Official OPPO BDP-103 Owner's Thread - Page 715 - AVS Forum | Home Theater Discussions And Reviews
 910Likes
post #21421 of 24720 Old 07-08-2015, 02:53 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by pbarach View Post
Gapless playback doesn't work if you are streaming the files wirelessly to the player; it works with files on drives that are plugged into the Oppo's USB ports.
Gapless playback can be enabled via the Oppo Media Control app with SMB shares or attached USB storage.
DanF8500 is offline
post #21422 of 24720 Old 07-08-2015, 02:57 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by MIIKE888 View Post
Hi!
How do i enable gapless playback? is it possible through the media control app?
i inly listen to FLAC and Mp3.
Thanks in advance.
//Mike
Gapless playback via the Oppo Media Control app can be enabled via a long press on a file via SMB shares or attached USB storage. Once you're viewing a given set of files you want to playback in the Media Control app, press and hold down on a filename from your tablet until the gapless feature window displays, then select gapless playback.
DanF8500 is offline
post #21423 of 24720 Old 07-08-2015, 03:23 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
I didn't know this would work on SMB shares, thanks! However, I find that this works for FLAC files but not mp3s. When I do a long press on an mp3 file using the app (iPhone version), nothing pops up.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #21424 of 24720 Old 07-08-2015, 03:25 PM
wse
wse's Avatar
Quoted: 2200 Post(s)
Liked: 805
wse is offline
post #21425 of 24720 Old 07-08-2015, 04:06 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
That's because the 10x players only support gapless via WAV, FLAC, or APE file formats.
DanF8500 is offline
post #21426 of 24720 Old 07-08-2015, 04:08 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by wse View Post
Can you move the subtitle location!
Is that a question "?" or are you stating a fact? (!)
DanF8500 is offline
post #21427 of 24720 Old 07-08-2015, 06:01 PM
JazzGuyy's Avatar
Quoted: 323 Post(s)
Liked: 331
In a movie with subtitles, hold down the Subtitle button on the remote and there will be a popup that will appear and you can use the up and down arrow keys to move the subtitles. This won't work for some movies though because the subtitles are hard-coded into the picture. The only issue I have found is that it would be nice if the movement up or down was a little finer.
JazzGuyy is offline
post #21428 of 24720 Old 07-09-2015, 04:11 AM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
The OP wanted to do gapless playback of mp3 files--you're right, that doesn't work on the 10x players.
pbarach is offline
post #21429 of 24720 Old 07-09-2015, 06:43 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3529 Post(s)
Liked: 4535
Hi!
Thanks in advance.
//Mike
For supported "gapless" file types (FLAC yes, MP3 no) which are held either on a hard drive attached to the player via a USB port, or available over your house network from an SMB shared file system (not DLNA), launch the Media Control app on your iOS or Android device and browse to the track list containing the starting track.
Tap and hold on the line for the starting track. A pop-up will appear in the Media Control app allowing you to select Gapless playback. If you've done it right, the Now Playing screen on your TV will also now show Gapless above the time line.
You must be using the latest version of the Media Control app and the player firmware.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #21430 of 24720 Old 07-09-2015, 06:45 AM
Read the FAQ!
Liked: 4535
Actually it does work if the files are on an SMB-share and you command the start of Gapless playback using the tap and hold trick just mentioned in the current Media Control app.
--Bob
pbarach likes this.
post #21431 of 24720 Old 07-09-2015, 06:47 AM
Read the FAQ!
Liked: 4535
Is your TV too heavy to lift!
--Bob
linger63 likes this.
post #21432 of 24720 Old 07-09-2015, 04:31 PM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
Anyone heard back about the Youtube issue? I know it's probably on Youtube's end and not Oppo, but it would be nice to know if Youtube has contacted Oppo or vice versa. It affects my Sony player too.
QuiGonJosh is offline
post #21433 of 24720 Old 07-10-2015, 02:11 AM
dragon1952's Avatar
Originally Posted by wmcclain View Post
Try setting resolution to 1080p. Then try 1080p24 both off and on.
If still no good, test with a direct connection from the player to the display.
-Bill
Sorry for the delay....we really don't watch many discs. I first tried setting 1080p24 to "off " and that seems to have resolved the issue. Thanks, I appreciate your assistance ;^ )
dragon1952 is offline
post #21434 of 24720 Old 07-12-2015, 10:06 AM
Quoted: 25 Post(s)
Liked: 3
I am curious about using the 103 as a video processor with the PS3. PS3 is known for having some of the most up-to-date streaming apps, and both video and audio would be output to 103 via HDMI. I am assuming 103 would be able to pass Dolby Digital Plus from PS3 to AVR via HDMI 2. Streaming video would be output from 103 via HDMI 1.
Anyone using this kind of a setup?
Does the 103 have preconfigured settings for streaming video?
Any surprises that I should be aware of?
ebefspz is offline
post #21435 of 24720 Old 07-13-2015, 11:36 AM
Super Moderator
markrubin's Avatar
Quoted: 1221 Post(s)
Liked: 2701
I just started using my OPPO 103 as a video processor for DirecTV HR44
I leave the HR44 out set on native and feed it to the 103 with its output set to 1080P (and yes I prefer this new setup)
my question: when I power up the 103, it always defaults to the BD disc: is there a way to have it power up to the HDMI back input?
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #21436 of 24720 Old 07-13-2015, 11:46 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3176 Post(s)
Liked: 2461
It has this: Setup -> Playback Setup -> Power On Input = "Last Input".
-Bill
markrubin likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #21437 of 24720 Old 07-14-2015, 03:07 PM
Shingster's Avatar
Quoted: 13 Post(s)
Dunno if anyone remembers my posts from a couple of years back, but I've got a serious issue with my Oppo 103 when it comes to playback of media files (mkv/avi/mp4) where I get terrible aliasing/shimmer in all content (1080p, whatever over res you can think of). I've sort of ignored the issue for years because I've not absolutely needed to use the oppo as a media player but now I do want to get back to ripping my DVD/BD collection to a portable HD and use the Oppo much more for this sort of thing.
Ok so basically I recently set up a test with my Only God Forgives BD, I ripped the video to mkv via Makemkv so I basically had the exact same video that's on the disc but in the mkv format. I then "acquired" a fully re-encoded rip as an alternate test to see if the issue was with Makemkv. Unfortunately my knowledge of encoding is very limited so that was my only option to get a 3rd test. I then skipped to the scene in the red room with Ryan Gosling and his Thai prostitute girlfriend, which is a scene bathed in deep red light shot in a room with this intricately detailed wallpaper that just goes absolutely nuts with shimmer whenever the camera moves in my mkv rips. This was the result:
Original BD = No shimmer at all
MakeMKV rip from original BD = Shimmer
Re-comprssed rip from other BD = Exact same shimmer.
I've gone through all the video settings, altered the resolution, etc and nothing seems to change the fact that the Oppo 103 is clearly doing something wrong when playing media files. Is this just a natural flaw in the product or some other issue? I've tried updating the firmware of my player but it won't search the network for updates (despite the player being connected OK), which is a major issue because it's a Region ABC player purchased from Ideal AV (who assured me at the time I bought the player than updates would always be periodically available).
Shingster is offline
post #21438 of 24720 Old 07-14-2015, 04:29 PM
JazzGuyy's Avatar
Quoted: 323 Post(s)
Liked: 331
To begin with, you should try downloading the latest firmware from the appropriate Oppo site, depending on what country you are in, rather than trying to get it via a network search on your Oppo player. Then burn the .iso file to a thumb drive or CD/DVD black disc. Some Oppo firmware updates have only worked when downloaded and then installed from a thumb drive or burned disc. Then you can proceed to other testing. BTW, there is no record of any firmware update either wrecking or being affected by a region-free mod.
The kind of problem you are reporting has not been reported by others and I'm sure has nothing to do with your region-free mod. There is a chance though that there is something wrong with your player.
Others here who are more knowledgeable about ripping apps may be able to identify settings or other things you need to change when using your ripping software.
Shingster likes this.
JazzGuyy is offline
post #21439 of 24720 Old 07-14-2015, 08:29 PM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1674
I watch almost nothing else but MKV files ripped from BD or DVD using DVDFab MKV pass-through. (full quality rips). Never had any issue at all with PQ.
rdgrimes is offline
post #21440 of 24720 Old 07-15-2015, 04:32 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
Just to be thorough and remove some other possibilities: What do the same MKV's look like when played back on another device?
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #21441 of 24720 Old 07-15-2015, 09:40 AM
SeeMoreDigital's Avatar
Quoted: 487 Post(s)
Liked: 207
Me neither
ellisr63 and Shingster like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #21442 of 24720 Old 07-15-2015, 10:23 AM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
Same here.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #21443 of 24720 Old 07-15-2015, 01:05 PM
Shingster's Avatar
Quoted: 13 Post(s)
Didn't know that JazzG, thanks! I think i'll have to play it safe and contact IdealAV first as I seem to recall them saying I add to update the firmware online as their region mod doesn't use the standard Oppo firmware but a modified one that the company who did the mod release periodically. That may have just been a precaution though.
The only readon I never updated my firmware before was because a couple years back when I first looked into the problem there was an issue with the latest Oppo firmware update for the player that screwed up the media playback function of the player. I assume they've fixed that since though.
They all look fine, it's only on my Oppo that I have any probs . My only other device is a PC btw, connected straight to my projector.
post #21444 of 24720 Old 07-15-2015, 02:32 PM
bkeeler10's Avatar
Quoted: 325 Post(s)
Liked: 197
I'm sure this has been addressed before, so I apologize for bringing it up again. This thread is huge though . . .
I am thinking about getting a 103 and using it as a preamp, for HDMI source selection, volume control, bass management, etc. It would replace my Onkyo preamp for a time. I would also use it to stream audio and video (mainly over the local network) and spin discs.
Can someone enumerate any potential issues I might run into when using it as a preamp, both in sound quality and operational quirks? This would likely be a somewhat temporary setup (perhaps a year) before I move and replace a lot of equipment for Atmos and possibly UHD.
bkeeler10 is offline
post #21445 of 24720 Old 07-15-2015, 04:59 PM
pbarach's Avatar
Quoted: 357 Post(s)
Liked: 210
I haven't used mine this way, but I can't foresee any problem. WARNING--make sure that the startup volume on the OPPO isn't set to FIXED for those analog outputs, or it will play everything at maximum volume. Another quirk to consider is whether you want it to start with the home screen or the last-used source. You can also decide if you want the 103 to automatically start playing a disk that's in its drive. You might not want that to happen--this is also a setup choice.
The player is very easy to operate, and there is plenty of rapid help available on this forum. Also, Oppo tech support is generally excellent via their website and always fast to get back to you.
I have had a few issues related to streaming sound files over my home WiFi network, but this is rarely an issue at this point.
Take a look at the manual if you like: http://download.oppodigital.com/BDP1...ish_v1.8.2.pdf
pbarach is offline
post #21446 of 24720 Old 07-15-2015, 05:55 PM
bkeeler10's Avatar
Quoted: 325 Post(s)
Liked: 197
Thanks for the information. I've always wanted an Oppo and now that I need a new BDP, this is my chance. I can cover most of the cost by selling my prepro (which I will shortly have to do anyway to move to Atmos).
Anyone who's used it this way have anything to add?
post #21447 of 24720 Old 07-15-2015, 06:25 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Will you be playing SACD's or DSD audio files on your 103? If not, then disregard the rest of this reply........If you are, be careful not to set the "SACD Output" setting to DSD (set it to LPCM instead). The 103 cannot control its volume for DSD Direct to Analog playback, and the volume will be fixed on max output (speakers will be fried). Setting SACD Output to LPCM will allow you to control the volume of your DSD audio. When using LPCM in this case, the 103 converts DSD audio to 88.2 kHz, 24-bit LPCM before the DAC converts to analog output.
DanF8500 is offline
post #21448 of 24720 Old 07-15-2015, 08:14 PM
bkeeler10's Avatar
Quoted: 325 Post(s)
Liked: 197
That's a good bit of information, as I will likely be playing both of those formats. Thanks for the tip!
post #21449 of 24720 Old 07-16-2015, 04:50 PM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
The Youtube app appears to be working normally for me now.
post #21450 of 24720 Old 07-17-2015, 02:43 PM
LarryGM's Avatar
Refurbished BDP-103 available on Oppo website.
LarryGM is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
