Official OPPO BDP-103 Owner's Thread - Page 709 - AVS Forum | Home Theater Discussions And Reviews
 862Likes
Old 05-14-2015, 01:27 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2272 Post(s)
Liked: 2852
Originally Posted by captnvideo View Post
Hi:
Besides turning off the video on the TV screen and turning off the display on the OPPO, does pressing "Pure Audio" on the remote have any other affect on the audio being output to HDMI 1?
Thank you.
captnvideo
No.
Video is not turned off by the way. It is muted to Black.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 05-14-2015, 01:28 PM
Read the FAQ!
Liked: 2852
Originally Posted by dmusoke View Post
. . . .So, this problem has been around for years, OPPO is well aware of it and I think their blaming the movie sound production is very surprising and very disappointing. They've known about this problem for 6 years and still haven't resolved it with their chipset makers??? How could everyone else have missed it who have lauded Oppo players from the beginning...
If you read on, you will discover that Audioholics also retracted this concern after further discussing the issue with OPPO.
--Bob
Old 05-14-2015, 03:05 PM
rdgrimes's Avatar
Quoted: 2000 Post(s)
Liked: 1337
gsr and smurraybhm like this.
rdgrimes is offline
Old 05-14-2015, 03:19 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
Arrow Oppo 103 and 105 (and 103D and 105D)
http://www.audioholics.com/blu-ray-a.../oppo-bdp-83se
--Bob
Which part Bob?
* I don't trust Audioholics; they are highly biased and counter-productive, even if they have some informative/technical articles.
__________
Measurements - Scope
Clipped signal Sub Out
NorthSky is offline
Old 05-14-2015, 05:40 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 141
I also fail to see the correction Bob is talking about. All I saw was this conclusion below:
Wrap Up
Please note the issues we found while testing these fine players may never be audible in real world usage but they are important to note when configuring the players to match your components. Until Oppo resolves these analog audio issues on both players we recommend the following setup guidelines for each.
Oppo BDP-83 Recommendations
  • Run “small” for all speaker settings when playing back 192kHz DVD-A
  • Utilize the subwoofer crossover when all speakers are set to “large” for all formats other than the Chesky 6.0 DVD-A recordings.
Oppo BDP-83SE Recommendation
  • If you experience distortion via the subwoofer output when playing DolbyTrueHD or DTS HD source material, set all speakers to “large” and utilize an external bass management solution (ie. A/V receiver, external crossover system, etc).
It is also important to note that these issues only reside in the analog domain when utilizing the 7.1 analog RCA outputs. If you are using the HDMI output for all of your audio needs, then there is no cause for alarm for any modes of operation at this time.
Fellow BDP-83 and BDP-83SE owners panic not about these findings, especially if you aren’t experiencing any notable performance issues as a result. We have never known an electronics company more dedicated to customer service and support than Oppo. You can rest assured that as you are reading this, they are working on solutions.
Once Oppo resolves these analog audio issues, we will do a follow-up article with listening tests to compare the analog audio performance of both players.
I fail to see the solution considering that Oppo says it still has the problem, even in its current 103/105 generation players. AH just says that they not use at 0dBFS signals but instead use -20dB signal and increase the bass trim in the AVR/PrePro by the same amount. This made the Oppo not to clip anymore and produce low distortion numbers but its not how its supposed to work.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
Old 05-14-2015, 05:58 PM
Read the FAQ!
Liked: 2852
This has been discussed multiple times. The correction/retraction comes in a later Audioholics article, not the original article you cited.
ETA: Doing some archaeology resulted in this link from 2010:
http://www.audioholics.com/audio-tec.../0dbfs-blu-ray
Note the Dolby recommendations.
--Bob
Old 05-14-2015, 06:10 PM
NorthSky's Avatar
Liked: 3546
Link?
NorthSky is offline
Old 05-14-2015, 06:11 PM
Read the FAQ!
Liked: 2852
^ Look now. It's edited in.
--Bob
Old 05-14-2015, 07:22 PM
NorthSky's Avatar
Liked: 3546
Thx Bob.
* If there are no standards, then anything goes; it's a free multichannel analog world.
As for Dolby; they are only one ingredient/particle in the full panoply of surround sound audio codecs.
...SACD (DSD), DVD Audio, dts, DTS-HD Master Audio, Blu-ray Audio, DAD, SAD, DAT, LPCM, CDs, hi-res audio streaming and dowmloads, music/movie servers, ...and next: Auro-3D, DTS:X audio decoding inside UHD Blu-ray players (if and when).
Anyway, I prefer to set all my speakers to Large when using the multichannel analog output.
And I would love to have Bass Management on the multichannel analog input of my pre/pro.
I accept this compromise, as to "my own" ears it sounds best.
NorthSky is offline
Old 05-15-2015, 03:15 PM
captnvideo's Avatar
Quoted: 49 Post(s)
No.
--Bob
Bob:
captnvideo
captnvideo is offline
Old 05-16-2015, 01:09 AM
audio4life's Avatar
Liked: 299
--Bob
No doubt it'll be brought up yet again down the road. Too bad Audioholics doesn't add the correction in the original article.
audio4life is offline
Old 05-16-2015, 11:53 AM
hawkster27's Avatar
Quoted: 29 Post(s)
Quote: Originally Posted by Gellidius
Bob, what is the reason you recommend setting DVD 24p conversion to OFF?
i often watch movies on DVD, and then i must, for obvious reasons, use 24p to make it a cinema-like experience.
These are "starting point" settings. DVD 24p Conversion OFF will work well with ALL SD-DVDs.
DVD 24p Conversion ON will work "better" with SOME SD-DVDs (typically newer discs of newer movies), but you need to know what to look for, and if the SD-DVD is not authored in a way that lets it work right, you need to know to turn it OFF.
Like you, I leave DVD 24p Conversion ON by default, but I know what to look for, and at the first sign of Frame Drop Stutter when playing an SD-DVD I know to turn it off and enjoy the rest of the disc that way.
Even for discs where it works well, if often will NOT work well for Extras content on those discs. Now this is a setting you can change "on the fly" -- while the disc is playing -- and it doesn't bother me to adjust it ON/OFF as needed. But if you don't want to be bothered, then just leave it OFF.
--Bob
How do you change DVD 24p conversion "on the fly"? I only found it in the setup menu.
hawkster27 is offline
Old 05-16-2015, 11:59 AM
Read the FAQ!
Liked: 2852
It is only accessible in the Setup menu, but the Setup menu can be viewed -- and this particular setting changed -- even while your SD-DVD is playing. The change takes effect immediately.
(NOTE: If you use the iOS or Android "Media Control" app from OPPO, it has a Settings page (the rightmost page) which also lets you alter the current Setup menu settings while content is playing. This is particularly handy when playing an Internet app, like Netflix, which blocks normal access to the Setup menu via the regular Remote control. Of course DVD 24p Conversion is not something that works with Netflix, but it doesn't hurt to remember this trick for other settings in there.)
--Bob
Old 05-16-2015, 12:23 PM
hawkster27's Avatar
Quoted: 29 Post(s)
Thanks for the clarification, Bob.
Old 05-17-2015, 04:28 AM
phsmith's Avatar
Problem with my BDP-103
Hi guys, hope someone has an idea here about this problem. Powered on my 103 today, blue light went on, eject symbol was lit up but nothing worked. No power at all. No eject, no nothing. Pressing the power button on remote turn off the unit after about 12 seconds. Any ideas? Ive turned it off and on, take plug out, at least 20 times. Still nothing.
phsmith is offline
Old 05-17-2015, 06:37 AM
Read the FAQ!
Liked: 2852
^ Disconnect everything from the player, including all cables and the Wifi dongle, and take the player and its power cord to another room (different wall power circuit).
While still unplugged, press and hold the Power button on the Front Panel for a few seconds.
Now reattach just the power cable and see if the unit will power up. If so, bring it back to its normal place and reattach things one at a time to see if you can find the culprit -- a faulty attachment cable or device.
If not, then the player will need service. OPPO Tech Support typically monitors their email even on weekends.
--Bob
Old 05-18-2015, 08:25 AM
Draden1's Avatar
Quoted: 122 Post(s)
Liked: 51
I got an email from tech support on external hard drives for the 103 and this was their exact response, "The player will support drives which are formatted as FAT16, FAT32, NTFS and exFAT with MBR and GPT and up to 16TB in size."
If I buy a drive from WD or Seagate, I have no problems reformatting to NTFS so I can rip my movies. My concern is about the MBR / GPT part of the statement. What exactly is that and is it something I'll need to setup or tweak in some way? Thanks for the help!
Audio: Emotiva XMC-1 Processor / Emotiva XPA-7 Gen 3 amp
Speakers: Triad Silver LCR (5), Triad Bronze LCR (2 rear), SVS PB13 Ultra sub
Video: Epson 5025 projector / Darbee Darblet / 98" 16:9 Seymour AV XD screen
Sources: Oppo 103, Dish Network, PS3/PS4
Draden1 is online now
Old 05-18-2015, 08:48 AM
Read the FAQ!
Liked: 2852
MBR and GPT are partitioning schemes -- how the data is created on the disk for partitioning. A disk drive can be partitioned into separate "logical volumes" which look and act like separate drives, even though existing on the same physical drive.
When setting up a drive, or reconfiguring an existing drive, you "partition" it into one or more logical drives (picking MBR or GPT), and then you "format" each logical drive into a file system (picking FAT, exFAT, or NTFS). All this is done with the drive attached to your computer.
You should know that MBR partitioning and FAT formatting of partitions impose their own limits on size. For max usable size, use GPT partitioning and NTFS. (I'm not actually sure how exFAT affects things.)
MAC users will know GPT as "GUID Partition Table" -- the standard partitioning scheme used with discs on the MAC. MBR is "Master Boot Record" and is popular on Windows computers (for suitable sized drives).
If you are setting up a USB stick for firmware install on the OPPO, partition it with MBR and format the partition with FAT.
--Bob
Old 05-18-2015, 09:00 AM
rdgrimes's Avatar
Liked: 1337
Note that some external drives coming from Seagate and possibly others are using a bastardized version of MBR partitioning in spite of being larger than 2TB. These will only work in the external enclosures they come in. Not a problem unless you try to take them out of the enclosure for use in a PC or dock. They will come pre-formatted to NTFS as well, unless they are intended for a MAC. So for the most part you should have plug-n-play functionality with the Oppo and most any external HDD.
rdgrimes is offline
Old 05-23-2015, 08:38 AM
Liked: 3
Hi, guys. I have some high resolution flac tracks 96khz/24 bits on my laptop. I Am streaming them to my Oppo 103 via Dlna. I am using oshare. My question is am I losing quality streaming the tracks this way? If so what should I do because I want to enjoy the high quality of the music? My avr is Denon 4520. Thank you.
Sanctuary is offline
Old 05-23-2015, 08:41 AM
Read the FAQ!
Liked: 2852
Presuming you don't have the oshare DLNA server set to transcode those files to something else, then what the player sees coming in is FLAC 96KHz 24-bit, and that's what it plays.
--Bob
Old 05-23-2015, 10:21 AM
rdgrimes's Avatar
Liked: 1337
--Bob
oShare does not have transcoding capability.
rdgrimes is offline
Old 05-23-2015, 10:33 AM
Read the FAQ!
Liked: 2852
^ So you'd have to be unusually clever to misconfigure it to do that.
--Bob
Old 05-23-2015, 11:07 AM
Liked: 3
Thanks a lot for the clarification.
Old 05-23-2015, 01:25 PM
planemechfrito's Avatar
Quoted: 87 Post(s)
Liked: 56
Can a oppo 103 be calibrated in the picture settings
planemechfrito is offline
Old 05-23-2015, 01:33 PM
Read the FAQ!
Liked: 2852
I'm not sure I understand what you are asking.
The OPPO 103 includes Picture Adjustment controls for things like brightness, contrast, color, and sharpness. You COULD use these when calibrating video levels.
However the Rule of Thumb is to leave all those settings in the OPPO at their factory default (0) values and instead do your video calibration using the controls found in your Display. Only tweak the OPPO settings for these if there is some problem in your Display that prevents proper calibration using the Display's own controls.
ETA:
Just to elaborate a bit more: The OPPO 103 puts out "Reference" HDMI signals when the Picture Adjustment controls are left at their factory default (0) values. The optimum picture quality will be achieved by using the controls in your Display itself to adjust it to correctly render those into images. I.e., you calibrate the Display. The OPPO is already calibrated.
--Bob
Old 05-23-2015, 03:30 PM
pbarach's Avatar
Quoted: 321 Post(s)
Liked: 194
Oppo weirdness:
I'm finding my 103 to be completely unpredictable when it comes to accessing things on the internet or over my home WiFi network. Just to give an idea of the setup, the wireless router is right next to the Oppo, and it's connected via ethernet. My home internet service is 15 Mbps or better. The PC containing my music files is in the next room, so its files are accessed wirelessly (using SMB).
So last night, I had the following problems:
1. Netflix never plays ("That isn't available right now" on every video) unless i first access Vudu and play a minute or so of a random trailer (never had any Vudu issues--or problems with Pandora, YouTube, Digital Concert Hall, or discs and flash drives). Oh, and twice last week I had to re-enter my Netflix ID/password.
2. Sometimes the home screen freezes, and the only thing the 103 responds to is the POWER button to shut it off and then on again.
3. While playing music files from the PC via wirelessly accessed SMB, sometimes the screen freezes but the file won't stop playing. Again, powering off and on is the only way to recover from this.
4. I had an ordinary 16/44.1 WAV file on the PC that would lock up the Oppo every time I tried to play it. Never heard any of it. The same file plays fine on the PC.
The following fixits didn't fix anything: Unplugging the player for 15 minutes. Saving my settings, resetting to factory defaults, reloading my settings.
BTW, I have a Roku 2 XS that is connected to the same router via ethernet, and I have never had a single problem accessing Netflix or any of its apps.
Is this what a $500 machine should be doing??
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
Old 05-23-2015, 03:46 PM
SeeMoreDigital's Avatar
Quoted: 467 Post(s)
Liked: 197
Out of interest, if your WiFi router is so close to your Oppo, why not use its hard-wire network connection to a multi-port switch and then use a hard-wire connection to your Oppo and another to the WiFi router?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
Old 05-23-2015, 03:56 PM
pbarach's Avatar
Quoted: 321 Post(s)
Liked: 194
Originally Posted by SeeMoreDigital View Post
Out of interest, if your WiFi router is so close to your Oppo, why not connect the WiFi router to a multi-port switch and then use a hard-wire connection to your Oppo?
Not sure what a multi-port switch is, but I suspect that's built into the router (there are about 6 ethernet ports on it, and one of them is the hard-wire connection to the Oppo, another is to the Roku).
pbarach is offline
Old 05-23-2015, 03:57 PM
Read the FAQ!
Liked: 2852
Nope!
Send the WAV file to OPPO Tech Support and they can likely discover what's odd about it. (Could be, for example, that there's some malformed data in there that your PC doesn't care about but the OPPO does.)
Player crashes could mean the player needs hardware service. But there are other things to eliminate first. For example, a faulty HDMI cable can cause the type of lockups you describe. There isn't enough information in your post to proffer this as a likely possibility yet, but just pointing out that there are side effects that may not be obvious to you. Your best bet for this is to spend some quality time with OPPO Tech Support, who will likely give you a set of things to try to isolate the problem. Of course if they can't help you isolate an external problem then they can also explain your options for getting the player serviced.
The Netflix never plays issue may be due to trying to launch the Netflix app before networking is fully live after you power up the player. Try checking in Setup > Network Setup > Connection Test first -- repeat if it doesn't come back good on the first try -- and then launch Netflix. If that's not it, and if it really is as easily repeatable a problem as you describe, then again, I suggest you talk to OPPO Tech Support to see if they have some other things for you to try. If waiting for a good Connection Test first DOES cure the problem, then there may be things you can do in your router to fix the delay.
--Bob
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
