? Because there's no way to configure the HDMI Inputs in the 10x players to expect that. The choice of RGB Video Level vs. RGB PC Level is not something that can be established by the HDMI handshake. It needs to be manually configured. And the OPPO Inputs are not capable of being configured to expect that incoming format -- evidently a hardware limitation. (For the technically inclined, you can't "fix" this simply by adjusting Contrast and Brightness, as the Color Space Math is also different between the two RGB formats.)
Second, if your Source is sending "Studio" RGB -- what OPPO calls "RGB Video Level" -- then there is a Color Space Math error if the Input Resolution is 720p or higher. This shows up most noticeably in Greens which are too dark. This has been known for quite some time, so I have to assume there is some hardware limitation which keeps this from being fixed. The error is not so blatant that it will jump out at you, but it's real.
The bottom line is that the HDMI Inputs work best if fed YCbCr (either 4:4:4 or 4:2:2). The issues here are on the INPUTS. There are no similar problems with the OUTPUTS.
--Bob
post #20274 of 24703 Old 02-12-2015, 07:49 PM
wagnerc's Avatar
Quoted: 34 Post(s)
Now I have some work more work to do.
wagnerc is offline
post #20275 of 24703 Old 02-12-2015, 07:53 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
--Bob
Thanks, Bob. Followup. So, if I have a Roku 3 which only outputs RGB color space, and the Oppo can't adjust for that type of input because of hardware limitations, can the Oppo pass that video out to an external device (i.e. tv) which has the ability to adjust for RGB color space via a setting called "HDMI Black Level"? I have a Samsung plasma tv which has that setting, and is only active/adjustable when receiving an RGB color space on its hdmi inputs. Just wondering if RGB video can be passed thru the Oppo without issue, or does the Oppo just hose up that type of video so it can't be adjusted by a source that is receiving the Oppo's output. ??
DanF8500 is offline
post #20276 of 24703 Old 02-12-2015, 07:57 PM
Read the FAQ!
Liked: 4276
The ROKU sends RGB Video Level, so you don't want to be futzing with "black level" choices.
--Bob
post #20277 of 24703 Old 02-12-2015, 08:10 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ Ok. I won't elaborate on hdmi black level high/low (that's for the samsumg thread, but must be a reason that setting is only active for RGB color space), but since the Roku 3 sends RGB Video Level, you're not recommending using its hdmi output on an Oppo input because of the color space math error you described above (when incoming video is 720p or higher).
DanF8500 is offline
post #20278 of 24703 Old 02-12-2015, 08:24 PM
rdgrimes's Avatar
Liked: 1609
Its a pretty minor error, mostly only shows up in test patterns. Try it and use it if it looks OK to you. LOTS of people do so and don't notice a thing.
post #20279 of 24703 Old 02-12-2015, 08:51 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 628
^ I have tried to see that error before (without test patterns or light meters)
and I couldn't see any difference to my naked eye when switching back and forth.
Smarty-pants is offline
post #20280 of 24703 Old 02-12-2015, 08:53 PM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
So now I'm confused. For the Roku MHL stick do we leave the color space for HDMI 1 and 2 on YCBR 4:4:4 or RGB Video?
Chere is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
