Official OPPO BDP-103 Owner's Thread - Page 733 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #21961 of 24632 Old 10-06-2015, 12:36 PM
Sittler27's Avatar
Quoted: 722 Post(s)
Liked: 63
Originally Posted by gene9p View Post
I have it set up that way and it works just fine. I have two Darblets so I did not feel it was necessary to buy the 103D.
Ok, next question would be any benefit in regards to picture quality to get a 103 vs. just using my Xbox One?
For sound, I'm routing it to my Marantz AVR for processing so I don't think the 103 would be advantageous, but just wondering if the pq would significantly improve over an Xbox One for blu ray playback (don't watch DVDs at all anymore) and also for streaming mkv (as I currently use Roku 3 with Plex).
Sittler27 is offline
post #21962 of 24632 Old 10-06-2015, 05:05 PM
gossamer88's Avatar
Quoted: 100 Post(s)
Liked: 57
My Oppo is the best MKV player I have. You get DTS HD or Dolby TrueHD if your MKV have it of course.
gossamer88 is offline
post #21963 of 24632 Old 10-06-2015, 10:31 PM
adriankelly's Avatar
Does anyone use the 4k upconversion ? What results have you noticed ? Does it work well with different sources ? I just bought a 65 js8500 and wanted to know of any special settings to try for the 4k data.
adriankelly is offline
post #21964 of 24632 Old 10-07-2015, 04:32 PM
thetman's Avatar
Quoted: 242 Post(s)
Liked: 47
just wondering how people with projectors are hooking up the 103. are you going straight to projector- or going to receiver and the receiver to projector. HDMI cable will be 30-40ft. not sure that makes a difference since the cable will have red mere.
thetman is offline
post #21965 of 24632 Old 10-08-2015, 06:55 AM
ckronengold's Avatar
Quoted: 56 Post(s)
I use both outputs. Split A/V mode allows you to send video out of HDMI 1 directly to your projector/monitor and send audio out of HDMI 2 to your receiver/processor.
That way, you avoid your receiver doing anything to the video signal along the way. Sometimes, even pass-thru mode can impact your video signal.
Worth noting, however, that HDMI 1 uses a Marvell QDEO video processor. HDMI 2 does not. So if you don't want the Oppo to do any video processing either, you can consider using HDMI2. However, you wont be able to (I don't believe) upscale to 4k on HDMI2.
it will all come down to personal preference. You'll need to experiment.
I have a 25' Redmere HDMI going from my Oppo directly to my projector.
Media Room: Epson 5030 / Marantz 7010 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #21966 of 24632 Old 10-08-2015, 01:39 PM
sbradley02's Avatar
Originally Posted by BobearQSI View Post
Another point of consideration: If you purchase a BDP-103 new (or refurbished direct from Oppo), it comes with a 2 year warranty. I had to use their warranty service once on my BDP-93 because when about 8 months after owning it, I finally tried to hook up my RF remote system to the IR Input port on the back, and it didn't work. The process was smooth - they paid shipping both ways, and it was only a couple days turnaround.
And, regarding playable discs, I regulary rent from Netflix and have never had an issue that wasn't due to a visibly damaged disc. Also, look at their first player as a longevity example: The player was released in early 2009. When X-Men Days of Future Past was released in Oct 2014 (almost 6 years later), it wouldn't play in the 83. So Oppo released a firmware update that fixed it a month later - and they probably had a beta firmware sooner people could download to play it.
Thanks for the feedback. I will add the player to my 'buy' list
sbradley02 is offline
post #21967 of 24632 Old 10-08-2015, 03:11 PM
thetman's Avatar
Quoted: 242 Post(s)
Liked: 47
thanks for the info. your right, will have to experiment when the times come. I usually go from player right to TV, but wasn't sure about throwing a projector in the mix from a much longer distance.
thetman is offline
post #21968 of 24632 Old 10-09-2015, 06:57 AM
Quoted: 56 Post(s)
really boils down to what your main consideration is.
if your question is about distance, you can try a redmere or other active cable. redmere isn't that much more money than a standard cable, so IMHO, its a worthwhile experiment.
if your question is about how the image looks out of HDMI 1 vs HDMI 2, or which components you want to handle the video processing, thats definitely a preference question.
both my receiver and the Oppo had QDEO in them, so I only needed one to handle any image processing. When I switched receivers, I switched inputs on the Oppo to maintain the image quality I had. (Sadly downgraded receivers in my media room in order to have 2-zone audio upstairs. Damn wife.)
post #21969 of 24632 Old 10-09-2015, 07:12 AM
thetman's Avatar
Quoted: 242 Post(s)
Liked: 47
well about both actually. usually not a problem when going from player to receiver and then receiver to tv. the distances are much shorter. but with projector setup I am now talking 30-40ft lengthwise. and if I go into receiver and then to projector another cable is now in the mix. but as you said with two outputs I could go straight to projector with the video part of it. just trying to avoid any hicups or handshake issues along the chain of cables. I have never owned a projector before so not sure how much more ( if any) they are to this than a Tv would be.
thetman is offline
post #21970 of 24632 Old 10-09-2015, 07:21 AM
Quoted: 56 Post(s)
I'm enjoying my first projector, too. And the bottom line is that there's nothing more than with a TV.
Cable for the image. Calibrate. Enjoy.
Given what you've described, I'd run a standard cable to your receiver and buy a Redmere for the long run directly to the projector. I use the Cabernet, and a 40' is $45. Their "Select Active" redmere is $40 for 40'. So really a toss-up, price-wise.
http://www.monoprice.com/Category?c_id=102&cp_id=10255
post #21971 of 24632 Old 10-09-2015, 09:38 AM
thetman's Avatar
Quoted: 242 Post(s)
Liked: 47
good to know, sounds easy enough. The room isn't ready yet for the projector. infact I haven't even took the projector out of the box yet, I'm intimidated for sure. Yes I will be picking up a few redeemer cables and run them through conduit just to have a spare on hand incase one fails.
thetman is offline
post #21972 of 24632 Old 10-10-2015, 12:24 AM
dmusoke's Avatar
Quoted: 315 Post(s)
Liked: 162
As many of you YouTuber's have known for a while, most of the HD and 4K videos on YT are encoded using google's open source VP9 codec (Google owns YT). The Oppo players(103/105) cannot play this newer format that has been around for more than 2 years now. Anyone knows if Oppo will support it in a latter release?
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #21973 of 24632 Old 10-10-2015, 02:27 AM
SeeMoreDigital's Avatar
Quoted: 479 Post(s)
Liked: 200
Support for VP9 (at any resolution) will require an entirely new AV hardware decoding chip-set. It can't be achieved with software alone!
Perhaps support for VP9 will be included when Oppo launch their new playback devices. But such discussions are for another topic
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #21974 of 24632 Old 10-10-2015, 10:11 PM
dmusoke's Avatar
Quoted: 315 Post(s)
Liked: 162
But the VLC program(from Videolan.org) on my 7+ year old Dell laptop can play it fine with an anaemic graphic chipset and slower 2GHz dual CPU. The Oppo's use faster and more efficient ARM based processors so they could do a SW only decode.
dmusoke is offline
post #21975 of 24632 Old 10-11-2015, 06:54 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1154 Post(s)
Liked: 1137
It's not going to happen. Just the architecture alone would mean MAJOR development work to support it, if it's even possible to do the decoding outside of the SOC (where all decoding currently happens). The other issue is that there's no support for input resolutions higher than 1080p anywhere in the processing chain and there's no getting around that without hardware changes.
gsr is offline
post #21976 of 24632 Old 10-11-2015, 07:36 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
My player says I have the latest firmware. But I can't access tidal. Any info?
Brian Fineberg is offline
post #21977 of 24632 Old 10-11-2015, 08:13 PM
rdgrimes's Avatar
Quoted: 2199 Post(s)
Liked: 1544
Tidal is accessed from the mobile app.
rdgrimes is online now
post #21978 of 24632 Old 10-12-2015, 06:25 AM
Liked: 3515
Gotcha.
Ok I see it and loaded it. But it won't play. I hit play and nothing happens :/
post #21979 of 24632 Old 10-12-2015, 06:51 AM
Quoted: 479 Post(s)
Liked: 200
So which version number do you actually have?
post #21980 of 24632 Old 10-12-2015, 08:07 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3024 Post(s)
Liked: 3886
Gotcha.
To use Tidal you need both the Public Beta (0711B) version of the firmware recently released, and the newest version of the MediaControl app:
http://www.oppodigital.com/blu-ray-b...3-Support.aspx
The Firmware Check in the player only checks that you have the latest "Official" release of the firmware installed. It will not tell you there is a more recent, Public Beta, version available.
The Public Beta firmware can not be installed via the Network (to reduce the odds people will install it without knowing it is Beta). Instead, you must download the Beta firmware version for USB install to your computer, and then onto a USB stick, and install it that way in the player. Detailed instructions are shown on that OPPO support page. It's quick and easy.
You will, of course, also need an account with Tidal. You set that up on Tidal's web site.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #21981 of 24632 Old 10-12-2015, 09:18 AM
Draden1's Avatar
Quoted: 136 Post(s)
Liked: 53
Does anyone know the easiest way to rip a 3d blu ray to an external drive and play it back on the bdp 103? Apparently makemkv does not play back the 3d track.
ellisr63 likes this.
Audio: Emotiva XMC-1 Processor / Emotiva XPA-7 Gen 3 amp
Speakers: Triad Silver LCR (5), Triad Bronze LCR (2 rear), SVS PB13 Ultra sub
Video: Epson 5025 projector / Darbee Darblet / 98" 16:9 Seymour AV XD screen
Sources: Oppo 103 / PS Vue / Apple TV / Audio Technica LP-120 TT
Draden1 is online now
post #21982 of 24632 Old 10-12-2015, 09:22 AM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
I use DVDFab for my BRs, and save them as a mkv file.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #21983 of 24632 Old 10-12-2015, 10:58 AM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Makemkv does save the 3D track, it is the Oppo that does not support frame-packed 3D in mkv. So any program you use to save in mkv will not work. Unfortunately, I can't help you with what format does work, as I've never tried anything else - hopefully someone else knows.
BobearQSI is offline
post #21984 of 24632 Old 10-15-2015, 04:00 AM
ltd76gold's Avatar
Quoted: 90 Post(s)
Liked: 41
Since my avr, an Onkyo 809, has the Marvell QDEO chip, is the Kyoto-G2H in the OPPO a significant improvement?
ltd76gold is offline
post #21985 of 24632 Old 10-15-2015, 09:59 AM
asharma's Avatar
Quoted: 901 Post(s)
Liked: 152
4K oppo
Hi folks, sorry if this has been covered...any rumours on Oppo 4K release date? Thanks
asharma is offline
post #21986 of 24632 Old 10-15-2015, 10:04 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2964 Post(s)
Liked: 2206
No. OPPO has said not this year and maybe not next year.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #21987 of 24632 Old 10-15-2015, 10:18 AM
tigger1612's Avatar
Liked: 25
Question for the group, sorry if its been answered. I haven't updated my firmware cause I use the AVCHD directory structure religiously to play movies from my HTPC to the Oppo. Basically it treats the AVCHD directory as an actual disk when playing. If i'm reading the change log right, it looks like they removed this feature? (I assume due to some licensing issue)
If they did remove it, im never updating
tigger1612 is offline
post #21988 of 24632 Old 10-15-2015, 10:18 AM
boe
boe's Avatar
Quoted: 928 Post(s)
Liked: 424
The playback is excellent and reliable, I just wish it could stream 4K. I'm hoping they come out with either an improved MKV player interface on their next unit or just a dedicated media player soon. I'm currently playing around with Kodi on a second PC - wondering if I should just build a HTPC.
Is Oppo going to be at CES in January?
boe is offline
post #21989 of 24632 Old 10-15-2015, 10:18 AM
tigger1612's Avatar
Liked: 25
post #21990 of 24632 Old 10-15-2015, 11:13 AM
wmcclain's Avatar
Liked: 2206
I tried a test directory and it did not work over SMB.
-Bill
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
