Official OPPO BDP-103 Owner's Thread - Page 688 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #20611 of 24577 Old 03-04-2015, 08:40 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3549
The better your display the better your Oppo 103's picture rendition.
eljr likes this.
NorthSky is offline
post #20612 of 24577 Old 03-05-2015, 03:36 AM
Bill Mac's Avatar
Quoted: 1309 Post(s)
Liked: 1509
I have a question for those that are using the Auto Resume feature. If a disc is in the player does it start playing from the resumed point without pushing play when the player is powered up? I could have sworn before the latest FW update that when you powered up the player you had to hit play for the disc to start playback from the resumed point. It really irritates me now that when I power up my 103 and the 105D that the disc starts playing automatically.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #20613 of 24577 Old 03-05-2015, 04:03 AM
pbarach's Avatar
Quoted: 336 Post(s)
Liked: 201
Bill
Turn off AutoPlay in the Setup menu, and when you turn on the player, you will be at the Oppo home screen with nothing playing. The disc won't start playing until you either press PLAY or highlight the disc icon and press ENTER, at which point the disc will auto-resume unless you cancel that by immediately pressing STOP.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #20614 of 24577 Old 03-05-2015, 05:35 AM
Bill Mac's Avatar
Liked: 1509
Auto Play is off in both the 103 and when the 105D was in my system. I just powered up the 103 and it went right to play and resumed playback with the SACD that was playing yesterday.
Edit: I just went into the setup menu of the 103 and both Auto Play and Auto Resume were off . But the 103 started playing when I initially powered it up this morning with both of those auto features disabled. Very strange. So I went back into the setup menu and enabled Auto Resume and now it is working properly. I powered the 103 off and on several times and the disc did not start playing till I hit playback. Very strange indeed!
Bill
post #20615 of 24577 Old 03-05-2015, 02:06 PM
80sGuy's Avatar
Quoted: 185 Post(s)
Liked: 35
Bill
Always best to do a power refresh after each Firmware update. It is recommended on many electronic devices, including cellphones.
80sGuy is offline
post #20616 of 24577 Old 03-05-2015, 04:03 PM
tezster's Avatar
Quoted: 430 Post(s)
Liked: 302
So, I've been operating in complete idiot mode with one aspect of my 103's operation since I've gotten it: I have the analog subwoofer output connected directly to my buttkicker's amp, and it never occurred to me that changing the volume control on my receiver obviously wouldn't effect the buttkicker's output. Duhhhh. I watch movies primarily at the same volume level, within a ~4db range, so that's my excuse for not catching it until now.
Anyway, to remedy this situation, I'm going to change the output volume of my Oppo to variable. Am I correct in assuming that the Oppo's volume control only affects the analog outputs?
My second question is, does anyone know how much each increment of the Oppo's volume control corresponds to in terms of dB output? It sure would be nice if there was an option of having the volume control method match the ones used by AVRs i.e. starting with negative values, going up to 0 as reference level.
tezster is offline
post #20617 of 24577 Old 03-05-2015, 04:21 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
Yes the volume control of the player only operates the analog volume.
Each notch on the volume scale should be 1/2 db. So from -0- to 100 is a total of 50 db.
Why don't you just use the sub output of your receiver to control the transducers?
If you already have a sub connected to it, you could just use a passive rca splitter to
send the signals to your sub and transducers simultaneously.
Smarty-pants is offline
post #20618 of 24577 Old 03-05-2015, 07:49 PM
tezster's Avatar
Quoted: 430 Post(s)
Liked: 302
Thanks for the info; I like being able to independently adjust the delay/distance of the buttkicker, as well as set a lower crossover (i.e. low-pass filter) than the sub.
tezster is offline
post #20619 of 24577 Old 03-07-2015, 05:15 AM
Super Moderator
teachsac's Avatar
Quoted: 687 Post(s)
Liked: 1093
Please remember that any and all personal sales belong in the classifieds.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #20620 of 24577 Old 03-07-2015, 10:14 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Hi guys,
I have a quick question regarding OPPO 103 Lineaer PCM conversion. I don't onw Oppo 103 yet but I think now I have a very good reason to based on the answer to my question.
I have been using PS3 (slim version) for a while and had it set to Linear PCM. Recently I bought miniDSP DL which provides Dirac room correction. It requires that the signal be sent as LPCM. So far so good.
Yesterday, I played Transformer Dark Of The Moon and it sounded very dull.I thought it was Dirac causing it. So I took it out of chain and connected PS3 straight to my avr (Marantz SR 6007). After Audyssey calibration, played movie and same issue. Now comes the interesting part. I went into PS3 sound settings and changed it to Bit-Stream from Linear PCM. Play movie and wooow day and night difference.
Even though ps3 shows support for DOLBY TRUE HD in Lineaer PCM, selecting Linear PCM brings a big difference in sound getting loss. Since I need to pass Linear PCM for Dirac to work, my only other option left is OPPO 103 only if it supports Dolby True HD and DTS HD in Linear PCM?
So my question, Does Oppo 103 support Dolby True HD + DTS HD in Lienar PCM mode? If yes then can someone please do a test by playing a movie that is in Dolby True HD (preferably Transformer Dark Of The Moon) with both modes to see if there is a noticeable difference b/w the two.
Thx a bunch.
SherazNJ is offline
post #20621 of 24577 Old 03-07-2015, 10:18 AM
rdgrimes's Avatar
Quoted: 2116 Post(s)
Liked: 1429
Yes, it does. Works for all supported audio codecs.
rdgrimes is offline
post #20622 of 24577 Old 03-07-2015, 10:33 AM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
And also on pretty much any other standalone blu-ray player.
fmalczewski is offline
post #20623 of 24577 Old 03-07-2015, 10:47 AM
SherazNJ's Avatar
Liked: 144
So does ps3. It shows it in the menu as well. But when I played Transformer the dark moon in Linear PCM, there is a huge difference in sound. Its so obvious that one doesn't even have to pay attention to know the difference.
Have you tested any movie that supports Dolby True HD in both format and noticed any difference?
SherazNJ is offline
post #20624 of 24577 Old 03-07-2015, 10:50 AM
slb
slb's Avatar
I'm not sure if the 103 will be any better. When I send LPCM to my Sony receiver, the sound is definitely "duller" than when sending PCM. I think a few other 103 owners here have reported something similar, and I don't recall seeing a resolution or explanation.
slb is offline
post #20625 of 24577 Old 03-07-2015, 11:00 AM
rdgrimes's Avatar
Liked: 1429
Pretty much any AVR or pre-pro will produce slightly different levels when LPCM is input vs bitstream. Some bitstream codecs also contain DRC and dialog boost instructions that can also effect results. That said, the differences are generally small, although even slight differences in levels can be perceived as changes in depth or quality of the audio. Any accurate comparison requires level matching, since some processors can produce level differences up to 5db or even more. Also good to note that not all processors will correctly apply the needed 10db boost to the LFE channel on LPCM input, or may also treat it differently with respect to DSP modes, EQ, etc.
Bottom line is that there's no appreciable difference in the sound of LPCM vs bitstream output from the player, but whatever is on the receiving end can/may treat the two differently.
With respect to your PS3, questions are best asked in the appropriate forum for that device.
rdgrimes is offline
post #20626 of 24577 Old 03-07-2015, 11:11 AM
SherazNJ's Avatar
Liked: 144
Thx for clarification.
Its not a slight difference. Its a big difference. I did feel that LPCM was less louder. I turned volumn 5db higher on my avr. Only dialog got louder and all other sound was dull.
Based on what you are saying rdgrimes, one is better of staying away from LPCM and let avr do the job?
Please note that this is not a PS3 related question. I did notice the issue arrising from PS3 but not asking for any opinion or solution for PS3 but was wondeing if OPPO solves the issue (just to be clear).
SherazNJ is offline
post #20627 of 24577 Old 03-07-2015, 11:13 AM
rdgrimes's Avatar
Liked: 1429
No, that's not what I meant. Here there's virtually no difference.
rdgrimes is offline
post #20628 of 24577 Old 03-07-2015, 01:26 PM
decibels's Avatar
Quoted: 358 Post(s)
Liked: 146
Hello, I am having a lot of issues all of sudden with playback of SACD's and they are freezing, seemingly randomly, and require me to power cycle the unit (sometimes more than once) to get the discs to start playing. When it freezes there is no access from any buttons from both the remote and the unit itself. I have recently started using the Media Control App from a Samsung tablet, would this contribute to this issue in any way? I was using my iPhone prior to that and never had any issues.
My humble yet growing like weeds SACD collection
HT: Anthem AVM60, Anthem MCA 50, Anthem PVA 7, Oppo BDP-103, Sony HAP-Z1ES, PS3, Graham Slee ULDE, Graham Slee ERA Gold V, Pioneer PL 518 turntable
SP: Paradigm Studio 100's, CC 690, Studio 20's SR, Studio 20's SB, SVS SB13 Plus
decibels is offline
post #20629 of 24577 Old 03-07-2015, 01:34 PM
rdgrimes's Avatar
Liked: 1429
Try not using the app and see if the problem goes away. I assume you are meaning actual SACD discs. You should contact Oppo support if the app is causing this. Support for audio discs in the app is a fairly new feature. But on the surface this sounds like an issue with loss of contact from the tablet to the player.
rdgrimes is offline
post #20630 of 24577 Old 03-07-2015, 01:36 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2833 Post(s)
Liked: 2076
Does it happen if you use just the player remote or the buttons on the front panel?
It happens only with SACDs, not with any other type of disc?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20631 of 24577 Old 03-07-2015, 01:47 PM
decibels's Avatar
Quoted: 358 Post(s)
Liked: 146
Yeah I just ditched the tablet, it was a free gift and sitting around so thought it would be easier than using my iPhone. I am hoping that this is the cause...will report back at the end of day.
-Bill
Yeah only seems to happen with the SACD's, I tried a couple of DVD's and they worked fine, not that it makes conclusive. I am going to try the rest of the day with the remote/buttons on the front.
Also sent a note off to Oppo support.
Thanks for the quick assistance!
decibels is offline
post #20632 of 24577 Old 03-07-2015, 09:27 PM
decibels's Avatar
Quoted: 358 Post(s)
Liked: 146
-Bill
Interesting enough I had no issues the rest of the day using the device and I went back to using my iPhone and absolutely no problems at all. There must be something with the Android app...glad it was a freebie and it can go back in the drawer!
decibels is offline
post #20633 of 24577 Old 03-08-2015, 06:21 AM
rdgrimes's Avatar
Liked: 1429
More likely an issue with the wireless in the tablet. The app and the Oppo do not respond well to interruptions in network connections.
rdgrimes is offline
post #20634 of 24577 Old 03-08-2015, 10:22 AM
decibels's Avatar
Quoted: 358 Post(s)
Liked: 146
Possibly a hardware/software issue in the tablet. I tried with my iPad as well and it works flawlessly too. When I connect the Samsung again it starts to freeze up again.
decibels is offline
post #20635 of 24577 Old 03-08-2015, 10:46 AM
Liked: 0
Adding Network Library
I am considering buying this player but I would like to know about the limitations of adding your media library. I currently have a Panasonic BDT-110. It supports MKV but it has a severe limitation on the number of files you may have in a directory. Go over that and you need to create a new directory and then you have to basically start over with the menu.
Can anyone tell me how the BDP-103 handles adding network media and what limitations is has as far as the number of files in a directory.
bmckain is offline
post #20636 of 24577 Old 03-08-2015, 01:48 PM
wmcclain's Avatar
Liked: 2076
Welcome to AVSForum.
I don't know what the upper limit on number of files would be. I sometimes experience some pauses when accessing a server with a few thousand files, but it does work. This is while displaying the file lists; not a problem when playing a file.
A bigger issue is the very basic file browser in the player itself. You can see illustrations and its capabilities in the online manual. Directories with hundreds of files will be tedious to navigate. I keep pools of symbolic links organized by household "profile" (me, my wife, everything) and first letter for that reason.
Some people are using tablets for player control; they have smoother interfaces.
-Bill
post #20637 of 24577 Old 03-09-2015, 07:39 AM
ckronengold's Avatar
Quoted: 56 Post(s)
What do you mean by "symbolic links"?
Guess I'll try for myself, but can the Oppo follow "shortcuts" from a Windows folder?
My biggest issue is that the movies on my network sit a little deeper in the file structure than I'd like, but I'm not rebuilding my server at this point just to accommodate the player.
Server/DrivePool/Media/Movies. When you combine that with the Oppo nav adding the "video/music/pictures" layer, its a little tedious, especially for the rest of the family.
I've been thinking about adding a shortcut to the top level of the navigation, but never was sure if the Oppo would be able to read and follow it.
-Bill
Media Room: Epson 5030 / Marantz 7010 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #20638 of 24577 Old 03-09-2015, 10:52 AM
wmcclain's Avatar
Liked: 2076
See this section of the FAQ: Are hard links supported on NTFS volumes?
It specifies NTFS, but the same links work over SMB file sharing, where the underlying file system can be anything supported by the server.
Links are not the same as shortcuts.
You might also look at DLNA servers; there is a list in the FAQ. Depending on their sophistication they can provide virtual views of your collection.
-Bill
post #20639 of 24577 Old 03-09-2015, 02:53 PM
scannerman's Avatar
Quoted: 26 Post(s)
Question analog out??
I am trying to get an analog 2 ch signal to a cd recorder but I have had no success so far. I down mixed a blu ray to 2 ch stereo but I am getting no signal to the analog in at the recorder (Sony WD###?). I did have success with an LG blu ray 2 ch to the analog in at the recorder. I am recording blu ray concert DVDs to 2 ch audio tracks on cdrs.
Thanks guys
No matter how hard you try - you cannot polish a turd!
scannerman is offline
post #20640 of 24577 Old 03-09-2015, 03:27 PM
rdgrimes's Avatar
Liked: 1429
Thanks guys
If the player is set to "stereo" downmix, those outputs are live all the time. You do have to have an active HDMI video connection at the same time.
rdgrimes is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
