Official OPPO BDP-103 Owner's Thread - Page 724 - AVS Forum | Home Theater Discussions And Reviews
 884Likes
post #21691 of 24577 Old 08-30-2015, 07:46 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by AuburnM5 View Post
This might be a better question for the McIntosh specific forum on Audio Karma or Audio Aficionado, but I wanted to get some thoughts from Oppo owners. What do you think is the best way to use the player as an SACD player? It would be primarily for 2 channel SACD playback. (Equipment: Oppo 103D, McIntosh MX121 processor, McIntosh C2500 tube preamp)
A. Playback over HDMI running through the MX121 (the C2500 is in pass through mode)
B. Playback through the analog outs on the 103D into the C2500 via PCM
C. Playback through the analog outs on the 103D into the cC2500 via DSD
I think the best advice Linger gave you above is to try all your options and see what "you" prefer best. In order to do that, you have to know and understand your options and its consequences. First off, I'm pretty sure your McIntosh processor cannot accept a pure DSD audio stream, so your "A" option would be to have your 103 convert DSD to PCM and send PCM via HDMI to your MX121 for further digital processing (Audyssey, etc.), or conversion to analog by your MX121 to your preamp, or even conversion to analog by your tube preamp (looks like it has a DAC also). With regards to digital processing of the signal, I provided you with a link from another forum concerning some of your issues/options. The OP of that discussion preferred to perform Audyssey processing on his audio playback. You'll have to be the final judge on that as to what you prefer..
http://www.audioaficionado.org/mcint...105-mx121.html
As for your B and C options, you're asking the 103 to either convert DSD to PCM before converting to analog(B), or convert DSD direct to analog (C). Be careful of your C option, because you won't be able to control your volume on the 103. In fact, the volume will be fixed at max output, but if you're connecting directly to a preamp, your preamp should provide you the necessary voltage reduction/attenuation before reaching your amp.
DanF8500 is offline
post #21692 of 24577 Old 08-30-2015, 09:28 AM
linger63's Avatar
Quoted: 86 Post(s)
Liked: 46
To GSR and DanF8500,
Thanks for cleaning up my misleading post guys.
I knew what I wanted to say in my head but messed up a bit when writing it.
AuburnM5 should definitely know his best options now!!
Cheers
linger63 is offline
post #21693 of 24577 Old 08-30-2015, 02:55 PM
JeffNebraska's Avatar
Quoted: 59 Post(s)
Having HDMI stability issue when I output at 1080p, Auto, or 4K2K
I have something quite weird happening between my Oppo 103 and my Sony 350ES 4K projector.
My projector is connected directly to my Oppo's HDMI 1 and I have HDMI 2 going to my preamp, because it is 8 years old and can't handle a 3D signal pass. I have the "Split A/V" signal on as well.
If I set the video output on my Oppo to 1080P, Auto, or 4K2K, when I am on the Oppo Home screen, the image keeps coming and going every few seconds, and I sometimes see the "frequency out of range" message from my projector. When I play a Bluray, this doesn't happen and the HDMI sync is stable. It also doesn't happen if I set the output resolution to 1080i or 720p.
Has anyone else experienced this problem? I really want to have 1080p/24, so I don't want to downgrade my output resolution just to keep the Home menu stable, but this is an annoying issue. The coming and going of the HDMI sync also appears to affect Netflix.
I apologize if this is discussed in the thread, but I couldn't figure out how to search for it.
Jeffnebraska
Reaching for the Next Level With a Sony 350ES and a 133" 2.35 AT Screen
JeffNebraska is offline
post #21694 of 24577 Old 08-30-2015, 02:58 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2823 Post(s)
Liked: 2073
Is the preamp also connected to the projector? If so, what happens when you disconnect that?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #21695 of 24577 Old 08-30-2015, 03:00 PM
Quoted: 59 Post(s)
-Bill
The preamp is connected to the projector's other input, since I pass my non-3D signals through the preamp. I don't think disconnecting that could have any effect on my ability to hold an HDMI sync on my other input.
Jeffnebraska
post #21696 of 24577 Old 08-30-2015, 03:04 PM
wmcclain's Avatar
Liked: 2073
Just as an experiment, could you try it?
-Bill
wmcclain is offline
post #21697 of 24577 Old 08-30-2015, 03:10 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2630 Post(s)
Liked: 3348
The Home Menu is 1080p/60, more than twice the bandwidth of 1080p/24 from a Blu-Ray. It could simply be that the cable from OPPO to projector needs to be upgraded. Or that the plug needs to be reseated at one or both ends.
But as suggested, START by disconnecting the cable from AVR to projector. The projector is getting HDMI signals on both inputs, and the first thing to check is that this is not causing it to fail.
I.E., simplify first, then diagnose from there.
--Bob
Bob Pariseau is offline
post #21698 of 24577 Old 08-30-2015, 03:31 PM
Quoted: 59 Post(s)
--Bob
I like this explanation, because it is a crappy cable and a 25'+ run. I'm going to try a cable swap first, then experiment with unplugging the other HDMI input. The problem with doing that is, I need both of them plugged in, because I use both.
Jeffnebraska
post #21699 of 24577 Old 08-30-2015, 03:39 PM
Read the FAQ!
Liked: 3348
^ Sure, we are talking about temporary steps for diagnosis. If the problem turns out to be due to having both cables connected to the projector, then the workarounds are different.
But if you already know the cable from OPPO to projector is a problem, then upgrading it now also makes sense.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
post #21700 of 24577 Old 08-30-2015, 04:25 PM
Quoted: 59 Post(s)
While I'm on the subject, has anyone formulated an opinion about whether 1080p or 4k2k is the better output for 4k projectors and TVs?
post #21701 of 24577 Old 08-30-2015, 04:39 PM
Mongo171's Avatar
Quoted: 853 Post(s)
Liked: 1299
You might look at Monoprice HDMI cables with Redmere technology for that long run.
Mongo171 is offline
post #21702 of 24577 Old 08-31-2015, 09:14 AM
Quoted: 59 Post(s)
The cable quality appears to be the problem. I have one good cable and one cheap cable running from my equipment area to my projector. When I swapped those cables, I was able to hold HDMI sync at both 1080p and 4K2K on the home menu and Netflix. That was a relief.
Still testing whether my cheap cable is adequate for all my other components (TiVo, AppleTV, XBox One), but I'm guessing it will be.
Also, still wondering if those with 4K displays prefer to output in 1080p or 4K2K. Any consensus on that?
Thanks for the insight.
post #21703 of 24577 Old 08-31-2015, 09:29 AM
Read the FAQ!
Liked: 3348
^ There's no consensus. Some 4K displays do a better job when fed 1080p (the display scales that to 4K), some when fed 4K. If you can't tell the difference, then I suggest you send 1080p as it is less bandwidth on the cable.
Get familiar with a calibration disc (e.g., Spears & Munsil v2, available direct from OPPO Digital), and be sure to check basic calibration levels both ways just in case the display does something unexpected with the two forms of input. I.e., black levels (Brightness), white levels (Contrast), colors (Saturation & Tint), and Sharpness. Some displays may also limit the "value added" video features they offer to just 1080p input. I.e., they don't have the processing power to do those as well as handle the data rate of 4K input. If those features are important to you, then that may limit you to 1080p input.
--Bob
post #21704 of 24577 Old 08-31-2015, 10:42 AM
Quoted: 59 Post(s)
Thanks, Bob. I should do some A/B testing, but I think I will stick with 1080P.
I have Spears and Munsil v.2, which I use for brightness and contrast, but my display color, white balance, and gamma is calibrated using Chromapure and a sensor.
post #21705 of 24577 Old 08-31-2015, 04:54 PM
videomax6's Avatar
OPPO 103 Player stopped reading discs.
My Oppo 103 player has suddenly stopped reading discs.
A few nights ago, I was watching the special features for The Kingsmen, the picture started freezing up. I stopped the player and turned it off(with disc still in the player.)
A few days later, I decided to try and watch the special features again, and this time it wouldn't read the disc. The player doesn't acknowledge that there is a disc in the player, and stays on the main menu.
I removed the disc and put it in another player and it played fine.
I assumed it was a compatibility issue with the disc and the Oppo player.
Tonight, I put The Criterion Time Bandits Blu-Ray disc in the Oppo player and I am getting the No Disc message. I tried playing a DVD and get the same No Disc message.
For the heck of it, I restored default settings, but still it will still not play any discs.
I have the latest software updates.
Has anyone had similar experiences or have any idea what the problem could be(hardware, software problem?) and how I can possibly fix the player?
Thanks in advance,
Dave
videomax6 is offline
post #21706 of 24577 Old 08-31-2015, 07:06 PM
gwsat's Avatar
Quoted: 2354 Post(s)
Liked: 2654
^^^ I fear the problem may be with something not working right in your player. A couple of weeks ago I rented the Kingsman: The Secret Service BD from Redbox. It played flawlessly in my 103, which makes me fear that something may be amiss with yours.
gwsat is offline
post #21707 of 24577 Old 08-31-2015, 07:17 PM
Read the FAQ!
Liked: 3348
Thanks in advance,
Dave
The most likely reason is that the laser lens needs to be cleaned. It may have picked up some dust or a particulate film.
Get in touch with OPPO Tech Support and they will walk you through what your options are for cleaning it yourself, or sending it in for service if you prefer. They have moderately priced flat rate service if your player is out of the 2 year warranty.
--Bob
post #21708 of 24577 Old 09-01-2015, 05:54 PM
bkeeler10's Avatar
Quoted: 308 Post(s)
Liked: 183
Originally Posted by bkeeler10 View Post
I'm having problems connecting to a network share with my 103. I have a USB drive plugged into my router directly, and have set up an SMB share through the router to that USB drive, with authentication enabled. I am able to connect and authenticate through my computers in the house, and also on my Android phone via the ES File Explorer app. However, when I enter those same credentials in the Oppo Media Player app, it returns login failed.
I did temporarily try authentication disabled (guest login, or anonymous login (no credentials required)) on the router SMB share and got the same result. Any ideas what I might be doing wrong? Thanks.
Bump.
bkeeler10 is offline
post #21709 of 24577 Old 09-02-2015, 10:25 AM
AudiophileWalt's Avatar
Quoted: 12 Post(s)
"My Oppo 103 player has suddenly stopped reading discs."
Had the same problem with 1 of my 3 Oppo's. Fixed it by completely unhooking it and then trying to read a disc at a different ac outlet. This worked so I plugged everything back in and never had a problem since.
AudiophileWalt is offline
post #21710 of 24577 Old 09-02-2015, 04:41 PM
Changeover35's Avatar
Thanks in advance,
Dave
I have had a similar experience. When playing extra features sometimes there was no audio but the video was fine. I could restart the movie and the audio returned. Other discs seemed fine so I thought that it must just be a faulty disc. However the problem returned on a number of discs. I then discovered that every time the audio dropped out the extra feature was ntsc 60Hz. Pal50Hz were fine. I replaced the HDMI cable between the Oppo and my receiver and the problem has never returned.
Changeover35 is offline
post #21711 of 24577 Old 09-02-2015, 07:52 PM
Jeremy Anderson's Avatar
Quoted: 354 Post(s)
Liked: 661
Just installed a 103 earlier tonight. First thing I did was pop in my AVS 709HD disc (burned AVCHD) and was surprised to find that it wouldn't play. My previous 93 played it just fine. I updated to the latest beta firmware. Does the 103 not recognize a burned disc like this? I figured if it played on the 83 and 93, it would definitely play on the 103.
"Never believe any quote you read on the internet." - Abraham Lincoln
Jeremy Anderson is online now
post #21712 of 24577 Old 09-03-2015, 03:58 AM
wmcclain's Avatar
Liked: 2073
I thought that did work; I'll check it later today. The AVCHD version should also work from a USB stick.
Are you sure you are using the AVCHD and not the BDMV version? There were licensing changes that forbid BDMV support on DVD discs on newer players.
-Bill
wmcclain is offline
post #21713 of 24577 Old 09-03-2015, 04:17 AM
Quoted: 354 Post(s)
Liked: 661
-Bill
Good question. I'll try to burn a new disc. Thought mine was the AVCHD one but it has been a while. Will report back.
post #21714 of 24577 Old 09-03-2015, 06:49 AM
Liked: 0
Region Free Hardware Modification
Dearest Forum,
I was curious on people's opinions on the best hardware modification for the OPP 103 to make it region free. I'm much less worried about the cost and much more worried about the quality.
Also, do these modification affect the quality of the video output or is that a silly question.
If this has been discussed earlier, sorry to ask again.
Brian
Randomdot is offline
post #21715 of 24577 Old 09-03-2015, 06:54 AM
Liked: 0
Oppo 103 - Dual Display Output
Hi Forums,
I'm currently using the Dual Display HDMI output function of my OPPO 103. I just learned today this might affect the quality of my video output
The main HDMI is going to my 2k projection system. The second HDMI is going to a 1080p video monitor (for controlling). The controlling monitor makes my life a lot easier, but I'm worried about it now affecting the quality of my main output. Quality is very important to me.
Is this true that the Dual Display function affects quality. If so, has anyone noticed this difference?
Brian
post #21716 of 24577 Old 09-03-2015, 07:01 AM
JazzGuyy's Avatar
Quoted: 297 Post(s)
Liked: 292
Originally Posted by Randomdot View Post
Dearest Forum,
Brian
I can't tell you which is the best mod (I've been using the Denmark mod for several years and it works fine but their customer support is lousy). I have never seen any picture quality effects of this mod and never heard anyone say anything about picture quality effects from any other mod. Since these mods seem to only affect the recognition of the region/zone code on the discs and allow your player to play any disc, I don't see how they could affect the picture quality at all.
JazzGuyy is offline
post #21717 of 24577 Old 09-03-2015, 07:05 AM
wmcclain's Avatar
Liked: 2073
I'm getting "Unknown Disc" with the BDMV version, but the AVCHD version on DVD loads and runs correctly.
If still no good for you we should check both the player firmware and AVS HD 709 version numbers.
-Bill
wmcclain is offline
post #21718 of 24577 Old 09-03-2015, 08:30 AM
Quoted: 354 Post(s)
Liked: 661
-Bill
I burned a fresh copy of the AVCHD version this morning and will try it tonight, though I'm pretty sure that's what I already had. No biggie either way... I can always put the MP4 version on my NAS and play it over the network. I just thought it was odd that it didn't work when this disc has worked on the 83 and 93 I had before this. I spot-checked with Spears & Munsil and nothing needed to be changed with my calibration anyway. I just wanted to make sure all was well before I had people over to watch Mad Max Fury Road last night.
post #21719 of 24577 Old 09-03-2015, 11:52 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Hi Forums,
Brian
http://www.oppodigital.com/KnowledgeBase.aspx?KBID=35
If audio and video quality is very important to you, then dual hdmi mode on your Oppo is probably not a good choice. When in dual display mode, your player will output via hdmi, the highest video resolution that "both" players can support....so, for your case, that would probably be 1080p. It will also output the highest audio resolution via hdmi, which for every tv, is 2-ch PCM. On second thought, all your 1080 movies, DVD's, etc will be upsampled by your 4k display, which is what you'll be watching mostly. So, it's probably not a deal breaker....you just won't be able to output 4k from the Oppo player in dual hdmi mode.
DanF8500 is offline
post #21720 of 24577 Old 09-04-2015, 11:36 AM
Liked: 4
Oppo BD 103 + Western Digital 4tb MyBook HDD
Hello Experts,
I have a lot of my own media digitally stored (TV shows & movies). In various formats, mp4, mkv, flv etc
If I purchase an OPPO will I be able to attach this HDD to it and then stream the media to my new projector?
any usb issues to deal with? etc...
(Previously I was using a WD TV live to achieve the same)
Thank you
Chuck
residency08 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
