Official OPPO BDP-103 Owner's Thread - Page 700 - AVS Forum | Home Theater Discussions And Reviews
 891Likes
post #20971 of 24634 Old 04-07-2015, 12:21 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2982 Post(s)
Liked: 2238
Originally Posted by Draden1 View Post
Hello everyone,
I've been doing some reading in this thread and online about mkv playback of a dolby true hd soundtrack. This is playing from an external drive plugged directly into the player. My processor shows true hd is playing but the oppo shows "mlp."
Is the mlp that the oppo is showing downgrading the true hd soundtrack in any way? Or is the mlp a bit for bit perfect copy of the true hd track from the blu ray and the oppo just needs to have that mlp renamed to true hd?
It's just a label in the player's on screen display. Same audio.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20972 of 24634 Old 04-07-2015, 12:27 PM
Draden1's Avatar
Quoted: 142 Post(s)
Liked: 59
-Bill
I find it confusing that oppo decided to allow this. I'm currently reading about mlp and am just starting to understand it but I'm sure this is confusing to others as well. I'm sure it's something that could be easily fixed in a firmware update, couldn't it?
Thanks for the quick response
Audio: Emotiva XMC-1 Processor / Emotiva XPA-7 Gen 3 amp
Speakers: Triad Silver LCR (5), Triad Bronze LCR (2 rear), SVS PB13 Ultra sub
Video: Epson 5025 projector / Darbee Darblet / 98" 16:9 Seymour AV XD screen
Sources: Oppo 103 / PS Vue / Apple TV / Audio Technica LP-120 TT
Draden1 is offline
post #20973 of 24634 Old 04-07-2015, 12:29 PM
wmcclain's Avatar
Liked: 2238
Sure. Tell them you want it.
-Bill
post #20974 of 24634 Old 04-07-2015, 12:41 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
Need help with connections
I started to buy some SACD titles and I want to listen to it without pcm conversion. I was reading on the manual of my Oppo 103 that to be able to take full advantage of my Oppo regarding SACD's i would have to connect my Anthem to HDMI 2 and the tv to HDMI 1.
That works for when i use the Oppo only but when I want to use my pvr there is no picture same for the PS4.
Here are my connections:
TV connected to the Anthem MRX510 HDMI 1 output
Oppo 103 HDMI 1 out to the Anthem HDMI 2 in
PVR composite and optical to Anthem composite 1 and optical 1
PS4 connected to the Anthem HDMI 3
Help would be appreciated.
skip61 is offline
post #20975 of 24634 Old 04-07-2015, 12:53 PM
Draden1's Avatar
Quoted: 142 Post(s)
Liked: 59
-Bill
On it.
Draden1 is offline
post #20976 of 24634 Old 04-07-2015, 01:12 PM
genegold's Avatar
Quoted: 38 Post(s)
Originally Posted by NorthSky View Post
Wow, even better. ...With three USB ports. ...And streaming too!
It's like having a video preamp processor for multiple sources and formats. ...And not counting the audio side.
Only if you have a TV where it makes a difference. As others here cautioned me (and others), the darbee version needs a larger screen TV to show its effects. With a 46" Samsung F8000, I couldn't reliably tell the difference, even with the split-screen tool. Ended up returning the 103D for a refurbed 103 and have been very happy.
genegold is offline
post #20977 of 24634 Old 04-07-2015, 01:57 PM
Philnick's Avatar
Quoted: 240 Post(s)
Liked: 106
Hello everyone,
My understanding is that Dolby TrueHD is based on Meridian Lossless Packing, which was developed long ago for DVD-Audio disks. Oppo DVD players were able to play DVD-A disks long before Blu-ray and TrueHD were introduced. I doubt that there's any loss in quality, or even any change in encoding - the Oppo's just calling the encoding by its "family" name.
Philnick is offline
post #20978 of 24634 Old 04-07-2015, 01:58 PM
Smarty-pants's Avatar
Quoted: 750 Post(s)
Liked: 627
^ If you still can't see the difference pausing it and running the split screen demo, then I would highly advise a visit to the eye doctor, lol.
Smarty-pants is offline
post #20979 of 24634 Old 04-07-2015, 02:16 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Actually, to take "full" advantage of your 103 when playing SACD's, you'd want to use your 103's analog outputs, but the catch is if you use the analog outputs and don't want to convert DSD to PCM, you cannot use the 103's volume control. Output will be at max volume via the analog outs. Utilizing the 103's hdmi 2 output for DSD means you are sending the digital audio to your Anthem to be decoded to an analog signal. So, your 103 is acting simply as a digital audio transport. If that is really what you want, with no DSD to PCM conversion, you should set "SACD Output" to DSD. Audio would be muted on the 103's hdmi 1 output then.
DanF8500 is offline
post #20980 of 24634 Old 04-07-2015, 02:24 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
So if i go analog do i still leave my hdmi connections the same?
skip61 is offline
post #20981 of 24634 Old 04-07-2015, 02:38 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I rather go via the HDMI.
But how do i get the picture when i use my pvr and ps4 ?
That's a question for the Anthem threads. You don't have your pvr or your ps4 going thru the Oppo, right?
DanF8500 is offline
post #20982 of 24634 Old 04-07-2015, 02:41 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
If you use the Oppo's analog connections, then you won't have to use the 103's hdmi 2 output, but you'll need to control volume from your Anthem if you don't want the 103 to convert DSD audio to PCM. The 103's DAC has no volume control when utilizing DSD straight to analog output.
DanF8500 is offline
post #20983 of 24634 Old 04-07-2015, 02:42 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
I have read a lot of comments on the Oppo BDP-103 Universal Blu-ray player and its matured sister; the Oppo BDP-103D.
The Darbee video processor/enhancer is enjoyed by many of them having an HD display of between 50 and 65".
It all depends; of the viewer's own set of eyes, and the calibration of his HD (or UHD) display. ...Size matters and it doesn't; all depends...
Preference in viewing is a subjective analysis and experience; a personal matter.
NorthSky is offline
post #20984 of 24634 Old 04-07-2015, 02:44 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
I was already using my Anthem for volume control. What is the difference using the oppo volume control?
skip61 is offline
post #20985 of 24634 Old 04-07-2015, 02:46 PM
NorthSky's Avatar
Liked: 3553
You are quite right in your understanding.
NorthSky is offline
post #20986 of 24634 Old 04-07-2015, 02:49 PM
genegold's Avatar
Quoted: 38 Post(s)
Good to know 20-10 and good color vision is not enough to tell the difference. If you read the bulk of commenters with relatively smaller screens, and those giving advice to those who do, the word "subtle" is used a lot. If subtle excites for an extra $100-$180, then by all means go for it. 65" is probably in the range where the difference starts to become more than that.
genegold is offline
post #20987 of 24634 Old 04-07-2015, 02:56 PM
Mongo171's Avatar
Quoted: 900 Post(s)
Liked: 1328
Usually, it's the pj guys talking about the difference.
Mongo171 is offline
post #20988 of 24634 Old 04-07-2015, 02:58 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Audibly, there might not be a difference you can hear. But electronically, there's a lot of differences between using volume controls from difference sources. When you utilize your Oppo's volume control (only functions for the 103's analog outputs), then you're listening to the 103's internal DAC (Digital to Analog Converter) output. When using your Anthem's volume control (from Oppo's hdmi source), you're listening to your Anthem's DAC output.
Since you say you never use the 103's volume control before (because you only use the 103's hdmi outputs), then you've never listened to the 103's DAC output. Like I stated earlier, you probably won't hear any differences. They would be subtle differences, if at all. The DACs in your Anthem are high quality. You're probalby correct to continue using the Anthem's volume control.
I know it's the "no" picture problem you'd like solved, but I don't have an answer to that....Sorry. But I can't see how the Oppo would be at fault, since your pvr and ps4 are connected to your Anthem.
DanF8500 is offline
post #20989 of 24634 Old 04-07-2015, 03:07 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
So if i want to make sure that it's not converted to pcm i have to use the analog connections, right ?
skip61 is offline
post #20990 of 24634 Old 04-07-2015, 03:15 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Skip, are you certain your Anthem receiver can even decode a DSD audio stream? Browsing around online for your Anthem receiver tells me it cannot decode DSD audio.
To make sure the 103 doesn't convert DSD to PCM, you need to set SACD Output to "DSD" on the 103. Remember, DSD and PCM are forms of "digital" audio. They still need to be converted to analog by a DAC. If your Anthem cannot decode DSD audio streams, and you still want to ensure no DSD to PCM conversion, then you'll need to use the 103's analog outputs, along with the SACD Output setting I mentioned, and then ensure your Anthem passes the analog audio straight thru to its amp stage (volume control on Anthem still ok to use) without any analog to digital, then digital to analog conversion internal to your receiver.
DanF8500 is offline
post #20991 of 24634 Old 04-07-2015, 03:20 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
Good question. So your saying that if my Anthem doesn't decode DSD i will not be able to use my Oppo to play SACD's in DSD ?
skip61 is offline
post #20992 of 24634 Old 04-07-2015, 03:24 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I added more to my reply above after you quoted me...
DanF8500 is offline
post #20993 of 24634 Old 04-07-2015, 03:31 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
Ok i will try that.
I much appreciate your help DanF8500
skip61 is offline
post #20994 of 24634 Old 04-07-2015, 03:39 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Ok i will try that.
No problem. We're here to help, and not blow out speakers...... Like I mentioned earlier, be careful when using the 103's analog outputs and setting SACD Output to DSD when playing SACD audio. The 103's analog outputs will be fixed at full volume (i.e. 100 max)!! Adjust your receiver's volume way down to prevent possible overdriving your receiver's analog inputs and blowing out your speakers.
DanF8500 is offline
post #20995 of 24634 Old 04-07-2015, 03:40 PM
skip61's Avatar
Quoted: 75 Post(s)
Liked: 69
No problem. We're here to help, and not blow out speakers...... Like I mentioned earlier, be careful when using the 103's analog outputs and setting SACD Output to DSD when playing SACD audio. The 103's analog output will be fixed at full volume output!! Adjust your receiver's volume way down to prevent possible overdriving your receiver's analog inputs and blowing out your speakers.
Will do
Success !!! Everything is great!! Wow !!!
skip61 is offline
post #20996 of 24634 Old 04-08-2015, 11:17 AM
Archaea's Avatar
Quoted: 3047 Post(s)
Liked: 2645
Could anyone quickly confirm the Oppo 103 can play m2ts clips directly? Or do they have to be mkv clips? I made a bunch of demo clips in m2ts format and play them off my htpc, but seeing the player's interface at a recent ht crawl made me think that's a superior solution to using the PC, as I never feel like my black levels are very good when playing clips off the PC on my projector.
Archaea is offline
post #20997 of 24634 Old 04-08-2015, 11:28 AM
wmcclain's Avatar
Liked: 2238
Yes.
-Bill
Archaea likes this.
post #20998 of 24634 Old 04-08-2015, 12:09 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Quick question about accessing SMB shares.
I got my 103 today. I was mentally prepared for the headache of accessing Win 8.1 shares, but nicely I was able to access my 2 Win 8.1 PCs (and all their shares) without a problem.
It's my older Win 7 box (which has always been visible from other PCs, my Dunes, etc) that I don't see from the Oppo. The name of the PC doesn't appear in the network server list.
Help!
Chris
HeffeMusic likes this.
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #20999 of 24634 Old 04-08-2015, 12:51 PM
lujan's Avatar
Quoted: 2237 Post(s)
Liked: 939
Help!
Chris
Would you please explain how to do this for me? I have been having many problems with the Oppo 103 playing my Merlin Series BD's. It works most of the time but some times the 103 won't work where it won't load the movie. I've heard from reading other forums that these disks were poorly manufactured and that might be one of the reasons it has trouble reading them? I have recently ripped the BDs and put them on an external USB drive. I don't know what I need to do to share them so that the 103 will find them on the network and which selection I have to make on the 103 on the first menu screen. Thanks
lujan
167 Ultra HD
816 HD
19 HD DVD
4 SD
lujan is online now
post #21000 of 24634 Old 04-08-2015, 12:59 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Dude, ummm...there are so many aspects that would be hard to walk you through...first of all, how have you ripped your BDs? The Oppo can't play BD ISOs.
fatherom is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
