Official OPPO BDP-103 Owner's Thread - Page 679 - AVS Forum | Home Theater Discussions And Reviews
 872Likes
post #20341 of 24484 Old 02-17-2015, 01:39 PM
mecmec's Avatar
Quoted: 407 Post(s)
Liked: 159
Originally Posted by Tgterm View Post
I am now running my DirecTV Genie set to 'Native - On' through my Oppo, and it is a significant upgrade in video appearance. I am not experiencing all the resynch flashes and issues with setting the cable box you describe, either.
The only thing I do occasionally get is an audible sound when I pause and then hit play. Kind of a low pop, but it doesn't always happen. Small price for the much better video processing though...very happy with it right now.
Hmmmmm, if I was not dead set against a genie I would be tempted to give one a whirl..
mecmec is offline
post #20342 of 24484 Old 02-17-2015, 01:49 PM
Keenan's Avatar
Quoted: 2232 Post(s)
Liked: 2034
Originally Posted by Chere View Post
No you were right. I took a closer look and it was on my menu screen as well although I had to be within 2-3 feet to be able to see it clearly.....
Yes, apparently it's normal, it's just a low color depth image, not enough bits used to smooth it out and some displays are less forgiving than others in showing those image deficiencies. Which is a good thing, I'd rather have my display show the bad stuff instead of hiding it along with possibly hiding some of the good stuff. :-)
Chere likes this.
Keenan is offline
post #20343 of 24484 Old 02-17-2015, 01:52 PM
Tgterm's Avatar
Quoted: 186 Post(s)
Liked: 26
Originally Posted by DanF8500 View Post
But you must be getting the 2-3 second delay/black screen when switching between channels with different native resolutions (i.e. 720p to 1080i and vice versa). You can't avoid the hdmi handshake when channel surfing native video from your STB/DVR being fed to a source (Oppo or tv), unless all you watch is 1080i broadcast channels.
You're right... I do get this every once in a while. Right now it is not annoying enough to get me to roll this back. Not much of a surfer I guess. Usually watching something either DVR-ed or going right to a program or movie.
Time will tell I guess.
Tgterm is offline
post #20344 of 24484 Old 02-17-2015, 02:26 PM
tym2relax's Avatar
Quoted: 22 Post(s)
I have an HR22 and the PQ is improved going through the 103. The only odd thing is when I pause/play the audio is delayed a few seconds. But after that, all is well.
tym2relax is offline
post #20345 of 24484 Old 02-17-2015, 03:12 PM
Quoted: 73 Post(s)
Liked: 112
Originally Posted by stash64 View Post
Is there any possibility that Oppo would add support for the new Sling TV/Dish programming in an upcoming firmware update ? Anything in the rumour mill ?
I'm tempted to give this a try at $20/month but really don't want to add another device to my system.
Tried it on my Roku stick plugged into my OPPO, but the interface is way too slow. That said, it could be my Harmony remote being wonky.
rnatalli is offline
post #20346 of 24484 Old 02-17-2015, 05:06 PM
Chere's Avatar
Quoted: 352 Post(s)
Liked: 185
Was it a 720p , 1080p @ 60hz or 1080p @ 24hz stream?
Chere is offline
post #20347 of 24484 Old 02-17-2015, 06:21 PM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
Well, fwiw, I did just give the Genie a whirl (a week or two ago I swapped out my HD24 + HR24s), and a whole lot better for me. HR24 had dolby digital audio dropouts and a noisy (whirring, not clicking) spinning disk; it also ran very hot temperature. Never ever hear the Genie disk and haven't noticed any audio dropouts (although the install guy said he wasn't going to swap out the lnbs, I think he actually may have (it showed up on the install list)); plus little/no heat that I've noticed. Also the PQ seems a lot better, far less noise (or perhaps it's just hiding things better, hard to say at this point, but for the time being I don't particularly care).
Haven't tried the Genie via the Oppo, but not really seeing the need as of yet (the Oppo didn't seem to do a whole lot for me when I briefly tried it with the HD24 a year or so ago, PQ didn't really improve all that much, plus also probably experienced the same or similar symptoms to those you are seeing).
About the only thing I miss with the HD24 was a good bunch of content that I never quite got around to watching.
I think my electric bill may end up at least a little bit lower too, I remember how much it jumped around the same time I got the HD24 (when I first subscribed to directv).
fmalczewski is offline
post #20348 of 24484 Old 02-18-2015, 09:39 AM
brollend's Avatar
Can I plug an Apple TV into Oppo-103 for streaming?
I have an older receiver used primarily for 2 channel audio. No HDMI ports. I want to add streaming for Spotify and apple airplay. Is it possible to plug an apple TV into one of the Oppo's HDMI in ports and then connect to the receiver over optical. How about a Roku Stick or Roku Box?
brollend is offline
post #20349 of 24484 Old 02-18-2015, 09:57 AM
Zcars's Avatar
Quoted: 84 Post(s)
I don't see why not. I sometimes connect my tablet via HDMI and stream internet music. I have the optical out to a headphone amp, and analog L/R out to my amp for stereo. Why don't you want to use the onboard DAC and use the analog outs?
Zcars is offline
post #20350 of 24484 Old 02-18-2015, 10:10 AM
brollend's Avatar
Will the Analog outs give better sound quality? I guess that is also an option. I was thinking the optical was a higher quality connection.
brollend is offline
post #20351 of 24484 Old 02-18-2015, 11:21 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1086 Post(s)
Liked: 1050
It all depends on how good the DAC in your receiver is compared to the DAC in the Oppo and whether you're using anything like room correction in the receiver.
gsr is offline
post #20352 of 24484 Old 02-18-2015, 01:28 PM
Philnick's Avatar
Quoted: 239 Post(s)
Liked: 104
The Oppo's analog outputs are great
The Oppo has very good DACs - even in their less-expensive models. I use my Oppo 93's multichannel analog outs (set to put out 5.1) into my AVR and it sounds beautiful through a set of old Paradigm Studio 40s and 20s (along with their matching front center and sub) - and I listen to a lot of DVD-A disks and true 96/24 and 192/24 downloads, as well as concert disks and movies.
The Oppo replaced a Panasonic BD-50 (the first player to be able to decode DTS-HD MA) to bring my Blu-ray sound quality up to the level of my Denon 2910 (my prior DVD-A/SACD player), once I realized that even CDs sounded richer played on the Denon instead of the Panny.
That the image quality was better as well was an unexpected bonus, as was the Oppo's ability to stream music from my PC over my LAN, sounding as good as when I played the original disk - and avoided the need to burn disks at all from downloaded high def music I bought.
One thing you don't want to do is use the optical connection for surround, which knocks the connection back to lossy Dolby Digital. For surround there's no question - the analog ouput is better than optical or coaxial SP|DIF, which only has sufficient bandwidth for lossless stereo or mono.
Philnick is offline
post #20353 of 24484 Old 02-18-2015, 01:39 PM
mecmec's Avatar
Quoted: 407 Post(s)
Liked: 159
all of my hr 24's have upgraded hard drives and have been running like tops for YEARS. they are super quiet, I don't experience drop outs and have no issues with them. My only gripe for the genie is if it dies then you lose all of your recordings! If there was a price savings then i might consider it, but there is not...
mecmec is offline
post #20354 of 24484 Old 02-18-2015, 01:55 PM
boe
boe's Avatar
Quoted: 920 Post(s)
Liked: 419
Questions for people who bought the Roku Streaming stick
Hello,
I see the Roku Streaming stick is now sold through Oppo. I use my Oppo most of the time to stream MKV files (I don't care about streaming neflix, amazon or games). I'm curious if I should get the Roku.
1. It says you use your Oppo remote - so I can control it with an IR remote such as my Harmony One?
2. Does it use the Oppos Ethernet or do you need wireless?
3. Any issues with streaming MKV audio - does it play DTS-MA as DTS-MA, TrueHD as TrueHD etc?
4. Does it stream MKV LPCM? (The Oppo does not as is).
5. Does it playback streamed MKV subtitles? The Oppo does not let you stream MKV subs or forced subs.
6. Is the Visual quality the same? The oppo video quality for streamed MKVs is excellent.
7. Is it an additional icon within the Oppo menu? Any pictures would be great.
Any additional info you can give regarding using the Roku in conjunction with the Oppo for streaming MKV files would be appreciated.
boe is offline
post #20355 of 24484 Old 02-18-2015, 01:58 PM
lujan's Avatar
Quoted: 2000 Post(s)
Liked: 807
Originally Posted by boe View Post
Hello,
I got the one sold via Oppo and now I regret it because they have the HDMI version now that would be more versatile whereas the one from Oppo can only be used on the Oppo (and other limited devices that support MHL).
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #20356 of 24484 Old 02-18-2015, 02:05 PM
rdgrimes's Avatar
Quoted: 2071 Post(s)
Liked: 1394
Hello,
There may be some confusion here.
1) The RSS -MHL version is controlled by the player's remote
2) The Stick must use its own wireless networking, and supports both 2.4 and 5GHz bands.
3, 4, 5) The RSS is not a media playback device unless you use one of the channels that does this, like Plex. Whatever functionality it has will be controlled by that app and usually depends on a networked PC running server software. Again, the Roku has no native support for streaming local media files.
6) The RSS scales 480 to 1080, and can passthrough 720 and 1080.
7) The Roku icon appears on the Oppo Home screen and is selected like any of the available apps.
rdgrimes is online now
post #20357 of 24484 Old 02-18-2015, 02:07 PM
rdgrimes's Avatar
Liked: 1394
Originally Posted by lujan View Post
I got the one sold via Oppo and now I regret it because they have the HDMI version now that would be more versatile whereas the one from Oppo can only be used on the Oppo.
This is incorrect. The MHL version of the RSS can be used on any MHL supporting device. Mine works on my AVR as well as it does the Oppo.
post #20358 of 24484 Old 02-18-2015, 02:52 PM
Zcars's Avatar
Quoted: 84 Post(s)
True. In my case, I think the analog outs sound great, but my amp doesn't have optical inputs so I can't compare. If you have both, just try both and compare for your situation. Experimenting is half the fun!
Zcars is offline
post #20359 of 24484 Old 02-18-2015, 03:02 PM
boe
boe's Avatar
Quoted: 920 Post(s)
Liked: 419
Thanks for taking the time to reply. Again all my questions pertain to streaming MKV files via DLNA.
1. Since I can control my oppo with the oppo remote I take it I should be able to use my Logitech remote?
2. That is a shame that it doesn't take advantage of the Oppo Ethernet wired connection for guaranteed streaming of large files such as BD MKV files.
3. Since I'm streaming via DLNA from my PC the question remains - will it handle DTS-MA, TrueHD from streamed MKV files and play them back as DTS-MA or TrueHD?
4. Does it handle streamed LPCM audio files?
5. Does it playback streamed MKV file subtitles? Forced subbed?
6. Any issues with feedback, artifacts or any other issues that make streamed MKV playback via the Roku of lower quality that streaming through the Oppo without Roku?
7. An additional icon on the Oppo makes sense.
Thanks again.
boe is offline
post #20360 of 24484 Old 02-18-2015, 03:14 PM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
The Roku sticks (and any other Roku device) do not do streaming from your computer.
JazzGuyy is online now
post #20361 of 24484 Old 02-18-2015, 04:43 PM
boe
boe's Avatar
Quoted: 920 Post(s)
Liked: 419
It is mentioned a few times that you can put channels/apps on them for streaming from DLNA sources.
boe is offline
post #20362 of 24484 Old 02-18-2015, 04:44 PM
Quoted: 102 Post(s)
Liked: 39
And you don't lose all of your recordings if the 24 dies? News to me, I thought the dvr recordings could only be used with the specific hardware they were recorded with.
Regardless, I was never a happy camper with my 24 setup, so aside from some of the content that went away with it (oh well, there's always plenty more where that came from, more than I'll ever be able to deal with), it's all better. At least for now.
post #20363 of 24484 Old 02-18-2015, 05:25 PM
lujan's Avatar
Liked: 807
Yeah, but I never heard of MHL until Oppo and the HDMI version can be used on far more devices.
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #20364 of 24484 Old 02-18-2015, 05:31 PM
Keenan's Avatar
Liked: 2034
It's still an HDMI connection, MHL(Mobile High Definition Link) just means it has to be powered by the device it's connected to.
But I see what you're saying, the non-MHL version is more versatile, as long as you have some AC power from somewhere.
Keenan is offline
post #20365 of 24484 Old 02-19-2015, 05:49 AM
kmh364's Avatar
Oppo BD-103: Buy now or wait?
Any scuttlebutt about a 103/D replacement/upgrade coming down the pipe soon? I always end-up a late adopter, usually right when the new model tends to be released.
My two faithful Pioneer BDP-51FD's are starting to refuse to play new BD's (i.e., UNKNOWN DISC) and there's no new FW update since 8/13, with no more updates likely. I hate to spend the cashish if I don't have to, but I tend to keep my stuff and I want something worthy of my 9th-gen Kuro PDP, not a throw-away Samsung/LG-of-the-month player.
kmh364 is offline
post #20366 of 24484 Old 02-19-2015, 05:58 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2780 Post(s)
Liked: 2001
No news. We presume the next player will support 4k Blu-ray, which hasn't appeared yet. OPPO has said not this year, and maybe not next year.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20367 of 24484 Old 02-19-2015, 06:30 AM
lujan's Avatar
Liked: 807
Thanks, I edited my OP to hopefully be more accurate.
lujan
137 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #20368 of 24484 Old 02-19-2015, 10:43 AM
warrian's Avatar
This is not to argue with anything in your rather detailed and useful post but I will echo what gsr said:
"It all depends on how good the DAC in your receiver is compared to the DAC in the Oppo and whether you're using anything like room correction in the receiver."
I have for the most part bypassed my analog outputs and lossless audio because to my ears, my receiver does a much better job with the lossy audio over optical than I'm able to achieve tweaking the analogue outputs in the OPPO myself. This is partly because I live in an apartment where I don't often push the limits of the system but still...
Lossless audio's superiority, like many other things, is only guaranteed when all other things are equal. If you have the option of analog inputs on your AVR, then you should definitely try them out. But optical can still have its uses for those of us with high-end non-HDMI receivers.
________________________________________
Sony Bravia KDL-55BX520 / Pioneer VSX-54TX
OPPO BDP-103D / Xfinity X1 / Klipsch Speakers
warrian is offline
post #20369 of 24484 Old 02-19-2015, 11:42 AM
jmacari's Avatar
Quoted: 112 Post(s)
Liked: 128
Thanks again.
This is my only complaint with the Roku stick (Oppo version); I use a wired connection also, and get much better streaming capability with the Oppo 103 Netflix app then streaming thru the Roku stick ( I get stuttering). I went with the Roku stick because it is capable of 1080P/24 whereas the Oppo Netflix app doesn't......
Anthem MRX-500,Outlaw 7500 5ch amp
Oppo BDP-103, Sony XBR-65X930D, Rotel RP-855, Phillips BDP-7501
Paradigm Studio 100 Fronts,Paradigm Studio ADP-590 Surrounds
Paradigm Studio cc-590 Center, Martin Logan Dynamo subwoofer, DefTech Supercube 4000
Roku Ultra, DIRECTV Genie DVR, OPPO Sonica DAC
jmacari is online now
post #20370 of 24484 Old 02-19-2015, 12:12 PM
Philnick's Avatar
Quoted: 239 Post(s)
Liked: 104
I understand completely, since my AVR is an old pre-HDMI Yamaha RX-V457. I use its multichannel analog input to connect my Oppo, but for Amazon Prime I connect its optical input to an Amazon Fire TV that can be set to transcode Amazon's (and Netflix's) Dolby Digital Plus (which requires HDMI) to classic Dolby Digital for its optical output.
One virtue of my old AVR is that it's a relatively unusual one that gives its Multichannel Analog input the benefit of the distance settings, bass management, and channel level trims applied to its other inputs, so those don't have to be set up separately inside the player.
I just took another look at the original question by brollend and saw that the post was asking about (a) stereo use and (b) streaming from an Apple TV. For those applications, optical would be fine, since (a) for stereo, optical can carry lossless PCM and (b) anything streamed by an Apple TV, a Roku, or a Fire TV is going to be lossy surround to start with. DD+ may be better than DD, but it's still lossy.
warrian likes this.
Philnick is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
