Official OPPO BDP-103 Owner's Thread - Page 769 - AVS Forum | Home Theater Discussions And Reviews
 3135Likes
post #23041 of 24770 Old 02-21-2016, 01:24 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 123
I always admired the oppo from afar but never pulled the trigger,always used the ps3/ps4 for much everything but with the new UHD 4K player probably a few months away I will definitely take another hard look...
Can any owners verify if the oppo does vudu at 24p as I have many HDX titles and the playstations will only play the vudu app at 60p?
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #23042 of 24770 Old 02-21-2016, 01:31 PM
SeeMoreDigital's Avatar
Quoted: 488 Post(s)
Liked: 208
Originally Posted by captnvideo View Post
...But how will this affect SACD multi-channel and Hi Resolution audio files (WAV)?
Given that your Yamaha RX-A1040 is not able to decode DSD audio bit-streams 'natively'.... None at all.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #23043 of 24770 Old 02-21-2016, 01:48 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3585 Post(s)
Liked: 4680
It does not. The HDX output of the native VUDU app on the OPPO is 1080p/60.
--Bob
PeterLewis likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #23044 of 24770 Old 02-21-2016, 02:07 PM
Molon_Labe's Avatar
Quoted: 2153 Post(s)
Liked: 2265
Originally Posted by Bob Pariseau View Post
It is possible that a fault in something you have connected to the player is screwing up its power supply.
To test this, disconnect EVERYTHING from the player. Take the player to another room (a different wall power circuit), just in case the problem is with your wall power. While the player is still unplugged, press and hold the front panel Power button for a few seconds to discharge any residual power in the power supply. This insures the lowest levels of the hardware in the player will boot up from scratch.
Now connect JUST the wall power cable and see if the problem still exists (based on what you see in the Front Panel display). If it does, try all three ways of powering up the player: Power button on the remote control, power button on the front panel, and Tray Open button on the front panel.
If all three ways show the problem, your player needs hardware service. Give OPPO Tech Support a call or email. They have reasonably priced, flat rate service for players out of warranty.
If only one way exhibits the problem you may need fresh batteries in the remote or you may have a sticky button.
If the player powers up NORMALLY in the new room, bring it back and connect just one thing at a time until you find the culprit. It could be a faulty cable, or a faulty device at the other end of the cable.
--Bob
Thanks Bob,
Tried the suggestions, but no joy. Unit still powers on for about 10 seconds then powers down. I will call tech support tomorrow to see what the repair bill is to fix it. I went to Best Buy and got an open box Samsung for $70 and cant see any discernible difference in picture quality. One thing is for certain, I won't own another Oppo. This thing doesnt even have that many hours on it. Used ir for movies only in a dedicated theater room. Pretty sad.....
Molon_Labe is online now
post #23045 of 24770 Old 02-21-2016, 02:14 PM
Read the FAQ!
Liked: 4680
^ When did you get it? It comes with a 2 year warranty.
--Bob
post #23046 of 24770 Old 02-21-2016, 02:18 PM
captnvideo's Avatar
Quoted: 49 Post(s)
Ok! I changed the HDMI audio setting from "bitstream" to "LPCM" and loaded the Skyfall blu-ray disc. The audio and video were perfectly in sync just like with the Panasonic.
So hopefully that solves the problem. I will continue to keep 24p processing "off" and the Samsung's Auto Motion Plus to "smooth". This provides me with the best picture quality.
I will do more testing tomorrow and let all you terrific people here if I have any problems.
captnvideo
captnvideo is offline
post #23047 of 24770 Old 02-21-2016, 02:22 PM
Molon_Labe's Avatar
Liked: 2265
--Bob
I honestly am not sure. I might be within the two years. Hopefully they can tell with my serial number the manufacture date. My luck I am at 25 months
post #23048 of 24770 Old 02-21-2016, 04:00 PM
Coyote Waits
htwaits's Avatar
Quoted: 950 Post(s)
Liked: 2100
Shut off 24p and also try setting HDMI audio to PCM. This will let the oppo decode the hires audio formats and you receiver will not have to process DTS MA and Dolby HD audio. It might help in your case. Worth a try!
Romony and htwaits:
I will try changing HDMI audio to PCM and see if it helps. But how will this affect SACD multi-channel and Hi Resolution audio files (WAV)?
If you're using HDMI, the first thing your AVR does is convert audio to PCM. The OPPO may be identical or even better at that task than your AVR -- or not. You can check that out after you solve the current problem.
htwaits is online now
post #23049 of 24770 Old 02-21-2016, 04:23 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1239 Post(s)
Liked: 1281
If you're past the 2 years, keep in mind that many credit cards provide an extra year...
gsr is offline
post #23050 of 24770 Old 02-21-2016, 04:43 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Quotes:
Doesn't appear you TV handles 24p very well. I have an older Sony bravia LCD TV in my living room and when sending it 24p it is jittery. 60p is best.
Romony and htwaits:
WAV is already in PCM. DSD will be converted to PCM too! DTS and Dolby all flavors will be decoded and sent over HDMI in multichannel PCM.
If it fixes your problem you will be happy!
Ronomy is offline
post #23051 of 24770 Old 02-21-2016, 04:50 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
captnvideo
Great news! Basically your AVR is a multichannel DAC with volume control using the LPCM output setting on your oppo.
Ronomy is offline
post #23052 of 24770 Old 02-21-2016, 05:45 PM
Molon_Labe's Avatar
Liked: 2265
I just found my Amazon invoice. I purchased 1 Aug 2013. I hope they work with me on this because $500 for a player that died after 2.5 years with light use is going to make for a bad Monday.
post #23053 of 24770 Old 02-21-2016, 06:10 PM
Read the FAQ!
Liked: 4680
^ Uh, typo on the date? Aug 1, 2015, is less than 1 year ago.
--Bob
post #23054 of 24770 Old 02-21-2016, 06:14 PM
Molon_Labe's Avatar
Liked: 2265
--Bob
Yeah, typo - thanks for catching that. My warranty expired in Aug 2015 but the translation was lost between brain and keyboard. My invoice date is Aug 1, 2013.
post #23055 of 24770 Old 02-21-2016, 08:17 PM
Coyote Waits
htwaits's Avatar
Quoted: 950 Post(s)
Liked: 2100
OPPO has a very reasonable fixed price for out of warranty players, and sometimes the only charge is the shipping. You should also contact them.
post #23056 of 24770 Old 02-22-2016, 05:43 AM
Molon_Labe's Avatar
Liked: 2265
I hope so. It is built like a tank compared to the Samsung I purchased yesterday. I have been very pleased with the performance thus far. Either way, I will get it fixed because I like it. I am just a little disgruntled that most products just don't last like they used to. Goodness, I am sounding like my grandfather. Well then again, my first grandson is due in two months...lol.
post #23057 of 24770 Old 02-22-2016, 10:29 AM
Molon_Labe's Avatar
Liked: 2265
Looks like leaving it unplugged for the night did the trick. Unit is working perfect now - weird.
post #23058 of 24770 Old 02-22-2016, 11:12 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Sort of like my recent lipsync issue...it just disappeared two days ago.
Still have a problem where HDMI 2 output defaults to RGB out after the player has been turned off overnight. HDMI 1 does not do this. So sometimes I have to change it to auto and back to 422 so it will send 422 color instead of RGB. In other words the player will be set to 422 but output RGB after a night powered off. Go figure!
Ron
Ronomy is offline
post #23059 of 24770 Old 02-22-2016, 01:19 PM
Coyote Waits
htwaits's Avatar
Quoted: 950 Post(s)
Liked: 2100
The first thing to understand about all electronic devices and automobiles is that at their heart, they are computers that need to be rebooted occasionally.
Smarty-pants likes this.
post #23060 of 24770 Old 02-22-2016, 01:29 PM
rdgrimes's Avatar
Quoted: 2401 Post(s)
Liked: 1720
If you're using "Quick Start" standby mode, take this as a lesson, all you really needed was an "Energy Efficient" reboot.
There's a long list of bizarre issues solved by a hard reboot, and it's still growing. Sooner or later you'll see one with QS standby.
rdgrimes is offline
post #23061 of 24770 Old 02-22-2016, 01:35 PM
Molon_Labe's Avatar
Liked: 2265
Thing is that I left it unplugged while I ate dinner and the problem remained. I work in IT (network engineer), and I have yet to see a device that wouldn't power drain completely in the course of eating a meal. Left it unplugged on the counter last night and it works this morning. Maybe I tilted it just right this morning Either way, I am back up operational and can take this flimsy Samsung back to Best Buy.
post #23062 of 24770 Old 02-22-2016, 03:09 PM
pbarach's Avatar
Quoted: 362 Post(s)
Liked: 214
Once a Dell tech support person told me to unplug my computer "so the bad electricity will go away."
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #23063 of 24770 Old 02-22-2016, 03:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 950 Post(s)
Liked: 2100
post #23064 of 24770 Old 02-22-2016, 03:54 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 123
Shot oppo an e-mailabout when their 4K UHD players will be available and this is what they said....
Peter,
We are looking to release our UHD player this Summer to Fall. At this time we are not taking pre-orders, but we should have more details and likely a better handle on our release schedule later this Spring.
Best Regards,
Customer Service
OPPO Digital, Inc.
162 Constitution Dr.
Menlo Park, CA 94025
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119
post #23065 of 24770 Old 02-22-2016, 06:46 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
My player is set to energy efficiency and the color changes from 422 to RGB only on HDMI 2 out while it is turned off over night. It's still set to 422 but outputs RGB. In my case it might be best to leave it in quick start. LOL
I might leave it unplugged for a day and see if that fixes the color issue.
Ron
Ronomy is offline
post #23066 of 24770 Old 02-23-2016, 06:40 AM
Read the FAQ!
Liked: 4680
^ The player powers up using RGB for the HDMI outputs and then switches to your selected choice as it proceeds through boot up.
Sounds like your HDMI 2 connection is not making the transition. There are two possibilities. You may have a problem with your Settings memory. That's not likely as that would typically show as the Setting changing IN THE MENU to RGB unexpectedly, not remaining at YCbCr 4:2:2 even though the output is RGB.
The more likely reason is that there is something screwy in your HDMI handshake on that path. The usual culprit here is power on sequencing. I.e., the HDMI handshake on the HDMI 2 path is happening before some device downstream from the OPPO is really ready to respond properly.
To test this, use the regular remotes for your devices (not some programmable remote that turns everything on together) and power up the devices in the reverse order of the signal flow. So for example: Power on Display. Wait. Power on AVR. Wait. Power on OPPO. (Adjust this list for your actual set of devices.)
If that cures the problem -- if you get YCbCr 4:2:2 reliably doing power up manually in this fashion -- then there are possibly settings in your programmable remote to set the order in which devices power up, and to add delay between each device during power up. The best order, as just mentioned is to power things up in the reverse order of the signal flow, and to leave enough time between each device to let them boot up fully.
--Bob
post #23067 of 24770 Old 02-23-2016, 03:56 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
--Bob
Thanks Bob! I do have that on my list of things to try. I use a Logitech Harmony Hitb with ultimate remote so I can program the order that everything powers up and add delay if need be. I had added the Oppo to the activity my old Pioneer 51FD was using and then deleted the Pioneer. So the step to add the oppo 103 probably put the oppo at the end of the list... But it could have also put it right at the beginning too. I need to look at that sequence when I get the chance. I will report if I discover a fix. Although I am pretty sure HDMI 1 did not do this and I was using the very same signal path. I have the ability to turn on hot plug on my DVDO Duo VP too. That might help if it's a handshake issue on bootup.
I have powered off the oppo and back on and it was fine...but when turned off over night it ends up RGB. If it's power up sequence issues that might explain it. Powering down and back up the oppo my VP is already turned on. So it could be power up sequence when turned on and everything else is turned off. All guesses until I try changing the settings.
Ron
Update: I changed the order of power up. My VP turns on before my Oppo and it appears to have fixed the RGB issue. The oppo was turning on before the VP so like you said it stayed in RGB mode. All appears to be well now. I have good lipsync too!
Ronomy is offline
post #23068 of 24770 Old 02-24-2016, 04:14 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Has anybody tried the MHL Roku stick with the 103? For some reason my stick is only streaming 720p. It's set to 1080p display. Interstellar on Hulu is in 1080p. Plays in 1080p on my Apple TV but only in 720p on the roku stick. Am I missing a setting somewhere? WiFi is strong near 100%. Bought the stick from Oppo at a reduced price. It's the 3400X Roku stick.
Ron
Ronomy is offline
post #23069 of 24770 Old 02-24-2016, 05:08 PM
JohnAV's Avatar
Quoted: 373 Post(s)
Liked: 519
Ron
its a recent update from Ruku that caused that. Before it was outputting 1080p.
Oppo Beta Group
JohnAV is offline
post #23070 of 24770 Old 02-24-2016, 06:01 PM
Read the FAQ!
Liked: 4680
Suddenly! As if by Logic!
--Bob
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
